path: root/fs/xfs/xfs_fsops.c
2007-02-10[XFS] Remove unused arguments from the XFS_BTREE_*_ADDR macros.Eric Sandeen
It makes it incrementally clearer to read the code when the top of a macro spaghetti-pile only receives the 3 arguments it uses, rather than 2 extra ones which are not used. Also when you start pulling this thread out of the sweater (i.e. remove unused args from XFS_BTREE_*_ADDR), a couple other third arms etc fall off too. If they're not used in the macro, then they sometimes don't need to be passed to the function calling the macro either, etc.... Patch provided by Eric Sandeen (sandeen@sandeen.net). SGI-PV: 960197 SGI-Modid: xfs-linux-melb:xfs-kern:28037a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Fix block reservation mechanism.David Chinner
The block reservation mechanism has been broken since the per-cpu superblock counters were introduced. Make the block reservation code work with the per-cpu counters by syncing the counters, snapshotting the amount of available space and then doing a modifcation of the counter state according to the result. Continue in a loop until we either have no space available or we reserve some space. SGI-PV: 956323 SGI-Modid: xfs-linux-melb:xfs-kern:27895a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-07[XFS] Prevent free space oversubscription and xfssyncd looping.David Chinner
The fix for recent ENOSPC deadlocks introduced certain limitations on allocations. The fix could cause xfssyncd to loop endlessly if we did not leave some space free for the allocator to work correctly. Basically, we needed to ensure that we had at least 4 blocks free for an AG free list and a block for the inode bmap btree at all times. However, this did not take into account the fact that each AG has a free list that needs 4 blocks. Hence any filesystem with more than one AG could cause oversubscription of free space and make xfssyncd spin forever trying to allocate space needed for AG freelists that was not available in the AG. The following patch reserves space for the free lists in all AGs plus the inode bmap btree which prevents oversubscription. It also prevents those blocks from being reported as free space (as they can never be used) and makes the SMP in-core superblock accounting code and the reserved block ioctl respect this requirement. SGI-PV: 955674 SGI-Modid: xfs-linux-melb:xfs-kern:26894a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: David Chatterton <chatz@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Fix mismerge of the fs_writable cleanup patch causing a freeze/thawNathan Scott
test hang. SGI-PV: 953563 SGI-Modid: xfs-linux-melb:xfs-kern:26182a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Resolve a namespace collision on vfs/vfsops for FreeBSD porters.Nathan Scott
SGI-PV: 9533338 SGI-Modid: xfs-linux-melb:xfs-kern:26106a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Shutdown the filesystem if all device paths have gone. MadeNathan Scott
shutdown vop flags consistent with sync vop flags declarations too. SGI-PV: 939911 SGI-Modid: xfs-linux-melb:xfs-kern:26096a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-29[XFS] We really suck at spulling. Thanks to Chris Pascoe for fixing allNathan Scott
these typos. SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:25539a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-14[XFS] On machines with more than 8 cpus, when running parallel I/ODavid Chinner
threads, the incore superblock lock becomes the limiting factor for buffered write throughput. Make the contended fields in the incore superblock use per-cpu counters so that there is no global lock to limit scalability. SGI-PV: 946630 SGI-Modid: xfs-linux-melb:xfs-kern:25106a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-15return statement cleanup - kill pointless parenthesesJesper Juhl
This patch removes pointless parentheses from return statements. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-11[XFS] Write log dummy record when freezing filesystemChristoph Hellwig
SGI-PV: 945483 SGI-Modid: xfs-linux-melb:xfs-kern:202638a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-25[XFS] handle error returns from freeze_bdevChristoph Hellwig
SGI-PV: 945483 SGI-Modid: xfs-linux-melb:xfs-kern:201884a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Rework fid encode/decode wrt 64 bit inums interacting with NFS.Nathan Scott
SGI-PV: 937127 SGI-Modid: xfs-linux:xfs-kern:24201a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Endianess annotations for various allocator data structuresChristoph Hellwig
SGI-PV: 943272 SGI-Modid: xfs-linux:xfs-kern:201006a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Ondisk format extension for extended attributes (attr2). Basically,Nathan Scott
the data/attr forks now grow up/down from either end of the literal area, rather than dividing the literal area into two chunks and growing both upward. Means we can now make much more efficient use of the attribute space, incl. fitting DMF attributes inline in 256 byte inodes, and large jumps in dbench3 performance numbers. It is self enabling, but can be forced on/off via the attr2/noattr2 mount options. SGI-PV: 941645 SGI-Modid: xfs-linux:xfs-kern:23835a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-06-21[XFS] Remove dead code. Patch from Adrian BunkChristoph Hellwig
SGI-PV: 936255 SGI-Modid: xfs-linux:xfs-kern:192759a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
