Similar to direct IO reads, direct IO writes are using
truncate_pagecache_range to invalidate the page cache. This is
incorrect due to the sub-block zeroing in the page cache that
truncate_pagecache_range() triggers.
This patch fixes things by using invalidate_inode_pages2_range
instead. It preserves the page cache invalidation, but won't zero
any pages.
cc: stable@vger.kernel.org
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Brian Foster <bfoster@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
xfs is using truncate_pagecache_range to invalidate the page cache
during DIO reads. This is different from the other filesystems who
only invalidate pages during DIO writes.
truncate_pagecache_range is meant to be used when we are freeing the
underlying data structs from disk, so it will zero any partial
ranges in the page. This means a DIO read can zero out part of the
page cache page, and it is possible the page will stay in cache.
buffered reads will find an up to date page with zeros instead of
the data actually on disk.
any pages.
[dchinner: catch error and warn if it fails. Comment.]
Signed-off-by: Chris Mason <clm@fb.com>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Move the IO flag definitions to xfs_inode.h and kill the header file
as it is now empty.
Removing the xfs_vnode.h file showed up an implicit header include
path:
xfs_linux.h -> xfs_vnode.h -> xfs_fs.h
And so every xfs header file has been inplicitly been including
xfs_fs.h where it is needed or not. Hence the removal of xfs_vnode.h
causes all sorts of build issues because BBTOB() and friends are no
longer automatically included in the build. This also gets fixed.
Speculative preallocation and and the associated throttling metrics
assume we're working with large files on large filesystems. Users have
reported inefficiencies in these mechanisms when we happen to be dealing
with large files on smaller filesystems. This can occur because while
prealloc throttling is aggressive under low free space conditions, it is
not active until we reach 5% free space or less.
For example, a 40GB filesystem has enough space for several files large
enough to have multi-GB preallocations at any given time. If those files
are slow growing, they might reserve preallocation for long periods of
time as well as avoid the background scanner due to frequent
modification. If a new file is written under these conditions, said file
has no access to this already reserved space and premature ENOSPC is
imminent.
To handle this scenario, modify the buffered write ENOSPC handling and
retry sequence to invoke an eofblocks scan. In the smaller filesystem
scenario, the eofblocks scan resets the usage of preallocation such that
when the 5% free space threshold is met, throttling effectively takes
over to provide fair and efficient preallocation until legitimate
ENOSPC.
The eofblocks scan is selective based on the nature of the failure. For
example, an EDQUOT failure in a particular quota will use a filtered
scan for that quota. Because we don't know which quota might have caused
an allocation failure at any given time, we include each applicable
quota determined to be under low free space conditions in the scan.
Signed-off-by: Brian Foster <bfoster@redhat.com>
Convert all the errors the core XFs code to negative error signs
like the rest of the kernel and remove all the sign conversion we
do in the interface layers.
Errors for conversion (and comparison) found via searches like:
$ git grep " E" fs/xfs
$ git grep "return E" fs/xfs
$ git grep " E[A-Z].*;$" fs/xfs
Negation points found via searches like:
$ git grep "= -[a-z,A-Z]" fs/xfs
$ git grep "return -[a-z,A-D,F-Z]" fs/xfs
$ git grep " -[a-z].*;" fs/xfs
[ with some bits I missed from Brian Foster ]
XFS_ERROR was designed long ago to trap return values, but it's not
runtime configurable, it's not consistently used, and we can do
similar error trapping with ftrace scripts and triggers from
userspace.
Just nuke XFS_ERROR and associated bits.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Pull vfs updates from Al Viro:
"This the bunch that sat in -next + lock_parent() fix. This is the
minimal set; there's more pending stuff.
In particular, I really hope to get acct.c fixes merged this cycle -
we need that to deal sanely with delayed-mntput stuff. In the next
pile, hopefully - that series is fairly short and localized
(kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more
iov_iter work. Most of prereqs for ->splice_write with sane locking
order are there and Kent's dio rewrite would also fit nicely on top of
this pile"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits)
lock_parent: don't step on stale ->d_parent of all-but-freed one
kill generic_file_splice_write()
ceph: switch to iter_file_splice_write()
shmem: switch to iter_file_splice_write()
nfs: switch to iter_splice_write_file()
fs/splice.c: remove unneeded exports
ocfs2: switch to iter_file_splice_write()
->splice_write() via ->write_iter()
bio_vec-backed iov_iter
optimize copy_page_{to,from}_iter()
bury generic_file_aio_{read,write}
lustre: get rid of messing with iovecs
ceph: switch to ->write_iter()
ceph_sync_direct_write: stop poking into iov_iter guts
ceph_sync_read: stop poking into iov_iter guts
new helper: copy_page_from_iter()
fuse: switch to ->write_iter()
btrfs: switch to ->write_iter()
ocfs2: switch to ->write_iter()
xfs: switch to ->write_iter()
Backmerge of dcache.c changes from mainline. It's that, or complete
rebase...
fs/splice.c
iter_file_splice_write() - a ->splice_write() instance that gathers the
pipe buffers, builds a bio_vec-based iov_iter covering those and feeds
it to ->write_iter(). A bunch of simple cases coverted to that...
[AV: fixed the braino spotted by Cyrill]
Reviewed-by: Jie Liu <jeff.liu@oracle.com>
And it should be negative.
pos is redundant (it's iocb->ki_pos), and iov/nr_segs/count are taken
care of by lifting iov_iter into the caller.
Now It Can Be Done(tm) - we don't need to do iov_shorten() in
generic_file_direct_write() anymore, now that all ->direct_IO()
instances are converted to proper iov_iter methods and honour
iter->count and iter->iov_offset properly.
Get rid of count/ocount arguments of generic_file_direct_write(),
while we are at it.
For now, just use the same thing we pass to ->direct_IO() - it's all
iovec-based at the moment. Pass it explicitly to iov_iter_init() and
account for kvec vs. iovec in there, by the same kludge NFS ->direct_IO()
uses.
all callers of ->aio_read() and ->aio_write() have iov/nr_segs already
checked - generic_segment_checks() done after that is just an odd way
to spell iov_length().
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 fixes from Ted Ts'o:
"These are regression and bug fixes for ext4.
We had a number of new features in ext4 during this merge window
(ZERO_RANGE and COLLAPSE_RANGE fallocate modes, renameat, etc.) so
there were many more regression and bug fixes this time around. It
didn't help that xfstests hadn't been fully updated to fully stress
test COLLAPSE_RANGE until after -rc1"
* tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (31 commits)
ext4: disable COLLAPSE_RANGE for bigalloc
ext4: fix COLLAPSE_RANGE failure with 1KB block size
ext4: use EINVAL if not a regular file in ext4_collapse_range()
ext4: enforce we are operating on a regular file in ext4_zero_range()
ext4: fix extent merging in ext4_ext_shift_path_extents()
ext4: discard preallocations after removing space
ext4: no need to truncate pagecache twice in collapse range
ext4: fix removing status extents in ext4_collapse_range()
ext4: use filemap_write_and_wait_range() correctly in collapse range
ext4: use truncate_pagecache() in collapse range
ext4: remove temporary shim used to merge COLLAPSE_RANGE and ZERO_RANGE
ext4: fix ext4_count_free_clusters() with EXT4FS_DEBUG and bigalloc enabled
ext4: always check ext4_ext_find_extent result
ext4: fix error handling in ext4_ext_shift_extents
ext4: silence sparse check warning for function ext4_trim_extent
ext4: COLLAPSE_RANGE only works on extent-based files
ext4: fix byte order problems introduced by the COLLAPSE_RANGE patches
ext4: use i_size_read in ext4_unaligned_aio()
fs: disallow all fallocate operation on active swapfile
fs: move falloc collapse range check into the filesystem methods
We negate the error value being returned from a generic function
incorrectly. The code path that it is running in returned negative
errors, so there is no need to negate it to get the correct error
signs here.
This was uncovered by generic/019.
This one hits a few functions as we unravel the unused arg
up through the callers.
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
Currently in do_fallocate in collapse range case we're checking
whether offset + len is not bigger than i_size. However there is
nothing which would prevent i_size from changing so the check is
pointless. It should be done in the file system itself and the file
system needs to make sure that i_size is not going to change. The
i_size check for the other fallocate modes are also done in the
filesystems.
As it is now we can easily crash the kernel by having two processes
doing truncate and fallocate collapse range at the same time. This
can be reproduced on ext4 and it is theoretically possible on xfs even
though I was not able to trigger it with this simple test.
This commit removes the check from do_fallocate and adds it to the
file system.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Acked-by: Dave Chinner <david@fromorbit.com>
filemap_map_pages() is generic implementation of ->map_pages() for
filesystems who uses page cache.
It should be safe to use filemap_map_pages() for ->map_pages() if
filesystem use filemap_fault() for ->fault().
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Ning Qu <quning@gmail.com>
Pull xfs update from Dave Chinner:
"There are a couple of new fallocate features in this request - it was
decided that it was easiest to push them through the XFS tree using
topic branches and have the ext4 support be based on those branches.
Hence you may see some overlap with the ext4 tree merge depending on
how they including those topic branches into their tree. Other than
that, there is O_TMPFILE support, some cleanups and bug fixes.
The main changes in the XFS tree for 3.15-rc1 are:
- O_TMPFILE support
- allowing AIO+DIO writes beyond EOF
- FALLOC_FL_COLLAPSE_RANGE support for fallocate syscall and XFS
implementation
- FALLOC_FL_ZERO_RANGE support for fallocate syscall and XFS
implementation
- IO verifier cleanup and rework
- stack usage reduction changes
- vm_map_ram NOIO context fixes to remove lockdep warings
- various bug fixes and cleanups"
* tag 'xfs-for-linus-3.15-rc1' of git://oss.sgi.com/xfs/xfs: (34 commits)
xfs: fix directory hash ordering bug
xfs: extra semi-colon breaks a condition
xfs: Add support for FALLOC_FL_ZERO_RANGE
fs: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate
xfs: inode log reservations are still too small
xfs: xfs_check_page_type buffer checks need help
xfs: avoid AGI/AGF deadlock scenario for inode chunk allocation
xfs: use NOIO contexts for vm_map_ram
xfs: don't leak EFSBADCRC to userspace
xfs: fix directory inode iolock lockdep false positive
xfs: allocate xfs_da_args to reduce stack footprint
xfs: always do log forces via the workqueue
xfs: modify verifiers to differentiate CRC from other errors
xfs: print useful caller information in xfs_error_report
xfs: add xfs_verifier_error()
xfs: add helper for updating checksums on xfs_bufs
xfs: add helper for verifying checksums on xfs_bufs
xfs: Use defines for CRC offsets in all cases
xfs: skip pointless CRC updates after verifier failures
xfs: Add support FALLOC_FL_COLLAPSE_RANGE for fallocate
always equal to &iocb->ki_pos.
same story - it's &iocb->ki_pos in all cases
Introduce new FALLOC_FL_ZERO_RANGE flag for fallocate. This has the same
functionality as xfs ioctl XFS_IOC_ZERO_RANGE.
We can also preallocate blocks past EOF in the same was as with
fallocate. Flag FALLOC_FL_KEEP_SIZE will cause the inode size to remain
the same even if we preallocate blocks past EOF.
It uses the same code to zero range as it is used by the
XFS_IOC_ZERO_RANGE ioctl.
This patch implements fallocate's FALLOC_FL_COLLAPSE_RANGE for XFS.
The semantics of this flag are following:
1) It collapses the range lying between offset and length by removing any data
blocks which are present in this range and than updates all the logical
offsets of extents beyond "offset + len" to nullify the hole created by
removing blocks. In short, it does not leave a hole.
2) It should be used exclusively. No other fallocate flag in combination.
3) Offset and length supplied to fallocate should be fs block size aligned
in case of xfs and ext4.
4) Collaspe range does not work beyond i_size.
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Ashish Sangwan <a.sangwan@samsung.com>
It actually goes back to 2004 ([PATCH] Concurrent O_SYNC write support)
when sync_page_range() had been introduced; generic_file_write{,v}() correctly
synced
pos_after_write - written .. pos_after_write - 1
but generic_file_aio_write() synced
pos_before_write .. pos_before_write + written - 1
instead. Which is not the same thing with O_APPEND, obviously.
A couple of years later correct variant had been killed off when
everything switched to use of generic_file_aio_write().
All users of generic_file_aio_write() are affected, and the same bug
has been copied into other instances of ->aio_write().
The fix is trivial; the only subtle point is that generic_write_sync()
ought to be inlined to avoid calculations useless for the majority of
calls.
Some time ago, mkfs.xfs started picking the storage physical
sector size as the default filesystem "sector size" in order
to avoid RMW costs incurred by doing IOs at logical sector
size alignments.
However, this means that for a filesystem made with i.e.
a 4k sector size on an "advanced format" 4k/512 disk,
512-byte direct IOs are no longer allowed. This means
that XFS has essentially turned this AF drive into a hard
4K device, from the filesystem on up.
XFS's mkfs-specified "sector size" is really just controlling
the minimum size & alignment of filesystem metadata.
There is no real need to tightly couple XFS's minimal
metadata size to the minimum allowed direct IO size;
XFS can continue doing metadata in optimal sizes, but
still allow smaller DIOs for apps which issue them,
for whatever reason.
This patch adds a new field to the xfs_buftarg, so that
we now track 2 sizes:
1) The metadata sector size, which is the minimum unit and
alignment of IO which will be performed by metadata operations.
2) The device logical sector size
The first is used internally by the file system for metadata
alignment and IOs.
The second is used for the minimum allowed direct IO alignment.
This has passed xfstests on filesystems made with 4k sectors,
including when run under the patch I sent to ignore
XFS_IOC_DIOINFO, and issue 512 DIOs anyway. I also directly
tested end of block behavior on preallocated, sparse, and
existing files when we do a 512 IO into a 4k file on a
4k-sector filesystem, to be sure there were no unexpected
behaviors.
Signed-off-by: Ben Myers <bpm@sgi.com>
In preparation for adding new members to the structure,
give these old ones more descriptive names:
bt_ssize -> bt_meta_sectorsize
bt_smask -> bt_meta_sectormask
Make it clear that we're only locking against the extent map on the data
fork. Also clean the function up a little bit.
We can just use xfs_iunlock without any loss of clarity.
Currently the xfs_inode.h header has a dependency on the definition
of the BMAP btree records as the inode fork includes an array of
xfs_bmbt_rec_host_t objects in it's definition.
Move all the btree format definitions from xfs_btree.h,
xfs_bmap_btree.h, xfs_alloc_btree.h and xfs_ialloc_btree.h to
xfs_format.h to continue the process of centralising the on-disk
format definitions. With this done, the xfs inode definitions are no
longer dependent on btree header files.
The enables a massive culling of unnecessary includes, with close to
200 #include directives removed from the XFS kernel code base.
Reviewed-by: Ben Myers <bpm@sgi.com>
xfs_trans.h has a dependency on xfs_log.h for a couple of
structures. Most code that does transactions doesn't need to know
anything about the log, but this dependency means that they have to
include xfs_log.h. Decouple the xfs_trans.h and xfs_log.h header
files and clean up the includes to be in dependency order.
In doing this, remove the direct include of xfs_trans_reserve.h from
xfs_trans.h so that we remove the dependency between xfs_trans.h and
xfs_mount.h. Hence the xfs_trans.h include can be moved to the
indicate the actual dependencies other header files have on it.
Note that these are kernel only header files, so this does not
translate to any userspace changes at all.
The on-disk format definitions for the directory and attribute
structures are spread across 3 header files right now, only one of
which is dedicated to defining on-disk structures and their
manipulation (xfs_dir2_format.h). Pull all the format definitions
into a single header file - xfs_da_format.h - and switch all the
code over to point at that.
All of the buffer operations structures are needed to be exported
for xfs_db, so move them all to a common location rather than
spreading them all over the place. They are verifying the on-disk
format, so while xfs_format.h might be a good place, it is not part
of the on disk format.
Hence we need to create a new header file that we centralise these
related definitions. Start by moving the bffer operations
structures, and then also move all the other definitions that have
crept into xfs_log_format.h and xfs_format.h as there was no other
shared header file to put them in.
Call xfs_alloc_file_space or xfs_free_file_space directly from
xfs_file_fallocate instead of going through xfs_change_file_space.
This simplified the code by removing the unessecary marshalling of the
arguments into an xfs_flock64_t structure and allows removing checks that
are already done in the VFS code.
Currently fallocate always holds the iolock when calling into
xfs_change_file_space, while the ioctl path lets some of the lower level
functions take it, but leave it out in others.
This patch makes sure the ioctl path also always holds the iolock and
thus introduces consistent locking for the preallocation operations while
simplifying the code and allowing to kill the now unused XFS_ATTR_NOLOCK
flag.
There is no reason to conditionally take the iolock inside xfs_setattr_size
when we can let the caller handle it unconditionally, which just incrases
the lock hold time for the case where it was previously taken internally
by a few instructions.
Now we have xfs_inode.c for holding kernel-only XFS inode
operations, move all the inode operations from xfs_vnodeops.c to
this new file as it holds another set of kernel-only inode
operations. The name of this file traces back to the days of Irix
and it's vnodes which we don't have anymore.
Essentially this move consolidates the inode locking functions
and a bunch of XFS inode operations into the one file. Eventually
the high level functions will be merged into the VFS interface
functions in xfs_iops.c.
This leaves only internal preallocation, EOF block manipulation and
hole punching functions in vnodeops.c. Move these to xfs_bmap_util.c
where we are already consolidating various in-kernel physical extent
manipulation and querying functions.
Reviewed-by: Mark Tinguely <tinguely@sgi.com>
Many of the definitions within xfs_dir2_priv.h are needed in
userspace outside libxfs. Definitions within xfs_dir2_priv.h are
wholly contained within libxfs, so we need to shuffle some of the
definitions around to keep consistency across files shared between
user and kernel space.
For those file systems(btrfs/ext4/ocfs2/tmpfs) that support
SEEK_DATA/SEEK_HOLE functions, we end up handling the similar
matter in lseek_execute() to update the current file offset
to the desired offset if it is valid, ceph also does the
simliar things at ceph_llseek().
To reduce the duplications, this patch make lseek_execute()
public accessible so that we can call it directly from the
underlying file systems.
Thanks Dave Chinner for this suggestion.
[AV: call it vfs_setpos(), don't bring the removed 'inode' argument back]
v2->v1:
- Add kernel-doc comments for lseek_execute()
- Call lseek_execute() in ceph->llseek()
Signed-off-by: Jie Liu <jeff.liu@oracle.com>
Cc: Dave Chinner <dchinner@redhat.com>
Cc: Chris Mason <chris.mason@fusionio.com>
Cc: Josef Bacik <jbacik@fusionio.com>
Cc: Ben Myers <bpm@sgi.com>
Cc: Ted Tso <tytso@mit.edu>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Sage Weil <sage@inktank.com>
Faster kernel compiles by way of fewer unnecessary includes.
[akpm@linux-foundation.org: fix fallout]
[akpm@linux-foundation.org: fix build]
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
