path: root/fs/xfs/xfs_iget.c
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-19[XFS] Kill direct access to ->count in valusema(); all we ever use it forAl Viro
is check if semaphore is actually locked, which can be trivially done in portable way. Code gets more reabable, while we are at it... SGI-PV: 953915 SGI-Modid: xfs-linux-melb:xfs-kern:26274a Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Resolve a namespace collision on vnode/vnodeops for FreeBSD porters.Nathan Scott
SGI-PV: 953338 SGI-Modid: xfs-linux-melb:xfs-kern:26107a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Resolve a namespace collision on vfs/vfsops for FreeBSD porters.Nathan Scott
SGI-PV: 9533338 SGI-Modid: xfs-linux-melb:xfs-kern:26106a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-04-11[XFS] Fix inode reclaim scalability regression. When a filesystem hasDavid Chinner
millions of inodes cached and has sparse cluster population, removing inodes from the cluster hash consumes excessive amounts of CPU time. Reduce the CPU cost by making removal O(1) via use of a double linked list for the hash chains. SGI-PV: 951551 SGI-Modid: xfs-linux-melb:xfs-kern:25683a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-29[XFS] We really suck at spulling. Thanks to Chris Pascoe for fixing allNathan Scott
these typos. SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:25539a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] Complete transition away from linvfs naming convention, finally.Nathan Scott
SGI-PV: 947038 SGI-Modid: xfs-linux-melb:xfs-kern:25474a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] add helper to get xfs_inode from vnodeChristoph Hellwig
SGI-PV: 947206 SGI-Modid: xfs-linux-melb:xfs-kern:203960a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-09-05[XFS] Retry linux inode cacech lookup if we found a stale inode. ThisChristoph Hellwig
fixes crashes under high nfs load SGI-PV: 941429 SGI-Modid: xfs-linux:xfs-kern:197929a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-09-02[XFS] remove unessecary vnode flagsChristoph Hellwig
SGI-PV: 934766 SGI-Modid: xfs-linux:xfs-kern:196852a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-05-05[XFS] Move the XFS inode to the front of its hash list on a cache hitNathan Scott
SGI Modid: xfs-linux:xfs-kern:21915a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Christoph Hellwig <hch@sgi.com>
