path: root/fs/xfs/xfs_bmap.c
2008-04-18[XFS] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30775a Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Prevent xfs_bmap_check_leaf_extents() referencing unmapped memory.Lachlan McIlroy
While investigating the extent corruption bug I ran into this bug in debug only code. xfs_bmap_check_leaf_extents() loops through the leaf blocks of the extent btree checking that every extent is entirely before the next extent. It also compares the last extent in the previous block to the first extent in the current block when the previous block has been released and potentially unmapped. So take a copy of the last extent instead of a pointer. Also move the last extent check out of the loop because we only need to do it once. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30718a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-04-18[XFS] cleanup vnode use in xfs_bmap.cChristoph Hellwig
SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30553a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] cleanup vnode use in dmapi callsChristoph Hellwig
SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30545a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] actually check error returned by xfs_flush_pages, clean up andNiv Sardi
bailout if fails. SGI-PV: 973041 SGI-Modid: xfs-linux-melb:xfs-kern:30462a Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-10[XFS] remove shouting-indirection macros from xfs_sb.hEric Sandeen
Remove macro-to-small-function indirection from xfs_sb.h, and remove some which are completely unused. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30528a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] Remove the BPCSHIFT and NB* based macros from XFS.Tim Shimmin
The BPCSHIFT based macros, btoc*, ctob*, offtoc* and ctooff are either not used or don't need to be used. The NDPP, NDPP, NBBY macros don't need to be used but instead are replaced directly by PAGE_SIZE and PAGE_CACHE_SIZE where appropriate. Initial patch and motivation from Nicolas Kaiser. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:30096a Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] optimize XFS_IS_REALTIME_INODE w/o realtime configEric Sandeen
Use XFS_IS_REALTIME_INODE in more places, and #define it to 0 if CONFIG_XFS_RT is off. This should be safe because mount checks in xfs_rtmount_init: so if we get mounted w/o CONFIG_XFS_RT, no realtime inodes should be encountered after that. Defining XFS_IS_REALTIME_INODE to 0 saves a bit of stack space, presumeably gcc can optimize around the various "if (0)" type checks: xfs_alloc_file_space -8 xfs_bmap_adjacent -16 xfs_bmapi -8 xfs_bmap_rtalloc -16 xfs_bunmapi -28 xfs_free_file_space -64 xfs_imap +8 <-- ? hmm. xfs_iomap_write_direct -12 xfs_qm_dqusage_adjust -4 xfs_qm_vop_chown_reserve -4 SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:30014a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] Fix up sparse warnings.David Chinner
These are mostly locking annotations, marking things static, casts where needed and declaring stuff in header files. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:30002a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] Unwrap XFS_SB_LOCK.Eric Sandeen
Un-obfuscate XFS_SB_LOCK, remove XFS_SB_LOCK->mutex_lock->spin_lock macros, call spin_lock directly, remove extraneous cookie holdover from old xfs code, and change lock type to spinlock_t. SGI-PV: 970382 SGI-Modid: xfs-linux-melb:xfs-kern:29746a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] call common xfs vnode-level helpers directly and remove vnode operationsChristoph Hellwig
SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29493a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] decontaminate vnode operations from behavior detailsChristoph Hellwig
All vnode ops now take struct xfs_inode pointers and the behaviour related glue is split out into methods of it's own. This required fixing xfs_create/mkdir/symlink to not mess with the inode pointer but rather use a separate boolean for error handling. Thanks to Dave Chinner for that fix. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29492a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] remove unessecary vfs argument to DM_EVENT_ENABLEDChristoph Hellwig
SGI-PV: 968690 SGI-Modid: xfs-linux-melb:xfs-kern:29340a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Vlad Apostolov <vapo@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] endianess annotations for xfs_bmbt_rec_tChristoph Hellwig
SGI-PV: 968563 SGI-Modid: xfs-linux-melb:xfs-kern:29321a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] split ondisk vs incore versions of xfs_bmbt_rec_tChristoph Hellwig
currently xfs_bmbt_rec_t is used both for ondisk extents as well as host-endian ones. This patch adds a new xfs_bmbt_rec_host_t for the native endian ones and cleans up the fallout. There have been various endianess issues in the tracing / debug printf code that are fixed by this patch. SGI-PV: 968563 SGI-Modid: xfs-linux-melb:xfs-kern:29318a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] hole not shown when file is created with resvspVlad Apostolov
SGI-PV: 967674 SGI-Modid: xfs-linux-melb:xfs-kern:29211a Signed-off-by: Vlad Apostolov <vapo@sgi.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-07-14[XFS] Clean up function name handling in tracing codeEric Sandeen
Remove the hardcoded "fnames" for tracing, and just embed them in tracing macros via __FUNCTION__. Kills a lot of #ifdefs too. SGI-PV: 967353 SGI-Modid: xfs-linux-melb:xfs-kern:29099a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-07-14[XFS] Concurrent Multi-File Data StreamsDavid Chinner
In media spaces, video is often stored in a frame-per-file format. When dealing with uncompressed realtime HD video streams in this format, it is crucial that files do not get fragmented and that multiple files a placed contiguously on disk. When multiple streams are being ingested and played out at the same time, it is critical that the filesystem does not cross the streams and interleave them together as this creates seek and readahead cache miss latency and prevents both ingest and playout from meeting frame rate targets. This patch set creates a "stream of files" concept into the allocator to place all the data from a single stream contiguously on disk so that RAID array readahead can be used effectively. Each additional stream gets placed in different allocation groups within the filesystem, thereby ensuring that we don't cross any streams. When an AG fills up, we select a new AG for the stream that is not in use. The core of the functionality is the stream tracking - each inode that we create in a directory needs to be associated with the directories' stream. Hence every time we create a file, we look up the directories' stream object and associate the new file with that object. Once we have a stream object for a file, we use the AG that the stream object point to for allocations. If we can't allocate in that AG (e.g. it is full) we move the entire stream to another AG. Other inodes in the same stream are moved to the new AG on their next allocation (i.e. lazy update). Stream objects are kept in a cache and hold a reference on the inode. Hence the inode cannot be reclaimed while there is an outstanding stream reference. This means that on unlink we need to remove the stream association and we also need to flush all the associations on certain events that want to reclaim all unreferenced inodes (e.g. filesystem freeze). SGI-PV: 964469 SGI-Modid: xfs-linux-melb:xfs-kern:29096a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Donald Douwsma <donaldd@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Vlad Apostolov <vapo@sgi.com>
2007-07-14[XFS] Use uninitialized_var macro to stop warning about rtxAndrew Morton
Appease gcc in regards to "warning: 'rtx' is used uninitialized in this function". SGI-PV: 907752 SGI-Modid: xfs-linux-melb:xfs-kern:29007a Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-07-14[XFS] Cleanup inode extent size hint extractionDavid Chinner
SGI-PV: 966004 SGI-Modid: xfs-linux-melb:xfs-kern:28866a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-07-14[XFS] xfs_bmapi fails to update the previous extent pointerDavid Chinner
When processing multiple extent maps, xfs_bmapi needs to keep track of the extent behind the one it is currently working on to be able to trim extent ranges correctly. Failing to update the previous pointer can result in corrupted extent lists in memory and this will result in panics or assert failures. Update the previous pointer correctly when we move to the next extent to process. SGI-PV: 965631 SGI-Modid: xfs-linux-melb:xfs-kern:28773a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Vlad Apostolov <vapo@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] Fix to prevent the notorious 'NULL files' problem after a crash.Lachlan McIlroy
The problem that has been addressed is that of synchronising updates of the file size with writes that extend a file. Without the fix the update of a file's size, as a result of a write beyond eof, is independent of when the cached data is flushed to disk. Often the file size update would be written to the filesystem log before the data is flushed to disk. When a system crashes between these two events and the filesystem log is replayed on mount the file's size will be set but since the contents never made it to disk the file is full of holes. If some of the cached data was flushed to disk then it may just be a section of the file at the end that has holes. There are existing fixes to help alleviate this problem, particularly in the case where a file has been truncated, that force cached data to be flushed to disk when the file is closed. If the system crashes while the file(s) are still open then this flushing will never occur. The fix that we have implemented is to introduce a second file size, called the in-memory file size, that represents the current file size as viewed by the user. The existing file size, called the on-disk file size, is the one that get's written to the filesystem log and we only update it when it is safe to do so. When we write to a file beyond eof we only update the in- memory file size in the write operation. Later when the I/O operation, that flushes the cached data to disk completes, an I/O completion routine will update the on-disk file size. The on-disk file size will be updated to the maximum offset of the I/O or to the value of the in-memory file size if the I/O includes eof. SGI-PV: 958522 SGI-Modid: xfs-linux-melb:xfs-kern:28322a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] remove more misc. unused argsEric Sandeen
Patch provided by Eric Sandeen. SGI-PV: 961695 SGI-Modid: xfs-linux-melb:xfs-kern:28205a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] The last argument "lsn" of xfs_trans_commit() is always called withEric Sandeen
NULL. Patch provided by Eric Sandeen. SGI-PV: 961693 SGI-Modid: xfs-linux-melb:xfs-kern:28199a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Remove a bunch of unused functions from XFS.Eric Sandeen
Patch provided by Eric Sandeen (sandeen@sandeen.net). SGI-PV: 960897 SGI-Modid: xfs-linux-melb:xfs-kern:28038a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Remove unused arguments from the XFS_BTREE_*_ADDR macros.Eric Sandeen
It makes it incrementally clearer to read the code when the top of a macro spaghetti-pile only receives the 3 arguments it uses, rather than 2 extra ones which are not used. Also when you start pulling this thread out of the sweater (i.e. remove unused args from XFS_BTREE_*_ADDR), a couple other third arms etc fall off too. If they're not used in the macro, then they sometimes don't need to be passed to the function calling the macro either, etc.... Patch provided by Eric Sandeen (sandeen@sandeen.net). SGI-PV: 960197 SGI-Modid: xfs-linux-melb:xfs-kern:28037a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Remove unused argument to xfs_bmap_finishEric Sandeen
The firstblock argument to xfs_bmap_finish is not used by that function. Remove it and cleanup the code a bit. Patch provided by Eric Sandeen. SGI-PV: 960196 SGI-Modid: xfs-linux-melb:xfs-kern:28034a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Make growfs work for amounts greater than 2TBDavid Chinner
The free block modification code has a 32bit interface, limiting the size the filesystem can be grown even on 64 bit machines. On 32 bit machines, there are other 32bit variables in transaction structures and interfaces that need to be expanded to allow this to work. SGI-PV: 959978 SGI-Modid: xfs-linux-melb:xfs-kern:27894a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Fix attr2 corruption with btree data extentsBarry Naujok
SGI-PV: 958747 SGI-Modid: xfs-linux-melb:xfs-kern:27792a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Russell Cattelan <cattelan@thebarn.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-11-21[XFS] Fix uninitialized br_state and br_startoff inLachlan McIlroy
xfs_bmap_add_extent_delay_real() SGI-PV: 957008 SGI-Modid: xfs-linux-melb:xfs-kern:27457a Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Shailendra Tripathi <stripathi@agami.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Improve error handling for the zero-fsblock extent detection code.Nathan Scott
SGI-PV: 955302 SGI-Modid: xfs-linux-melb:xfs-kern:26802a Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] endianess annotations for xfs_bmbt_key Trivial as there are noChristoph Hellwig
incore users. SGI-PV: 954580 SGI-Modid: xfs-linux-melb:xfs-kern:26561a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] endianess annotate XFS_BMAP_BROOT_PTR_ADDR Make sure it returns aChristoph Hellwig
__be64 and let the callers use the proper macros. SGI-PV: 954580 SGI-Modid: xfs-linux-melb:xfs-kern:26560a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] add xfs_btree_check_lptr_disk variant which handles endianChristoph Hellwig
conversion SGI-PV: 954580 SGI-Modid: xfs-linux-melb:xfs-kern:26558a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-08-30[XFS] Fix char size overflow in bmap_alloc call for unwritten extentAdrian Bunk
conversion. Since bma.conv is a char and XFS_BMAPI_CONVERT is 0x1000, bma.conv was always assigned zero. Spotted by the GNU C compiler (SVN version). SGI-PV: 947312 SGI-Modid: xfs-linux-melb:xfs-kern:26887a Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-19[XFS] Remove an incorrect use of unlikely() on a relatively likely codeNathan Scott
path. SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:26249a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Resolve a namespace collision on vnode/vnodeops for FreeBSD porters.Nathan Scott
SGI-PV: 953338 SGI-Modid: xfs-linux-melb:xfs-kern:26107a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Shutdown the filesystem if all device paths have gone. MadeNathan Scott
shutdown vop flags consistent with sync vop flags declarations too. SGI-PV: 939911 SGI-Modid: xfs-linux-melb:xfs-kern:26096a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] In actual allocation of file system blocks and freeing extents, theYingping Lu
transaction within each such operation may involve multiple locking of AGF buffer. While the freeing extent function has sorted the extents based on AGF number before entering into transaction, however, when the file system space is very limited, the allocation of space would try every AGF to get space allocated, this could potentially cause out-of-order locking, thus deadlock could happen. This fix mitigates the scarce space for allocation by setting aside a few blocks without reservation, and avoid deadlock by maintaining ascending order of AGF locking. SGI-PV: 947395 SGI-Modid: xfs-linux-melb:xfs-kern:210801a Signed-off-by: Yingping Lu <yingping@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Add parameters to xfs_bmapi() and xfs_bunmapi() to have them reportOlaf Weber
the range spanned by modifications to the in-core extent map. Add XFS_BUNMAPI() and XFS_SWAP_EXTENTS() macros that call xfs_bunmapi() and xfs_swap_extents() via the ioops vector. Change all calls that may modify the in-core extent map for the data fork to go through the ioops vector. This allows a cache of extent map data to be kept in sync. SGI-PV: 947615 SGI-Modid: xfs-linux-melb:xfs-kern:209226a Signed-off-by: Olaf Weber <olaf@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-31[XFS] Make project quota enforcement return an error code consistent withNathan Scott
its use. SGI-PV: 951300 SGI-Modid: xfs-linux-melb:xfs-kern:25633a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-29[XFS] Remove unused/obsoleted function: xfs_bmap_do_search_extents()Mandy Kirkconnell
SGI-PV: 951415 SGI-Modid: xfs-linux-melb:xfs-kern:208490a Signed-off-by: Mandy Kirkconnell <alkirkco@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] There are a few problems with the newMandy Kirkconnell
xfs_bmap_search_multi_extents() wrapper function that I introduced in mod xfs-linux:xfs-kern:207393a. The function was added as a wrapper around xfs_bmap_do_search_extents() to avoid breaking the top-of-tree CXFS interface. The idea of the function was basically to extract the target extent buffer (if muli- level extent allocation mode), then call xfs_bmap_do_search_extents() with either a pointer to the first extent in the target buffer or a pointer to the first extent in the file, depending on which extent mode was being used. However, in addition to locating the target extent record for block bno, xfs_bmap_do_search_extents() also sets four parameters needed by the caller: *lastx, *eofp, *gotp, *prevp. Passing only the target extent buffer to xfs_bmap_do_search_extents() causes *eofp to be set incorrectly if the extent is at the end of the target list but there are actually more extents in the next er_extbuf. Likewise, if the extent is the first one in the buffer but NOT the first in the file, *prevp is incorrectly set to NULL. Adding the needed functionality to xfs_bmap_search_multi_extents() to re-set any incorrectly set fields is redundant and makes the call to xfs_bmap_do_search_extents() not make much sense when multi-level extent allocation mode is being used. This mod basically extracts the two functional components from xfs_bmap_do_search_extents(), with the intent of obsoleting/removing xfs_bmap_do_search_extents() after the CXFS mult-level in-core extent changes are checked in. The two components are: 1) The binary search to locate the target extent record, and 2) Setting the four parameters needed by the caller (*lastx, *eofp, *gotp, *prevp). Component 1: I created a new function in xfs_inode.c called xfs_iext_bno_to_ext(), which executes the binary search to find the target extent record. xfs_bmap_search_multi_extents() has been modified to call xfs_iext_bno_to_ext() rather than xfs_bmap_do_search_extents(). Component 2: The parameter setting functionality has been added to xfs_bmap_search_multi_extents(), eliminating the need for xfs_bmap_do_search_extents(). These changes make the removal of xfs_bmap_do_search_extents() trival once the CXFS changes are in place. They also allow us to maintain the current XFS interface, using the new search function introduced in mod xfs-linux:xfs-kern:207393a. SGI-PV: 928864 SGI-Modid: xfs-linux-melb:xfs-kern:207866a Signed-off-by: Mandy Kirkconnell <alkirkco@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-14[XFS] Fix assert to check that in-core extents are inline only.Mandy Kirkconnell
SGI-PV: 950678 SGI-Modid: xfs-linux-melb:xfs-kern:207634a Signed-off-by: Mandy Kirkconnell <alkirkco@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-14[XFS] Reduce stack usage within xfs_bmapi by rearranging some code,Nathan Scott
splitting realtime/btree allocators apart. Based on Glens original patches. SGI-PV: 947312 SGI-Modid: xfs-linux-melb:xfs-kern:25372a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-14[XFS] Reduce xfs_bmapi stack use by removing some local state variables,Nathan Scott
and directly testing flags instead. SGI-PV: 947312 SGI-Modid: xfs-linux-melb:xfs-kern:25370a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-14[XFS] 929045 567344 This mod introduces multi-level in-core file extentMandy Kirkconnell
functionality, building upon the new layout introduced in mod xfs-linux:xfs-kern:207390a. The new multi-level extent allocations are only required for heavily fragmented files, so the old-style linear extent list is used on files until the extents reach a pre-determined size of 4k. 4k buffers are used because this is the system page size on Linux i386 and systems with larger page sizes don't seem to gain much, if anything, by using their native page size as the extent buffer size. Also, using 4k extent buffers everywhere provides a consistent interface for CXFS across different platforms. The 4k extent buffers are managed by an indirection array (xfs_ext_irec_t) which is basically just a pointer array with a bit of extra information to keep track of the number of extents in each buffer as well as the extent offset of each buffer. Major changes include: - Add multi-level in-core file extent functionality to the xfs_iext_ subroutines introduced in mod: xfs-linux:xfs-kern:207390a - Introduce 13 new subroutines which add functionality for multi-level in-core file extents: xfs_iext_add_indirect_multi() xfs_iext_remove_indirect() xfs_iext_realloc_indirect() xfs_iext_indirect_to_direct() xfs_iext_bno_to_irec() xfs_iext_idx_to_irec() xfs_iext_irec_init() xfs_iext_irec_new() xfs_iext_irec_remove() xfs_iext_irec_compact() xfs_iext_irec_compact_pages() xfs_iext_irec_compact_full() xfs_iext_irec_update_extoffs() SGI-PV: 928864 SGI-Modid: xfs-linux-melb:xfs-kern:207393a Signed-off-by: Mandy Kirkconnell <alkirkco@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-14[XFS] 929045 567344 This mod re-organizes some of the in-core file extentMandy Kirkconnell
code to prepare for an upcoming mod which will introduce multi-level in-core extent allocations. Although the in-core extent management is using a new code path in this mod, the functionality remains the same. Major changes include: - Introduce 10 new subroutines which re-orgainze the existing code but do NOT change functionality: xfs_iext_get_ext() xfs_iext_insert() xfs_iext_add() xfs_iext_remove() xfs_iext_remove_inline() xfs_iext_remove_direct() xfs_iext_realloc_direct() xfs_iext_direct_to_inline() xfs_iext_inline_to_direct() xfs_iext_destroy() - Remove 2 subroutines (functionality moved to new subroutines above): xfs_iext_realloc() -replaced by xfs_iext_add() and xfs_iext_remove() xfs_bmap_insert_exlist() - replaced by xfs_iext_insert() xfs_bmap_delete_exlist() - replaced by xfs_iext_remove() - Replace all hard-coded (indexed) extent assignments with a call to xfs_iext_get_ext() - Replace all extent record pointer arithmetic (ep++, ep--, base + lastx,..) with calls to xfs_iext_get_ext() - Update comments to remove the idea of a single "extent list" and introduce "extent record" terminology instead SGI-PV: 928864 SGI-Modid: xfs-linux-melb:xfs-kern:207390a Signed-off-by: Mandy Kirkconnell <alkirkco@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-12[XFS] Merge in trivial changes, sync up headers with userspaceNathan Scott
equivalents. SGI-PV: 907752 SGI-Modid: xfs-linux-melb:xfs-kern:24961a Signed-off-by: Nathan Scott <nathans@sgi.com>
