path: root/fs/xfs/xfs_inode.h
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-08-13[XFS] update timestamp in xfs_ialloc manuallyChristoph Hellwig
In xfs_ialloc we just want to set all timestamps to the current time. We don't need to mark the inode dirty like xfs_ichgtime does, and we don't need nor want the opimizations in xfs_ichgtime that I will introduce in the next patch. So just opencode the timestamp update in xfs_ialloc, and remove the new unused XFS_ICHGTIME_ACC case in xfs_ichgtime. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31825a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] replace inode flush semaphore with a completionDavid Chinner
Use the new completion flush code to implement the inode flush lock. Removes one of the final users of semaphores in the XFS code base. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31817a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] kill bhv_vnode_tChristoph Hellwig
All remaining bhv_vnode_t instance are in code that's more or less Linux specific. (Well, for xfs_acl.c that could be argued, but that code is on the removal list, too). So just do an s/bhv_vnode_t/struct inode/ over the whole tree. We can clean up variable naming and some useless helpers later. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31781a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] kill xfs_lock_dir_and_entryChristoph Hellwig
When multiple inodes are locked in XFS it happens in order of the inode number, with the everything but the first inode trylocked if any of the previous inodes is in the AIL. Except for the sorting of the inodes this logic is implemented in xfs_lock_inodes, but also partially duplicated in xfs_lock_dir_and_entry in a particularly stupid way adds a lock roundtrip if the inode ordering is not optimal. This patch adds a new helper xfs_lock_two_inodes that takes two inodes and locks them in the most optimal way according to the above locking protocol and uses it for all places that want to lock two inodes. The only caller of xfs_lock_inodes is xfs_rename which might lock up to four inodes. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31772a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] XFS: Kill xfs_vtoi()David Chinner
xfs_vtoi() is redundant and only unsed in small sections of code. Replace them with widely used XFS_I() inline and kill xfs_vtoi(). SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31725a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] Kill shouty XFS_ITOV() macroDavid Chinner
Replace XFS_ITOV() with the new VFS_I() inline. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31724a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] kill shouty XFS_ITOV_NULL macroDavid Chinner
Replace XFS_ITOV_NULL() with the new VFS_I() inline. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31722a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] Avoid directly referencing the VFS inode.David Chinner
In several places we directly convert from the XFS inode to the linux (VFS) inode by a simple deference of ip->i_vnode. We should not do this - a helper function should be used to extract the VFS inode from the XFS inode. Introduce the function VFS_I() to extract the VFS inode from the XFS inode. The name was chosen to match XFS_I() which is used to extract the XFS inode from the VFS inode. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31720a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] kill xfs_igrow_start and xfs_igrow_finishChristoph Hellwig
xfs_igrow_start just expands to xfs_zero_eof with two asserts that are useless in the context of the only caller and some rather confusing comments. xfs_igrow_finish is just a few lines of code decorated again with useless asserts and confusing comments. Just kill those two and merge them into xfs_setattr. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31186a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-29[XFS] remove manual lookup from xfs_rename and simplify lockingChristoph Hellwig
->rename already gets the target inode passed if it exits. Pass it down to xfs_rename so that we can avoid looking it up again. Also simplify locking as the first lock section in xfs_rename can go away now: the isdir is an invariant over the lifetime of the inode, and new_parent and the nlink check are namespace topology protected by i_mutex in the VFS. The projid check needs to move into the second lock section anyway to not be racy. Also kill the now unused xfs_dir_lookup_int and remove the now-unused first_locked argumet to xfs_lock_inodes. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30903a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-29[XFS] shrink mrlock_tChristoph Hellwig
The writer field is not needed for non_DEBU builds so remove it. While we're at i also clean up the interface for is locked asserts to go through and xfs_iget.c helper with an interface like the xfs_ilock routines to isolated the XFS codebase from mrlock internals. That way we can kill mrlock_t entirely once rw_semaphores grow an islocked facility. Also remove unused flags to the ilock family of functions. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30902a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Remove the xfs_icluster structureDavid Chinner
Remove the xfs_icluster structure and replace with a radix tree lookup. We don't need to keep a list of inodes in each cluster around anymore as we can look them up quickly when we need to. The only time we need to do this now is during inode writeback. Factor the inode cluster writeback code out of xfs_iflush and convert it to use radix_tree_gang_lookup() instead of walking a list of inodes built when we first read in the inodes. This remove 3 pointers from each xfs_inode structure and the xfs_icluster structure per inode cluster. Hence we reduce the cache footprint of the xfs_inodes by between 5-10% depending on cluster sparseness. To be truly efficient we need a radix_tree_gang_lookup_range() call to stop searching once we are past the end of the cluster instead of trying to find a full cluster's worth of inodes. Before (ia64): $ cat /sys/slab/xfs_inode/object_size 536 After: $ cat /sys/slab/xfs_inode/object_size 512 SGI-PV: 977460 SGI-Modid: xfs-linux-melb:xfs-kern:30502a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Don't block pdflush when writing back inodesDavid Chinner
When pdflush is writing back inodes, it can get stuck on inode cluster buffers that are currently under I/O. This occurs when we write data to multiple inodes in the same inode cluster at the same time. Effectively, delayed allocation marks the inode dirty during the data writeback. Hence if the inode cluster was flushed during the writeback of the first inode, the writeback of the second inode will block waiting for the inode cluster write to complete before writing it again for the newly dirtied inode. Basically, we want to avoid this from happening so we don't block pdflush and slow down all of writeback. Hence we introduce a non-blocking async inode flush flag that pdflush uses. If this flag is set, we use non-blocking operations (e.g. try locks) whereever we can to avoid blocking or extra I/O being issued. SGI-PV: 970925 SGI-Modid: xfs-linux-melb:xfs-kern:30501a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Remove the xfs_refcacheDonald Douwsma
Remove the xfs_refcache, it was only needed while we were still building for 2.4 kernels. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:30472a Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] use generic_permissionChristoph Hellwig
Now that all direct caller of xfs_iaccess are gone we can kill xfs_iaccess and xfs_access and just use generic_permission with a check_acl callback. This is required for the per-mount read-only patchset in -mm to work properly with XFS. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:30370a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] Remove CFORK macros and use code directly in IFORK and DFORK macros.Christoph Hellwig
Currently XFS_IFORK_* and XFS_DFORK* are implemented by means of XFS_CFORK* macros. But given that XFS_IFORK_* operates on an xfs_inode that embedds and xfs_icdinode_core and XFS_DFORK_* operates on an xfs_dinode that embedds a xfs_dinode_core one will have to do endian swapping while the other doesn't. Instead of having the current mess with the CFORK macros that have byteswapping and non-byteswapping version (which are inconsistantly named while we're at it) just define each family of the macros to stand by itself and simplify the whole matter. A few direct references to the CFORK variants were cleaned up to use IFORK or DFORK to make this possible. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:30163a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] Use kernel-supplied "roundup_pow_of_two" for simplicityRobert P. J. Day
SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:30098a Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] Fix inode allocation latencyDavid Chinner
The log force added in xfs_iget_core() has been a performance issue since it was introduced for tight loops that allocate then unlink a single file. under heavy writeback, this can introduce unnecessary latency due tothe log I/o getting stuck behind bulk data writes. Fix this latency problem by avoinding the need for the log force by moving the place we mark linux inode dirty to the transaction commit rather than on transaction completion. This also closes a potential hole in the sync code where a linux inode is not dirty between the time it is modified and the time the log buffer has been written to disk. SGI-PV: 972753 SGI-Modid: xfs-linux-melb:xfs-kern:30007a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] cleanup vnode useage in xfs_iget.cChristoph Hellwig
Get rid of vnode useage in xfs_iget.c and pass Linux inode / xfs_inode where apropinquate. And kill some useless helpers while we're at it. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:29808a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2008-02-07[XFS] kill xfs_iocore_tChristoph Hellwig
xfs_iocore_t is a structure embedded in xfs_inode. Except for one field it just duplicates fields already in xfs_inode, and there is nothing this abstraction buys us on XFS/Linux. This patch removes it and shrinks source and binary size of xfs aswell as shrinking the size of xfs_inode by 60/44 bytes in debug/non-debug builds. SGI-PV: 970852 SGI-Modid: xfs-linux-melb:xfs-kern:29754a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2008-02-07[XFS] Cleanup lock goop.Eric Sandeen
Switch last couple lock_t's to spinlock_t's. Remove now-unused spinlock-related macros & types. SGI-PV: 970382 SGI-Modid: xfs-linux-melb:xfs-kern:29748a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2008-02-07[XFS] clean up vnode/inode tracingLachlan McIlroy
Simplify vnode tracing calls by embedding function name & return addr in the calling macro. Also do a lot of vnode->inode renaming for consistency, while we're at it. SGI-PV: 970335 SGI-Modid: xfs-linux-melb:xfs-kern:29650a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] kill the vfs_flags member in struct bhv_vfsChristoph Hellwig
All flags are added to xfs_mount's m_flag instead. Note that the 32bit inode flag was duplicated in both of them, but only cleared in the mount when it was not nessecary due to the filesystem beeing small enough. Two flags are still required here - one to indicate the mount option setting, and one to indicate if it applies or not. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29507a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] kill struct bhv_vnodeChristoph Hellwig
Now that struct bhv_vnode is empty we can just kill it. Retain bhv_vnode_t as a typedef for struct inode for the time being until all the fallout is cleaned up. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29500a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] move v_trace from bhv_vnode to xfs_inodeChristoph Hellwig
struct bhv_vnode is on it's way out, so move the trace buffer to the XFS inode. Note that this makes the tracing macros rather misnamed, but this kind of fallout will be fixed up incrementally later on. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29498a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] move v_iocount from bhv_vnode to xfs_inodeChristoph Hellwig
struct bhv_vnode is on it's way out, so move the I/O count to the XFS inode. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29497a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] Create xfs_iflags_test_and_clear helper functionChristoph Hellwig
SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29496a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] kill the v_flag member in struct bhv_vnodeChristoph Hellwig
All flags previously handled at the vnode level are not in the xfs_inode where we already have a flags mechanisms and free bits for flags previously in the vnode. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29495a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] call common xfs vnode-level helpers directly and remove vnode operationsChristoph Hellwig
SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29493a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] Radix tree based inode cachingDavid Chinner
One of the perpetual scaling problems XFS has is indexing it's incore inodes. We currently uses hashes and the default hash sizes chosen can only ever be a tradeoff between memory consumption and the maximum realistic size of the cache. As a result, anyone who has millions of inodes cached on a filesystem needs to tunes the size of the cache via the ihashsize mount option to allow decent scalability with inode cache operations. A further problem is the separate inode cluster hash, whose size is based on the ihashsize but is smaller, and so under certain conditions (sparse cluster cache population) this can become a limitation long before the inode hash is causing issues. The following patchset removes the inode hash and cluster hash and replaces them with radix trees to avoid the scalability limitations of the hashes. It also reduces the size of the inodes by 3 pointers.... SGI-PV: 969561 SGI-Modid: xfs-linux-melb:xfs-kern:29481a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] dinode endianess annotationsChristoph Hellwig
Biggest bit is duplicating the dinode structure so we have one annotated for native endianess and one for disk endianess. The other significant change is that xfs_xlate_dinode_core is split into one helper per direction to allow for proper annotations, everything else is trivial. As a sidenode splitting out the incore dinode means we can move it into xfs_inode.h in a later patch and severely improving on the include hell in xfs. SGI-PV: 968563 SGI-Modid: xfs-linux-melb:xfs-kern:29476a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] split ondisk vs incore versions of xfs_bmbt_rec_tChristoph Hellwig
currently xfs_bmbt_rec_t is used both for ondisk extents as well as host-endian ones. This patch adds a new xfs_bmbt_rec_host_t for the native endian ones and cleans up the fallout. There have been various endianess issues in the tracing / debug printf code that are fixed by this patch. SGI-PV: 968563 SGI-Modid: xfs-linux-melb:xfs-kern:29318a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-07-14[XFS] Fix lockdep annotations for xfs_lock_inodesDavid Chinner
SGI-PV: 967035 SGI-Modid: xfs-linux-melb:xfs-kern:29026a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-07-14[XFS] Concurrent Multi-File Data StreamsDavid Chinner
In media spaces, video is often stored in a frame-per-file format. When dealing with uncompressed realtime HD video streams in this format, it is crucial that files do not get fragmented and that multiple files a placed contiguously on disk. When multiple streams are being ingested and played out at the same time, it is critical that the filesystem does not cross the streams and interleave them together as this creates seek and readahead cache miss latency and prevents both ingest and playout from meeting frame rate targets. This patch set creates a "stream of files" concept into the allocator to place all the data from a single stream contiguously on disk so that RAID array readahead can be used effectively. Each additional stream gets placed in different allocation groups within the filesystem, thereby ensuring that we don't cross any streams. When an AG fills up, we select a new AG for the stream that is not in use. The core of the functionality is the stream tracking - each inode that we create in a directory needs to be associated with the directories' stream. Hence every time we create a file, we look up the directories' stream object and associate the new file with that object. Once we have a stream object for a file, we use the AG that the stream object point to for allocations. If we can't allocate in that AG (e.g. it is full) we move the entire stream to another AG. Other inodes in the same stream are moved to the new AG on their next allocation (i.e. lazy update). Stream objects are kept in a cache and hold a reference on the inode. Hence the inode cannot be reclaimed while there is an outstanding stream reference. This means that on unlink we need to remove the stream association and we also need to flush all the associations on certain events that want to reclaim all unreferenced inodes (e.g. filesystem freeze). SGI-PV: 964469 SGI-Modid: xfs-linux-melb:xfs-kern:29096a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Vlad Apostolov <vapo@sgi.com>
2007-05-08[XFS] Add lockdep support for XFSLachlan McIlroy
SGI-PV: 963965 SGI-Modid: xfs-linux-melb:xfs-kern:28485a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] Fix to prevent the notorious 'NULL files' problem after a crash.Lachlan McIlroy
The problem that has been addressed is that of synchronising updates of the file size with writes that extend a file. Without the fix the update of a file's size, as a result of a write beyond eof, is independent of when the cached data is flushed to disk. Often the file size update would be written to the filesystem log before the data is flushed to disk. When a system crashes between these two events and the filesystem log is replayed on mount the file's size will be set but since the contents never made it to disk the file is full of holes. If some of the cached data was flushed to disk then it may just be a section of the file at the end that has holes. There are existing fixes to help alleviate this problem, particularly in the case where a file has been truncated, that force cached data to be flushed to disk when the file is closed. If the system crashes while the file(s) are still open then this flushing will never occur. The fix that we have implemented is to introduce a second file size, called the in-memory file size, that represents the current file size as viewed by the user. The existing file size, called the on-disk file size, is the one that get's written to the filesystem log and we only update it when it is safe to do so. When we write to a file beyond eof we only update the in- memory file size in the write operation. Later when the I/O operation, that flushes the cached data to disk completes, an I/O completion routine will update the on-disk file size. The on-disk file size will be updated to the maximum offset of the I/O or to the value of the in-memory file size if the I/O includes eof. SGI-PV: 958522 SGI-Modid: xfs-linux-melb:xfs-kern:28322a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] propogate return codes from flush routinesLachlan McIlroy
This patch handles error return values in fs_flush_pages and fs_flushinval_pages. It changes the prototype of fs_flushinval_pages so we can propogate the errors and handle them at higher layers. I also modified xfs_itruncate_start so that it could propogate the error further. SGI-PV: 961990 SGI-Modid: xfs-linux-melb:xfs-kern:28231a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Stewart Smith <stewart@flamingspork.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-11-11[XFS] Clean up i_flags and i_flags_lock handling.David Chinner
SGI-PV: 956832 SGI-Modid: xfs-linux-melb:xfs-kern:27358a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Nathan Scott <nscott@aconex.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Really fix use after free in xfs_iunpin.David Chinner
The previous attempts to fix the linux inode use-after-free in xfs_iunpin simply made the problem harder to hit. We actually need complete exclusion between xfs_reclaim and xfs_iunpin, as well as ensuring that the i_flags are consistent during both of these functions. Introduce a new spinlock for exclusion and the i_flags, and fix up xfs_iunpin to use igrab before marking the inode dirty. SGI-PV: 952967 SGI-Modid: xfs-linux-melb:xfs-kern:26964a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Remove last bulkstat false-positives with debug kernels.Nathan Scott
SGI-PV: 953819 SGI-Modid: xfs-linux-melb:xfs-kern:26628a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-09[XFS] Resolve a namespace collision on vnode/vnodeops for FreeBSD porters.Nathan Scott
SGI-PV: 953338 SGI-Modid: xfs-linux-melb:xfs-kern:26107a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Resolve a namespace collision on vfs/vfsops for FreeBSD porters.Nathan Scott
SGI-PV: 9533338 SGI-Modid: xfs-linux-melb:xfs-kern:26106a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-04-11[XFS] Fix inode reclaim scalability regression. When a filesystem hasDavid Chinner
millions of inodes cached and has sparse cluster population, removing inodes from the cluster hash consumes excessive amounts of CPU time. Reduce the CPU cost by making removal O(1) via use of a double linked list for the hash chains. SGI-PV: 951551 SGI-Modid: xfs-linux-melb:xfs-kern:25683a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] Fix an infinite loop issue in bulkstat when a corrupt inode isNathan Scott
detected. Thanks to Roger Willcocks. SGI-PV: 951054 SGI-Modid: xfs-linux-melb:xfs-kern:25477a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] There are a few problems with the newMandy Kirkconnell
xfs_bmap_search_multi_extents() wrapper function that I introduced in mod xfs-linux:xfs-kern:207393a. The function was added as a wrapper around xfs_bmap_do_search_extents() to avoid breaking the top-of-tree CXFS interface. The idea of the function was basically to extract the target extent buffer (if muli- level extent allocation mode), then call xfs_bmap_do_search_extents() with either a pointer to the first extent in the target buffer or a pointer to the first extent in the file, depending on which extent mode was being used. However, in addition to locating the target extent record for block bno, xfs_bmap_do_search_extents() also sets four parameters needed by the caller: *lastx, *eofp, *gotp, *prevp. Passing only the target extent buffer to xfs_bmap_do_search_extents() causes *eofp to be set incorrectly if the extent is at the end of the target list but there are actually more extents in the next er_extbuf. Likewise, if the extent is the first one in the buffer but NOT the first in the file, *prevp is incorrectly set to NULL. Adding the needed functionality to xfs_bmap_search_multi_extents() to re-set any incorrectly set fields is redundant and makes the call to xfs_bmap_do_search_extents() not make much sense when multi-level extent allocation mode is being used. This mod basically extracts the two functional components from xfs_bmap_do_search_extents(), with the intent of obsoleting/removing xfs_bmap_do_search_extents() after the CXFS mult-level in-core extent changes are checked in. The two components are: 1) The binary search to locate the target extent record, and 2) Setting the four parameters needed by the caller (*lastx, *eofp, *gotp, *prevp). Component 1: I created a new function in xfs_inode.c called xfs_iext_bno_to_ext(), which executes the binary search to find the target extent record. xfs_bmap_search_multi_extents() has been modified to call xfs_iext_bno_to_ext() rather than xfs_bmap_do_search_extents(). Component 2: The parameter setting functionality has been added to xfs_bmap_search_multi_extents(), eliminating the need for xfs_bmap_do_search_extents(). These changes make the removal of xfs_bmap_do_search_extents() trival once the CXFS changes are in place. They also allow us to maintain the current XFS interface, using the new search function introduced in mod xfs-linux:xfs-kern:207393a. SGI-PV: 928864 SGI-Modid: xfs-linux-melb:xfs-kern:207866a Signed-off-by: Mandy Kirkconnell <alkirkco@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-14[XFS] 929045 567344 This mod introduces multi-level in-core file extentMandy Kirkconnell
functionality, building upon the new layout introduced in mod xfs-linux:xfs-kern:207390a. The new multi-level extent allocations are only required for heavily fragmented files, so the old-style linear extent list is used on files until the extents reach a pre-determined size of 4k. 4k buffers are used because this is the system page size on Linux i386 and systems with larger page sizes don't seem to gain much, if anything, by using their native page size as the extent buffer size. Also, using 4k extent buffers everywhere provides a consistent interface for CXFS across different platforms. The 4k extent buffers are managed by an indirection array (xfs_ext_irec_t) which is basically just a pointer array with a bit of extra information to keep track of the number of extents in each buffer as well as the extent offset of each buffer. Major changes include: - Add multi-level in-core file extent functionality to the xfs_iext_ subroutines introduced in mod: xfs-linux:xfs-kern:207390a - Introduce 13 new subroutines which add functionality for multi-level in-core file extents: xfs_iext_add_indirect_multi() xfs_iext_remove_indirect() xfs_iext_realloc_indirect() xfs_iext_indirect_to_direct() xfs_iext_bno_to_irec() xfs_iext_idx_to_irec() xfs_iext_irec_init() xfs_iext_irec_new() xfs_iext_irec_remove() xfs_iext_irec_compact() xfs_iext_irec_compact_pages() xfs_iext_irec_compact_full() xfs_iext_irec_update_extoffs() SGI-PV: 928864 SGI-Modid: xfs-linux-melb:xfs-kern:207393a Signed-off-by: Mandy Kirkconnell <alkirkco@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-14[XFS] 929045 567344 This mod re-organizes some of the in-core file extentMandy Kirkconnell
code to prepare for an upcoming mod which will introduce multi-level in-core extent allocations. Although the in-core extent management is using a new code path in this mod, the functionality remains the same. Major changes include: - Introduce 10 new subroutines which re-orgainze the existing code but do NOT change functionality: xfs_iext_get_ext() xfs_iext_insert() xfs_iext_add() xfs_iext_remove() xfs_iext_remove_inline() xfs_iext_remove_direct() xfs_iext_realloc_direct() xfs_iext_direct_to_inline() xfs_iext_inline_to_direct() xfs_iext_destroy() - Remove 2 subroutines (functionality moved to new subroutines above): xfs_iext_realloc() -replaced by xfs_iext_add() and xfs_iext_remove() xfs_bmap_insert_exlist() - replaced by xfs_iext_insert() xfs_bmap_delete_exlist() - replaced by xfs_iext_remove() - Replace all hard-coded (indexed) extent assignments with a call to xfs_iext_get_ext() - Replace all extent record pointer arithmetic (ep++, ep--, base + lastx,..) with calls to xfs_iext_get_ext() - Update comments to remove the idea of a single "extent list" and introduce "extent record" terminology instead SGI-PV: 928864 SGI-Modid: xfs-linux-melb:xfs-kern:207390a Signed-off-by: Mandy Kirkconnell <alkirkco@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] add helper to get xfs_inode from vnodeChristoph Hellwig
SGI-PV: 947206 SGI-Modid: xfs-linux-melb:xfs-kern:203960a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] fix, speedup and simplify atime handling let the VFS handle atimeChristoph Hellwig
updates and only sync back to the xfs inode when nessecary SGI-PV: 946679 SGI-Modid: xfs-linux-melb:xfs-kern:203362a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
