path: root/fs
2011-03-22block: fix non-atomic access to genhd inflight structuresShaohua Li
After the stack plugging introduction, these are called lockless. Ensure that the counters are updated atomically. Signed-off-by: Shaohua Li<shaohua.li@intel.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-19block: NULL dereference on error path in __blkdev_get()Dan Carpenter
"disk" is always NULL when we goto out. There was a check for this before, but it was removed in 69e02c59a7d9 "block: Don't check events while open is in progress". Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@carl>
2011-03-17fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going awayJens Axboe
We don't have proper reference counting for this yet, so we run into cases where the device is pulled and we OOPS on flushing the fs data. This happens even though the dirty inodes have already been migrated to the default_backing_dev_info. Reported-by: Torsten Hilbrich <torsten.hilbrich@secunet.com> Tested-by: Torsten Hilbrich <torsten.hilbrich@secunet.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-17block: Require subsystems to explicitly allocate bio_set integrity mempoolMartin K. Petersen
MD and DM create a new bio_set for every metadevice. Each bio_set has an integrity mempool attached regardless of whether the metadevice is capable of passing integrity metadata. This is a waste of memory. Instead we defer the allocation decision to MD and DM since we know at metadevice creation time whether integrity passthrough is needed or not. Automatic integrity mempool allocation can then be removed from bioset_create() and we make an explicit integrity allocation for the fs_bio_set. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reported-by: Zdenek Kabelac <zkabelac@redhat.com> Acked-by: Mike Snitzer <snizer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-17jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit pluggingJens Axboe
'write_op' was still used, even though it was always WRITE_SYNC now. Add plugging around the cases where it submits IO, and flush them before we end up waiting for that IO. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-17jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit pluggingJens Axboe
2011-03-17fs: make fsync_buffers_list() plugJens Axboe
It used WRITE_SYNC_PLUG before and potentially submits a batch of IO, so lets enable plugging for this case. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10Merge branch 'for-2.6.39/stack-plug' into for-2.6.39/coreJens Axboe
Conflicts: block/blk-core.c block/blk-flush.c drivers/md/raid1.c drivers/md/raid10.c drivers/md/raid5.c fs/nilfs2/btnode.c fs/nilfs2/mdt.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: kill off REQ_UNPLUGJens Axboe
With the plugging now being explicitly controlled by the submitter, callers need not pass down unplugging hints to the block layer. If they want to unplug, it's because they manually plugged on their own - in which case, they should just unplug at will. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10aio: remove request submission batchingJens Axboe
This should be useless now that we have on-stack plugging. So lets just kill it. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10fs: make aio plugShaohua Li
Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10fs: make mpage read/write_pages() plugJens Axboe
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-09block: Don't check events while open is in progressTejun Heo
Not all block drivers clear events immediately after reporting. Some do so in ->revalidate_disk() or other steps during ->open(). There is a slim chance event poll may happen between the clearing event check from check_disk_change() and the actual clearing of the events which would result in spurious events. Block event checks while block device open is in progress. There is no need to kick explicit event check afterwards as events are always checked during open. -v2: The original patch could have called disk_unblock_events() with an already released or %NULL @disk causing oops. Fixed by making sure references are put after disk_unblock_events() is called. It also makes the error path of __blkdev_get() a bit simpler. This problem was reported by Jens. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kay Sievers <kay.sievers@vrfy.org>
2011-03-09block: Don't check events on close unless it was blockedTejun Heo
The block event mechanism currently always checks events when the device is being closed regardless of the open mode. The intention was to allow detection of EJECT_REQUEST when a device is closed whether disk event polling is enabled or not. This is unnecessary as, for devices of interest, events are checked from either userland or kernel and in the former case ->check_events() is performed on open of each poll attempt anyway. Furthermore, this unconditional event check on close makes the code susceptible to event loop if the block driver doesn't clear reported events correctly - an event triggers userland to open and close the device which in turn causes another event, rinse and repeat. Check events on close only if it was blocked by excl write open. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kay Sievers <kay.sievers@vrfy.org>
2011-03-09block: Don't implicitly trigger event check on disk_unblock_events()Tejun Heo
Currently, disk_unblock_events() implicitly kick event check if the block count reaches zero. This behavior is not described in the comment and hinders with future changes. Make the unblocker explicitly check events by calling disk_check_events() as necessary. This patch doesn't cause any behavior difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kay Sievers <kay.sievers@vrfy.org>
2011-03-08block: biovec_slab vs. CONFIG_BLK_DEV_INTEGRITYMartin K. Petersen
The block integrity subsystem no longer uses the bio_vec slabs so this code can safely be compiled in. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-02-28fs/block_dev.c: fix new kernel-doc warningRandy Dunlap
Fix new kernel-doc warning in fs/block_dev.c: Warning(fs/block_dev.c:937): No description found for parameter 'kill_dirty' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: fix truncate after open fuse: fix hang of single threaded fuseblk filesystem
2011-02-28Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: ocfs2: Check heartbeat mode for kernel stacks only Ocfs2/refcounttree: Fix a bug for refcounttree to writeback clusters in a right number. ocfs2: Fix estimate of necessary credits for mkdir
2011-02-25aio: fix race between io_destroy() and io_submit()Jan Kara
A race can occur when io_submit() races with io_destroy(): CPU1 CPU2 io_submit() do_io_submit() ... ctx = lookup_ioctx(ctx_id); io_destroy() Now do_io_submit() holds the last reference to ctx. ... queue new AIO put_ioctx(ctx) - frees ctx with active AIOs We solve this issue by checking whether ctx is being destroyed in AIO submission path after adding new AIO to ctx. Then we are guaranteed that either io_destroy() waits for new AIO or we see that ctx is being destroyed and bail out. Cc: Nick Piggin <npiggin@kernel.dk> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25aio: fix rcu ioctx lookupNick Piggin
aio-dio-invalidate-failure GPFs in aio_put_req from io_submit. lookup_ioctx doesn't implement the rcu lookup pattern properly. rcu_read_lock does not prevent refcount going to zero, so we might take a refcount on a zero count ioctx. Fix the bug by atomically testing for zero refcount before incrementing. [jack@suse.cz: added comment into the code] Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Nick Piggin <npiggin@kernel.dk> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25ldm: corrupted partition table can cause kernel oopsTimo Warns
The kernel automatically evaluates partition tables of storage devices. The code for evaluating LDM partitions (in fs/partitions/ldm.c) contains a bug that causes a kernel oops on certain corrupted LDM partitions. A kernel subsystem seems to crash, because, after the oops, the kernel no longer recognizes newly connected storage devices. The patch changes ldm_parse_vmdb() to Validate the value of vblk_size. Signed-off-by: Timo Warns <warns@pre-sense.de> Cc: Eugene Teo <eugeneteo@kernel.sg> Acked-by: Richard Russon <ldm@flatcap.org> Cc: Harvey Harrison <harvey.harrison@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25epoll: prevent creating circular epoll structuresDavide Libenzi
In several places, an epoll fd can call another file's ->f_op->poll() method with ep->mtx held. This is in general unsafe, because that other file could itself be an epoll fd that contains the original epoll fd. The code defends against this possibility in its own ->poll() method using ep_call_nested, but there are several other unsafe calls to ->poll elsewhere that can be made to deadlock. For example, the following simple program causes the call in ep_insert recursively call the original fd's ->poll, leading to deadlock: #include <unistd.h> #include <sys/epoll.h> int main(void) { int e1, e2, p[2]; struct epoll_event evt = { .events = EPOLLIN }; e1 = epoll_create(1); e2 = epoll_create(2); pipe(p); epoll_ctl(e2, EPOLL_CTL_ADD, e1, &evt); epoll_ctl(e1, EPOLL_CTL_ADD, p[0], &evt); write(p[1], p, sizeof p); epoll_ctl(e1, EPOLL_CTL_ADD, e2, &evt); return 0; } On insertion, check whether the inserted file is itself a struct epoll, and if so, do a recursive walk to detect whether inserting this file would create a loop of epoll structures, which could lead to deadlock. [nelhage@ksplice.com: Use epmutex to serialize concurrent inserts] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Nelson Elhage <nelhage@ksplice.com> Reported-by: Nelson Elhage <nelhage@ksplice.com> Tested-by: Nelson Elhage <nelhage@ksplice.com> Cc: <stable@kernel.org> [2.6.34+, possibly earlier] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: fix fiemap bugs with delalloc Btrfs: set FMODE_EXCL in btrfs_device->mode Btrfs: make btrfs_rm_device() fail gracefully Btrfs: Avoid accessing unmapped kernel address Btrfs: Fix BTRFS_IOC_SUBVOL_SETFLAGS ioctl Btrfs: allow balance to explicitly allocate chunks as it relocates Btrfs: put ENOSPC debugging under a mount option
2011-02-25Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: Fix - again - partition detection when array becomes active Fix over-zealous flush_disk when changing device size. md: avoid spinlock problem in blk_throtl_exit md: correctly handle probe of an 'mdp' device. md: don't set_capacity before array is active. md: Fix raid1->raid0 takeover
2011-02-25afs: Fix oops in afs_unlink_writebackAnton Blanchard
I'm seeing the following oops when testing afs: Unable to handle kernel paging request for data at address 0x00000008 ... NIP [c0000000003393b0] .afs_unlink_writeback+0x38/0xc0 LR [c00000000033987c] .afs_put_writeback+0x98/0xec Call Trace: [c00000000345f600] [c00000000033987c] .afs_put_writeback+0x98/0xec [c00000000345f690] [c00000000033ae80] .afs_write_begin+0x6a4/0x75c [c00000000345f790] [c00000000012b77c] .generic_file_buffered_write+0x148/0x320 [c00000000345f8d0] [c00000000012e1b8] .__generic_file_aio_write+0x37c/0x3e4 [c00000000345f9d0] [c00000000012e2a8] .generic_file_aio_write+0x88/0xfc [c00000000345fa90] [c0000000003390a8] .afs_file_write+0x10c/0x178 [c00000000345fb40] [c000000000188788] .do_sync_write+0xc4/0x128 [c00000000345fcc0] [c000000000189658] .vfs_write+0xe8/0x1d8 [c00000000345fd70] [c000000000189884] .SyS_write+0x68/0xb0 [c00000000345fe30] [c000000000008564] syscall_exit+0x0/0x40 afs_write_begin hits an error and calls afs_unlink_writeback. In there we do list_del_init on an uninitialised list. The patch below initialises ->link when creating the afs_writeback struct. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25fuse: fix truncate after openMiklos Szeredi
Commit e1181ee6 "vfs: pass struct file to do_truncate on O_TRUNC opens" broke the behavior of open(O_TRUNC|O_RDONLY) in fuse. Fuse assumed that when called from open, a truncate() will be done, not an ftruncate(). Fix by restoring the old behavior, based on the ATTR_OPEN flag. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-02-25fuse: fix hang of single threaded fuseblk filesystemMiklos Szeredi
Single threaded NTFS-3G could get stuck if a delayed RELEASE reply triggered a DESTROY request via path_put(). Fix this by a) making RELEASE requests synchronous, whenever possible, on fuseblk filesystems b) if not possible (triggered by an asynchronous read/write) then do the path_put() in a separate thread with schedule_work(). Reported-by: Oliver Neukum <oneukum@suse.de> Cc: stable@kernel.org Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-02-24block: bd_link_disk_holder() should hold on to holder_dirTejun Heo
The new implementation of bd_link_disk_holder() added by 49731baa41d (block: restore multiple bd_link_disk_holder() support) didn't get an extra reference for the holder_dir kobject of the slave bdev; however, bdev kills holder_dir on removal, not release, so if the slave bdev is removed while there are holder links, the holder_dir will be destroyed while there still are holder links, which leads to oops later when bd_unlink_disk_order() tries to remove those links. Make bd_link_disk_holder() grab an extra reference for the slave's holder_dir and put it in bd_unlink_disk_holder(). Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: "Hawrylewicz Czarnowski, Przemyslaw" <przemyslaw.hawrylewicz.czarnowski@intel.com> Tested-by: "Hawrylewicz Czarnowski, Przemyslaw" <przemyslaw.hawrylewicz.czarnowski@intel.com> Cc: Neil Brown <neilb@suse.de> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-24Unlock vfsmount_lock in do_umountJ. R. Okajima
By the commit b3e19d9 2011-01-07 fs: scale mntget/mntput vfsmount_lock was introduced around testing mnt_count. Fix the mis-typed 'unlock' Signed-off-by: J. R. Okajima <hooanon05@yahoo.co.jp> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-02-24Fix over-zealous flush_disk when changing device size.NeilBrown
There are two cases when we call flush_disk. In one, the device has disappeared (check_disk_change) so any data will hold becomes irrelevant. In the oter, the device has changed size (check_disk_size_change) so data we hold may be irrelevant. In both cases it makes sense to discard any 'clean' buffers, so they will be read back from the device if needed. In the former case it makes sense to discard 'dirty' buffers as there will never be anywhere safe to write the data. In the second case it *does*not* make sense to discard dirty buffers as that will lead to file system corruption when you simply enlarge the containing devices. flush_disk calls __invalidate_devices. __invalidate_device calls both invalidate_inodes and invalidate_bdev. invalidate_inodes *does* discard I_DIRTY inodes and this does lead to fs corruption. invalidate_bev *does*not* discard dirty pages, but I don't really care about that at present. So this patch adds a flag to __invalidate_device (calling it __invalidate_device2) to indicate whether dirty buffers should be killed, and this is passed to invalidate_inodes which can choose to skip dirty inodes. flusk_disk then passes true from check_disk_change and false from check_disk_size_change. dm avoids tripping over this problem by calling i_size_write directly rathher than using check_disk_size_change. md does use check_disk_size_change and so is affected. This regression was introduced by commit 608aeef17a which causes check_disk_size_change to call flush_disk, so it is suitable for any kernel since 2.6.27. Cc: stable@kernel.org Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Andrew Patterson <andrew.patterson@hp.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: NeilBrown <neilb@suse.de>
2011-02-23mm: prevent concurrent unmap_mapping_range() on the same inodeMiklos Szeredi
Michael Leun reported that running parallel opens on a fuse filesystem can trigger a "kernel BUG at mm/truncate.c:475" Gurudas Pai reported the same bug on NFS. The reason is, unmap_mapping_range() is not prepared for more than one concurrent invocation per inode. For example: thread1: going through a big range, stops in the middle of a vma and stores the restart address in vm_truncate_count. thread2: comes in with a small (e.g. single page) unmap request on the same vma, somewhere before restart_address, finds that the vma was already unmapped up to the restart address and happily returns without doing anything. Another scenario would be two big unmap requests, both having to restart the unmapping and each one setting vm_truncate_count to its own value. This could go on forever without any of them being able to finish. Truncate and hole punching already serialize with i_mutex. Other callers of unmap_mapping_range() do not, and it's difficult to get i_mutex protection for all callers. In particular ->d_revalidate(), which calls invalidate_inode_pages2_range() in fuse, may be called with or without i_mutex. This patch adds a new mutex to 'struct address_space' to prevent running multiple concurrent unmap_mapping_range() on the same mapping. [ We'll hopefully get rid of all this with the upcoming mm preemptibility series by Peter Zijlstra, the "mm: Remove i_mmap_mutex lockbreak" patch in particular. But that is for 2.6.39 ] Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Reported-by: Michael Leun <lkml20101129@newton.leun.net> Reported-by: Gurudas Pai <gurudas.pai@oracle.com> Tested-by: Gurudas Pai <gurudas.pai@oracle.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-23Btrfs: fix fiemap bugs with delallocChris Mason
The Btrfs fiemap code wasn't properly returning delalloc extents, so applications that trust fiemap to decide if there are holes in the file see holes instead of delalloc. This reworks the btrfs fiemap code, adding a get_extent helper that searches for delalloc ranges and also adding a helper for extent_fiemap that skips past holes in the file. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-02-22xfs: check if device support discard in xfs_ioc_trim()Lukas Czerner
Right now we, are relying on the fact that when we attempt to actually do the discard, blkdev_issue_discar() returns -EOPNOTSUPP and the user is informed that the device does not support discard. However, in the case where the we do not hit any suitable free extent to trim in FITRIM code, it will finish without any error. This is very confusing, because it seems that FITRIM was successful even though the device does not actually supports discard. Solution: Check for the discard support before attempt to search for free extents. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-02-22xfs: prevent leaking uninitialized stack memory in FSGEOMETRY_V1Dan Rosenberg
The FSGEOMETRY_V1 ioctl (and its compat equivalent) calls out to xfs_fs_geometry() with a version number of 3. This code path does not fill in the logsunit member of the passed xfs_fsop_geom_t, leading to the leaking of four bytes of uninitialized stack data to potentially unprivileged callers. v2 switches to memset() to avoid future issues if structure members change, on suggestion of Dave Chinner. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Reviewed-by: Eugene Teo <eugeneteo@kernel.org> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6: eCryptfs: Copy up lower inode attrs in getattr ecryptfs: read on a directory should return EISDIR if not supported eCryptfs: Handle NULL nameidata pointers eCryptfs: Revert "dont call lookup_one_len to avoid NULL nameidata"
2011-02-21Docbook: add fs/eventfd.c and fix typos in itRandy Dunlap
Add fs/eventfd.c to filesystems docbook. Make typo corrections in fs/eventfd.c. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: keep reference to parent inode on ceph_dentry ceph: queue cap_snaps once per realm libceph: fix socket write error handling libceph: fix socket read error handling
2011-02-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [CIFS] update cifs version cifs: Fix regression in LANMAN (LM) auth code cifs: fix handling of scopeid in cifs_convert_address
2011-02-21[CIFS] update cifs versionSteve French
Update version to 1.71 so we can more easily spot modules with the last two fixes Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-02-21cifs: Fix regression in LANMAN (LM) auth codeShirish Pargaonkar
LANMAN response length was changed to 16 bytes instead of 24 bytes. Revert it back to 24 bytes. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> CC: stable@kernel.org Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-02-21eCryptfs: Copy up lower inode attrs in getattrTyler Hicks
The lower filesystem may do some type of inode revalidation during a getattr call. eCryptfs should take advantage of that by copying the lower inode attributes to the eCryptfs inode after a call to vfs_getattr() on the lower inode. I originally wrote this fix while working on eCryptfs on nfsv3 support, but discovered it also fixed an eCryptfs on ext4 nanosecond timestamp bug that was reported. https://bugs.launchpad.net/bugs/613873 Cc: <stable@kernel.org> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-02-21ecryptfs: read on a directory should return EISDIR if not supportedAndy Whitcroft
read() calls against a file descriptor connected to a directory are incorrectly returning EINVAL rather than EISDIR: [EISDIR] [XSI] [Option Start] The fildes argument refers to a directory and the implementation does not allow the directory to be read using read() or pread(). The readdir() function should be used instead. [Option End] This occurs because we do not have a .read operation defined for ecryptfs directories. Connect this up to generic_read_dir(). BugLink: http://bugs.launchpad.net/bugs/719691 Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-02-21eCryptfs: Handle NULL nameidata pointersTyler Hicks
Allow for NULL nameidata pointers in eCryptfs create, lookup, and d_revalidate functions. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-02-20ocfs2: Check heartbeat mode for kernel stacks onlyMark Fasheh
Commit 2c442719e90a44a6982c033d69df4aae4b167cfa added some checks for proper heartbeat mode when the o2cb stack is running. Unfortunately, it didn't take into account that a userpsace stack could be running. Fix this by only doing the check if o2cb is in use. This patch allows userspace stacks to mount the fs again. Cc: stable@kernel.org Signed-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-02-20Ocfs2/refcounttree: Fix a bug for refcounttree to writeback clusters in a ↵Tristan Ye
right number. Current refcounttree codes actually didn't writeback the new pages out in write-back mode, due to a bug of always passing a ZERO number of clusters to 'ocfs2_cow_sync_writeback', the patch tries to pass a proper one in. Signed-off-by: Tristan Ye <tristan.ye@oracle.com> Cc: stable@kernel.org Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-02-20ocfs2: Fix estimate of necessary credits for mkdirJan Kara
In the rare case that INLINE_DATA, INDEX_DIR, QUOTA, XATTR features are disabled and both the allocation of the directory inode and the allocation of the first directory block need to relink allocation group, there need not be enough credits reserved in a transaction. Fix the estimate. CC: Mark Fasheh <mfasheh@suse.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-02-19ceph: keep reference to parent inode on ceph_dentryYehuda Sadeh
When creating a new dentry we now hold a reference to the parent inode in the ceph_dentry. This is required due to the new RCU changes from 949854d0, which set dentry->d_parent to NULL in d_kill before calling the ->release() callback. If/when that behavior is changed, we can revert this hack. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2011-02-18Merge branch 'fixes-2.6.38' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq * 'fixes-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: make sure MAYDAY_INITIAL_TIMEOUT is at least 2 jiffies long workqueue, freezer: unify spelling of 'freeze' + 'able' to 'freezable' workqueue: wake up a worker when a rescuer is leaving a gcwq
