path: root/fs/xfs/xfs_rtalloc.c
2009-01-19[XFS] Remove the rest of the macro-to-function indirections.Eric Sandeen
Remove the last of the macros-defined-to-static-functions. Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-12-02[XFS] Move copy_from_user calls out of ioctl helpers into ioctl switch.sandeen@sandeen.net
Moving the copy_from_user out of some of the ioctl helpers will make it easier for the compat ioctl switch to copy in the right struct, then just pass to the underlying helper. Also, move common access checks into the helpers themselves, and out of the native ioctl switch code, to reduce code duplication between native & compat ioctl callers. Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-12-01[XFS] fix uninitialised variable bug in dquot release.Dave Chinner
gcc is warning about an uninitialised variable in xfs_growfs_rt(). This is a false positive. Fix it by changing the scope of the transaction pointer to wholly within the internal loop inside the function. While there, preemptively change xfs_growfs_rt_alloc() in the same way as it has exactly the same structure as xfs_growfs_rt() but gcc is not warning about it. Yet. Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-08-13[XFS] Use the generic bitops rather than implementing them ourselves.David Chinner
This keeps xfs_lowbit64 as it was since there aren't good generic helpers there ... Patch inspired by Andi Kleen. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31472a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] Remove unused arg from kmem_free()Denys Vlasenko
kmem_free() function takes (ptr, size) arguments but doesn't actually use second one. This patch removes size argument from all callsites. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31050a Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Propagate errors from xfs_trans_commit().David Chinner
xfs_trans_commit() can return errors when there are problems in the transaction subsystem. They are indicative that the entire transaction may be incomplete, and hence the error should be propagated as there is a good possibility that there is something fatally wrong in the filesystem. Catch and propagate or warn about commit errors in the places where they are currently ignored. SGI-PV: 980084 SGI-Modid: xfs-linux-melb:xfs-kern:30795a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] remove most calls to VN_RELEChristoph Hellwig
Most VN_RELE calls either directly contain a XFS_ITOV or have the corresponding xfs_inode already in scope. Use the IRELE helper instead of VN_RELE to clarify the code. With a little more work we can kill VN_RELE altogether and define IRELE in terms of iput directly. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30710a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-26[XFS] Undo bit ops cleanup mod due to regression on 32-bit powermacLachlan McIlroy
platform. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:30559a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] Use the generic bitops rather than implementing them ourselves.David Chinner
Patch inspired by Andi Kleen. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:30000a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2007-07-14[XFS] Don't grow filesystems past the size they can index.Nathan Scott
When growing a filesystem we don't check to see if the new size overflows the page cache index range, so we can do silly things like grow a filesystem page 16TB on a 32bit. Check new filesystem sizes against the limits the kernel can support. SGI-PV: 957886 SGI-Modid: xfs-linux-melb:xfs-kern:28563a Signed-Off-By: Nathan Scott <nscott@aconex.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] The last argument "lsn" of xfs_trans_commit() is always called withEric Sandeen
NULL. Patch provided by Eric Sandeen. SGI-PV: 961693 SGI-Modid: xfs-linux-melb:xfs-kern:28199a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Remove a bunch of unused functions from XFS.Eric Sandeen
Patch provided by Eric Sandeen (sandeen@sandeen.net). SGI-PV: 960897 SGI-Modid: xfs-linux-melb:xfs-kern:28038a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Remove unused argument to xfs_bmap_finishEric Sandeen
The firstblock argument to xfs_bmap_finish is not used by that function. Remove it and cleanup the code a bit. Patch provided by Eric Sandeen. SGI-PV: 960196 SGI-Modid: xfs-linux-melb:xfs-kern:28034a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Fix a porting botch on the realtime subvol growfs code path.Nathan Scott
SGI-PV: 955515 SGI-Modid: xfs-linux-melb:xfs-kern:26806a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Minor code rearranging and cleanup to prevent some coverity falseNathan Scott
positives. SGI-PV: 955502 SGI-Modid: xfs-linux-melb:xfs-kern:26805a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-28[XFS] Fix realtime subvolume expansion, a porting bug b0rked it. CoverityEric Sesterhenn
made me look at this code (bug id #344). We only return with XFS_ERROR(EINVAL) if mp->m_rtdev_targp is valid and pass it otherwise to xfs_read_buf() where some function calls later it gets dereferenced by an assert. SGI-PV: 954266 SGI-Modid: xfs-linux-melb:xfs-kern:26363a Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Portability changes: remove prdev, stick to one diagnosticNathan Scott
interface. SGI-PV: 953338 SGI-Modid: xfs-linux-melb:xfs-kern:26103a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Add parameters to xfs_bmapi() and xfs_bunmapi() to have them reportOlaf Weber
the range spanned by modifications to the in-core extent map. Add XFS_BUNMAPI() and XFS_SWAP_EXTENTS() macros that call xfs_bunmapi() and xfs_swap_extents() via the ioops vector. Change all calls that may modify the in-core extent map for the data fork to go through the ioops vector. This allows a cache of extent map data to be kept in sync. SGI-PV: 947615 SGI-Modid: xfs-linux-melb:xfs-kern:209226a Signed-off-by: Olaf Weber <olaf@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-02-28[XFS] Fix a realtime allocator regression introduced by an old iget raceNathan Scott
fix. Noticed by Roger Willcocks. SGI-PV: 949821 SGI-Modid: xfs-linux-melb:xfs-kern:25257a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
