path: root/fs
2014-04-12Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit updates from Eric Paris. * git://git.infradead.org/users/eparis/audit: (28 commits) AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range audit: do not cast audit_rule_data pointers pointlesly AUDIT: Allow login in non-init namespaces audit: define audit_is_compat in kernel internal header kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c sched: declare pid_alive as inline audit: use uapi/linux/audit.h for AUDIT_ARCH declarations syscall_get_arch: remove useless function arguments audit: remove stray newline from audit_log_execve_info() audit_panic() call audit: remove stray newlines from audit_log_lost messages audit: include subject in login records audit: remove superfluous new- prefix in AUDIT_LOGIN messages audit: allow user processes to log from another PID namespace audit: anchor all pid references in the initial pid namespace audit: convert PPIDs to the inital PID namespace. pid: get pid_t ppid of task in init_pid_ns audit: rename the misleading audit_get_context() to audit_take_context() audit: Add generic compat syscall support audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL ...
2014-04-11Merge git://git.kvack.org/~bcrl/aio-nextLinus Torvalds
Pull aio ctx->ring_pages migration serialization fix from Ben LaHaise. * git://git.kvack.org/~bcrl/aio-next: aio: v4 ensure access to ctx->ring_pages is correctly serialised for migration
2014-04-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull second set of btrfs updates from Chris Mason: "The most important changes here are from Josef, fixing a btrfs regression in 3.14 that can cause corruptions in the extent allocation tree when snapshots are in use. Josef also fixed some deadlocks in send/recv and other assorted races when balance is running" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (23 commits) Btrfs: fix compile warnings on on avr32 platform btrfs: allow mounting btrfs subvolumes with different ro/rw options btrfs: export global block reserve size as space_info btrfs: fix crash in remount(thread_pool=) case Btrfs: abort the transaction when we don't find our extent ref Btrfs: fix EINVAL checks in btrfs_clone Btrfs: fix unlock in __start_delalloc_inodes() Btrfs: scrub raid56 stripes in the right way Btrfs: don't compress for a small write Btrfs: more efficient io tree navigation on wait_extent_bit Btrfs: send, build path string only once in send_hole btrfs: filter invalid arg for btrfs resize Btrfs: send, fix data corruption due to incorrect hole detection Btrfs: kmalloc() doesn't return an ERR_PTR Btrfs: fix snapshot vs nocow writting btrfs: Change the expanding write sequence to fix snapshot related bug. btrfs: make device scan less noisy btrfs: fix lockdep warning with reclaim lock inversion Btrfs: hold the commit_root_sem when getting the commit root during send Btrfs: remove transaction from send ...
2014-04-11Btrfs: fix compile warnings on on avr32 platformWang Shilong
fs/btrfs/scrub.c: In function 'get_raid56_logic_offset': fs/btrfs/scrub.c:2269: warning: comparison of distinct pointer types lacks a cast fs/btrfs/scrub.c:2269: warning: right shift count >= width of type fs/btrfs/scrub.c:2269: warning: passing argument 1 of '__div64_32' from incompatible pointer type Since @rot is an int type, we should not use do_div(), fix it. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-04-10Merge branch 'for-linus' of git://git.open-osd.org/linux-open-osdLinus Torvalds
Pull exofs updates from Boaz Harrosh: "Trivial updates to exofs for 3.15-rc1 Just a few fixes sent by people" * 'for-linus' of git://git.open-osd.org/linux-open-osd: MAINTAINERS: Update email address for bhalevy fs: Mark functions as static in exofs/ore_raid.c fs: Mark function as static in exofs/super.c
2014-04-10btrfs: allow mounting btrfs subvolumes with different ro/rw optionsHarald Hoyer
Given the following /etc/fstab entries: /dev/sda3 /mnt/foo btrfs subvol=foo,ro 0 0 /dev/sda3 /mnt/bar btrfs subvol=bar,rw 0 0 you can't issue: $ mount /mnt/foo $ mount /mnt/bar You would have to do: $ mount /mnt/foo $ mount -o remount,rw /mnt/foo $ mount --bind -o remount,ro /mnt/foo $ mount /mnt/bar or $ mount /mnt/bar $ mount --rw /mnt/foo $ mount --bind -o remount,ro /mnt/foo With this patch you can do $ mount /mnt/foo $ mount /mnt/bar $ cat /proc/self/mountinfo 49 33 0:41 /foo /mnt/foo ro,relatime shared:36 - btrfs /dev/sda3 rw,ssd,space_cache 87 33 0:41 /bar /mnt/bar rw,relatime shared:74 - btrfs /dev/sda3 rw,ssd,space_cache Signed-off-by: Chris Mason <clm@fb.com>
2014-04-10Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "A small collection of fixes that should go in before -rc1. The pull request contains: - A two patch fix for a regression with block enabled tagging caused by a commit in the initial pull request. One patch is from Martin and ensures that SCSI doesn't truncate 64-bit block flags, the other one is from me and prevents us from double using struct request queuelist for both completion and busy tags. This caused anything from a boot crash for some, to crashes under load. - A blk-mq fix for a potential soft stall when hot unplugging CPUs with busy IO. - percpu_counter fix is listed in here, that caused a suspend issue with virtio-blk due to percpu counters having an inconsistent state during CPU removal. Andrew sent this in separately a few days ago, but it's here. JFYI. - A few fixes for block integrity from Martin. - A ratelimit fix for loop from Mike Galbraith, to avoid spewing too much in error cases" * 'for-linus' of git://git.kernel.dk/linux-block: block: fix regression with block enabled tagging scsi: Make sure cmd_flags are 64-bit block: Ensure we only enable integrity metadata for reads and writes block: Fix integrity verification block: Fix for_each_bvec() drivers/block/loop.c: ratelimit error messages blk-mq: fix potential stall during CPU unplug with IO pending percpu_counter: fix bad counter state during suspend
2014-04-09block: Ensure we only enable integrity metadata for reads and writesMartin K. Petersen
We'd occasionally attempt to generate protection information for flushes and other requests with a zero payload. Make sure we only attempt to enable integrity for reads and writes. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-04-09block: Fix integrity verificationMartin K. Petersen
Commit bf36f9cfa6d3d caused a regression by effectively reverting Nic's fix from 5837c80e870b that ensures we traverse the full bio_vec list upon completion. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Cc: Nicholas Bellinger <nab@linux-iscsi.org> Cc: Gu Zheng <guz.fnst@cn.fujitsu.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-04-08Merge branch 'for-3.15' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: "Highlights: - server-side nfs/rdma fixes from Jeff Layton and Tom Tucker - xdr fixes (a larger xdr rewrite has been posted but I decided it would be better to queue it up for 3.16). - miscellaneous fixes and cleanup from all over (thanks especially to Kinglong Mee)" * 'for-3.15' of git://linux-nfs.org/~bfields/linux: (36 commits) nfsd4: don't create unnecessary mask acl nfsd: revert v2 half of "nfsd: don't return high mode bits" nfsd4: fix memory leak in nfsd4_encode_fattr() nfsd: check passed socket's net matches NFSd superblock's one SUNRPC: Clear xpt_bc_xprt if xs_setup_bc_tcp failed NFSD/SUNRPC: Check rpc_xprt out of xs_setup_bc_tcp SUNRPC: New helper for creating client with rpc_xprt NFSD: Free backchannel xprt in bc_destroy NFSD: Clear wcc data between compound ops nfsd: Don't return NFS4ERR_STALE_STATEID for NFSv4.1+ nfsd4: fix nfs4err_resource in 4.1 case nfsd4: fix setclientid encode size nfsd4: remove redundant check from nfsd4_check_resp_size nfsd4: use more generous NFS4_ACL_MAX nfsd4: minor nfsd4_replay_cache_entry cleanup nfsd4: nfsd4_replay_cache_entry should be static nfsd4: update comments with obsolete function name rpc: Allow xdr_buf_subsegment to operate in-place NFSD: Using free_conn free connection SUNRPC: fix memory leak of peer addresses in XPRT ...
2014-04-08fs/ncpfs/dir.c: fix indenting in ncp_lookup()Dan Carpenter
My static checker suggests adding curly braces here. Probably that was the intent, but actually the code works the same either way. I've just changed the indenting and left the code as-is. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Petr Vandrovec <petr@vandrovec.name> Acked-by: Dave Chiluk <chiluk@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-08ncpfs/inode.c: fix mismatch printk formats and argumentsJoe Perches
Conversions to ncp_dbg showed some format/argument mismatches so fix them. Signed-off-by: Joe Perches <joe@perches.com> Cc: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-08ncpfs: remove now unused PRINTK macroJoe Perches
Uses are gone, remove the macro. Signed-off-by: Joe Perches <joe@perches.com> Cc: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-08ncpfs: convert PPRINTK to ncp_vdbgJoe Perches
Use a more current logging style. Convert the paranoia debug statement to vdbg. Remove the embedded function names as dynamic_debug can do that. Signed-off-by: Joe Perches <joe@perches.com> Cc: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-08ncpfs: convert DPRINTK/DDPRINTK to ncp_dbgJoe Perches
Use a more current logging style and enable use of dynamic debugging. Remove embedded function names, dynamic debug can add this instead. Signed-off-by: Joe Perches <joe@perches.com> Cc: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-08ncpfs: Add pr_fmt and convert printks to pr_<level>Joe Perches
Convert to a more current logging style. Add pr_fmt to prefix with "ncpfs: ". Remove the embedded function names and use "%s: ", __func__ Some previously unprefixed messages now have "ncpfs: " Signed-off-by: Joe Perches <joe@perches.com> Cc: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-08autofs4: check dev ioctl size before allocatingSasha Levin
There wasn't any check of the size passed from userspace before trying to allocate the memory required. This meant that userspace might request more space than allowed, triggering an OOM. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-08Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "Highlights: - drm: Generic display port aux features, primary plane support, drm master management fixes, logging cleanups, enforced locking checks (instead of docs), documentation improvements, minor number handling cleanup, pseudofs for shared inodes. - ttm: add ability to allocate from both ends - i915: broadwell features, power domain and runtime pm, per-process address space infrastructure (not enabled) - msm: power management, hdmi audio support - nouveau: ongoing GPU fault recovery, initial maxwell support, random fixes - exynos: refactored driver to clean up a lot of abstraction, DP support moved into drm, LVDS bridge support added, parallel panel support - gma500: SGX MMU support, SGX irq handling, asle irq work fixes - radeon: video engine bringup, ring handling fixes, use dp aux helpers - vmwgfx: add rendernode support" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (849 commits) DRM: armada: fix corruption while loading cursors drm/dp_helper: don't return EPROTO for defers (v2) drm/bridge: export ptn3460_init function drm/exynos: remove MODULE_DEVICE_TABLE definitions ARM: dts: exynos4412-trats2: enable exynos/fimd node ARM: dts: exynos4210-trats: enable exynos/fimd node ARM: dts: exynos4412-trats2: add panel node ARM: dts: exynos4210-trats: add panel node ARM: dts: exynos4: add MIPI DSI Master node drm/panel: add S6E8AA0 driver ARM: dts: exynos4210-universal_c210: add proper panel node drm/panel: add ld9040 driver panel/ld9040: add DT bindings panel/s6e8aa0: add DT bindings drm/exynos: add DSIM driver exynos/dsim: add DT bindings drm/exynos: disallow fbdev initialization if no device is connected drm/mipi_dsi: create dsi devices only for nodes with reg property drm/mipi_dsi: add flags to DSI messages Skip intel_crt_init for Dell XPS 8700 ...
2014-04-07Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull ext3 improvements, cleanups, reiserfs fix from Jan Kara: "various cleanups for ext2, ext3, udf, isofs, a documentation update for quota, and a fix of a race in reiserfs readdir implementation" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: reiserfs: fix race in readdir ext2: acl: remove unneeded include of linux/capability.h ext3: explicitly remove inode from orphan list after failed direct io fs/isofs/inode.c add __init to init_inodecache() ext3: Speedup WB_SYNC_ALL pass fs/quota/Kconfig: Update filesystems ext3: Update outdated comment before ext3_ordered_writepage() ext3: Update PF_MEMALLOC handling in ext3_write_inode() ext2/3: use prandom_u32() instead of get_random_bytes() ext3: remove an unneeded check in ext3_new_blocks() ext3: remove unneeded check in ext3_ordered_writepage() fs: Mark function as static in ext3/xattr_security.c fs: Mark function as static in ext3/dir.c fs: Mark function as static in ext2/xattr_security.c ext3: Add __init macro to init_inodecache ext2: Add __init macro to init_inodecache udf: Add __init macro to init_inodecache fs: udf: parse_options: blocksize check
2014-04-07Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge second patch-bomb from Andrew Morton: - the rest of MM - zram updates - zswap updates - exit - procfs - exec - wait - crash dump - lib/idr - rapidio - adfs, affs, bfs, ufs - cris - Kconfig things - initramfs - small amount of IPC material - percpu enhancements - early ioremap support - various other misc things * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (156 commits) MAINTAINERS: update Intel C600 SAS driver maintainers fs/ufs: remove unused ufs_super_block_third pointer fs/ufs: remove unused ufs_super_block_second pointer fs/ufs: remove unused ufs_super_block_first pointer fs/ufs/super.c: add __init to init_inodecache() doc/kernel-parameters.txt: add early_ioremap_debug arm64: add early_ioremap support arm64: initialize pgprot info earlier in boot x86: use generic early_ioremap mm: create generic early_ioremap() support x86/mm: sparse warning fix for early_memremap lglock: map to spinlock when !CONFIG_SMP percpu: add preemption checks to __this_cpu ops vmstat: use raw_cpu_ops to avoid false positives on preemption checks slub: use raw_cpu_inc for incrementing statistics net: replace __this_cpu_inc in route.c with raw_cpu_inc modules: use raw_cpu_write for initialization of per cpu refcount. mm: use raw_cpu ops for determining current NUMA node percpu: add raw_cpu_ops slub: fix leak of 'name' in sysfs_slab_add ...
2014-04-07fs/ufs: remove unused ufs_super_block_third pointerChristian Engelmayer
Pointer 'usb3' to struct ufs_super_block_third acquired via ubh_get_usb_third() is never used in function ufs_read_cylinder_structures(). Thus remove it. Detected by Coverity: CID 139939. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07fs/ufs: remove unused ufs_super_block_second pointerChristian Engelmayer
Pointer 'usb2' to struct ufs_super_block_second acquired via ubh_get_usb_second() is never used in function ufs_statfs(). Thus remove it. Detected by Coverity: CID 139940. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07fs/ufs: remove unused ufs_super_block_first pointerChristian Engelmayer
Remove occurences of unused pointers to struct ufs_super_block_first that were acquired via ubh_get_usb_first(). Detected by Coverity: CID 139929 - CID 139936, CID 139940. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07fs/ufs/super.c: add __init to init_inodecache()Fabian Frederick
init_inodecache is only called by __init init_ufs_fs. Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07fault-injection: set bounds on what /proc/self/make-it-fail accepts.Dave Jones
/proc/self/make-it-fail is a boolean, but accepts any number, including negative ones. Change variable to unsigned, and cap upper bound at 1. [akpm@linux-foundation.org: don't make make_it_fail unsigned] Signed-off-by: Dave Jones <davej@fedoraproject.org> Reviewed-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07fs/bfs/inode.c: add __init to init_inodecache()Fabian Frederick
init_inodecache is only called by __init init_bfs_fs Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07affs: add mount option to avoid filename truncatesFabian Frederick
Normal behavior for filenames exceeding specific filesystem limits is to refuse operation. AFFS standard name length being only 30 characters against 255 for usual Linux filesystems, original implementation does filename truncate by default with a define value AFFS_NO_TRUNCATE which can be enabled but needs module compilation. This patch adds 'nofilenametruncate' mount option so that user can easily activate that feature and avoid a lot of problems (eg overwrite files ...) Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07fs/affs/dir.c: unlock/brelse dir on failure + code clean-upFabian Frederick
Commit 0edf977d2ae3 ("[readdir] convert affs") returns directly -EIO without unlocking dir inode and releasing dir bh when second affs_bread sequence fails. This patch restores initial behaviour. It also fixes pr_debug and affs_error to fit in 80 columns + removes reference to filldir (replaced by dir_emit in the commit above). Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07affs: add __init to init_inodecache ()Fabian Frederick
init_inodecache is only called by __init init_affs_fs Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07fs/adfs/super.c: add __init to init_inodecache()Fabian Frederick
init_inodecache is only called by __init init_adfs_fs. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07vmcore: continue vmcore initialization if PT_NOTE is found emptyWANG Chao
Currently when an empty PT_NOTE is detected, vmcore initialization fails. It sounds too harsh. Because PT_NOTE could be empty, for example, one offlined a cpu but never restarted kdump service, and after crash, PT_NOTE program header is there but no data contains. It's better to warn about the empty PT_NOTE and continue to initialise vmcore. And ultimately the multiple PT_NOTE are merged into a single one, all empty PT_NOTE are discarded naturally during the merge. So empty PT_NOTE is not visible to user space and vmcore is as good as expected. Signed-off-by: WANG Chao <chaowang@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Cc: Greg Pearson <greg.pearson@hp.com> Cc: Baoquan He <bhe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07include/linux/crash_dump.h: add vmcore_cleanup() prototypeRashika Kheria
Eliminate the following warning in proc/vmcore.c: fs/proc/vmcore.c:1088:6: warning: no previous prototype for `vmcore_cleanup' [-Wmissing-prototypes] [akpm@linux-foundation.org: clean up powerpc, remove unneeded EXPORT_SYMBOL] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07wait: swap EXIT_ZOMBIE and EXIT_DEAD to hide EXIT_TRACE from user-spaceOleg Nesterov
get_task_state() uses the most significant bit to report the state to user-space, this means that EXIT_ZOMBIE->EXIT_TRACE->EXIT_DEAD transition can be noticed via /proc as Z -> X -> Z change. Note that this was possible even before EXIT_TRACE was introduced. This is not really bad but imho it make sense to hide EXIT_TRACE from user-space completely. So the patch simply swaps EXIT_ZOMBIE and EXIT_DEAD, this way EXIT_TRACE will be seen as EXIT_ZOMBIE by user-space. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Jan Kratochvil <jan.kratochvil@redhat.com> Cc: Michal Schmidt <mschmidt@redhat.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Lennart Poettering <lpoetter@redhat.com> Cc: Roland McGrath <roland@hack.frob.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07exec: kill bprm->tcomm[], simplify the "basename" logicOleg Nesterov
Starting from commit c4ad8f98bef7 ("execve: use 'struct filename *' for executable name passing") bprm->filename can not go away after flush_old_exec(), so we do not need to save the binary name in bprm->tcomm[] added by 96e02d158678 ("exec: fix use-after-free bug in setup_new_exec()"). And there was never need for filename_to_taskname-like code, we can simply do set_task_comm(kbasename(filename). This patch has to change set_task_comm() and trace_task_rename() to accept "const char *", but I think this change is also good. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07procfs: make /proc/*/pagemap 0400Djalal Harouni
The /proc/*/pagemap contain sensitive information and currently its mode is 0444. Change this to 0400, so the VFS will prevent unprivileged processes from getting file descriptors on arbitrary privileged /proc/*/pagemap files. This reduces the scope of address space leaking and bypasses by protecting already running processes. Signed-off-by: Djalal Harouni <tixxdz@opendz.org> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Andy Lutomirski <luto@amacapital.net> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07procfs: make /proc/*/{stack,syscall,personality} 0400Djalal Harouni
These procfs files contain sensitive information and currently their mode is 0444. Change this to 0400, so the VFS will be able to block unprivileged processes from getting file descriptors on arbitrary privileged /proc/*/{stack,syscall,personality} files. This reduces the scope of ASLR leaking and bypasses by protecting already running processes. Signed-off-by: Djalal Harouni <tixxdz@opendz.org> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Andy Lutomirski <luto@amacapital.net> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07fs/proc/inode.c: use RCU_INIT_POINTER(x, NULL)Monam Agarwal
Replace rcu_assign_pointer(x, NULL) with RCU_INIT_POINTER(x, NULL) The rcu_assign_pointer() ensures that the initialization of a structure is carried out before storing a pointer to that structure. And in the case of the NULL pointer, there is no structure to initialize. So, rcu_assign_pointer(p, NULL) can be safely converted to RCU_INIT_POINTER(p, NULL) Signed-off-by: Monam Agarwal <monamagarwal123@gmail.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07proc: show mnt_id in /proc/pid/fdinfoAndrey Vagin
Currently we don't have a way how to determing from which mount point file has been opened. This information is required for proper dumping and restoring file descriptos due to presence of mount namespaces. It's possible, that two file descriptors are opened using the same paths, but one fd references mount point from one namespace while the other fd -- from other namespace. $ ls -l /proc/1/fd/1 lrwx------ 1 root root 64 Mar 19 23:54 /proc/1/fd/1 -> /dev/null $ cat /proc/1/fdinfo/1 pos: 0 flags: 0100002 mnt_id: 16 $ cat /proc/1/mountinfo | grep ^16 16 32 0:4 / /dev rw,nosuid shared:2 - devtmpfs devtmpfs rw,size=1013356k,nr_inodes=253339,mode=755 Signed-off-by: Andrey Vagin <avagin@openvz.org> Acked-by: Pavel Emelyanov <xemul@parallels.com> Acked-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Rob Landley <rob@landley.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07fs/proc/meminfo: meminfo_proc_show(): fix typo in commentLuiz Capitulino
It should read "reclaimable slab" and not "reclaimable swap". Signed-off-by: Luiz Capitulino <lcapitulino@redhat.com> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Rafael Aquini <aquini@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07mm: per-thread vma cachingDavidlohr Bueso
This patch is a continuation of efforts trying to optimize find_vma(), avoiding potentially expensive rbtree walks to locate a vma upon faults. The original approach (https://lkml.org/lkml/2013/11/1/410), where the largest vma was also cached, ended up being too specific and random, thus further comparison with other approaches were needed. There are two things to consider when dealing with this, the cache hit rate and the latency of find_vma(). Improving the hit-rate does not necessarily translate in finding the vma any faster, as the overhead of any fancy caching schemes can be too high to consider. We currently cache the last used vma for the whole address space, which provides a nice optimization, reducing the total cycles in find_vma() by up to 250%, for workloads with good locality. On the other hand, this simple scheme is pretty much useless for workloads with poor locality. Analyzing ebizzy runs shows that, no matter how many threads are running, the mmap_cache hit rate is less than 2%, and in many situations below 1%. The proposed approach is to replace this scheme with a small per-thread cache, maximizing hit rates at a very low maintenance cost. Invalidations are performed by simply bumping up a 32-bit sequence number. The only expensive operation is in the rare case of a seq number overflow, where all caches that share the same address space are flushed. Upon a miss, the proposed replacement policy is based on the page number that contains the virtual address in question. Concretely, the following results are seen on an 80 core, 8 socket x86-64 box: 1) System bootup: Most programs are single threaded, so the per-thread scheme does improve ~50% hit rate by just adding a few more slots to the cache. +----------------+----------+------------------+ | caching scheme | hit-rate | cycles (billion) | +----------------+----------+------------------+ | baseline | 50.61% | 19.90 | | patched | 73.45% | 13.58 | +----------------+----------+------------------+ 2) Kernel build: This one is already pretty good with the current approach as we're dealing with good locality. +----------------+----------+------------------+ | caching scheme | hit-rate | cycles (billion) | +----------------+----------+------------------+ | baseline | 75.28% | 11.03 | | patched | 88.09% | 9.31 | +----------------+----------+------------------+ 3) Oracle 11g Data Mining (4k pages): Similar to the kernel build workload. +----------------+----------+------------------+ | caching scheme | hit-rate | cycles (billion) | +----------------+----------+------------------+ | baseline | 70.66% | 17.14 | | patched | 91.15% | 12.57 | +----------------+----------+------------------+ 4) Ebizzy: There's a fair amount of variation from run to run, but this approach always shows nearly perfect hit rates, while baseline is just about non-existent. The amounts of cycles can fluctuate between anywhere from ~60 to ~116 for the baseline scheme, but this approach reduces it considerably. For instance, with 80 threads: +----------------+----------+------------------+ | caching scheme | hit-rate | cycles (billion) | +----------------+----------+------------------+ | baseline | 1.06% | 91.54 | | patched | 99.97% | 14.18 | +----------------+----------+------------------+ [akpm@linux-foundation.org: fix nommu build, per Davidlohr] [akpm@linux-foundation.org: document vmacache_valid() logic] [akpm@linux-foundation.org: attempt to untangle header files] [akpm@linux-foundation.org: add vmacache_find() BUG_ON] [hughd@google.com: add vmacache_valid_mm() (from Oleg)] [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: adjust and enhance comments] Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Reviewed-by: Michel Lespinasse <walken@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Tested-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07mm: implement ->map_pages for page cacheKirill A. Shutemov
filemap_map_pages() is generic implementation of ->map_pages() for filesystems who uses page cache. It should be safe to use filemap_map_pages() for ->map_pages() if filesystem use filemap_fault() for ->fault(). Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Dave Chinner <david@fromorbit.com> Cc: Ning Qu <quning@gmail.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07exec: kill the unnecessary mm->def_flags setting in load_elf_binary()Alex Thorlton
load_elf_binary() sets current->mm->def_flags = def_flags and def_flags is always zero. Not only this looks strange, this is unnecessary because mm_init() has already set ->def_flags = 0. Signed-off-by: Alex Thorlton <athorlton@sgi.com> Suggested-by: Oleg Nesterov <oleg@redhat.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: David Rientjes <rientjes@google.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07ntfs: logging clean-upFabian Frederick
- Convert spinlock/static array to va_format (inspired by Joe Perches help on previous logging patches). - Convert printk(KERN_ERR to pr_warn in __ntfs_warning. - Convert printk(KERN_ERR to pr_err in __ntfs_error. - Convert printk(KERN_DEBUG to pr_debug in __ntfs_debug. (Note that __ntfs_debug is still guarded by #if DEBUG) - Improve !DEBUG to parse all arguments (Joe Perches). - Sparse pr_foo() conversions in super.c NTFS, NTFS-fs prefixes as well as 'warning' and 'error' were removed : pr_foo() automatically adds module name and error level is already specified. Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Anton Altaparmakov <anton@tuxera.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull Ceph updates from Sage Weil: "The biggest chunk is a series of patches from Ilya that add support for new Ceph osd and crush map features, including some new tunables, primary affinity, and the new encoding that is needed for erasure coding support. This brings things into parity with the server side and the looming firefly release. There is also support for allocation hints in RBD that help limit fragmentation on the server side. There is also a series of patches from Zheng fixing NFS reexport, directory fragmentation support, flock vs fnctl behavior, and some issues with clustered MDS. Finally, there are some miscellaneous fixes from Yunchuan Wen for fscache, Fabian Frederick for ACLs, and from me for fsync(dirfd) behavior" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (79 commits) ceph: skip invalid dentry during dcache readdir libceph: dump pool {read,write}_tier to debugfs libceph: output primary affinity values on osdmap updates ceph: flush cap release queue when trimming session caps ceph: don't grabs open file reference for aborted request ceph: drop extra open file reference in ceph_atomic_open() ceph: preallocate buffer for readdir reply libceph: enable PRIMARY_AFFINITY feature bit libceph: redo ceph_calc_pg_primary() in terms of ceph_calc_pg_acting() libceph: add support for osd primary affinity libceph: add support for primary_temp mappings libceph: return primary from ceph_calc_pg_acting() libceph: switch ceph_calc_pg_acting() to new helpers libceph: introduce apply_temps() helper libceph: introduce pg_to_raw_osds() and raw_to_up_osds() helpers libceph: ceph_can_shift_osds(pool) and pool type defines libceph: ceph_osd_{exists,is_up,is_down}(osd) definitions libceph: enable OSDMAP_ENC feature bit libceph: primary_affinity decode bits libceph: primary_affinity infrastructure ...
2014-04-07Merge tag 'for-f2fs-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull f2fs updates from Jaegeuk Kim: "This patch-set includes the following major enhancement patches. - introduce large directory support - introduce f2fs_issue_flush to merge redundant flush commands - merge write IOs as much as possible aligned to the segment - add sysfs entries to tune the f2fs configuration - use radix_tree for the free_nid_list to reduce in-memory operations - remove costly bit operations in f2fs_find_entry - enhance the readahead flow for CP/NAT/SIT/SSA blocks The other bug fixes are as follows: - recover xattr node blocks correctly after sudden-power-cut - fix to calculate the maximum number of node ids - enhance to handle many error cases And, there are a bunch of cleanups" * tag 'for-f2fs-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (62 commits) f2fs: fix wrong statistics of inline data f2fs: check the acl's validity before setting f2fs: introduce f2fs_issue_flush to avoid redundant flush issue f2fs: fix to cover io->bio with io_rwsem f2fs: fix error path when fail to read inline data f2fs: use list_for_each_entry{_safe} for simplyfying code f2fs: avoid free slab cache under spinlock f2fs: avoid unneeded lookup when xattr name length is too long f2fs: avoid unnecessary bio submit when wait page writeback f2fs: return -EIO when node id is not matched f2fs: avoid RECLAIM_FS-ON-W warning f2fs: skip unnecessary node writes during fsync f2fs: introduce fi->i_sem to protect fi's info f2fs: change reclaim rate in percentage f2fs: add missing documentation for dir_level f2fs: remove unnecessary threshold f2fs: throttle the memory footprint with a sysfs entry f2fs: avoid to drop nat entries due to the negative nr_shrink f2fs: call f2fs_wait_on_page_writeback instead of native function f2fs: introduce nr_pages_to_write for segment alignment ...
2014-04-07btrfs: export global block reserve size as space_infoDavid Sterba
Introduce a block group type bit for a global reserve and fill the space info for SPACE_INFO ioctl. This should replace the newly added ioctl (01e219e8069516cdb98594d417b8bb8d906ed30d) to get just the 'size' part of the global reserve, while the actual usage can be now visible in the 'btrfs fi df' output during ENOSPC stress. The unpatched userspace tools will show the blockgroup as 'unknown'. CC: Jeff Mahoney <jeffm@suse.com> CC: Josef Bacik <jbacik@fb.com> Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2014-04-07btrfs: fix crash in remount(thread_pool=) caseSergei Trofimovich
Reproducer: mount /dev/ubda /mnt mount -oremount,thread_pool=42 /mnt Gives a crash: ? btrfs_workqueue_set_max+0x0/0x70 btrfs_resize_thread_pool+0xe3/0xf0 ? sync_filesystem+0x0/0xc0 ? btrfs_resize_thread_pool+0x0/0xf0 btrfs_remount+0x1d2/0x570 ? kern_path+0x0/0x80 do_remount_sb+0xd9/0x1c0 do_mount+0x26a/0xbf0 ? kfree+0x0/0x1b0 SyS_mount+0xc4/0x110 It's a call btrfs_workqueue_set_max(fs_info->scrub_wr_completion_workers, new_pool_size); with fs_info->scrub_wr_completion_workers = NULL; as scrub wqs get created only on user's demand. Patch skips not-created-yet workqueues. Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org> CC: Qu Wenruo <quwenruo@cn.fujitsu.com> CC: Chris Mason <clm@fb.com> CC: Josef Bacik <jbacik@fb.com> CC: linux-btrfs@vger.kernel.org Signed-off-by: Chris Mason <clm@fb.com>
2014-04-07Merge tag 'for-linus-20140405' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD updates from Brian Norris: - A few SPI NOR ID definitions - Kill the NAND "max pagesize" restriction - Fix some x16 bus-width NAND support - Add NAND JEDEC parameter page support - DT bindings for NAND ECC - GPMI NAND updates (subpage reads) - More OMAP NAND refactoring - New STMicro SPI NOR driver (now in 40 patches!) - A few other random bugfixes * tag 'for-linus-20140405' of git://git.infradead.org/linux-mtd: (120 commits) Fix index regression in nand_read_subpage mtd: diskonchip: mem resource name is not optional mtd: nand: fix mention to CONFIG_MTD_NAND_ECC_BCH mtd: nand: fix GET/SET_FEATURES address on 16-bit devices mtd: omap2: Use devm_ioremap_resource() mtd: denali_dt: Use devm_ioremap_resource() mtd: devices: elm: update DRIVER_NAME as "omap-elm" mtd: devices: elm: configure parallel channels based on ecc_steps mtd: devices: elm: clean elm_load_syndrome mtd: devices: elm: check for hardware engine's design constraints mtd: st_spi_fsm: Succinctly reorganise .remove() mtd: st_spi_fsm: Allow loop to run at least once before giving up CPU mtd: st_spi_fsm: Correct vendor name spelling issue - missing "M" mtd: st_spi_fsm: Avoid duplicating MTD core code mtd: st_spi_fsm: Remove useless consts from function arguments mtd: st_spi_fsm: Convert ST SPI FSM (NOR) Flash driver to new DT partitions mtd: st_spi_fsm: Move runtime configurable msg sequences into device's struct mtd: st_spi_fsm: Supply the W25Qxxx chip specific configuration call-back mtd: st_spi_fsm: Supply the S25FLxxx chip specific configuration call-back mtd: st_spi_fsm: Supply the MX25xxx chip specific configuration call-back ...
2014-04-07Btrfs: abort the transaction when we don't find our extent refJosef Bacik
I'm not sure why we weren't aborting here in the first place, it is obviously a bad time from the fact that we print the leaf and yell loudly about it. Fix this up, otherwise we panic because our path could be pointing into oblivion. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-04-07Btrfs: fix EINVAL checks in btrfs_cloneChris Mason
btrfs_drop_extents can now return -EINVAL, but only one caller in btrfs_clone was checking for it. This adds it to the caller for inline extents, which is where we really need it. Signed-off-by: Chris Mason <clm@fb.com>
