Add a dquot buffer verify callback function and pass it into the
buffer read functions. This checks all the dquots in a buffer, but
cannot completely verify the dquot ids are correct. Also, errors
cannot be repaired, so an additional function is added to repair bad
dquots in the buffer if such an error is detected in a context where
repair is allowed.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Phil White <pwhite@sgi.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
Add a verifier function callback capability to the buffer read
interfaces. This will be used by the callers to supply a function
that verifies the contents of the buffer when it is read from disk.
This patch does not provide callback functions, but simply modifies
the interfaces to allow them to be called.
The reason for adding this to the read interfaces is that it is very
difficult to tell fom the outside is a buffer was just read from
disk or whether we just pulled it out of cache. Supplying a callbck
allows the buffer cache to use it's internal knowledge of the buffer
to execute it only when the buffer is read from disk.
It is intended that the verifier functions will mark the buffer with
an EFSCORRUPTED error when verification fails. This allows the
reading context to distinguish a verification error from an IO
error, and potentially take further actions on the buffer (e.g.
attempt repair) based on the error reported.
The inode cache functions remaining in xfs_iget.c can be moved to xfs_icache.c
along with the other inode cache functions. This removes all functionality from
xfs_iget.c, so the file can simply be removed.
This move results in various functions now only having the scope of a single
file (e.g. xfs_inode_free()), so clean up all the definitions and exported
prototypes in xfs_icache.[ch] and xfs_inode.h appropriately.
Reviewed-by: Mark Tinguely <tinguely@sgi.com>
XFS_MAXIOFFSET() is just a simple macro that resolves to
mp->m_maxioffset. It doesn't need to exist, and it just makes the
code unnecessarily loud and shouty.
Make it quiet and easy to read.
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
Untangle the header file includes a bit by moving the definition of
xfs_agino_t to xfs_types.h. This removes the dependency that xfs_ag.h has on
xfs_inum.h, meaning we don't need to include xfs_inum.h everywhere we include
xfs_ag.h.
Queue delwri buffers on a local on-stack list instead of a per-buftarg one,
and write back the buffers per-process instead of by waking up xfsbufd.
This is now easily doable given that we have very few places left that write
delwri buffers:
- log recovery:
Only done at mount time, and already forcing out the buffers
synchronously using xfs_flush_buftarg
- quotacheck:
Same story.
- dquot reclaim:
Writes out dirty dquots on the LRU under memory pressure. We might
want to look into doing more of this via xfsaild, but it's already
more optimal than the synchronous inode reclaim that writes each
buffer synchronously.
- xfsaild:
This is the main beneficiary of the change. By keeping a local list
of buffers to write we reduce latency of writing out buffers, and
more importably we can remove all the delwri list promotions which
were hitting the buffer cache hard under sustained metadata loads.
The implementation is very straight forward - xfs_buf_delwri_queue now gets
a new list_head pointer that it adds the delwri buffers to, and all callers
need to eventually submit the list using xfs_buf_delwi_submit or
xfs_buf_delwi_submit_nowait. Buffers that already are on a delwri list are
skipped in xfs_buf_delwri_queue, assuming they already are on another delwri
list. The biggest change to pass down the buffer list was done to the AIL
pushing. Now that we operate on buffers the trylock, push and pushbuf log
item methods are merged into a single push routine, which tries to lock the
item, and if possible add the buffer that needs writeback to the buffer list.
This leads to much simpler code than the previous split but requires the
individual IOP_PUSH instances to unlock and reacquire the AIL around calls
to blocking routines.
Given that xfsailds now also handle writing out buffers, the conditions for
log forcing and the sleep times needed some small changes. The most
important one is that we consider an AIL busy as long we still have buffers
to push, and the other one is that we do increment the pushed LSN for
buffers that are under flushing at this moment, but still count them towards
the stuck items for restart purposes. Without this we could hammer on stuck
items without ever forcing the log and not make progress under heavy random
delete workloads on fast flash storage devices.
[ Dave Chinner:
- rebase on previous patches.
- improved comments for XBF_DELWRI_Q handling
- fix XBF_ASYNC handling in queue submission (test 106 failure)
- rename delwri submit function buffer list parameters for clarity
- xfs_efd_item_push() should return XFS_ITEM_PINNED ]
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Instead of writing the buffer directly from inside xfs_qm_dqflush return it
to the caller and let the caller decide what to do with the buffer. Also
remove the pincount check in xfs_qm_dqflush that all non-blocking callers
already implement and the now unused flags parameter and the XFS_DQ_IS_DIRTY
check that all callers already perform.
[ Dave Chinner: fixed build error cause by missing '{'. ]
Check if we actually need to attach a dquot before taking the ilock in
xfs_qm_dqattach. This avoid superflous lock roundtrips for the common cases
of quota support compiled in but not activated on a filesystem and an
inode that already has the dquots attached.
If we initialize the slab caches for the quota code when XFS is loaded there
is no need for a global and reference counted quota manager structure. Drop
all this overhead and also fix the error handling during quota initialization.
Instead of keeping a separate per-filesystem list of dquots we can walk
the radix tree for the two places where we need to iterate all quota
structures.
Replace the global hash tables for looking up in-memory dquot structures
with per-filesystem radix trees to allow scaling to a large number of
in-memory dquot structures.
Replace the global dquot lru lists with a per-filesystem one.
Note that the shrinker isn't wire up to the per-superblock VFS shrinker
infrastructure as would have problems summing up and splitting the counts
for inodes and dquots. I don't think this is a major problem as the quota
cache isn't as interwinded with the inode cache as the dentry cache is,
because an inode that is dropped from the cache will generally release
a dquot reference, but most of the time it won't be the last one.
Switch the quota code over to use the generic XFS statistics infrastructure.
While the legacy /proc/fs/xfs/xqm and /proc/fs/xfs/xqmstats interfaces are
preserved for now the statistics that still have a meaning with the current
code are now also available from /proc/fs/xfs/stats.
Stop reusing dquots from the freelist when allocating new ones directly, and
implement a shrinker that actually follows the specifications for the
interface. The shrinker implementation is still highly suboptimal at this
point, but we can gradually work on it.
This also fixes an bug in the previous lock ordering, where we would take
the hash and dqlist locks inside of the freelist lock against the normal
lock ordering. This is only solvable by introducing the dispose list,
and thus not when using direct reclaim of unused dquots for new allocations.
As a side-effect the quota upper bound and used to free ratio values in
/proc/fs/xfs/xqm are set to 0 as these values don't make any sense in the
new world order.
(cherry picked from commit 04da0c8196ac0b12fb6b84f4b7a51ad2fa56d869)
Define new macro XFS_ALL_QUOTA_ACTIVE and simply some usage
of quota macros.
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
There is no reason to drop qi_dqlist_lock around calls to xfs_qm_dqrele
because the free list lock now nests inside qi_dqlist_lock and the
dquot lock.
Just read the id 0 dquot from disk directly in xfs_qm_init_quotainfo instead
of going through dqget and requiring a special flag to not add the dquot to
any lists.
Factor the common pattern of:
xfs_dqlock(dqp);
XFS_DQHOLD(dqp);
xfs_dqunlock(dqp);
into a new helper, and remove XFS_DQHOLD now that only one other caller
is left.
No need to play games with the qlock now that the freelist lock nests inside
it. Also clean up various outdated comments.
Allow xfs_qm_dqput to work without trylock loops by nesting the freelist lock
inside the dquot qlock. In turn that requires trylocks in the reclaim path
instead, but given it's a classic tradeoff between fast and slow path, and
we follow the model of the inode and dentry caches.
Document our new lock order now that it has settled.
Introduce a new XFS_DQ_FREEING flag that tells lookup and mplist walks
to skip a dquot that is beeing freed, and use this avoid the trylock
on the hash and mplist locks in xfs_qm_dqreclaim_one. Also simplify
xfs_dqpurge by moving the inodes to a dispose list after marking them
XFS_DQ_FREEING and avoid the locker ordering constraints.
Do not remove dquots from the freelist when we grab a reference to them in
xfs_qm_dqlookup, but leave them on the freelist util scanning notices that
they have a reference. This speeds up the lookup fastpath, and greatly
simplifies the lock ordering constraints. Note that the same scheme is
used by the VFS inode and dentry caches.
Free dquots when purging them during umount instead of keeping them around
on the freelist in a degraded state. The out of order locking in
xfs_qm_dqpurge will be removed again later in this series.
Mark the trivial lock wrappers as inline, and make the naming consistent
for all of them.
It always is zero, and removing it will make future changes easier.
Now that we can't have any dirty dquots around that aren't in the AIL we
can get rid of the explicit dquot syncing from xfssyncd and xfs_fs_sync_fs
and instead rely on AIL pushing to write out any quota updates.
Make sure we do not skip any dquots when flushing them out after a
quotacheck to make sure that we will never have any dirty dquots on a
live filesystem. At this point no dquot should be pinnable, but lets
be pedantic about it.
Only skip pinned dquots if SYNC_TRYLOCK is specified, and adjust the callers
to keep the behaviour unchanged.
The doalloc arg in xfs_qm_dqattach_one() is a flag that indicates
whether a new area to handle quota information will be allocated
if needed. Originally, it was passed to xfs_qm_dqget(), but has
been removed by the following commit (probably by mistake):
commit 8e9b6e7fa4544ea8a0e030c8987b918509c8ff47
Author: Christoph Hellwig <hch@lst.de>
Date: Sun Feb 8 21:51:42 2009 +0100
xfs: remove the unused XFS_QMOPT_DQLOCK flag
As the result, xfs_qm_dqget() called from xfs_qm_dqattach_one()
never allocates the new area even if it is needed.
This patch gives the doalloc arg to xfs_qm_dqget() in
xfs_qm_dqattach_one() to fix this problem.
Signed-off-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com>
Cc: Alex Elder <aelder@sgi.com>
Signed-off-by: Alex Elder <aelder@sgi.com>
xfs_bmapi() currently handles both extent map reading and
allocation. As a result, the code is littered with "if (wr)"
branches to conditionally do allocation operations if required.
This makes the code much harder to follow and causes significant
indent issues with the code.
Given that read mapping is much simpler than allocation, we can
split out read mapping from xfs_bmapi() and reuse the logic that
we have already factored out do do all the hard work of handling the
extent map manipulations. The results in a much simpler function for
the common extent read operations, and will allow the allocation
code to be simplified in another commit.
Once xfs_bmapi_read() is implemented, convert all the callers of
xfs_bmapi() that are only reading extents to use the new function.
Unify the ways we add buffers to the delwri queue by always calling
xfs_buf_delwri_queue directly. The xfs_bdwrite functions is removed and
opencoded in its callers, and the two places setting XBF_DELWRI while a
buffer is locked and expecting xfs_buf_unlock to pick it up are converted
to call xfs_buf_delwri_queue directly, too. Also replace the
XFS_BUF_UNDELAYWRITE macro with direct calls to xfs_buf_delwri_dequeue
to make the explicit queuing/dequeuing more obvious.
Use the move from Linux 2.6 to Linux 3.x as an excuse to kill the
annoying subdirectories in the XFS source code. Besides the large
amount of file rename the only changes are to the Makefile, a few
files including headers with the subdirectory prefix, and the binary
sysctl compat code that includes a header under fs/xfs/ from
kernel/.
