Pull xfs updates from Dave Chinner:
"This update contains:
- cleanup removing unused function args
- rework of the filestreams allocator to use dentry cache parent
lookups
- new on-disk free inode btree and optimised inode allocator
- various bug fixes
- rework of internal attribute API
- cleanup of superblock feature bit support to remove historic cruft
- more fixes and minor cleanups
- added a new directory/attribute geometry abstraction
- yet more fixes and minor cleanups"
* tag 'xfs-for-linus-3.16-rc1' of git://oss.sgi.com/xfs/xfs: (86 commits)
xfs: fix xfs_da_args sparse warning in xfs_readdir
xfs: Fix rounding in xfs_alloc_fix_len()
xfs: tone down writepage/releasepage WARN_ONs
xfs: small cleanup in xfs_lowbit64()
xfs: kill xfs_buf_geterror()
xfs: xfs_readsb needs to check for magic numbers
xfs: block allocation work needs to be kswapd aware
xfs: remove redundant geometry information from xfs_da_state
xfs: replace attr LBSIZE with xfs_da_geometry
xfs: pass xfs_da_args to xfs_attr_leaf_newentsize
xfs: use xfs_da_geometry for block size in attr code
xfs: remove mp->m_dir_geo from directory logging
xfs: reduce direct usage of mp->m_dir_geo
xfs: move node entry counts to xfs_da_geometry
xfs: convert dir/attr btree threshold to xfs_da_geometry
xfs: convert m_dirblksize to xfs_da_geometry
xfs: convert m_dirblkfsbs to xfs_da_geometry
xfs: convert directory segment limits to xfs_da_geometry
xfs: convert directory db conversion to xfs_da_geometry
xfs: convert directory dablk conversion to xfs_da_geometry
The kernel has no concept of capabilities with respect to inodes; inodes
exist independently of namespaces. For example, inode_capable(inode,
CAP_LINUX_IMMUTABLE) would be nonsense.
This patch changes inode_capable to check for uid and gid mappings and
renames it to capable_wrt_inode_uidgid, which should make it more
obvious what it does.
Fixes CVE-2014-4014.
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Serge Hallyn <serge.hallyn@ubuntu.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: stable@vger.kernel.org
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
fs/xfs/xfs_inode.c
mkfs has turned on the XFS_SB_VERSION_NLINKBIT feature bit by
default since November 2007. It's about time we simply made the
kernel code turn it on by default and so always convert v1 inodes to
v2 inodes when reading them in from disk or allocating them. This
This removes needless version checks and modification when bumping
link counts on inodes, and will take code out of a few common code
paths.
783251 100867 616 884734 d7ffe fs/xfs/xfs.o.orig
782664 100867 616 884147 d7db3 fs/xfs/xfs.o.patched
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
xfs_{compat_,}attrmulti_by_handle could return an errno with incorrect
sign in some cases. While at it, make sure ENOMEM is returned instead of
E2BIG if kmalloc fails.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Some time ago, mkfs.xfs started picking the storage physical
sector size as the default filesystem "sector size" in order
to avoid RMW costs incurred by doing IOs at logical sector
size alignments.
However, this means that for a filesystem made with i.e.
a 4k sector size on an "advanced format" 4k/512 disk,
512-byte direct IOs are no longer allowed. This means
that XFS has essentially turned this AF drive into a hard
4K device, from the filesystem on up.
XFS's mkfs-specified "sector size" is really just controlling
the minimum size & alignment of filesystem metadata.
There is no real need to tightly couple XFS's minimal
metadata size to the minimum allowed direct IO size;
XFS can continue doing metadata in optimal sizes, but
still allow smaller DIOs for apps which issue them,
for whatever reason.
This patch adds a new field to the xfs_buftarg, so that
we now track 2 sizes:
1) The metadata sector size, which is the minimum unit and
alignment of IO which will be performed by metadata operations.
2) The device logical sector size
The first is used internally by the file system for metadata
alignment and IOs.
The second is used for the minimum allowed direct IO alignment.
This has passed xfstests on filesystems made with 4k sectors,
including when run under the patch I sent to ignore
XFS_IOC_DIOINFO, and issue 512 DIOs anyway. I also directly
tested end of block behavior on preallocated, sparse, and
existing files when we do a 512 IO into a 4k file on a
4k-sector filesystem, to be sure there were no unexpected
behaviors.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
In preparation for adding new members to the structure,
give these old ones more descriptive names:
bt_ssize -> bt_meta_sectorsize
bt_smask -> bt_meta_sectormask
Clean up the xfs_buftarg structure a bit:
- remove bt_bsize which is never used
- replace bt_sshift with bt_ssize; we only ever shift it back
Both the inode number and the generation do not change on a live inode.
If we allocate less than sizeof(struct attrlist) then we end up
corrupting memory or doing a ZERO_PTR_SIZE dereference.
This can only be triggered with CAP_SYS_ADMIN.
Reported-by: Nico Golde <nico@ngolde.de>
Reported-by: Fabian Yamaguchi <fabs@goesec.de>
Currently the xfs_inode.h header has a dependency on the definition
of the BMAP btree records as the inode fork includes an array of
xfs_bmbt_rec_host_t objects in it's definition.
Move all the btree format definitions from xfs_btree.h,
xfs_bmap_btree.h, xfs_alloc_btree.h and xfs_ialloc_btree.h to
xfs_format.h to continue the process of centralising the on-disk
format definitions. With this done, the xfs inode definitions are no
longer dependent on btree header files.
The enables a massive culling of unnecessary includes, with close to
200 #include directives removed from the XFS kernel code base.
Reviewed-by: Ben Myers <bpm@sgi.com>
xfs_trans.h has a dependency on xfs_log.h for a couple of
structures. Most code that does transactions doesn't need to know
anything about the log, but this dependency means that they have to
include xfs_log.h. Decouple the xfs_trans.h and xfs_log.h header
files and clean up the includes to be in dependency order.
In doing this, remove the direct include of xfs_trans_reserve.h from
xfs_trans.h so that we remove the dependency between xfs_trans.h and
xfs_mount.h. Hence the xfs_trans.h include can be moved to the
indicate the actual dependencies other header files have on it.
Note that these are kernel only header files, so this does not
translate to any userspace changes at all.
All of the buffer operations structures are needed to be exported
for xfs_db, so move them all to a common location rather than
spreading them all over the place. They are verifying the on-disk
format, so while xfs_format.h might be a good place, it is not part
of the on disk format.
Hence we need to create a new header file that we centralise these
related definitions. Start by moving the bffer operations
structures, and then also move all the other definitions that have
crept into xfs_log_format.h and xfs_format.h as there was no other
shared header file to put them in.
Now that only one caller of xfs_change_file_space is left it can be merged
into said caller.
Currently fallocate always holds the iolock when calling into
xfs_change_file_space, while the ioctl path lets some of the lower level
functions take it, but leave it out in others.
This patch makes sure the ioctl path also always holds the iolock and
thus introduces consistent locking for the preallocation operations while
simplifying the code and allowing to kill the now unused XFS_ATTR_NOLOCK
flag.
We have quite a few places now where we do:
x = kmem_zalloc(large size)
if (!x)
x = kmem_zalloc_large(large size)
and do a similar dance when freeing the memory. kmem_free() already
does the correct freeing dance, and kmem_zalloc_large() is only ever
called in these constructs, so just factor it all into
kmem_zalloc_large() and kmem_free().
Reviewed-by: Mark Tinguely <tinguely@sgi.com>
A couple of simple locking annotations and 0 vs NULL warnings.
Nothing that changes any code behaviour, just removes build noise.
Check for CAP_SYS_ADMIN since the caller can truncate preallocated
blocks from files they do not own nor have write access to. A more
fine grained access check was considered: require the caller to
specify their own uid/gid and to use inode_permission to check for
write, but this would not catch the case of an inode not reachable
via path traversal from the callers mount namespace.
Add check for read-only filesystem to free eofblocks ioctl.
Reviewed-by: Gao feng <gaofeng@cn.fujitsu.com>
Signed-off-by: Dwight Engen <dwight.engen@oracle.com>
Have eofblocks ioctl convert uid_t to kuid_t into internal structure.
Update internal filter matching to compare ids with kuid_t types.
Use inode_capable() to check if SUID|SGID bits should be cleared to match
similar check in inode_change_ok().
The check for CAP_LINUX_IMMUTABLE was not modified since all other file
systems also check against init_user_ns rather than current_user_ns.
Only allow changing of projid from init_user_ns.
With the new xfs_trans_res structure has been introduced, the log
reservation size, log count as well as log flags are pre-initialized
at mount time. So it's time to refine xfs_trans_reserve() interface
to be more neat.
Also, introduce a new helper M_RES() to return a pointer to the
mp->m_resv structure to simplify the input.
Signed-off-by: Jie Liu <jeff.liu@oracle.com>
So we don't need xfs_dfrag.h in userspace anymore, move the extent
swap ioctl structure definition to xfs_fs.h where most of the other
ioctl structure definitions are.
Now that we don't need separate files for extent swapping, separate
the basic file descriptor checking code to xfs_ioctl.c, and the code
that does the extent swap operation to xfs_bmap_util.c. This
cleanly separates the user interface code from the physical
mechanism used to do the extent swap.
There are a few small helper functions in xfs_util, all related to
xfs_inode modifications. Move them all to xfs_inode.c so all
xfs_inode operations are consiolidated in the one place.
Now we have xfs_inode.c for holding kernel-only XFS inode
operations, move all the inode operations from xfs_vnodeops.c to
this new file as it holds another set of kernel-only inode
operations. The name of this file traces back to the days of Irix
and it's vnodes which we don't have anymore.
Essentially this move consolidates the inode locking functions
and a bunch of XFS inode operations into the one file. Eventually
the high level functions will be merged into the VFS interface
functions in xfs_iops.c.
This leaves only internal preallocation, EOF block manipulation and
hole punching functions in vnodeops.c. Move these to xfs_bmap_util.c
where we are already consolidating various in-kernel physical extent
manipulation and querying functions.
There is a bunch of code in xfs_bmap.c that is kernel specific and
not shared with userspace. To minimise the difference between the
kernel and userspace code, shift this unshared code to
xfs_bmap_util.c, and the declarations to xfs_bmap_util.h.
The biggest issue here is xfs_bmap_finish() - userspace has it's own
definition of this function, and so we need to move it out of
xfs_bmap.[ch]. This means several other files need to include
xfs_bmap_util.h as well.
It also introduces and interesting dance for the stack switching
code in xfs_bmapi_allocate(). The stack switching/workqueue code is
actually moved to xfs_bmap_util.c, so that userspace can simply use
a #define in a header file to connect the dots without needing to
know about the stack switch code at all.
The on disk format definitions of the on-disk dquot, log formats and
quota off log formats are all intertwined with other definitions for
quotas. Separate them out into their own header file so they can
easily be shared with userspace.
Add project quota changes to all the places where group quota field
is used:
* add separate project quota members into various structures
* split project quota and group quotas so that instead of overriding
the group quota members incore, the new project quota members are
used instead
* get rid of usage of the OQUOTA flag incore, in favor of separate
group and project quota flags.
* add a project dquot argument to various functions.
Not using the pquotino field from superblock yet.
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Macro get_unused_fd() is used to allocate a file descriptor with
default flags. Those default flags (0) can be "unsafe":
O_CLOEXEC must be used by default to not leak file descriptor
across exec().
Instead of macro get_unused_fd(), functions anon_inode_getfd()
or get_unused_fd_flags() should be used with flags given by userspace.
If not possible, flags should be set to O_CLOEXEC to provide userspace
with a default safe behavor.
In a further patch, get_unused_fd() will be removed so that
new code start using anon_inode_getfd() or get_unused_fd_flags()
with correct flags.
This patch replaces calls to get_unused_fd() with equivalent call to
get_unused_fd_flags(0) to preserve current behavor for existing code.
The hard coded flag value (0) should be reviewed on a per-subsystem basis,
and, if possible, set to O_CLOEXEC.
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
Shamelessly copied from dchinner's:
ad650f5b xfs: fallback to vmalloc for large buffers in xfs_attrmulti_attr_get
xfsdump uses for a large buffer for extended attributes, which has a
kmalloc'd shadow buffer in the kernel. This can fail after the
system has been running for some time as it is a high order
allocation. Add a fallback to vmalloc so that it doesn't require
contiguous memory and so won't randomly fail while xfsdump is
running.
Support inode ID filtering in the eofblocks scan. The caller must
set the associated XFS_EOF_FLAGS_*ID bit and ID field.
Signed-off-by: Brian Foster <bfoster@redhat.com>
The XFS_IOC_FREE_EOFBLOCKS ioctl allows users to invoke an EOFBLOCKS
scan. The xfs_eofblocks structure is defined to support the command
parameters (scan mode).
Uninitialised variable build warning introduced by 2903ff0 ("switch
simple cases of fget_light to fdget"), gcc is not smart enough to
work out that the variable is not used uninitialised, and the commit
removed the initialisation at declaration that the old variable had.
Generic code now blocks all writers from standard write paths. So we add
blocking of all writers coming from ioctl (we get a protection of ioctl against
racing remount read-only as a bonus) and convert xfs_file_aio_write() to a
non-racy freeze protection. We also keep freeze protection on transaction
start to block internal filesystem writes such as removal of preallocated
blocks.
CC: Ben Myers <bpm@sgi.com>
CC: Alex Elder <elder@kernel.org>
CC: xfs@oss.sgi.com
With the removal of xfs_rw.h and other changes over time, xfs_bit.h
is being included in many files that don't actually need it. Clean
up the includes as necessary.
Also move the only-used-once xfs_ialloc_find_free() static inline
function out of a header file that is widely included to reduce
the number of needless dependencies on xfs_bit.h.
Untangle the header file includes a bit by moving the definition of
xfs_agino_t to xfs_types.h. This removes the dependency that xfs_ag.h has on
xfs_inum.h, meaning we don't need to include xfs_inum.h everywhere we include
xfs_ag.h.
Sparse identified some unsafe handling of open flags in the xfs open
by handle ioctl code. Update the code to use the correct access
macros to ensure that we handle the open flags correctly.
running.
new helper (wrapper around mnt_drop_write()) to be used in pair with
mnt_want_write_file().
it's both faster (in case when file has been opened for write) and cleaner.
There is no reason to keep a reference to the inode even if we unlock
it during transaction commit because we never drop a reference between
the ijoin and commit. Also use this fact to merge xfs_trans_ijoin_ref
back into xfs_trans_ijoin - the third argument decides if an unlock
is needed now.
I'm actually starting to wonder if allowing inodes to be unlocked
at transaction commit really is worth the effort. The only real
benefit is that they can be unlocked earlier when commiting a
synchronous transactions, but that could be solved by doing the
log force manually after the unlock, too.
Signed-off-by: Alex Elder <aelder@sgi.com>
Use the move from Linux 2.6 to Linux 3.x as an excuse to kill the
annoying subdirectories in the XFS source code. Besides the large
amount of file rename the only changes are to the Makefile, a few
files including headers with the subdirectory prefix, and the binary
sysctl compat code that includes a header under fs/xfs/ from
kernel/.
