path: root/fs/xfs/xfs_sb.h
2013-10-23xfs: create a shared header file for format-related informationDave Chinner
All of the buffer operations structures are needed to be exported for xfs_db, so move them all to a common location rather than spreading them all over the place. They are verifying the on-disk format, so while xfs_format.h might be a good place, it is not part of the on disk format. Hence we need to create a new header file that we centralise these related definitions. Start by moving the bffer operations structures, and then also move all the other definitions that have crept into xfs_log_format.h and xfs_format.h as there was no other shared header file to put them in. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-08-22xfs: add xfs sb v4 support for dirent filetype fieldMark Tinguely
Add XFS superblock v4 support for the file type field in the directory entry feature. This support adds a feature bit for version 4 superblocks and leaves the original superblock 5 incompatibility bit. Signed-off-by: Mark Tinguely <tinguely@sgi.com> Reviewed-by: Geoffrey Wehrman <gwehrman@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-08-22xfs: Add write support for dirent filetype fieldDave Chinner
Add support to propagate and add filetype values into the on-disk directs. This involves passing the filetype into the xfs_da_args structure along with the name and namelength for direct operations, and encoding it into the dirent at the same time we write the inode number into the dirent. With write support, add the feature flag to the XFS_SB_FEAT_INCOMPAT_ALL mask so we can now mount filesystems with this feature set. Performance of directory recursion is now much improved. Parallel walk of ~50 million directory entries across hundreds of directories improves significantly. Unpatched, no CRCs: Walking via ls -R real 3m19.886s user 6m36.960s sys 28m19.087s THis is doing roughly 500 getdents() calls per second, and 250,000 inode lookups per second to determine the inode type at roughly 17,000 read IOPS. CPU usage is 90% kernel space. With dtype support patched in and the fileset recreated with CRCs enabled: Walking via ls -R real 0m31.316s user 6m32.975s sys 0m21.111s This is doing roughly 3500 getdents() calls per second at 16,000 IOPS. There are no inode lookups at all. CPU usages is almost 100% userspace. This is a big win for recursive directory walks that only need to find file names and file types. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-08-22xfs: Add read-only support for dirent filetype fieldDave Chinner
Add support for the file type field in directory entries so that readdir can return the type of the inode the dirent points to to userspace without first having to read the inode off disk. The encoding of the type field is a single byte that is added to the end of the directory entry name length. For all intents and purposes, it appends a "hidden" byte to the name field which contains the type information. As the directory entry is already of dynamic size, helpers are already required to access and decode the direct entry structures. Hence the relevent extraction and iteration helpers are updated to understand the hidden byte. Helpers for reading and writing the filetype field from the directory entries are also added. Only the read helpers are used by this patch. It also adds all the code necessary to read the type information out of the dirents on disk. Further we add the superblock feature bit and helpers to indicate that we understand the on-disk format change. This is not a compatible change - existing kernels cannot read the new format successfully - so an incompatible feature flag is added. We don't yet allow filesystems to mount with this flag yet - that will be added once write support is added. Finally, the code to take the type from the VFS, convert it to an XFS on-disk type and put it into the xfs_name structures passed around is added, but the directory code does not use this field yet. That will be in the next patch. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-08-12xfs: don't special case shared superblock mountsDave Chinner
Neither kernel or userspace support shared read-only mounts, so don't bother special casing the support check to be different between kernel and userspace. The same check can be used as neither like it... Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-08-12xfs: introduce xfs_sb.c for sharing with libxfsDave Chinner
xfs_mount.c is shared with userspace, but the only functions that are shared are to do with physical superblock manipulations. This means that less than 25% of the xfs_mount.c code is actually shared with userspace. Move all the superblock functions to xfs_sb.c and share that instead with libxfs. Note that this will leave all the in-core transaction related superblock counter modifications in xfs_mount.c as none of that is shared with userspace. With a few more small changes, xfs_mount.h won't need to be shared with userspace anymore, either. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-08-12xfs: sync minor header differences needed by userspace.Dave Chinner
Little things like exported functions, __KERNEL__ protections, and so on that ensure user and kernel shared headers are identical. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-07-22xfs: Start using pquotaino from the superblock.Chandra Seetharaman
Start using pquotino and define a macro to check if the superblock has pquotino. Keep backward compatibilty by alowing mount of older superblock with no separate pquota inode. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-06-28xfs: Define a new function xfs_is_quota_inode()Chandra Seetharaman
In preparation for combined pquota/gquota support, define a new function to check if the given inode is a quota inode. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-04-27xfs: implement extended feature masksDave Chinner
The version 5 superblock has extended feature masks for compatible, incompatible and read-only compatible feature sets. Implement the masking and mount-time checking for these feature masks. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-04-27xfs: add CRC checks to the superblockDave Chinner
With the addition of CRCs, there is such a wide and varied change to the on disk format that it makes sense to bump the superblock version number rather than try to use feature bits for all the new functionality. This commit introduces all the new superblock fields needed for all the new functionality: feature masks similar to ext4, separate project quota inodes, a LSN field for recovery and the CRC field. This commit does not bump the superblock version number, however. That will be done as a separate commit at the end of the series after all the new functionality is present so we switch it all on in one commit. This means that we can slowly introduce the changes without them being active and hence maintain bisectability of the tree. This patch is based on a patch originally written by myself back from SGI days, which was subsequently modified by Christoph Hellwig. There is relatively little of that patch remaining, but the history of the patch still should be acknowledged here. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-11-19xfs: add CRC infrastructureChristoph Hellwig
- add a mount feature bit for CRC enabled filesystems - add some helpers for generating and verifying the CRCs - add a copy_uuid helper The checksumming helpers are loosely based on similar ones in sctp, all other bits come from Dave Chinner. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-02-02xfs: kill the unused XFS_BB_FSB_OFFSET macroAmit Sahrawat
Removing the macro, as this is no more needed in the code. Tried to find the reference when it was last used - but the usage for this seemed to have been dropped long time ago. Signed-off-by: Amit Sahrawat <amit.sahrawat83@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com>
2011-07-25xfs: Remove the macro XFS_BUF_PTRChandra Seetharaman
Remove the definition and usages of the macro XFS_BUF_PTR. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-10-18xfs: Extend project quotas to support 32bit project idsArkadiusz Mi?kiewicz
This patch adds support for 32bit project quota identifiers. On disk format is backward compatible with 16bit projid numbers. projid on disk is now kept in two 16bit values - di_projid_lo (which holds the same position as old 16bit projid value) and new di_projid_hi (takes existing padding) and converts from/to 32bit value on the fly. xfs_admin (for existing fs), mkfs.xfs (for new fs) needs to be used to enable PROJID32BIT support. Signed-off-by: Arkadiusz Miƛkiewicz <arekm@maven.pl> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-01-19[XFS] Remove the rest of the macro-to-function indirections.Eric Sandeen
Remove the last of the macros-defined-to-static-functions. Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-12-11[XFS] resync headers with libxfsChristoph Hellwig
- xfs_sb.h add the XFS_SB_VERSION2_PARENTBIT features2 that has been around in userspace for some time - xfs_inode.h: move a few things out of __KERNEL__ that are needed by userspace - xfs_mount.h: only include xfs_sync.h under __KERNEL__ - xfs_inode.c: minor whitespace fixup. I accidentaly changes this when importing this file for use by userspace. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-12-04cleanup xfs_sb.h feature flag helpersChristoph Hellwig
The various inlines in xfs_sb.h that deal with the superblock version and fature flags were converted from macros a while ago, and this show by the odd coding style full of useless braces and backslashes and the avoidance of conditionals. Clean these up to look like normal C code. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-07-28[XFS] XFS: ASCII case-insensitive supportBarry Naujok
Implement ASCII case-insensitive support. It's primary purpose is for supporting existing filesystems that already use this case-insensitive mode migrated from IRIX. But, if you only need ASCII-only case-insensitive support (ie. English only) and will never use another language, then this mode is perfectly adequate. ASCII-CI is implemented by generating hashes based on lower-case letters and doing lower-case compares. It implements a new xfs_nameops vector for doing the hashes and comparisons for all filename operations. To create a filesystem with this CI mode, use: # mkfs.xfs -n version=ci <device> SGI-PV: 981516 SGI-Modid: xfs-linux-melb:xfs-kern:31209a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-07-28[XFS] Fix up noattr2 so that it will properly update the versionnum andTim Shimmin
features2 fields. Previously, mounting with noattr2 failed to achieve anything because although it cleared the attr2 mount flag, it would set it again as soon as it processed the superblock fields. The fix now has an explicit noattr2 flag and uses it later to fix up the versionnum and features2 fields. SGI-PV: 980021 SGI-Modid: xfs-linux-melb:xfs-kern:31003a Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-10[XFS] Ensure "both" features2 slots are consistentEric Sandeen
Since older kernels may look in the sb_bad_features2 slot for flags, rather than zeroing it out on fixup, we should make it equal to the sb_features2 value. Also, if the ATTR2 flag was not found prior to features2 fixup, it was not set in the mount flags, so re-check after the fixup so that the current session will use the feature. Also fix up the comments to reflect these changes. SGI-PV: 980085 SGI-Modid: xfs-linux-melb:xfs-kern:30778a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-10[XFS] Fix superblock features2 field alignment problemDavid Chinner
Due to the xfs_dsb_t structure not being 64 bit aligned, the last field of the on-disk superblock can vary in location This causes problems when the filesystem gets moved to a different platform, or there is a 32 bit userspace and 64 bit kernel. This patch detects the defect at mount time, logs a warning such as: XFS: correcting sb_features alignment problem in dmesg and corrects the problem so that everything is OK. it also blacklists the bad field in the superblock so it does not get used for something else later on. SGI-PV: 977636 SGI-Modid: xfs-linux-melb:xfs-kern:30539a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-10[XFS] remove shouting-indirection macros from xfs_sb.hEric Sandeen
Remove macro-to-small-function indirection from xfs_sb.h, and remove some which are completely unused. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30528a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2007-10-15[XFS] superblock endianess annotationsChristoph Hellwig
Creates a new xfs_dsb_t that is __be annotated and keeps xfs_sb_t for the incore one. xfs_xlatesb is renamed to xfs_sb_to_disk and only handles the incore -> disk conversion. A new helper xfs_sb_from_disk handles the other direction and doesn't need the slightly hacky table-driven approach because we only ever read the full sb from disk. The handling of shared r/o filesystems has been buggy on little endian system and fixing this required shuffling around of some code in that area. SGI-PV: 968563 SGI-Modid: xfs-linux-melb:xfs-kern:29477a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-07-14[XFS] Lazy Superblock CountersDavid Chinner
When we have a couple of hundred transactions on the fly at once, they all typically modify the on disk superblock in some way. create/unclink/mkdir/rmdir modify inode counts, allocation/freeing modify free block counts. When these counts are modified in a transaction, they must eventually lock the superblock buffer and apply the mods. The buffer then remains locked until the transaction is committed into the incore log buffer. The result of this is that with enough transactions on the fly the incore superblock buffer becomes a bottleneck. The result of contention on the incore superblock buffer is that transaction rates fall - the more pressure that is put on the superblock buffer, the slower things go. The key to removing the contention is to not require the superblock fields in question to be locked. We do that by not marking the superblock dirty in the transaction. IOWs, we modify the incore superblock but do not modify the cached superblock buffer. In short, we do not log superblock modifications to critical fields in the superblock on every transaction. In fact we only do it just before we write the superblock to disk every sync period or just before unmount. This creates an interesting problem - if we don't log or write out the fields in every transaction, then how do the values get recovered after a crash? the answer is simple - we keep enough duplicate, logged information in other structures that we can reconstruct the correct count after log recovery has been performed. It is the AGF and AGI structures that contain the duplicate information; after recovery, we walk every AGI and AGF and sum their individual counters to get the correct value, and we do a transaction into the log to correct them. An optimisation of this is that if we have a clean unmount record, we know the value in the superblock is correct, so we can avoid the summation walk under normal conditions and so mount/recovery times do not change under normal operation. One wrinkle that was discovered during development was that the blocks used in the freespace btrees are never accounted for in the AGF counters. This was once a valid optimisation to make; when the filesystem is full, the free space btrees are empty and consume no space. Hence when it matters, the "accounting" is correct. But that means the when we do the AGF summations, we would not have a correct count and xfs_check would complain. Hence a new counter was added to track the number of blocks used by the free space btrees. This is an *on-disk format change*. As a result of this, lazy superblock counters are a mkfs option and at the moment on linux there is no way to convert an old filesystem. This is possible - xfs_db can be used to twiddle the right bits and then xfs_repair will do the format conversion for you. Similarly, you can convert backwards as well. At some point we'll add functionality to xfs_admin to do the bit twiddling easily.... SGI-PV: 964999 SGI-Modid: xfs-linux-melb:xfs-kern:28652a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Remove several macros that are no longer used anywhereEric Sandeen
SGI-PV: 955302 SGI-Modid: xfs-linux-melb:xfs-kern:26749a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-01-11[XFS] Sort out cosmetic differences between user and kernel copies of someNathan Scott
sources. SGI-PV: 907752 SGI-Modid: xfs-linux-melb:xfs-kern:24659a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Ondisk format extension for extended attributes (attr2). Basically,Nathan Scott
the data/attr forks now grow up/down from either end of the literal area, rather than dividing the literal area into two chunks and growing both upward. Means we can now make much more efficient use of the attribute space, incl. fitting DMF attributes inline in 256 byte inodes, and large jumps in dbench3 performance numbers. It is self enabling, but can be forced on/off via the attr2/noattr2 mount options. SGI-PV: 941645 SGI-Modid: xfs-linux:xfs-kern:23835a Signed-off-by: Nathan Scott <nathans@sgi.com>
