path: root/fs
2011-01-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: nilfs2: fix crash after one superblock became unavailable
2011-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: Make CIFS mount work in a container. CIFS: Remove pointless variable assignment in cifs_dfs_do_automount()
2011-01-24Make CIFS mount work in a container.Rob Landley
Teach cifs about network namespaces, so mounting uses adresses/routing visible from the container rather than from init context. A container is a chroot on steroids that changes more than just the root filesystem the new processes see. One thing containers can isolate is "network namespaces", meaning each container can have its own set of ethernet interfaces, each with its own own IP address and routing to the outside world. And if you open a socket in _userspace_ from processes within such a container, this works fine. But sockets opened from within the kernel still use a single global networking context in a lot of places, meaning the new socket's address and routing are correct for PID 1 on the host, but are _not_ what userspace processes in the container get to use. So when you mount a network filesystem from within in a container, the mount code in the CIFS driver uses the host's networking context and not the container's networking context, so it gets the wrong address, uses the wrong routing, and may even try to go out an interface that the container can't even access... Bad stuff. This patch copies the mount process's network context into the CIFS structure that stores the rest of the server information for that mount point, and changes the socket open code to use the saved network context instead of the global network context. I.E. "when you attempt to use these addresses, do so relative to THIS set of network interfaces and routing rules, not the old global context from back before we supported containers". The big long HOWTO sets up a test environment on the assumption you've never used ocntainers before. It basically says: 1) configure and build a new kernel that has container support 2) build a new root filesystem that includes the userspace container control package (LXC) 3) package/run them under KVM (so you don't have to mess up your host system in order to play with containers). 4) set up some containers under the KVM system 5) set up contradictory routing in the KVM system and the container so that the host and the container see different things for the same address 6) try to mount a CIFS share from both contexts so you can both force it to work and force it to fail. For a long drawn out test reproduction sequence, see: http://landley.livejournal.com/47024.html http://landley.livejournal.com/47205.html http://landley.livejournal.com/47476.html Signed-off-by: Rob Landley <rlandley@parallels.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-24CIFS: Remove pointless variable assignment in cifs_dfs_do_automount()Jesper Juhl
In fs/cifs/cifs_dfs_ref.c::cifs_dfs_do_automount() we have this code: ... mnt = ERR_PTR(-EINVAL); if (IS_ERR(tlink)) { mnt = ERR_CAST(tlink); goto free_full_path; } ses = tlink_tcon(tlink)->ses; rc = get_dfs_path(xid, ses, full_path + 1, cifs_sb->local_nls, &num_referrals, &referrals, cifs_sb->mnt_cifs_flags & CIFS_MOUNT_MAP_SPECIAL_CHR); cifs_put_tlink(tlink); mnt = ERR_PTR(-ENOENT); ... The assignment of 'mnt = ERR_PTR(-EINVAL);' is completely pointless. If we take the 'if (IS_ERR(tlink))' branch we'll set 'mnt' again and we'll also do so if we do not take the branch. There is no way we'll ever use 'mnt' with the assigned 'ERR_PTR(-EINVAL)' value, so we may as well just remove the pointless assignment. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-22fs: fix new dcache.c kernel-doc warningsRandy Dunlap
Fix new fs/dcache.c kernel-doc warnings: Warning(fs/dcache.c:184): No description found for parameter 'dentry' Warning(fs/dcache.c:296): No description found for parameter 'parent' Warning(fs/dcache.c:1985): No description found for parameter 'dparent' Warning(fs/dcache.c:1985): Excess function parameter 'parent' description in 'd_validate' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Nick Piggin <npiggin@kernel.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-22nilfs2: fix crash after one superblock became unavailableRyusuke Konishi
Fixes the following kernel oops in nilfs_setup_super() which could arise if one of two super-blocks is unavailable. > BUG: unable to handle kernel NULL pointer dereference at (null) > Pid: 3529, comm: mount.nilfs2 Not tainted 2.6.37 #1 / > EIP: 0060:[<c03196bc>] EFLAGS: 00010202 CPU: 3 > EIP is at memcpy+0xc/0x1b > Call Trace: > [<f953720e>] ? nilfs_setup_super+0x6c/0xa5 [nilfs2] > [<f95369e9>] ? nilfs_get_root_dentry+0x81/0xcb [nilfs2] > [<f9537a08>] ? nilfs_mount+0x4f9/0x62c [nilfs2] > [<c02745cf>] ? kstrdup+0x36/0x3f > [<f953750f>] ? nilfs_mount+0x0/0x62c [nilfs2] > [<c0293940>] ? vfs_kern_mount+0x4d/0x12c > [<c02a5100>] ? get_fs_type+0x76/0x8f > [<c0293a68>] ? do_kern_mount+0x33/0xbf > [<c02a784a>] ? do_mount+0x2ed/0x714 > [<c02a6171>] ? copy_mount_options+0x28/0xfc > [<c02a7ce3>] ? sys_mount+0x72/0xaf > [<c0473085>] ? syscall_call+0x7/0xb Reported-by: Wakko Warner <wakko@animx.eu.org> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Wakko Warner <wakko@animx.eu.org> Cc: stable <stable@kernel.org> [2.6.37, 2.6.36] LKML-Reference: <20110121024918.GA29598@animx.eu.org>
2011-01-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: fix up CIFSSMBEcho for unaligned access cifs: fix unaligned accesses in cifsConvertToUCS cifs: clean up unaligned accesses in cifs_unicode.c cifs: fix unaligned access in check2ndT2 and coalesce_t2 cifs: clean up unaligned accesses in validate_t2 cifs: use get/put_unaligned functions to access ByteCount cifs: move time field in cifsInodeInfo cifs: TCP_Server_Info diet CIFS: Implement cifs_strict_readv (try #4) CIFS: Implement cifs_file_strict_mmap (try #2) CIFS: Implement cifs_strict_fsync CIFS: Make cifsFileInfo_put work with strict cache mode
2011-01-21Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: quota: Fix deadlock during path resolution
2011-01-21cifs: fix up CIFSSMBEcho for unaligned accessJeff Layton
Make sure that CIFSSMBEcho can handle unaligned fields. Also fix a minor bug that causes this warning: fs/cifs/cifssmb.c: In function 'CIFSSMBEcho': fs/cifs/cifssmb.c:740: warning: large integer implicitly truncated to unsigned type ...WordCount is u8, not __le16, so no need to convert it. This patch should apply cleanly on top of the rest of the patchset to clean up unaligned access. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-21Merge branch 'for-next'Steve French
2011-01-20Merge branch 'akpm'Linus Torvalds
* akpm: kernel/smp.c: consolidate writes in smp_call_function_interrupt() kernel/smp.c: fix smp_call_function_many() SMP race memcg: correctly order reading PCG_USED and pc->mem_cgroup backlight: fix 88pm860x_bl macro collision drivers/leds/ledtrig-gpio.c: make output match input, tighten input checking MAINTAINERS: update Atmel AT91 entry mm: fix truncate_setsize() comment memcg: fix rmdir, force_empty with THP memcg: fix LRU accounting with THP memcg: fix USED bit handling at uncharge in THP memcg: modify accounting function for supporting THP better fs/direct-io.c: don't try to allocate more than BIO_MAX_PAGES in a bio mm: compaction: prevent division-by-zero during user-requested compaction mm/vmscan.c: remove duplicate include of compaction.h memblock: fix memblock_is_region_memory() thp: keep highpte mapped until it is no longer needed kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERT
2011-01-20fs/direct-io.c: don't try to allocate more than BIO_MAX_PAGES in a bioDavid Dillow
When using devices that support max_segments > BIO_MAX_PAGES (256), direct IO tries to allocate a bio with more pages than allowed, which leads to an oops in dio_bio_alloc(). Clamp the request to the supported maximum, and change dio_bio_alloc() to reflect that bio_alloc() will always return a bio when called with __GFP_WAIT and a valid number of vectors. [akpm@linux-foundation.org: remove redundant BUG_ON()] Signed-off-by: David Dillow <dillowda@ornl.gov> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-20Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: mangle existing header for SMB_COM_NT_CANCEL cifs: remove code for setting timeouts on requests [CIFS] cifs: reconnect unresponsive servers cifs: set up recurring workqueue job to do SMB echo requests cifs: add ability to send an echo request cifs: add cifs_call_async cifs: allow for different handling of received response cifs: clean up sync_mid_result cifs: don't reconnect server when we don't get a response cifs: wait indefinitely for responses cifs: Use mask of ACEs for SID Everyone to calculate all three permissions user, group, and other cifs: Fix regression during share-level security mounts (Repost) [CIFS] Update cifs version number cifs: move mid result processing into common function cifs: move locked sections out of DeleteMidQEntry and AllocMidQEntry cifs: clean up accesses to midCount cifs: make wait_for_free_request take a TCP_Server_Info pointer cifs: no need to mark smb_ses_list as cifs_demultiplex_thread is exiting cifs: don't fail writepages on -EAGAIN errors CIFS: Fix oplock break handling (try #2)
2011-01-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixes: GFS2: Fix error path in gfs2_lookup_by_inum() GFS2: remove iopen glocks from cache on failed deletes
2011-01-20Fix broken "pipe: use event aware wakeups" optimizationLinus Torvalds
Commit e462c448fdc8 ("pipe: use event aware wakeups") optimized the pipe event wakeup calls to avoid wakeups if the events do not match the requested set. However, the optimization was buggy, in that it didn't actually use the correct sets for the events: when we make room for more data to be written, the pipe poll() routine will return both the POLLOUT _and_ POLLWRNORM bits. Similarly for read. And most critically, when a pipe is released, that will potentially result in POLLHUP|POLLERR (depending on whether it was the last reader or writer), not just the regular POLLIN|POLLOUT. This bug showed itself as a hung gnome-screensaver-dialog process, stuck forever (or at least until it was poked by a signal or by being traced) in a poll() system call. Cc: Davide Libenzi <davidel@xmailserver.org> Cc: David S. Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-20cifs: fix unaligned accesses in cifsConvertToUCSJeff Layton
Move cifsConvertToUCS to cifs_unicode.c where all of the other unicode related functions live. Have it store mapped characters in 'temp' and then use put_unaligned_le16 to copy it to the target buffer. Also fix the comments to match kernel coding style. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Pavel Shilovsky <piastryyy@gmail.com> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20cifs: clean up unaligned accesses in cifs_unicode.cJeff Layton
Make sure we use get/put_unaligned routines when accessing wide character strings. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Pavel Shilovsky <piastryyy@gmail.com> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20cifs: fix unaligned access in check2ndT2 and coalesce_t2Jeff Layton
2011-01-20cifs: clean up unaligned accesses in validate_t2Jeff Layton
...and clean up function to reduce indentation. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Pavel Shilovsky <piastryyy@gmail.com> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20cifs: use get/put_unaligned functions to access ByteCountJeff Layton
It's possible that when we access the ByteCount that the alignment will be off. Most CPUs deal with that transparently, but there's usually some performance impact. Some CPUs raise an exception on unaligned accesses. Fix this by accessing the byte count using the get_unaligned and put_unaligned inlined functions. While we're at it, fix the types of some of the variables that end up getting returns from these functions. Acked-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20cifs: move time field in cifsInodeInfoJeff Layton
...and remove length qualifiers from bools. Before: /* size: 1176, cachelines: 19, members: 13 */ /* sum members: 1165, holes: 2, sum holes: 11 */ /* bit holes: 1, sum bit holes: 4 bits */ /* last cacheline: 24 bytes */ After: /* size: 1168, cachelines: 19, members: 13 */ /* last cacheline: 16 bytes */ ...savings of 8 bytes per inode. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20cifs: TCP_Server_Info dietJeff Layton
Remove fields that are completely unused, and rearrange struct according to recommendations by "pahole". Before: /* size: 1112, cachelines: 18, members: 49 */ /* sum members: 1086, holes: 8, sum holes: 26 */ /* bit holes: 1, sum bit holes: 7 bits */ /* last cacheline: 24 bytes */ After: /* size: 1072, cachelines: 17, members: 42 */ /* sum members: 1065, holes: 3, sum holes: 7 */ /* last cacheline: 48 bytes */ ...savings of 40 bytes per struct on x86_64. 21 bytes by field removal, and 19 by reorganizing to eliminate holes. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20CIFS: Implement cifs_strict_readv (try #4)Pavel Shilovsky
Read from the cache if we have at least Level II oplock - otherwise read from the server. Add cifs_user_readv to let the client read into iovec buffers. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20CIFS: Implement cifs_file_strict_mmap (try #2)Pavel Shilovsky
Invalidate inode mapping if we don't have at least Level II oplock. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20CIFS: Implement cifs_strict_fsyncPavel Shilovsky
Invalidate inode mapping if we don't have at least Level II oplock in cifs_strict_fsync. Also remove filemap_write_and_wait call from cifs_fsync because it is previously called from vfs_fsync_range. Add file operations' structures for strict cache mode. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20CIFS: Make cifsFileInfo_put work with strict cache modePavel Shilovsky
On strict cache mode when we close the last file handle of the inode we should set invalid_mapping flag on this inode to prevent data coherency problem when we open it again but it has been modified on the server. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20cifs: mangle existing header for SMB_COM_NT_CANCELJeff Layton
The NT_CANCEL command looks just like the original command, except for a few small differences. The send_nt_cancel function however currently takes a tcon, which we don't have in SendReceive and SendReceive2. Instead of "respinning" the entire header for an NT_CANCEL, just mangle the existing header by replacing just the fields we need. This means we don't need a tcon and allows us to call it from other places. Reviewed-by: Pavel Shilovsky <piastryyy@gmail.com> Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20cifs: remove code for setting timeouts on requestsJeff Layton
Since we don't time out individual requests anymore, remove the code that we used to use for setting timeouts on different requests. Reviewed-by: Pavel Shilovsky <piastryyy@gmail.com> Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20[CIFS] cifs: reconnect unresponsive serversSteve French
If the server isn't responding to echoes, we don't want to leave tasks hung waiting for it to reply. At that point, we'll want to reconnect so that soft mounts can return an error to userspace quickly. If the client hasn't received a reply after a specified number of echo intervals, assume that the transport is down and attempt to reconnect the socket. The number of echo_intervals to wait before attempting to reconnect is tunable via a module parameter. Setting it to 0, means that the client will never attempt to reconnect. The default is 5. Signed-off-by: Jeff Layton <jlayton@redhat.com>
2011-01-20cifs: set up recurring workqueue job to do SMB echo requestsJeff Layton
2011-01-20cifs: add ability to send an echo requestJeff Layton
2011-01-20cifs: add cifs_call_asyncJeff Layton
Add a function that will send a request, and set up the mid for an async reply. Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20cifs: allow for different handling of received responseJeff Layton
In order to incorporate async requests, we need to allow for a more general way to do things on receive, rather than just waking up a process. Turn the task pointer in the mid_q_entry into a callback function and a generic data pointer. When a response comes in, or the socket is reconnected, cifsd can call the callback function in order to wake up the process. The default is to just wake up the current process which should mean no change in behavior for existing code. Also, clean up the locking in cifs_reconnect. There doesn't seem to be any need to hold both the srv_mutex and GlobalMid_Lock when walking the list of mids. Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20cifs: clean up sync_mid_resultJeff Layton
Make it use a switch statement based on the value of the midStatus. If the resp_buf is set, then MID_RESPONSE_RECEIVED is too. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20cifs: don't reconnect server when we don't get a responseJeff Layton
We only want to force a reconnect to the server under very limited and specific circumstances. Now that we have processes waiting indefinitely for responses, we shouldn't reach this point unless a reconnect is already in process. Thus, there's no reason to re-mark the server for reconnect here. Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Reviewed-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20cifs: wait indefinitely for responsesJeff Layton
The client should not be timing out on individual SMB requests. Too much of the state between client and server is tied to the state of the socket. If we time out requests and issue spurious disconnects then that comprimises data integrity. Instead of doing this complicated dance where we try to decide how long to wait for a response for particular requests, have the client instead wait indefinitely for a response. Also, use a TASK_KILLABLE sleep here so that fatal signals will break out of this waiting. Later patches will add support for detecting dead peers and forcing reconnects based on that. Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Reviewed-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-19cifs: Use mask of ACEs for SID Everyone to calculate all three permissions ↵Shirish Pargaonkar
user, group, and other If a DACL has entries for ACEs for SID Everyone and Authenticated Users, factor in mask in respective entries during calculation of permissions for all three, user, group, and other. http://technet.microsoft.com/en-us/library/bb463216.aspx Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-19cifs: Fix regression during share-level security mounts (Repost)Shirish Pargaonkar
NTLM response length was changed to 16 bytes instead of 24 bytes that are sent in Tree Connection Request during share-level security share mounts. Revert it back to 24 bytes. Reported-and-Tested-by: Grzegorz Ozanski <grzegorz.ozanski@intel.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Acked-by: Suresh Jayaraman <sjayaraman@suse.de> Cc: stable@kernel.org Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-19[CIFS] Update cifs version numberSteve French
2011-01-19cifs: move mid result processing into common functionJeff Layton
2011-01-19cifs: move locked sections out of DeleteMidQEntry and AllocMidQEntryJeff Layton
In later patches, we're going to need to have finer-grained control over the addition and removal of these structs from the pending_mid_q and we'll need to be able to call the destructor while holding the spinlock. Move the locked sections out of both routines and into the callers. Fix up current callers of DeleteMidQEntry to call a new routine that dequeues the entry and then destroys it. Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Reviewed-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-19cifs: clean up accesses to midCountJeff Layton
It's an atomic_t and the code accesses the "counter" field in it directly instead of using atomic_read(). It also is sometimes accessed under a spinlock and sometimes not. Move it out of the spinlock since we don't need belt-and-suspenders for something that's just informational. Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Reviewed-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-19cifs: make wait_for_free_request take a TCP_Server_Info pointerJeff Layton
The cifsSesInfo pointer is only used to get at the server. Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Reviewed-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-19cifs: no need to mark smb_ses_list as cifs_demultiplex_thread is exitingJeff Layton
The TCP_Server_Info is refcounted and every SMB session holds a reference to it. Thus, smb_ses_list is always going to be empty when cifsd is coming down. This is dead code. Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Reviewed-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-19cifs: don't fail writepages on -EAGAIN errorsJeff Layton
If CIFSSMBWrite2 returns -EAGAIN, then the error should be considered temporary. CIFS should retry the write instead of setting an error on the mapping and returning. For WB_SYNC_ALL, just retry the write immediately. In the WB_SYNC_NONE case, call redirty_page_for_writeback on all of the pages that didn't get written out and then move on. Also, fix up the handling of a short write with a successful return code. MS-CIFS says that 0 bytes_written means ENOSPC or EFBIG. It doesn't mention what a short, but non-zero write means, so for now treat it as we would an -EAGAIN return. Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Reviewed-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-19CIFS: Fix oplock break handling (try #2)Pavel Shilovsky
When we get oplock break notification we should set the appropriate value of OplockLevel field in oplock break acknowledge according to the oplock level held by the client in this time. As we only can have level II oplock or no oplock in the case of oplock break, we should be aware only about clientCanCacheRead field in cifsInodeInfo structure. Also fix bug connected with wrong interpretation of OplockLevel field during oplock break notification processing. Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-18GFS2: Fix error path in gfs2_lookup_by_inum()Steven Whitehouse
In the (impossible, except if there is fs corruption) error path in gfs2_lookup_by_inum() if the call to gfs2_inode_refresh() fails, it was leaving the function by calling iput() rather than iget_failed(). This would cause future lookups of the same inode to block forever. This patch fixes the problem by moving the call to gfs2_inode_refresh() into gfs2_inode_lookup() where iget_failed() is part of the error path already. Also this cleans up some unreachable code and makes gfs2_set_iop() static. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2011-01-18GFS2: remove iopen glocks from cache on failed deletesBenjamin Marzinski
When a file gets deleted on GFS2, if a node can't get an exclusive lock on the file's iopen glock, it punts on actually freeing up the space, because another node is using the file. When it does this, it needs to drop the iopen glock from its cache so that the other node can get an exclusive lock on it. Now, gfs2_delete_inode() sets GL_NOCACHE before dropping the shared lock on the iopen glock in preparation for grabbing it in the exclusive state. Since the node needs the glock in the exclusive state, dropping the shared lock from the cache doesn't slow down the case where no other nodes are using the file. Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2011-01-18autofs4: clean ->d_release() and autofs4_free_ino() upAl Viro
The latter is called only when both ino and dentry are about to be freed, so cleaning ->d_fsdata and ->dentry is pointless. Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
