path: root/fs
2013-11-11Btrfs: remove duplicated ino cache's inode lookupFilipe David Borba Manana
We're doing a unnecessary extra lookup of the ino cache's inode when we already have it (and holding a reference) during the process of saving the ino cache contents to disk. Therefore remove this extra lookup. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: do a full search everytime in btrfs_search_old_slotJosef Bacik
While running some snashot aware defrag tests I noticed I was panicing every once and a while in key_search. This is because of the optimization that says if we find a key at slot 0 it will be at slot 0 all the way down the rest of the tree. This isn't the case for btrfs_search_old_slot since it will likely replay changes to a buffer if something has changed since we took our sequence number. So short circuit this optimization by setting prev_cmp to -1 every time we call key_search so we will do our normal binary search. With this patch I am no longer seeing the panics I was seeing before. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: add a sanity test for btrfs_split_itemJosef Bacik
While looking at somebodys corruption I became completely convinced that btrfs_split_item was broken, so I wrote this test to verify that it was working as it was supposed to. Thankfully it appears to be working as intended, so just add this test to make sure nobody breaks it in the future. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11btrfs: drop unused parameter from btrfs_item_nrRoss Kirk
Remove unused eb parameter from btrfs_item_nr Signed-off-by: Ross Kirk <ross.kirk@gmail.com> Reviewed-by: David Sterba <dsterba@suse.cz> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: don't store NULL byte in symlink extentsFilipe David Borba Manana
It is not necessary to store the NULL byte in a symlink inline file extent. There's currently no code that requires the NULL byte to be present in the extent. This change also doesn't break file format compatibility nor the send/receive feature. The VFS also doesn't need the NULL byte to be present in the extent, as it reads up to inode->i_size bytes (which already excluded the NULL byte) and sets the NULL byte for us (in fs/namei.c:page_getlink()). So with this change we save 1 byte per symlink file extent (which is always inlined in the btree leaf) without losing backward and forward compatibility. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: eliminate the exceptional root_tree refs=0Stefan Behrens
The fact that btrfs_root_refs() returned 0 for the tree_root caused bugs in the past, therefore it is set to 1 with this patch and (hopefully) all affected code is adapted to this change. I verified this change by temporarily adding WARN_ON() checks everywhere where btrfs_root_refs() is used, checking whether the logic of the code is changed by btrfs_root_refs() returning 1 instead of 0 for root->root_key.objectid == BTRFS_ROOT_TREE_OBJECTID. With these added checks, I ran the xfstests './check -g auto'. The two roots chunk_root and log_root_tree that are only referenced by the superblock and the log_roots below the log_root_tree still have btrfs_root_refs() == 0, only the tree_root is changed. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-10-31vfs: decrapify dput(), fix cache behavior under normal loadLinus Torvalds
We do not want to dirty the dentry->d_flags cacheline in dput() just to set the DCACHE_REFERENCED flag when it is already set in the common case anyway. This way the first cacheline of the dentry (which contains the RCU lookup information etc) can stay shared among multiple CPU's. This finishes off some of the details of all the scalability patches merged during the merge window. Also don't mark dentry_kill() for inlining, since it's the uncommon path and inlining it just makes the common path slower due to extra function entry/exit overhead. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-30Revert "select: use freezable blocking call"Rafael J. Wysocki
This reverts commit 9745cdb36da8 (select: use freezable blocking call) that triggers problems during resume from suspend to RAM on Paul Bolle's 32-bit x86 machines. Paul says: Ever since I tried running (release candidates of) v3.11 on the two working i686s I still have lying around I ran into issues on resuming from suspend. Reverting 9745cdb36da8 (select: use freezable blocking call) resolves those issues. Resuming from suspend on i686 on (release candidates of) v3.11 and later triggers issues like: traps: systemd[1] general protection ip:b738e490 sp:bf882fc0 error:0 in libc-2.16.so[b731c000+1b0000] and traps: rtkit-daemon[552] general protection ip:804d6e5 sp:b6cb32f0 error:0 in rtkit-daemon[8048000+d000] Once I hit the systemd error I can only get out of the mess that the system is at that point by power cycling it. Since we are reverting another freezer-related change causing similar problems to happen, this one should be reverted as well. References: https://lkml.org/lkml/2013/10/29/583 Reported-by: Paul Bolle <pebolle@tiscali.nl> Fixes: 9745cdb36da8 (select: use freezable blocking call) Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: 3.11+ <stable@vger.kernel.org> # 3.11+
2013-10-30Revert "epoll: use freezable blocking call"Rafael J. Wysocki
This reverts commit 1c441e921201 (epoll: use freezable blocking call) which is reported to cause user space memory corruption to happen after suspend to RAM. Since it appears to be extremely difficult to root cause this problem, it is best to revert the offending commit and try to address the original issue in a better way later. References: https://bugzilla.kernel.org/show_bug.cgi?id=61781 Reported-by: Natrio <natrio@list.ru> Reported-by: Jeff Pohlmeyer <yetanothergeek@gmail.com> Bisected-by: Leo Wolf <jclw@ymail.com> Fixes: 1c441e921201 (epoll: use freezable blocking call) Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: 3.11+ <stable@vger.kernel.org> # 3.11+
2013-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes (try two) from Al Viro: "nfsd performance regression fix + seq_file lseek(2) fix" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: seq_file: always update file->f_pos in seq_lseek() nfsd regression since delayed fput()
2013-10-25seq_file: always update file->f_pos in seq_lseek()Gu Zheng
This issue was first pointed out by Jiaxing Wang several months ago, but no further comments: https://lkml.org/lkml/2013/6/29/41 As we know pread() does not change f_pos, so after pread(), file->f_pos and m->read_pos become different. And seq_lseek() does not update file->f_pos if offset equals to m->read_pos, so after pread() and seq_lseek()(lseek to m->read_pos), then a subsequent read may read from a wrong position, the following program produces the problem: char str1[32] = { 0 }; char str2[32] = { 0 }; int poffset = 10; int count = 20; /*open any seq file*/ int fd = open("/proc/modules", O_RDONLY); pread(fd, str1, count, poffset); printf("pread:%s\n", str1); /*seek to where m->read_pos is*/ lseek(fd, poffset+count, SEEK_SET); /*supposed to read from poffset+count, but this read from position 0*/ read(fd, str2, count); printf("read:%s\n", str2); out put: pread: ck_netbios_ns 12665 read: nf_conntrack_netbios /proc/modules: nf_conntrack_netbios_ns 12665 0 - Live 0xffffffffa038b000 nf_conntrack_broadcast 12589 1 nf_conntrack_netbios_ns, Live 0xffffffffa0386000 So we always update file->f_pos to offset in seq_lseek() to fix this issue. Signed-off-by: Jiaxing Wang <hello.wjx@gmail.com> Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-10-25Merge tag 'ecryptfs-3.12-rc7-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs Pull ecryptfs fixes from Tyler Hicks: "Two important fixes - Fix long standing memory leak in the (rarely used) public key support - Fix large file corruption on 32 bit architectures" * tag 'ecryptfs-3.12-rc7-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs: eCryptfs: fix 32 bit corruption issue ecryptfs: Fix memory leakage in keystore.c
2013-10-24eCryptfs: fix 32 bit corruption issueColin Ian King
Shifting page->index on 32 bit systems was overflowing, causing data corruption of > 4GB files. Fix this by casting it first. https://launchpad.net/bugs/1243636 Signed-off-by: Colin Ian King <colin.king@canonical.com> Reported-by: Lars Duesing <lars.duesing@camelotsweb.de> Cc: stable@vger.kernel.org # v3.11+ Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2013-10-22vfs: fix new kernel-doc warningsRandy Dunlap
Move kernel-doc notation to immediately before its function to eliminate kernel-doc warnings introduced by commit db14fc3abcd5 ("vfs: add d_walk()") Warning(fs/dcache.c:1343): No description found for parameter 'data' Warning(fs/dcache.c:1343): No description found for parameter 'dentry' Warning(fs/dcache.c:1343): Excess function parameter 'parent' description in 'check_mount' Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Cc: Miklos Szeredi <mszeredi@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-22fs/namei.c: fix new kernel-doc warningRandy Dunlap
Add @path parameter to fix kernel-doc warning. Also fix a spello/typo. Warning(fs/namei.c:2304): No description found for parameter 'path' Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-22Merge tag 'jfs-3.12' of git://github.com/kleikamp/linux-shaggyLinus Torvalds
Pull jfs bugfix from David Kleikamp: "Just a patch to fix an oops in an error path" * tag 'jfs-3.12' of git://github.com/kleikamp/linux-shaggy: jfs: fix error path in ialloc
2013-10-20nfsd regression since delayed fput()Al Viro
Background: nfsd v[23] had throughput regression since delayed fput went in; every read or write ends up doing fput() and we get a pair of extra context switches out of that (plus quite a bit of work in queue_work itselfi, apparently). Use of schedule_delayed_work() gives it a chance to accumulate a bit before we do __fput() on all of them. I'm not too happy about that solution, but... on at least one real-world setup it reverts about 10% throughput loss we got from switch to delayed fput. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-10-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fix from Chris Mason: "Sage hit a deadlock with ceph on btrfs, and Josef tracked it down to a regression in our initial rc1 pull. When doing nocow writes we were sometimes starting a transaction with locks held" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: release path before starting transaction in can_nocow_extent
2013-10-18Btrfs: release path before starting transaction in can_nocow_extentJosef Bacik
We can't be holding tree locks while we try to start a transaction, we will deadlock. Thanks, Reported-by: Sage Weil <sage@inktank.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-10-17Merge branch 'for-linus' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "Five small cifs fixes (includes fixes for: unmount hang, 2 security related, symlink, large file writes)" * 'for-linus' of git://git.samba.org/sfrench/cifs-2.6: cifs: ntstatus_to_dos_map[] is not terminated cifs: Allow LANMAN auth method for servers supporting unencapsulated authentication methods cifs: Fix inability to write files >2GB to SMB2/3 shares cifs: Avoid umount hangs with smb2 when server is unresponsive do not treat non-symlink reparse points as valid symlinks
2013-10-16Merge branch 'akpm' (fixes from Andrew Morton)Linus Torvalds
Merge misc fixes from Andrew Morton. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (21 commits) mm: revert mremap pud_free anti-fix mm: fix BUG in __split_huge_page_pmd swap: fix set_blocksize race during swapon/swapoff procfs: call default get_unmapped_area on MMU-present architectures procfs: fix unintended truncation of returned mapped address writeback: fix negative bdi max pause percpu_refcount: export symbols fs: buffer: move allocation failure loop into the allocator mm: memcg: handle non-error OOM situations more gracefully tools/testing/selftests: fix uninitialized variable block/partitions/efi.c: treat size mismatch as a warning, not an error mm: hugetlb: initialize PG_reserved for tail pages of gigantic compound pages mm/zswap: bugfix: memory leak when re-swapon mm: /proc/pid/pagemap: inspect _PAGE_SOFT_DIRTY only on present pages mm: migration: do not lose soft dirty bit if page is in migration state gcov: MAINTAINERS: Add an entry for gcov mm/hugetlb.c: correct missing private flag clearing mm/vmscan.c: don't forget to free shrinker->nr_deferred ipc/sem.c: synchronize semop and semctl with IPC_RMID ipc: update locking scheme comments ...
2013-10-16procfs: call default get_unmapped_area on MMU-present architecturesHATAYAMA Daisuke
Commit c4fe24485729 ("sparc: fix PCI device proc file mmap(2)") added proc_reg_get_unmapped_area in proc_reg_file_ops and proc_reg_file_ops_no_compat, by which now mmap always returns EIO if get_unmapped_area method is not defined for the target procfs file, which causes regression of mmap on /proc/vmcore. To address this issue, like get_unmapped_area(), call default current->mm->get_unmapped_area on MMU-present architectures if pde->proc_fops->get_unmapped_area, i.e. the one in actual file operation in the procfs file, is not defined. Reported-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: David S. Miller <davem@davemloft.net> Tested-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16procfs: fix unintended truncation of returned mapped addressHATAYAMA Daisuke
Currently, proc_reg_get_unmapped_area truncates upper 32-bit of the mapped virtual address returned from get_unmapped_area method in pde->proc_fops due to the variable rv of signed integer on x86_64. This is too small to have vitual address of unsigned long on x86_64 since on x86_64, signed integer is of 4 bytes while unsigned long is of 8 bytes. To fix this issue, use unsigned long instead. Fixes a regression added in commit c4fe24485729 ("sparc: fix PCI device proc file mmap(2)"). Signed-off-by: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: David S. Miller <davem@davemloft.net> Tested-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16fs: buffer: move allocation failure loop into the allocatorJohannes Weiner
Buffer allocation has a very crude indefinite loop around waking the flusher threads and performing global NOFS direct reclaim because it can not handle allocation failures. The most immediate problem with this is that the allocation may fail due to a memory cgroup limit, where flushers + direct reclaim might not make any progress towards resolving the situation at all. Because unlike the global case, a memory cgroup may not have any cache at all, only anonymous pages but no swap. This situation will lead to a reclaim livelock with insane IO from waking the flushers and thrashing unrelated filesystem cache in a tight loop. Use __GFP_NOFAIL allocations for buffers for now. This makes sure that any looping happens in the page allocator, which knows how to orchestrate kswapd, direct reclaim, and the flushers sensibly. It also allows memory cgroups to detect allocations that can't handle failure and will allow them to ultimately bypass the limit if reclaim can not make progress. Reported-by: azurIt <azurit@pobox.sk> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16mm: /proc/pid/pagemap: inspect _PAGE_SOFT_DIRTY only on present pagesCyrill Gorcunov
If a page we are inspecting is in swap we may occasionally report it as having soft dirty bit (even if it is clean). The pte_soft_dirty helper should be called on present pte only. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Matt Mackall <mpm@selenic.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Peter Zijlstra <peterz@infradead.org> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull tmpfile fix from Al Viro: "A fix for double iput() in ->tmpfile() on ext3 and ext4; I'd fucked it up, Miklos has caught it" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: ext[34]: fix double put in tmpfile
2013-10-16ecryptfs: Fix memory leakage in keystore.cGeyslan G. Bem
In 'decrypt_pki_encrypted_session_key' function: Initializes 'payload' pointer and releases it on exit. Signed-off-by: Geyslan G. Bem <geyslan@gmail.com> Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Cc: stable@vger.kernel.org # v2.6.28+
2013-10-15ext[34]: fix double put in tmpfileMiklos Szeredi
d_tmpfile() already swallowed the inode ref. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-10-14cifs: ntstatus_to_dos_map[] is not terminatedTim Gardner
Functions that walk the ntstatus_to_dos_map[] array could run off the end. For example, ntstatus_to_dos() loops while ntstatus_to_dos_map[].ntstatus is not 0. Granted, this is mostly theoretical, but could be used as a DOS attack if the error code in the SMB header is bogus. [Might consider adding to stable, as this patch is low risk - Steve] Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-10-12vfs: allow O_PATH file descriptors for fstatfs()Linus Torvalds
Olga reported that file descriptors opened with O_PATH do not work with fstatfs(), found during further development of ksh93's thread support. There is no reason to not allow O_PATH file descriptors here (fstatfs is very much a path operation), so use "fdget_raw()". See commit 55815f70147d ("vfs: make O_PATH file descriptors usable for 'fstat()'") for a very similar issue reported for fstat() by the same team. Reported-and-tested-by: ольга крыжановская <olga.kryzhanovska@gmail.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@kernel.org # O_PATH introduced in 3.0+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-12Merge tag 'ext4_for_linus_stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 bugfixes from Ted Ts'o: "A bug fix and performance regression fix for ext4" * tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: fix memory leak in xattr ext4: fix performance regression in writeback of random writes
2013-10-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "We've got more bug fixes in my for-linus branch: One of these fixes another corner of the compression oops from last time. Miao nailed down some problems with concurrent snapshot deletion and drive balancing. I kept out one of his patches for more testing, but these are all stable" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: fix oops caused by the space balance and dead roots Btrfs: insert orphan roots into fs radix tree Btrfs: limit delalloc pages outside of find_delalloc_range Btrfs: use right root when checking for hash collision
2013-10-12ext4: fix memory leak in xattrDave Jones
If we take the 2nd retry path in ext4_expand_extra_isize_ea, we potentionally return from the function without having freed these allocations. If we don't do the return, we over-write the previous allocation pointers, so we leak either way. Spotted with Coverity. [ Fixed by tytso to set is and bs to NULL after freeing these pointers, in case in the retry loop we later end up triggering an error causing a jump to cleanup, at which point we could have a double free bug. -- Ted ] Signed-off-by: Dave Jones <davej@fedoraproject.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Eric Sandeen <sandeen@redhat.com> Cc: stable@vger.kernel.org
2013-10-10Btrfs: fix oops caused by the space balance and dead rootsMiao Xie
When doing space balance and subvolume destroy at the same time, we met the following oops: kernel BUG at fs/btrfs/relocation.c:2247! RIP: 0010: [<ffffffffa04cec16>] prepare_to_merge+0x154/0x1f0 [btrfs] Call Trace: [<ffffffffa04b5ab7>] relocate_block_group+0x466/0x4e6 [btrfs] [<ffffffffa04b5c7a>] btrfs_relocate_block_group+0x143/0x275 [btrfs] [<ffffffffa0495c56>] btrfs_relocate_chunk.isra.27+0x5c/0x5a2 [btrfs] [<ffffffffa0459871>] ? btrfs_item_key_to_cpu+0x15/0x31 [btrfs] [<ffffffffa048b46a>] ? btrfs_get_token_64+0x7e/0xcd [btrfs] [<ffffffffa04a3467>] ? btrfs_tree_read_unlock_blocking+0xb2/0xb7 [btrfs] [<ffffffffa049907d>] btrfs_balance+0x9c7/0xb6f [btrfs] [<ffffffffa049ef84>] btrfs_ioctl_balance+0x234/0x2ac [btrfs] [<ffffffffa04a1e8e>] btrfs_ioctl+0xd87/0x1ef9 [btrfs] [<ffffffff81122f53>] ? path_openat+0x234/0x4db [<ffffffff813c3b78>] ? __do_page_fault+0x31d/0x391 [<ffffffff810f8ab6>] ? vma_link+0x74/0x94 [<ffffffff811250f5>] vfs_ioctl+0x1d/0x39 [<ffffffff811258c8>] do_vfs_ioctl+0x32d/0x3e2 [<ffffffff811259d4>] SyS_ioctl+0x57/0x83 [<ffffffff813c3bfa>] ? do_page_fault+0xe/0x10 [<ffffffff813c73c2>] system_call_fastpath+0x16/0x1b It is because we returned the error number if the reference of the root was 0 when doing space relocation. It was not right here, because though the root was dead(refs == 0), but the space it held still need be relocated, or we could not remove the block group. So in this case, we should return the root no matter it is dead or not. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-10-10Btrfs: insert orphan roots into fs radix treeMiao Xie
Now we don't drop all the deleted snapshots/subvolumes before the space balance. It means we have to relocate the space which is held by the dead snapshots/subvolumes. So we must into them into fs radix tree, or we would forget to commit the change of them when doing transaction commit, and it would corrupt the metadata. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-10-10Btrfs: limit delalloc pages outside of find_delalloc_rangeJosef Bacik
Liu fixed part of this problem and unfortunately I steered him in slightly the wrong direction and so didn't completely fix the problem. The problem is we limit the size of the delalloc range we are looking for to max bytes and then we try to lock that range. If we fail to lock the pages in that range we will shrink the max bytes to a single page and re loop. However if our first page is inside of the delalloc range then we will end up limiting the end of the range to a period before our first page. This is illustrated below [0 -------- delalloc range --------- 256mb] [page] So find_delalloc_range will return with delalloc_start as 0 and end as 128mb, and then we will notice that delalloc_start < *start and adjust it up, but not adjust delalloc_end up, so things go sideways. To fix this we need to not limit the max bytes in find_delalloc_range, but in find_lock_delalloc_range and that way we don't end up with this confusion. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-10-10Btrfs: use right root when checking for hash collisionJosef Bacik
btrfs_rename was using the root of the old dir instead of the root of the new dir when checking for a hash collision, so if you tried to move a file into a subvol it would freak out because it would see the file you are trying to move in its current root. This fixes the bug where this would fail btrfs subvol create test1 btrfs subvol create test2 mv test1 test2. Thanks to Chris Murphy for catching this, Cc: stable@vger.kernel.org Reported-by: Chris Murphy <lists@colorremedies.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-10-07cifs: Allow LANMAN auth method for servers supporting unencapsulated ↵Sachin Prabhu
authentication methods This allows users to use LANMAN authentication on servers which support unencapsulated authentication. The patch fixes a regression where users using plaintext authentication were no longer able to do so because of changed bought in by patch 3f618223dc0bdcbc8d510350e78ee2195ff93768 https://bugzilla.redhat.com/show_bug.cgi?id=1011621 Reported-by: Panos Kavalagios <Panagiotis.Kavalagios@eurodyn.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-10-07cifs: Fix inability to write files >2GB to SMB2/3 sharesJan Klos
When connecting to SMB2/3 shares, maximum file size is set to non-LFS maximum in superblock. This is due to cap_large_files bit being different for SMB1 and SMB2/3 (where it is just an internal flag that is not negotiated and the SMB1 one corresponds to multichannel capability, so maybe LFS works correctly if server sends 0x08 flag) while capabilities are checked always for the SMB1 bit in cifs_read_super(). The patch fixes this by checking for the correct bit according to the protocol version. CC: Stable <stable@kernel.org> Signed-off-by: Jan Klos <honza.klos@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-10-06cifs: Avoid umount hangs with smb2 when server is unresponsiveShirish Pargaonkar
Do not send SMB2 Logoff command when reconnecting, the way smb1 code base works. Also, no need to wait for a credit for an echo command when one is already in flight. Without these changes, umount command hangs if the server is unresponsive e.g. hibernating. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@us.ibm.com>
2013-10-05do not treat non-symlink reparse points as valid symlinksSteve French
Windows 8 and later can create NFS symlinks (within reparse points) which we were assuming were normal NTFS symlinks and thus reporting corrupt paths for. Add check for reparse points to make sure that they really are normal symlinks before we try to parse the pathname. We also should not be parsing other types of reparse points (DFS junctions etc) as if they were a symlink so return EOPNOTSUPP on those. Also fix endian errors (we were not parsing symlink lengths as little endian). This fixes commit d244bf2dfbebfded05f494ffd53659fa7b1e32c1 which implemented follow link for non-Unix CIFS mounts CC: Stable <stable@kernel.org> Reviewed-by: Andrew Bartlett <abartlet@samba.org> Signed-off-by: Steve French <smfrench@gmail.com>
2013-10-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "This is a small collection of fixes, including a regression fix from Liu Bo that solves rare crashes with compression on. I've merged my for-linus up to 3.12-rc3 because the top commit is only meant for 3.12. The rest of the fixes are also available in my master branch on top of my last 3.11 based pull" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: btrfs: Fix crash due to not allocating integrity data for a bioset Btrfs: fix a use-after-free bug in btrfs_dev_replace_finishing Btrfs: eliminate races in worker stopping code Btrfs: fix crash of compressed writes Btrfs: fix transid verify errors when recovering log tree
2013-10-05btrfs: Fix crash due to not allocating integrity data for a biosetDarrick J. Wong
When btrfs creates a bioset, we must also allocate the integrity data pool. Otherwise btrfs will crash when it tries to submit a bio to a checksumming disk: BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: [<ffffffff8111e28a>] mempool_alloc+0x4a/0x150 PGD 2305e4067 PUD 23063d067 PMD 0 Oops: 0000 [#1] PREEMPT SMP Modules linked in: btrfs scsi_debug xfs ext4 jbd2 ext3 jbd mbcache sch_fq_codel eeprom lpc_ich mfd_core nfsd exportfs auth_rpcgss af_packet raid6_pq xor zlib_deflate libcrc32c [last unloaded: scsi_debug] CPU: 1 PID: 4486 Comm: mount Not tainted 3.12.0-rc1-mcsum #2 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 task: ffff8802451c9720 ti: ffff880230698000 task.ti: ffff880230698000 RIP: 0010:[<ffffffff8111e28a>] [<ffffffff8111e28a>] mempool_alloc+0x4a/0x150 RSP: 0018:ffff880230699688 EFLAGS: 00010286 RAX: 0000000000000001 RBX: 0000000000000000 RCX: 00000000005f8445 RDX: 0000000000000001 RSI: 0000000000000010 RDI: 0000000000000000 RBP: ffff8802306996f8 R08: 0000000000011200 R09: 0000000000000008 R10: 0000000000000020 R11: ffff88009d6e8000 R12: 0000000000011210 R13: 0000000000000030 R14: ffff8802306996b8 R15: ffff8802451c9720 FS: 00007f25b8a16800(0000) GS:ffff88024fc80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000018 CR3: 0000000230576000 CR4: 00000000000007e0 Stack: ffff8802451c9720 0000000000000002 ffffffff81a97100 0000000000281250 ffffffff81a96480 ffff88024fc99150 ffff880228d18200 0000000000000000 0000000000000000 0000000000000040 ffff880230e8c2e8 ffff8802459dc900 Call Trace: [<ffffffff811b2208>] bio_integrity_alloc+0x48/0x1b0 [<ffffffff811b26fc>] bio_integrity_prep+0xac/0x360 [<ffffffff8111e298>] ? mempool_alloc+0x58/0x150 [<ffffffffa03e8041>] ? alloc_extent_state+0x31/0x110 [btrfs] [<ffffffff81241579>] blk_queue_bio+0x1c9/0x460 [<ffffffff8123e58a>] generic_make_request+0xca/0x100 [<ffffffff8123e639>] submit_bio+0x79/0x160 [<ffffffffa03f865e>] btrfs_map_bio+0x48e/0x5b0 [btrfs] [<ffffffffa03c821a>] btree_submit_bio_hook+0xda/0x110 [btrfs] [<ffffffffa03e7eba>] submit_one_bio+0x6a/0xa0 [btrfs] [<ffffffffa03ef450>] read_extent_buffer_pages+0x250/0x310 [btrfs] [<ffffffff8125eef6>] ? __radix_tree_preload+0x66/0xf0 [<ffffffff8125f1c5>] ? radix_tree_insert+0x95/0x260 [<ffffffffa03c66f6>] btree_read_extent_buffer_pages.constprop.128+0xb6/0x120 [btrfs] [<ffffffffa03c8c1a>] read_tree_block+0x3a/0x60 [btrfs] [<ffffffffa03caefd>] open_ctree+0x139d/0x2030 [btrfs] [<ffffffffa03a282a>] btrfs_mount+0x53a/0x7d0 [btrfs] [<ffffffff8113ab0b>] ? pcpu_alloc+0x8eb/0x9f0 [<ffffffff81167305>] ? __kmalloc_track_caller+0x35/0x1e0 [<ffffffff81176ba0>] mount_fs+0x20/0xd0 [<ffffffff81191096>] vfs_kern_mount+0x76/0x120 [<ffffffff81193320>] do_mount+0x200/0xa40 [<ffffffff81135cdb>] ? strndup_user+0x5b/0x80 [<ffffffff81193bf0>] SyS_mount+0x90/0xe0 [<ffffffff8156d31d>] system_call_fastpath+0x1a/0x1f Code: 4c 8d 75 a8 4c 89 6d e8 45 89 e0 4c 8d 6f 30 48 89 5d d8 41 83 e0 af 48 89 fb 49 83 c6 18 4c 89 7d f8 65 4c 8b 3c 25 c0 b8 00 00 <48> 8b 73 18 44 89 c7 44 89 45 98 ff 53 20 48 85 c0 48 89 c2 74 RIP [<ffffffff8111e28a>] mempool_alloc+0x4a/0x150 RSP <ffff880230699688> CR2: 0000000000000018 ---[ end trace 7a96042017ed21e2 ]--- Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-10-05Merge branch 'for-linus' into for-linus-3.12Chris Mason
2013-10-04Merge branch 'for-linus' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "Small set of cifs fixes. Most important is Jeff's fix that works around disconnection problems which can be caused by simultaneous use of user space tools (starting a long running smbclient backup then doing a cifs kernel mount) or multiple cifs mounts through a NAT, and Jim's fix to deal with reexport of cifs share. I expect to send two more cifs fixes next week (being tested now) - fixes to address an SMB2 unmount hang when server dies and a fix for cifs symlink handling of Windows "NFS" symlinks" * 'for-linus' of git://git.samba.org/sfrench/cifs-2.6: [CIFS] update cifs.ko version [CIFS] Remove ext2 flags that have been moved to fs.h [CIFS] Provide sane values for nlink cifs: stop trying to use virtual circuits CIFS: FS-Cache: Uncache unread pages in cifs_readpages() before freeing them
2013-10-04Merge tag 'xfs-for-linus-v3.12-rc4' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull xfs bugfixes from Ben Myers: "There are lockdep annotations for project quotas, a fix for dirent dtype support on v4 filesystems, a fix for a memory leak in recovery, and a fix for the build error that resulted from it. D'oh" * tag 'xfs-for-linus-v3.12-rc4' of git://oss.sgi.com/xfs/xfs: xfs: Use kmem_free() instead of free() xfs: fix memory leak in xlog_recover_add_to_trans xfs: dirent dtype presence is dependent on directory magic numbers xfs: lockdep needs to know about 3 dquot-deep nesting
2013-10-04Btrfs: fix a use-after-free bug in btrfs_dev_replace_finishingIlya Dryomov
free_device rcu callback, scheduled from btrfs_rm_dev_replace_srcdev, can be processed before btrfs_scratch_superblock is called, which would result in a use-after-free on btrfs_device contents. Fix this by zeroing the superblock before the rcu callback is registered. Cc: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-10-04Btrfs: eliminate races in worker stopping codeIlya Dryomov
The current implementation of worker threads in Btrfs has races in worker stopping code, which cause all kinds of panics and lockups when running btrfs/011 xfstest in a loop. The problem is that btrfs_stop_workers is unsynchronized with respect to check_idle_worker, check_busy_worker and __btrfs_start_workers. E.g., check_idle_worker race flow: btrfs_stop_workers(): check_idle_worker(aworker): - grabs the lock - splices the idle list into the working list - removes the first worker from the working list - releases the lock to wait for its kthread's completion - grabs the lock - if aworker is on the working list, moves aworker from the working list to the idle list - releases the lock - grabs the lock - puts the worker - removes the second worker from the working list ...... btrfs_stop_workers returns, aworker is on the idle list FS is umounted, memory is freed ...... aworker is waken up, fireworks ensue With this applied, I wasn't able to trigger the problem in 48 hours, whereas previously I could reliably reproduce at least one of these races within an hour. Reported-by: David Sterba <dsterba@suse.cz> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-10-04Btrfs: fix crash of compressed writesLiu Bo
The crash[1] is found by xfstests/generic/208 with "-o compress", it's not reproduced everytime, but it does panic. The bug is quite interesting, it's actually introduced by a recent commit (573aecafca1cf7a974231b759197a1aebcf39c2a, Btrfs: actually limit the size of delalloc range). Btrfs implements delay allocation, so during writeback, we (1) get a page A and lock it (2) search the state tree for delalloc bytes and lock all pages within the range (3) process the delalloc range, including find disk space and create ordered extent and so on. (4) submit the page A. It runs well in normal cases, but if we're in a racy case, eg. buffered compressed writes and aio-dio writes, sometimes we may fail to lock all pages in the 'delalloc' range, in which case, we need to fall back to search the state tree again with a smaller range limit(max_bytes = PAGE_CACHE_SIZE - offset). The mentioned commit has a side effect, that is, in the fallback case, we can find delalloc bytes before the index of the page we already have locked, so we're in the case of (delalloc_end <= *start) and return with (found > 0). This ends with not locking delalloc pages but making ->writepage still process them, and the crash happens. This fixes it by just thinking that we find nothing and returning to caller as the caller knows how to deal with it properly. [1]: ------------[ cut here ]------------ kernel BUG at mm/page-writeback.c:2170! [...] CPU: 2 PID: 11755 Comm: btrfs-delalloc- Tainted: G O 3.11.0+ #8 [...] RIP: 0010:[<ffffffff810f5093>] [<ffffffff810f5093>] clear_page_dirty_for_io+0x1e/0x83 [...] [ 4934.248731] Stack: [ 4934.248731] ffff8801477e5dc8 ffffea00049b9f00 ffff8801869f9ce8 ffffffffa02b841a [ 4934.248731] 0000000000000000 0000000000000000 0000000000000fff 0000000000000620 [ 4934.248731] ffff88018db59c78 ffffea0005da8d40 ffffffffa02ff860 00000001810016c0 [ 4934.248731] Call Trace: [ 4934.248731] [<ffffffffa02b841a>] extent_range_clear_dirty_for_io+0xcf/0xf5 [btrfs] [ 4934.248731] [<ffffffffa02a8889>] compress_file_range+0x1dc/0x4cb [btrfs] [ 4934.248731] [<ffffffff8104f7af>] ? detach_if_pending+0x22/0x4b [ 4934.248731] [<ffffffffa02a8bad>] async_cow_start+0x35/0x53 [btrfs] [ 4934.248731] [<ffffffffa02c694b>] worker_loop+0x14b/0x48c [btrfs] [ 4934.248731] [<ffffffffa02c6800>] ? btrfs_queue_worker+0x25c/0x25c [btrfs] [ 4934.248731] [<ffffffff810608f5>] kthread+0x8d/0x95 [ 4934.248731] [<ffffffff81060868>] ? kthread_freezable_should_stop+0x43/0x43 [ 4934.248731] [<ffffffff814fe09c>] ret_from_fork+0x7c/0xb0 [ 4934.248731] [<ffffffff81060868>] ? kthread_freezable_should_stop+0x43/0x43 [ 4934.248731] Code: ff 85 c0 0f 94 c0 0f b6 c0 59 5b 5d c3 0f 1f 44 00 00 55 48 89 e5 41 54 53 48 89 fb e8 2c de 00 00 49 89 c4 48 8b 03 a8 01 75 02 <0f> 0b 4d 85 e4 74 52 49 8b 84 24 80 00 00 00 f6 40 20 01 75 44 [ 4934.248731] RIP [<ffffffff810f5093>] clear_page_dirty_for_io+0x1e/0x83 [ 4934.248731] RSP <ffff8801869f9c48> [ 4934.280307] ---[ end trace 36f06d3f8750236a ]--- Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2013-10-04Btrfs: fix transid verify errors when recovering log treeJosef Bacik
If we crash with a log, remount and recover that log, and then crash before we can commit another transaction we will get transid verify errors on the next mount. This is because we were not zero'ing out the log when we committed the transaction after recovery. This is ok as long as we commit another transaction at some point in the future, but if you abort or something else goes wrong you can end up in this weird state because the recovery stuff says that the tree log should have a generation+1 of the super generation, which won't be the case of the transaction that was started for recovery. Fix this by removing the check and _always_ zero out the log portion of the super when we commit a transaction. This fixes the transid verify issues I was seeing with my force errors tests. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com>
