path: root/fs
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[patch 05/14] hpfs: dont call permission()Miklos Szeredi
hpfs_unlink() calls permission() prior to truncating the file. HPFS doesn't define a .permission method, so replace with explicit call to generic_permission(). This is equivalent, except that devcgroup_inode_permission() and security_inode_permission() are not called. The truncation is just an implementation detail of the unlink, so these security checks are unnecessary. I suspect that even calling generic_permission() is unnecessary, since we shouldn't mind if the file isn't writable. But I leave that to the maintainer to decide. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
2008-07-26[PATCH] sanitize proc_sysctlAl Viro
* keep references to ctl_table_head and ctl_table in /proc/sys inodes * grab the former during operations, use the latter for access to entry if that succeeds * have ->d_compare() check if table should be seen for one who does lookup; that allows us to avoid flipping inodes - if we have the same name resolve to different things, we'll just keep several dentries and ->d_compare() will reject the wrong ones. * have ->lookup() and ->readdir() scan the table of our inode first, then walk all ctl_table_header and scan ->attached_by for those that are attached to our directory. * implement ->getattr(). * get rid of insane amounts of tree-walking * get rid of the need to know dentry in ->permission() and of the contortions induced by that. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[patch] hppfs: remove hppfs_permissionMiklos Szeredi
hppfs_permission() is equivalent to the '.permission == NULL' case. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] reuse xxx_fifo_fops for xxx_pipe_fopsDenys Vlasenko
Merge fifo and pipe file_operations. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[patch] vfs: fix lookup on deleted directoryMiklos Szeredi
Lookup can install a child dentry for a deleted directory. This keeps the directory dentry alive, and the inode pinned in the cache and on disk, even after all external references have gone away. This isn't a big problem normally, since memory pressure or umount will clear out the directory dentry and its children, releasing the inode. But for UBIFS this causes problems because its orphan area can overflow. Fix this by returning ENOENT for all lookups on a S_DEAD directory before creating a child dentry. Thanks to Zoltan Sogor for noticing this while testing UBIFS, and Artem for the excellent analysis of the problem and testing. Reported-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Tested-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: When verifying the decoded header before decoding the object identifier [CIFS] Fix warnings from checkpatch [CIFS] Fix improper endian conversion of ACL subauth field [CIFS] Fix possible double free if search immediately after search rewind fails [CIFS] remove checkpatch warning Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> cifs: assorted endian annotations [CIFS] break ATTR_SIZE changes out into their own function lockdep: annotate cifs in-kernel sockets [CIFS] Fix compiler warning on 64-bit
2008-07-26/proc/PID/syscallRoland McGrath
This adds /proc/PID/syscall and /proc/PID/task/TID/syscall magic files. These use task_current_syscall() to show the task's current system call number and argument registers, stack pointer and PC. For a task blocked but not in a syscall, the file shows "-1" in place of the syscall number, followed by only the SP and PC. For a task that's not blocked, it shows "running". Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26tracehook: tracehook_tracer_taskRoland McGrath
This adds the tracehook_tracer_task() hook to consolidate all forms of "Who is using ptrace on me?" logic. This is used for "TracerPid:" in /proc and for permission checks. We also clean up the selinux code the called an identical accessor. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26tracehook: execRoland McGrath
This moves all the ptrace hooks related to exec into tracehook.h inlines. This also lifts the calls for tracing out of the binfmt load_binary hooks into search_binary_handler() after it calls into the binfmt module. This change has no effect, since all the binfmt modules' load_binary functions did the call at the end on success, and now search_binary_handler() does it immediately after return if successful. We consolidate the repeated code, and binfmt modules no longer need to import ptrace_notify(). Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26Use WARN() in fs/proc/Arjan van de Ven
Use WARN() instead of a printk+WARN_ON() pair; this way the message becomes part of the warning section for better reporting/collection. This way, the entire if() {} section can collapse into the WARN() as well. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26Use WARN() in fs/sysfsArjan van de Ven
Use WARN() instead of a printk+WARN_ON() pair; this way the message becomes part of the warning section for better reporting/collection. Also, with this, one fo the if() sections collapses entirely into the WARN(). Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26Use WARN() in fs/Arjan van de Ven
Use WARN() instead of a printk+WARN_ON() pair; this way the message becomes part of the warning section for better reporting/collection. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26mm: spinlock tree_lockNick Piggin
mapping->tree_lock has no read lockers. convert the lock from an rwlock to a spinlock. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Hugh Dickins <hugh@veritas.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26splice: use get_user_pages_fastNick Piggin
Use get_user_pages_fast in splice. This reverts some mmap_sem batching there, however the biggest problem with mmap_sem tends to be hold times blocking out other threads rather than cacheline bouncing. Further: on architectures that implement get_user_pages_fast without locks, mmap_sem can be avoided completely anyway. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Zach Brown <zach.brown@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26dio: use get_user_pages_fastNick Piggin
Use get_user_pages_fast in the common/generic block and fs direct IO paths. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Zach Brown <zach.brown@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26omfs: update kbuild to include OMFSBob Copeland
Adds OMFS to the fs Kconfig and Makefile Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26omfs: add bitmap routinesBob Copeland
Add block allocation and block bitmap management routines for OMFS. Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26omfs: add file routinesBob Copeland
Add functions for reading and manipulating the storage of file data in the extent-based OMFS. Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26omfs: add directory routinesBob Copeland
Add lookup and directory management routines for OMFS. The filesystem uses hashing based on the filename and stores collisions, unordered, in siblings of files' inode structures. To support telldir, the current position in the hash table is encoded in fpos. Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26omfs: add inode routinesBob Copeland
Add basic superblock and inode handling routines for OMFS Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26omfs: define filesystem structuresBob Copeland
Add header files containing OMFS on-disk and memory structures. Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26bfs: kill BKLDmitri Vorobiev
Replace the BKL-based locking scheme used in the bfs driver by a private filesystem-wide mutex. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi> Cc: Tigran Aivazian <tigran_aivazian@symantec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26bfs: assorted cleanupsDmitri Vorobiev
This patch makes the following cleanups: o removing an unused variable from bfs_fill_super(); o removing unneeded blank spaces from pointer definitions. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi> Cc: Tigran Aivazian <tigran_aivazian@symantec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26affs: convert s_bmlock into a mutexMatthias Kaehlcke
The semaphore s_bmlock is used as a mutex. Convert it to the mutex API. Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26vfs: add cond_resched_lock while scanning dentry LRU listsKentaro Makita
Add cond_resched_lock(&dcache_lock) while scanning LRU lists on superblocks in __shrink_dcache_sb() Signed-off-by: Kentaro Makita <k-makita@np.css.fujitsu.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (34 commits) powerpc: Wireup new syscalls Move update_mmu_cache() declaration from tlbflush.h to pgtable.h powerpc/pseries: Remove kmalloc call in handling writes to lparcfg powerpc/pseries: Update arch vector to indicate support for CMO ibmvfc: Add support for collaborative memory overcommit ibmvscsi: driver enablement for CMO ibmveth: enable driver for CMO ibmveth: Automatically enable larger rx buffer pools for larger mtu powerpc/pseries: Verify CMO memory entitlement updates with virtual I/O powerpc/pseries: vio bus support for CMO powerpc/pseries: iommu enablement for CMO powerpc/pseries: Add CMO paging statistics powerpc/pseries: Add collaborative memory manager powerpc/pseries: Utilities to set firmware page state powerpc/pseries: Enable CMO feature during platform setup powerpc/pseries: Split retrieval of processor entitlement data into a helper routine powerpc/pseries: Add memory entitlement capabilities to /proc/ppc64/lparcfg powerpc/pseries: Split processor entitlement retrieval and gathering to helper routines powerpc/pseries: Remove extraneous error reporting for hcall failures in lparcfg powerpc: Fix compile error with binutils 2.15 ... Fixed up conflict in arch/powerpc/platforms/52xx/Kconfig manually.
2008-07-25fuse: lockd supportMiklos Szeredi
If fuse filesystem doesn't define it's own lock operations, then allow the lock manager to work with fuse. Adding lockd support for remote locking is also possible, but more rarely used, so leave it till later. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Matthew Wilcox <matthew@wil.cx> Cc: David Teigland <teigland@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25fuse: nfs export special lookupsMiklos Szeredi
Implement the get_parent export operation by sending a LOOKUP request with ".." as the name. Implement looking up an inode by node ID after it has been evicted from the cache. This is done by seding a LOOKUP request with "." as the name (for all file types, not just directories). The filesystem can set the FUSE_EXPORT_SUPPORT flag in the INIT reply, to indicate that it supports these special lookups. Thanks to John Muir for the original implementation of this feature. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Matthew Wilcox <matthew@wil.cx> Cc: David Teigland <teigland@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25fuse: add fuse_lookup_name() helperMiklos Szeredi
Add a new helper function which sends a LOOKUP request with the supplied name. This will be used by the next patch to send special LOOKUP requests with "." and ".." as the name. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25fuse: add export operationsMiklos Szeredi
Implement export_operations, to allow fuse filesystems to be exported to NFS. This feature has been in the out-of-tree fuse module, and is widely used and tested. It has not been originally merged into mainline, because doing the NFS export in userspace was thought to be a cleaner and more efficient way of doing it, than through the kernel. While that is true, it would also have involved a lot of duplicated effort at reimplementing NFS exporting (all the different versions of the protocol). This effort was unfortunately not undertaken by anyone, so we are left with doing it the easy but less efficient way. If this feature goes in, the out-of-tree fuse module can go away, which would have several advantages: - not having to maintain two versions - less confusion for users - no bugs due to kernel API changes Comment from hch: - Use the same fh_type values as XFS, since we use the same fh encoding. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25fuse: prepare lookup for nfs exportMiklos Szeredi
Use d_splice_alias() instead of d_add() in fuse lookup code, to allow NFS exporting. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25locks: allow ->lock() to return FILE_LOCK_DEFERREDMiklos Szeredi
Allow filesystem's ->lock() method to call posix_lock_file() instead of posix_lock_file_wait(), and return FILE_LOCK_DEFERRED. This makes it possible to implement a such a ->lock() function, that works with the lock manager, which needs the call to be asynchronous. Now the vfs_lock_file() helper can be used, so this is a cleanup as well. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Matthew Wilcox <matthew@wil.cx> Cc: David Teigland <teigland@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25locks: cleanup code duplicationMiklos Szeredi
Extract common code into a function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Matthew Wilcox <matthew@wil.cx> Cc: David Teigland <teigland@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25locks: add special return value for asynchronous locksMiklos Szeredi
Use a special error value FILE_LOCK_DEFERRED to mean that a locking operation returned asynchronously. This is returned by posix_lock_file() for sleeping locks to mean that the lock has been queued on the block list, and will be woken up when it might become available and needs to be retried (either fl_lmops->fl_notify() is called or fl_wait is woken up). f_op->lock() to mean either the above, or that the filesystem will call back with fl_lmops->fl_grant() when the result of the locking operation is known. The filesystem can do this for sleeping as well as non-sleeping locks. This is to make sure, that return values of -EAGAIN and -EINPROGRESS by filesystems are not mistaken to mean an asynchronous locking. This also makes error handling in fs/locks.c and lockd/svclock.c slightly cleaner. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: David Teigland <teigland@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25lockd: dont return EAGAIN for a permanent errorMiklos Szeredi
Fix nlm_fopen() to return NLM_FAILED (or NLM_LCK_DENIED_NOLOCKS) instead of NLM_LCK_DENIED. The latter means the lock request failed because of a conflicting lock (i.e. a temporary error), which is wrong in this case. Also fix the client to return ENOLCK instead of EAGAIN if a blocking lock request returns with NLM_LOCK_DENIED. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: David Teigland <teigland@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25task IO accounting: provide distinct tgid/tid I/O statisticsAndrea Righi
Report per-thread I/O statistics in /proc/pid/task/tid/io and aggregate parent I/O statistics in /proc/pid/io. This approach follows the same model used to account per-process and per-thread CPU times. As a practial application, this allows for example to quickly find the top I/O consumer when a process spawns many child threads that perform the actual I/O work, because the aggregated I/O statistics can always be found in /proc/pid/io. [ Oleg Nesterov points out that we should check that the task is still alive before we iterate over the threads, but also says that we can do that fixup on top of this later. - Linus ] Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: Matt Heaton <matt@hostmonster.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Acked-by-with-comments: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25proc: move Kconfig to fs/proc/KconfigAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25proc: remove pathetic remount codeAlexey Dobriyan
MS_RMT_MASK will unmask changes in do_remount_sb() anyway. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25proc: always do ->releaseAlexey Dobriyan
Current two-stage scheme of removing PDE emphasizes one bug in proc: open rmmod remove_proc_entry close ->release won't be called because ->proc_fops were cleared. In simple cases it's small memory leak. For every ->open, ->release has to be done. List of openers is introduced which is traversed at remove_proc_entry() if neeeded. Discussions with Al long ago (sigh). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25move proc_kmsg_operations to fs/proc/internal.hAdrian Bunk
This patch moves the extern of struct proc_kmsg_operations to fs/proc/internal.h and adds an #include "internal.h" to fs/proc/kmsg.c so that the latter sees the former. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25fs/partitions/efi: convert to pr_debugThomas Gleixner
convert the local Dprintk() compile time debug printk wrappers to the generic pr_debug() wrapper. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25block/ioctl.c and fs/partition/check.c: check value returned by add_partition()Abdel Benamrouche
Now that add_partition() has been aught to propagate errors, let's check them. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Abdel Benamrouche <draconux@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25fs/partition/check.c: fix return value warningAbdel Benamrouche
fs/partitions/check.c:381: warning: ignoring return value of ___device_add___, declared with attribute warn_unused_result [akpm@linux-foundation.org: multiple-return-statements-per-function are evil] Signed-off-by: Abdel Benamrouche <draconux@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25elf: use ELF_CORE_EFLAGS for kcore ELF header flagsEdgar E. Iglesias
ELF_CORE_EFLAGS is already used by the binfmt_elf coredumper to set correct arch specific ELF header flags on coredumps. Use it for kcore dumps as well. At the moment, this affects the CRIS and the H8300 arch. Signed-off-by: Edgar E. Iglesias <edgar@axis.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25coredump: format_corename: fix the "core_uses_pid" logicOleg Nesterov
I don't understand why the multi-thread coredump implies the core_uses_pid behaviour, but we shouldn't use mm->mm_users for that. This counter can be incremented by get_task_mm(). Use the valued returned by coredump_wait() instead. Also, remove the "const char *pattern" argument, format_corename() can use core_pattern directly. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25coredump: kill mm->core_doneOleg Nesterov
Now that we have core_state->dumper list we can use it to wake up the sub-threads waiting for the coredump completion. This uglifies the code and .text grows by 47 bytes, but otoh mm_struct lessens by sizeof(struct completion). Also, with this change we can decouple exit_mm() from the coredumping code. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25coredump: elf_fdpic_core_dump: use core_state->dumper listOleg Nesterov
Kill the nasty rcu_read_lock() + do_each_thread() loop, use the list encoded in mm->core_state instead, s/GFP_ATOMIC/GFP_KERNEL/. This patch allows futher cleanups in binfmt_elf_fdpic.c. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Roland McGrath <roland@redhat.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25coredump: elf_core_dump: use core_state->dumper listOleg Nesterov
Kill the nasty rcu_read_lock() + do_each_thread() loop, use the list encoded in mm->core_state instead, s/GFP_ATOMIC/GFP_KERNEL/. This patch allows futher cleanups in binfmt_elf.c, in particular we can kill the parallel info->threads list. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
