xfs_ialloc_log_di is only used to log the full inode core + di_next_unlinked.
That means all the offset magic is not nessecary and we can simply use
xfs_trans_log_buf directly. Also add a comment describing what we should do
here instead.
(First sent on October 7th)
Reviewed-by: Dave Chinner <david@fromorbit.com>
Signed-off-by: Niv Sardi <xaiki@sgi.com>
Move all fields from xlog_iclog_fields_t into xlog_in_core_t instead of having
them in a substructure and the using #defines to make it look like they were
directly in xlog_in_core_t. Also document that xlog_in_core_2_t is grossly
misnamed, and make all references to it typesafe.
(First sent on Semptember 15th)
Add a helper to read the AGF header and perform basic verification.
Based on hunks from a larger patch from Dave Chinner.
(First sent on Juli 23rd)
Add a helper to read the AGI header and perform basic verification.
i_gen is incremented in directory operations when the
directory is changed. It is never read or otherwise used
so it should be removed to help reduce the size of the
struct xfs_inode.
The patch also removes a duplicate logging of the directory
inode core. We only need to do this once per transaction
so kill the one associated with the i_gen increment.
Signed-off-by: Dave Chinner <david@fromorbit.com>
The only thing left is xfs_do_force_shutdown which already has a defintion
in xfs_mount.h.
The only thing left are the forced shutdown flags and freeze macros which
fit into xfs_mount.h much better.
This adds the fiemap inode_operation, which for us converts the
fiemap values & flags into a getbmapx structure which can be sent
to xfs_getbmap. The formatter then copies the bmv array back into
the user's fiemap buffer via the fiemap helpers.
If we wanted to be more clever, we could also return mapping data
for in-inode attributes, but I'm not terribly motivated to do that
just yet.
Signed-off-by: Eric Sandeen <sandeen@sandeen.net>
This adds a new output flag, BMV_OF_LAST to indicate if we've hit
the last extent in the inode. This potentially saves an extra call
from userspace to see when the whole mapping is done.
It also adds BMV_IF_DELALLOC and BMV_OF_DELALLOC to request, and
indicate, delayed-allocation extents. In this case bmv_block
is set to -2 (-1 was already taken for HOLESTARTBLOCK; unfortunately
these are the reverse of the in-kernel constants.)
These new flags facilitate addition of the new fiemap interface.
Rather than adding sh_delalloc, remove sh_unwritten & just test
the flags directly.
Preliminary work to hook up fiemap, this allows us to pass in an
arbitrary formatter to copy extent data back to userspace.
The formatter takes info for 1 extent, a pointer to the user "thing*"
and a pointer to a "filled" variable to indicate whether a userspace
buffer did get filled in (for fiemap, hole "extents" are skipped).
I'm just using the getbmapx struct as a "common denominator" because
as far as I can see, it holds all info that any formatters will care
about.
("*thing" because fiemap doesn't pass the user pointer around, but rather
has a pointer to a fiemap info structure, and helpers associated with it)
gcc is warning about an uninitialised variable in xfs_growfs_rt().
This is a false positive. Fix it by changing the scope of the
transaction pointer to wholly within the internal loop inside
the function.
While there, preemptively change xfs_growfs_rt_alloc() in the
same way as it has exactly the same structure as xfs_growfs_rt()
but gcc is not warning about it. Yet.
XFS gets the sign of the error wrong in several places when
gathering the error from generic linux functions. These functions
return negative error values, while the core XFS code returns
positive error values. Hence when XFS inverts the error to be
returned to the VFS, it can incorrectly invert a negative
error and this error will be ignored by the syscall return.
Fix all the problems related to calling filemap_* functions.
Problem initially identified by Nick Piggin in xfs_fsync().
Some recent gcc warnings don't like passing string variables to
printf-like functions without using at least a "%s" format string.
Change the two occurances of that in xfs to please gcc.
Reviewed-by: Eric Sandeen <sandeen@sandeen.net>
Now that we've stopped using the Linux inode cache when can trivally
support the inode64 mount option on 32bit architectures. As far as the
kernel and most userspace is concerned this works perfectly, but
applications still using really old stat and readdir interfaces will get
an EOVERFLOW error when hitting an inode number not fitting into 32
bits (that problem of course also exists when using these applications
on a 64bit kernel).
Note that because inode64 is simply a mount option we can currently
mount a filesystem having > 32 bit inode numbers and cause a variety of
problems, all this is solved but this patch which enables XFS_BIG_INUMS,
even when inode64 is not used.
(First sent on October 18th)
Currently there's no ->open method set for directories on XFS. That
means we don't perform any check for opening too large directories
without O_LARGEFILE, we don't check for shut down filesystems, and we
don't actually do the readahead for the first block in the directory.
Instead of just setting the directories open routine to xfs_file_open
we merge the shutdown check directly into xfs_file_open and create
a new xfs_dir_open that first calls xfs_file_open and then performs
the readahead for block 0.
(First sent on September 29th)
xfs_log_force_umount may be called very early during log recovery where
If we fail a buffer read in xlog_recover_do_inode_trans we abort the mount.
But at that point log recovery has started delayed writeback of inode
buffers. As part of the aborted mount we try to flush out all delwri
buffers, but at that point we have already freed the superblock, and set
mp->m_sb_bp to NULL, and xfs_log_force_umount which gets called after
the inode buffer writeback trips over it.
Make xfs_log_force_umount a little more careful when accessing mp->m_sb_bp
to avoid this.
When an I/O error occurs during an intermediate commit on a rolling
transaction, xfs_trans_commit() will free the transaction structure
and the related ticket. However, the duplicate transaction that
gets used as the transaction continues still contains a pointer
to the ticket. Hence when the duplicate transaction is cancelled
and freed, we free the ticket a second time.
Add reference counting to the ticket so that we hold an extra
reference to the ticket over the transaction commit. We drop the
extra reference once we have checked that the transaction commit
did not return an error, thus avoiding a double free on commit
error.
Credit to Nick Piggin for tripping over the problem.
SGI-PV: 989741
Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
The radix tree walks in xfs_sync_inodes_ag and xfs_qm_dqrele_all_inodes()
can find inodes that are still undergoing initialisation. Avoid
them by checking for the the XFS_INEW() flag once we have a reference
on the inode. This flag is cleared once the inode is properly initialised.
SGI-PV: 987246
gcc on ARM warns about an using an uninitialised variable
in xfs_qm_dqrele_all_inodes(). This is a real bug, but gcc
on x86_64 is not reporting this warning so it went unnoticed.
Fix the bug by bring the inode radix tree walk code up to
date with xfs_sync_inodes_ag().
SGI-PV: 987246
When there is no memory left in the system, xfs_buf_get_noaddr()
can fail. If this happens at mount time during xlog_alloc_log()
we fail to catch the error and oops.
Catch the error from xfs_buf_get_noaddr(), and allow other memory
allocations to fail and catch those errors too. Report the error
to the console and fail the mount with ENOMEM.
Tested by manually injecting errors into xfs_buf_get_noaddr() and
xlog_alloc_log().
Version 2:
o remove unnecessary casts of the returned pointer from kmem_zalloc()
SGI-PV: 987246
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
If we get a race looking up a reclaimable inode, we can end up with the
winner proceeding to use the inode before it has been completely
re-initialised. This is a Bad Thing.
Fix the race by checking whether we are still initialising the inod eonce
we have a reference to it, and if so wait for the initialisation to
complete before continuing.
While there, fix a leaked reference count in the same code when
encountering an unlinked inode and we are not doing a lookup for a create
operation.
SGI-PV: 987246
SGI-Modid: xfs-linux-melb:xfs-kern:32429a
Signed-off-by: David Chinner <david@fromorbit.com>
On Linux all filesystems are supposed to be operating under Posix'
restricted chown. Restricted chown means it restricts chown to the owner
unless you have CAP_FOWNER.
NOTE: that 2 files outside of fs/xfs have been modified too for this
change.
SGI-PV: 988919
SGI-Modid: xfs-linux-melb:xfs-kern:32413a
Signed-off-by: Tim Shimmin <tes@sgi.com>
Signed-off-by: Christoph Hellwig <hch@infradead.org>
capable_cred has been unused for a while so we can kill it and sys_cred.
That also means the cred argument to xfs_setattr and xfs_change_file_space
can be removed now.
SGI-PV: 988918
SGI-Modid: xfs-linux-melb:xfs-kern:32412a
Under heavy metadata load we are seeing log hangs. The AIL has items in it
ready to be pushed, and they are within the push target window. However,
we are not pushing them when the last pushed LSN is less than the LSN of
the first log item on the AIL. This is a regression introduced by the AIL
push cursor modifications.
SGI-PV: 987246
SGI-Modid: xfs-linux-melb:xfs-kern:32409a
To make sure we free the security data inodes need to be freed using the
proper VFS helper (which we also need to export for this). We mark these
inodes bad so we can skip the flush path for them.
SGI-PV: 987246
SGI-Modid: xfs-linux-melb:xfs-kern:32398a
xfs_bulkstat only wants the dinode, offset and buffer from a given inode
number. Instead of using xfs_itobp on a fake inode which is complicated
and currently leads to leaks of the security data just use xfs_inotobp
which is designed to do exactly the kind of lookup xfs_bulkstat wants. The
only thing that's missing in xfs_inotobp is a flags paramter that let's us
pass down XFS_IMAP_BULKSTAT, but that can easily added.
SGI-PV: 987246
SGI-Modid: xfs-linux-melb:xfs-kern:32397a
If we are syncing data in xfs_sync_inodes_ag(), the VFS inode must still
be referencable as the dirty data state is carried on the VFS inode. hence
if we can't get a reference via igrab(), the inode must be in reclaim
which implies that it has no dirty data attached.
Leave such inodes to the reclaim code to flush the dirty inode state to
disk and so avoid attempting to access the VFS inode when it may not exist
in xfs_sync_inodes_ag().
Version 4:
o don't reference linux inode until after igrab() succeeds
Version 3:
o converted unlock/rele to an xfs_iput() call.
Version 2:
o change igrab logic to be more linear
o remove initial reclaimable inode check now that we are using
igrab() failure to find reclaimable inodes
o assert that igrab failure occurs only on reclaimable inodes
o clean up inode locking - only grab the iolock if we are doing
a SYNC_DELWRI call and we have a dirty inode.
SGI-PV: 987246
SGI-Modid: xfs-linux-melb:xfs-kern:32391a
Signed-off-by: Peter Leckie <pleckie@sgi.com>
When we are inside a radix tree preload region, we cannot sleep. Recently
we moved the inode locking inside the preload region for the inode radix
tree. Fix that, and fix a missed unlock in another error path in the same
code at the same time.
SGI-PV: 987246
SGI-Modid: xfs-linux-melb:xfs-kern:32385a
The dp to ip comment should be for the unconditional xfs_droplink call,
and the "." link obviously only exists for directories, so it should be in
the is_dir conditional.
SGI-PV: 987246
SGI-Modid: xfs-linux-melb:xfs-kern:32374a
Signed-off-by: Donald Douwsma <donaldd@sgi.com>
iosizelog shouldn't be the same as iosize but the logarithm of it. Then
again the current biosize option doesn't make much sense to me as it
doesn't set the preferred I/O size as mentioned in the comment next to it
but rather the allocation size and thus is identical to the allocsize
option (except for the missing logarithm). It's also not documented in
Documentation/filesystems/xfs.txt or the mount manpage.
SGI-PV: 987246
SGI-Modid: xfs-linux-melb:xfs-kern:32373a
Noquota should clear all mount options, and not just user and group quota.
Probably doesn't matter very much in real life.
SGI-PV: 987246
SGI-Modid: xfs-linux-melb:xfs-kern:32372a
No need to parse the mount option into a structure before applying it to
struct xfs_mount.
The content of xfs_start_flags gets merged into xfs_parseargs. Calls
inbetween don't care and can use mount members instead of the args struct.
This patch uncovered that the mount option for shared filesystems wasn't
ever exposed on Linux. The code to handle it is #if 0'ed in this patch
pending a decision on this feature. I'll send a writeup about it to the
list soon.
SGI-PV: 987246
SGI-Modid: xfs-linux-melb:xfs-kern:32371a
When we are about to add a new item to a transaction in recovery, we need
to check that it is valid first. Currently we just assert that header
magic number matches, but in production systems that is not present and we
add a corrupted transaction to the list to be processed. This results in a
kernel oops later when processing the corrupted transaction.
Instead, if we detect a corrupted transaction, abort recovery and leave
the user to clean up the mess that has occurred.
SGI-PV: 988145
SGI-Modid: xfs-linux-melb:xfs-kern:32356a
Change all the remaining AIL API functions that are passed struct
xfs_mount pointers to pass pointers directly to the struct xfs_ail being
used. With this conversion, all external access to the AIL is via the
struct xfs_ail. Hence the operation and referencing of the AIL is almost
entirely independent of the xfs_mount that is using it - it is now much
more tightly tied to the log and the items it is tracking in the log than
it is tied to the xfs_mount.
SGI-PV: 988143
SGI-Modid: xfs-linux-melb:xfs-kern:32353a
Add an xfs_ail pointer to log items so that the log items can reference
the AIL directly during callbacks without needed a struct xfs_mount.
SGI-PV: 988143
SGI-Modid: xfs-linux-melb:xfs-kern:32352a
When we need to go from the log to the AIL, we have to go via the
xfs_mount. Add a xfs_ail pointer to the log so we can go directly to the
AIL associated with the log.
SGI-PV: 988143
SGI-Modid: xfs-linux-melb:xfs-kern:32351a
Bring the ail lock inside the struct xfs_ail. This means the AIL can be
entirely manipulated via the struct xfs_ail rather than needing both the
struct xfs_mount and the struct xfs_ail.
SGI-PV: 988143
SGI-Modid: xfs-linux-melb:xfs-kern:32350a
When copying lsn's from the log item to the inode or dquot flush lsn, we
currently grab the AIL lock. We do this because the LSN is a 64 bit
quantity and it needs to be read atomically. The lock is used to guarantee
atomicity for 32 bit platforms.
Make the LSN copying a small function, and make the function used
conditional on BITS_PER_LONG so that 64 bit machines don't need to take
the AIL lock in these places.
SGI-PV: 988143
SGI-Modid: xfs-linux-melb:xfs-kern:32349a
With the new cursor interface, it makes sense to make all the traversing
code use the cursor interface and make the old one go away. This means
more of the AIL interfacing is done by passing struct xfs_ail pointers
around the place instead of struct xfs_mount pointers.
We can replace the use of xfs_trans_first_ail() in xfs_log_need_covered()
as it is only checking if the AIL is empty. We can do that with a call to
xfs_trans_ail_tail() instead, where a zero LSN returned indicates and
empty AIL...
SGI-PV: 988143
SGI-Modid: xfs-linux-melb:xfs-kern:32348a
To replace the current generation number ensuring sanity of the AIL
traversal, replace it with an external cursor that is linked to the AIL.
Basically, we store the next item in the cursor whenever we want to drop
the AIL lock to do something to the current item. When we regain the lock.
the current item may already be free, so we can't reference it, but the
next item in the traversal is already held in the cursor.
When we move or delete an object, we search all the active cursors and if
there is an item match we clear the cursor(s) that point to the object.
This forces the traversal to restart transparently.
We don't invalidate the cursor on insert because the cursor still points
to a valid item. If the intem is inserted between the current item and the
cursor it does not matter; the traversal is considered to be past the
insertion point so it will be picked up in the next traversal.
Hence traversal restarts pretty much disappear altogether with this method
of traversal, which should substantially reduce the overhead of pushing on
a busy AIL.
Version 2 o add restart logic o comment cursor interface o minor cleanups
SGI-PV: 988143
SGI-Modid: xfs-linux-melb:xfs-kern:32347a
Rather than embedding the struct xfs_ail in the struct xfs_mount, allocate
it during AIL initialisation. Add a back pointer to the struct xfs_ail so
that we can pass around the xfs_ail and still be able to access the
xfs_mount if need be. This is th first step involved in isolating the AIL
implementation from the surrounding filesystem code.
SGI-PV: 988143
SGI-Modid: xfs-linux-melb:xfs-kern:32346a
When we create a directory, we reserve a number of blocks for the maximum
possible expansion of of the directory due to various btree splits,
freespace allocation, etc. Unfortunately, each allocation is not reflected
in the total number of blocks still available to the transaction, so the
maximal reservation is used over and over again.
This leads to problems where an allocation group has only enough blocks
for *some* of the allocations required for the directory modification.
After the first N allocations, the remaining blocks in the allocation
group drops below the total reservation, and subsequent allocations fail
because the allocator will not allow the allocation to proceed if the AG
does not have the enough blocks available for the entire allocation total.
This results in an ENOSPC occurring after an allocation has already
occurred. This results in aborting the directory operation (leaving the
directory in an inconsistent state) and cancelling a dirty transaction,
which results in a filesystem shutdown.
Avoid the problem by reflecting the number of blocks allocated in any
directory expansion in the total number of blocks available to the
modification in progress. This prevents a directory modification from
being aborted part way through with an ENOSPC.
SGI-PV: 988144
SGI-Modid: xfs-linux-melb:xfs-kern:32340a
If the last block of the AG has inodes in it and the AG is an exactly
power-of-2 size then the last inode in the AG points to the last block in
the AG. If we try to find the next inode in the AG by adding one to the
inode number, we increment the inode number past the size of the AG. The
result is that the macro XFS_INO_TO_AGINO() will strip the AG portion of
the inode number and return an inode number of zero.
That is, instead of terminating the lookup loop because we hit the inode
number went outside the valid range for the AG, the search index returns
to zero and we start traversing the radix tree from the start again. This
results in an endless loop in xfs_sync_inodes_ag().
Fix it be detecting if the new search index decreases as a result of
incrementing the current inode number. That indicate an overflow and hence
that we have finished processing the AG so we can terminate the loop.
SGI-PV: 988142
SGI-Modid: xfs-linux-melb:xfs-kern:32335a
Now that the deleted inodes list is unused, kill it. This also removes the
i_reclaim list head from the xfs_inode, shrinking it by two pointers.
SGI-PV: 988142
SGI-Modid: xfs-linux-melb:xfs-kern:32334a
Use the reclaim tag to walk the radix tree and find the inodes under
reclaim. This was the only user of the deleted inode list.
SGI-PV: 988142
SGI-Modid: xfs-linux-melb:xfs-kern:32333a
Prepare for removing the deleted inode list by marking inodes for reclaim
in the inode radix trees so that we can use the radix trees to find
reclaimable inodes.
SGI-PV: 988142
SGI-Modid: xfs-linux-melb:xfs-kern:32331a
The function names xfs_finish_reclaim and xfs_finish_reclaim_all are not
very descriptive of what they are reclaiming. Rename to
xfs_reclaim_inode[s] to match the xfs_sync_inodes() function.
SGI-PV: 988142
SGI-Modid: xfs-linux-melb:xfs-kern:32330a
Background inode reclaim is run by the xfssyncd. Move the reclaim worker
functions to be close to the sync code as the are very similar in
structure and are both run from the same background thread.
SGI-PV: 988142
SGI-Modid: xfs-linux-melb:xfs-kern:32329a
