path: root/fs/xfs/xfs_ialloc_btree.h
2014-06-25libxfs: move header filesDave Chinner
Move all the header files that are shared with userspace into libxfs. This is done as one big chunk simpy to get it done quickly. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-04-24xfs: refactor xfs_ialloc_btree.c to support multiple inobt numbersBrian Foster
The introduction of the free inode btree (finobt) requires that xfs_ialloc_btree.c handle multiple trees. Refactor xfs_ialloc_btree.c so the caller specifies the btree type on cursor initialization to prepare for addition of the finobt. Signed-off-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <david@fromorbit.com>
2013-10-23xfs: decouple inode and bmap btree header filesDave Chinner
Currently the xfs_inode.h header has a dependency on the definition of the BMAP btree records as the inode fork includes an array of xfs_bmbt_rec_host_t objects in it's definition. Move all the btree format definitions from xfs_btree.h, xfs_bmap_btree.h, xfs_alloc_btree.h and xfs_ialloc_btree.h to xfs_format.h to continue the process of centralising the on-disk format definitions. With this done, the xfs inode definitions are no longer dependent on btree header files. The enables a massive culling of unnecessary includes, with close to 200 #include directives removed from the XFS kernel code base. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-10-23xfs: create a shared header file for format-related informationDave Chinner
All of the buffer operations structures are needed to be exported for xfs_db, so move them all to a common location rather than spreading them all over the place. They are verifying the on-disk format, so while xfs_format.h might be a good place, it is not part of the on disk format. Hence we need to create a new header file that we centralise these related definitions. Start by moving the bffer operations structures, and then also move all the other definitions that have crept into xfs_log_format.h and xfs_format.h as there was no other shared header file to put them in. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-04-21xfs: add support for large btree blocksChristoph Hellwig
Add support for larger btree blocks that contains a CRC32C checksum, a filesystem uuid and block number for detecting filesystem consistency and out of place writes. [dchinner@redhat.com] Also include an owner field to allow reverse mappings to be implemented for improved repairability and a LSN field to so that log recovery can easily determine the last modification that made it to disk for each buffer. [dchinner@redhat.com] Add buffer log format flags to indicate the type of buffer to recovery so that we don't have to do blind magic number tests to determine what the buffer is. [dchinner@redhat.com] Modified to fit into the verifier structure. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-11-15xfs: convert buffer verifiers to an ops structure.Dave Chinner
To separate the verifiers from iodone functions and associate read and write verifiers at the same time, introduce a buffer verifier operations structure to the xfs_buf. This avoids the need for assigning the write verifier, clearing the iodone function and re-running ioend processing in the read verifier, and gets rid of the nasty "b_pre_io" name for the write verifier function pointer. If we ever need to, it will also be easier to add further content specific callbacks to a buffer with an ops structure in place. We also avoid needing to export verifier functions, instead we can simply export the ops structures for those that are needed outside the function they are defined in. This patch also fixes a directory block readahead verifier issue it exposed. This patch also adds ops callbacks to the inode/alloc btree blocks initialised by growfs. These will need more work before they will work with CRCs. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Phil White <pwhite@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2009-02-09xfs: remove superflous inobt macrosChristoph Hellwig
xfs_ialloc_btree.h has a a cuple of macros that only obsfucate the code but don't provide any abstraction benefits. This patches removes those and cleans up the reamaining defintions up a little. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com>
2009-01-16[XFS] Remove the rest of the macro-to-function indirections.Eric Sandeen
Remove the last of the macros-defined-to-static-functions. Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-10-30[XFS] Always use struct xfs_btree_block instead of short / longformChristoph Hellwig
structures. Always use the generic xfs_btree_block type instead of the short / long structures. Add XFS_BTREE_SBLOCK_LEN / XFS_BTREE_LBLOCK_LEN defines for the length of a short / long form block. The rationale for this is that we will grow more btree block header variants to support CRCs and other RAS information, and always accessing them through the same datatype with unions for the short / long form pointers makes implementing this much easier. SGI-PV: 988146 SGI-Modid: xfs-linux-melb:xfs-kern:32300a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-10-30[XFS] cleanup btree record / key / ptr addressing macros.Christoph Hellwig
Replace the generic record / key / ptr addressing macros that use cpp token pasting with simpler macros that do the job for just one given btree type. The new macros lose the cur argument and thus can be used outside the core btree code, but also gain an xfs_mount * argument to allow for checking the CRC flag in the near future. Note that many of these macros aren't actually used in the kernel code, but only in userspace (mostly in xfs_repair). SGI-PV: 988146 SGI-Modid: xfs-linux-melb:xfs-kern:32295a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-10-30[XFS] Cleanup maxrecs calculation.Christoph Hellwig
Clean up the way the maximum and minimum records for the btree blocks are calculated. For the alloc and inobt btrees all the values are pre-calculated in xfs_mount_common, and we switch the current loop around the ugly generic macros that use cpp token pasting to generate type names to two small helpers in normal C code. For the bmbt and bmdr trees these helpers also exist, but can be called during runtime, too. Here we also kill various macros dealing with them and inline the logic into the get_minrecs / get_maxrecs / get_dmaxrecs methods in xfs_bmap_btree.c. Note that all these new helpers take an xfs_mount * argument which will be needed to determine the size of a btree block once we add support for extended btree blocks with CRCs and other RAS information. SGI-PV: 988146 SGI-Modid: xfs-linux-melb:xfs-kern:32292a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-10-30[XFS] implement generic xfs_btree_get_recChristoph Hellwig
Not really much reason to make it generic given that it's so small, but this is the last non-method in xfs_alloc_btree.c and xfs_ialloc_btree.c, so it makes the whole btree implementation more structured. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32206a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_delete/delrecChristoph Hellwig
Make the btree delete code generic. Based on a patch from David Chinner with lots of changes to follow the original btree implementations more closely. While this loses some of the generic helper routines for inserting/moving/removing records it also solves some of the one off bugs in the original code and makes it easier to verify. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32205a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_insert/insrecChristoph Hellwig
Make the btree insert code generic. Based on a patch from David Chinner with lots of changes to follow the original btree implementations more closely. While this loses some of the generic helper routines for inserting/moving/removing records it also solves some of the one off bugs in the original code and makes it easier to verify. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32202a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_updateChristoph Hellwig
From: Dave Chinner <dgc@sgi.com> The most complicated part here is the lastrec tracking for the alloc btree. Most logic is in the update_lastrec method which has to do some hopefully good enough dirty magic to maintain it. [hch: split out from bigger patch and a rework of the lastrec logic] SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32194a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_lookupChristoph Hellwig
From: Dave Chinner <dgc@sgi.com> [hch: split out from bigger patch and minor adaptions] SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32192a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_decrementChristoph Hellwig
From: Dave Chinner <dgc@sgi.com> [hch: split out from bigger patch and minor adaptions] SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32191a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] implement generic xfs_btree_incrementChristoph Hellwig
From: Dave Chinner <dgc@sgi.com> Because this is the first major generic btree routine this patch includes some infrastrucure, first a few routines to deal with a btree block that can be either in short or long form, second xfs_btree_read_buf_block, which is the new central routine to read a btree block given a cursor, and third the new xfs_btree_ptr_addr routine to calculate the address for a given btree pointer record. [hch: split out from bigger patch and minor adaptions] SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32190a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-10-30[XFS] split up xfs_btree_init_cursorChristoph Hellwig
xfs_btree_init_cursor contains close to little shared code for the different btrees and will get even more non-common code in the future. Split it up into one routine per btree type. Because xfs_btree_dup_cursor needs to call the init routine for a generic btree cursor add a new btree operation vector that contains a dup_cursor method that initializes a new cursor based on an existing one. The btree operations vector is based on an idea and code from Dave Chinner and will grow more entries later during this series. SGI-PV: 985583 SGI-Modid: xfs-linux-melb:xfs-kern:32176a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Bill O'Donnell <billodo@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com>
2008-02-07[XFS] kill XFS_INOBT_IS_FREE_DISKChristoph Hellwig
This macro is unused an all other acros in this family operate on native types, so we most likely won't grow a user either. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:29846a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Remove unused arguments from the XFS_BTREE_*_ADDR macros.Eric Sandeen
It makes it incrementally clearer to read the code when the top of a macro spaghetti-pile only receives the 3 arguments it uses, rather than 2 extra ones which are not used. Also when you start pulling this thread out of the sweater (i.e. remove unused args from XFS_BTREE_*_ADDR), a couple other third arms etc fall off too. If they're not used in the macro, then they sometimes don't need to be passed to the function calling the macro either, etc.... Patch provided by Eric Sandeen (sandeen@sandeen.net). SGI-PV: 960197 SGI-Modid: xfs-linux-melb:xfs-kern:28037a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] endianess annotations for xfs_inobt_rec_t / xfs_inobt_key_tChristoph Hellwig
SGI-PV: 954580 SGI-Modid: xfs-linux-melb:xfs-kern:26556a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2005-11-02[XFS] Endianess annotations for various allocator data structuresChristoph Hellwig
SGI-PV: 943272 SGI-Modid: xfs-linux:xfs-kern:201006a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-06-21[XFS] add XFS_INOBT_IS_FREE_DISKChristoph Hellwig
SGI-PV: 928382 SGI-Modid: xfs-linux:xfs-kern:193778a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
