path: root/fs/xfs/xfs_vfsops.c
2006-07-28[XFS] Fix a barrier related forced shutdown on mounts with quota enabled.Nathan Scott
SGI-PV: 912426 SGI-Modid: xfs-linux-melb:xfs-kern:26622a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Fix broken const use inside local suffix_strtoul routine.Nathan Scott
SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:26201a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Resolve a namespace collision on remaining vtypes for FreeBSDNathan Scott
porters. SGI-PV: 953338 SGI-Modid: xfs-linux-melb:xfs-kern:26108a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Resolve a namespace collision on vnode/vnodeops for FreeBSD porters.Nathan Scott
SGI-PV: 953338 SGI-Modid: xfs-linux-melb:xfs-kern:26107a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Resolve a namespace collision on vfs/vfsops for FreeBSD porters.Nathan Scott
SGI-PV: 9533338 SGI-Modid: xfs-linux-melb:xfs-kern:26106a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Portability changes: remove prdev, stick to one diagnosticNathan Scott
interface. SGI-PV: 953338 SGI-Modid: xfs-linux-melb:xfs-kern:26103a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-05-08[XFS] Fix a possible forced shutdown due to mishandling write barriersNathan Scott
with remount,ro. SGI-PV: 951944 SGI-Modid: xfs-linux-melb:xfs-kern:25742a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-31[XFS] Reenable write barriers by default.Nathan Scott
SGI-PV: 912426 SGI-Modid: xfs-linux-melb:xfs-kern:25634a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-31[XFS] Implement the silent parameter to fill_super, previously ignored.Nathan Scott
SGI-PV: 951299 SGI-Modid: xfs-linux-melb:xfs-kern:25632a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-29[XFS] We really suck at spulling. Thanks to Chris Pascoe for fixing allNathan Scott
these typos. SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:25539a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-22[XFS] Reenable the noikeep (delete inode cluster space) option by default.Nathan Scott
SGI-PV: 951200 SGI-Modid: xfs-linux-melb:xfs-kern:25535a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-22[XFS] Fixup naming inconsistencies found by Pekka Enberg and one from JanNathan Scott
Engelhardt. SGI-PV: 947038 SGI-Modid: xfs-linux-melb:xfs-kern:25529a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] Fix an infinite loop issue in bulkstat when a corrupt inode isNathan Scott
detected. Thanks to Roger Willcocks. SGI-PV: 951054 SGI-Modid: xfs-linux-melb:xfs-kern:25477a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-14[XFS] Cleanup the use of zones/slabs, more consistent and allows flags toNathan Scott
be passed. SGI-PV: 949073 SGI-Modid: xfs-linux-melb:xfs-kern:25122a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-14[XFS] On machines with more than 8 cpus, when running parallel I/ODavid Chinner
threads, the incore superblock lock becomes the limiting factor for buffered write throughput. Make the contended fields in the incore superblock use per-cpu counters so that there is no global lock to limit scalability. SGI-PV: 946630 SGI-Modid: xfs-linux-melb:xfs-kern:25106a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-14[XFS] XFS propagates MS_NOATIME through two levels internally but doesn'tNathan Scott
actually use it. Kill this dead code. Signed-off-by: Christoph Hellwig <hch@lst.de> SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:25086a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Fix v2 log bufsize reporting in /proc/mounts.Nathan Scott
SGI-PV: 946760 SGI-Modid: xfs-linux-melb:xfs-kern:24765a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Disable write barriers for now till intermittent IO errors areNathan Scott
understood. SGI-PV: 912426 SGI-Modid: xfs-linux-melb:xfs-kern:202962a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Reverse the sense of COMPAT_ATTR and ATTR2, keeps it simple andNathan Scott
consistent. SGI-PV: 941645 SGI-Modid: xfs-linux-melb:xfs-kern:202961a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Write log dummy record when freezing filesystemChristoph Hellwig
SGI-PV: 945483 SGI-Modid: xfs-linux-melb:xfs-kern:202638a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] do barrier checks earlier. quota initialization may write to theChristoph Hellwig
filesystem SGI-PV: 912426 SGI-Modid: xfs-linux-melb:xfs-kern:202355a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Fix typo from when enabling write barriers by default, flags botchNathan Scott
in showargs. SGI-PV: 912426 SGI-Modid: xfs-linux-melb:xfs-kern:24383a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] enable write barriers by defaultChristoph Hellwig
SGI-PV: 912426 SGI-Modid: xfs-linux-melb:xfs-kern:201981a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-04[XFS] Fix an inode32 regression - if no options are presented, must stillNathan Scott
set default flags. SGI-PV: 945242 SGI-Modid: xfs-linux-melb:xfs-kern:24292a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove old, broken nolog-mode code - noone plans to ever fix it.Nathan Scott
SGI-PV: 944821 SGI-Modid: xfs-linux:xfs-kern:24213a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Rework fid encode/decode wrt 64 bit inums interacting with NFS.Nathan Scott
SGI-PV: 937127 SGI-Modid: xfs-linux:xfs-kern:24201a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Rework the final mount options flag bit to make room for more.Nathan Scott
SGI-PV: 943866 SGI-Modid: xfs-linux:xfs-kern:24030a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Disable attr2 by default, until a more appropriate time to enableNathan Scott
it. SGI-PV: 941645 SGI-Modid: xfs-linux:xfs-kern:24002a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Show additional mount options in /proc/mounts, fix up some debugNathan Scott
code. SGI-PV: 941645 SGI-Modid: xfs-linux:xfs-kern:23926a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Track external log/realtime device names for correct reporting inNathan Scott
/proc/mounts. SGI-PV: 942984 SGI-Modid: xfs-linux:xfs-kern:23862a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Ondisk format extension for extended attributes (attr2). Basically,Nathan Scott
the data/attr forks now grow up/down from either end of the literal area, rather than dividing the literal area into two chunks and growing both upward. Means we can now make much more efficient use of the attribute space, incl. fitting DMF attributes inline in 256 byte inodes, and large jumps in dbench3 performance numbers. It is self enabling, but can be forced on/off via the attr2/noattr2 mount options. SGI-PV: 941645 SGI-Modid: xfs-linux:xfs-kern:23835a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Introduce two new mount options (nolargeio/largeio) to allowDavid Chinner
filesystems to expose the filesystem stripe width in stat(2) rather than the page cache size. This allows applications requiring high bandwidth to easily determine the optimum I/O size for the underlying filesystem. The default is to report the page cache size (i.e. "nolargeio"). SGI-PV: 942818 SGI-Modid: xfs-linux:xfs-kern:23830a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Provide a mechiansm for flushing delalloc before quota reporting.Nathan Scott
SGI-PV: 942815 SGI-Modid: xfs-linux:xfs-kern:23829a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] write barrier support Issue all log sync operations as orderedChristoph Hellwig
writes. In addition flush the disk cache on fsync if the sync cached operation didn't sync the log to disk (this requires some additional bookeping in the transaction and log code). If the device doesn't claim to support barriers, the filesystem has an extern log volume or the trial superblock write with barriers enabled failed we disable barriers and print a warning. We should probably fail the mount completely, but that could lead to nasty boot failures for the root filesystem. Not enabled by default yet, needs more destructive testing first. SGI-PV: 912426 SGI-Modid: xfs-linux:xfs-kern:198723a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-09-05[XFS] Sort out some cosmetic differences between XFS trees.Nathan Scott
SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:23719a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-09-02[XFS] Add in grpid/nogrpid mount option parsing, actual code was alwaysNathan Scott
there.. SGI-PV: 939444 SGI-Modid: xfs-linux:xfs-kern:23162a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-09-02[XFS] replace vn_get usage by iholdChristoph Hellwig
SGI-PV: 938306 SGI-Modid: xfs-linux:xfs-kern:194627a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-06-21[XFS] quiesce the filesystem proper when freezingChristoph Hellwig
SGI-PV: 936977 SGI-Modid: xfs-linux:xfs-kern:193840a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-06-21[XFS] Add support for project quota, based on Dan Knappes earlier work.Nathan Scott
SGI-PV: 932952 SGI-Modid: xfs-linux:xfs-kern:22805a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-06-21[XFS] mark various symbols static Patch from Adrian BunkChristoph Hellwig
SGI-PV: 936255 SGI-Modid: xfs-linux:xfs-kern:192760a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-05-05[XFS] Allow initial XFS delayed allocation size to be increased beyond 64KB.Nathan Scott
SGI Modid: xfs-linux:xfs-kern:22261a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Christoph Hellwig <hch@sgi.com>
