path: root/fs/xfs/xfs_ialloc.c
2006-04-11[XFS] Fix a problem in aligning inode allocations to stripe unitNathan Scott
boundaries. SGI-PV: 951862 SGI-Modid: xfs-linux-melb:xfs-kern:25726a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-29[XFS] A change to inode chunk allocation to try allocating the new chunkGlen Overby
contiguous with the most recently allocated chunk. On a striped filesystem, this will fill a stripe unit with inodes before allocating new inodes in another stripe unit. SGI-PV: 951416 SGI-Modid: xfs-linux-melb:xfs-kern:208488a Signed-off-by: Glen Overby <overby@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-29[XFS] We really suck at spulling. Thanks to Chris Pascoe for fixing allNathan Scott
these typos. SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:25539a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-14[XFS] Dynamically allocate the xfs_dinode_core_t structure to reduce ourNathan Scott
stack footprint in xfs_ialloc_ag_alloc. SGI-PV: 947312 SGI-Modid: xfs-linux-melb:xfs-kern:25420a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Endianess annotations for various allocator data structuresChristoph Hellwig
SGI-PV: 943272 SGI-Modid: xfs-linux:xfs-kern:201006a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Add format checking to cmn_err and icmn_errChristoph Hellwig
SGI-PV: 942243 SGI-Modid: xfs-linux:xfs-kern:198658a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
