path: root/fs/xfs/xfs_attr.c
2007-10-16[XFS] call common xfs vnode-level helpers directly and remove vnode operationsChristoph Hellwig
SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29493a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] decontaminate vnode operations from behavior detailsChristoph Hellwig
All vnode ops now take struct xfs_inode pointers and the behaviour related glue is split out into methods of it's own. This required fixing xfs_create/mkdir/symlink to not mess with the inode pointer but rather use a separate boolean for error handling. Thanks to Dave Chinner for that fix. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29492a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] The last argument "lsn" of xfs_trans_commit() is always called withEric Sandeen
NULL. Patch provided by Eric Sandeen. SGI-PV: 961693 SGI-Modid: xfs-linux-melb:xfs-kern:28199a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Remove unused argument to xfs_bmap_finishEric Sandeen
The firstblock argument to xfs_bmap_finish is not used by that function. Remove it and cleanup the code a bit. Patch provided by Eric Sandeen. SGI-PV: 960196 SGI-Modid: xfs-linux-melb:xfs-kern:28034a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Fix attr2 corruption with btree data extentsBarry Naujok
SGI-PV: 958747 SGI-Modid: xfs-linux-melb:xfs-kern:27792a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Russell Cattelan <cattelan@thebarn.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Keep stack usage down for 4k stacks by using noinline.David Chinner
gcc-4.1 and more recent aggressively inline static functions which increases XFS stack usage by ~15% in critical paths. Prevent this from occurring by adding noinline to the STATIC definition. Also uninline some functions that are too large to be inlined and were causing problems with CONFIG_FORCED_INLINING=y. Finally, clean up all the different users of inline, __inline and __inline__ and put them under one STATIC_INLINE macro. For debug kernels the STATIC_INLINE macro uninlines those functions. SGI-PV: 957159 SGI-Modid: xfs-linux-melb:xfs-kern:27585a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: David Chatterton <chatz@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-09-28[XFS] Add EA list callbacks for xfs kernel use. Cleanup some namespaceTim Shimmin
code. SGI-PV: 954372 SGI-Modid: xfs-linux-melb:xfs-kern:26583a Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Resolve a namespace collision on vnode/vnodeops for FreeBSD porters.Nathan Scott
SGI-PV: 953338 SGI-Modid: xfs-linux-melb:xfs-kern:26107a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Add parameters to xfs_bmapi() and xfs_bunmapi() to have them reportOlaf Weber
the range spanned by modifications to the in-core extent map. Add XFS_BUNMAPI() and XFS_SWAP_EXTENTS() macros that call xfs_bunmapi() and xfs_swap_extents() via the ioops vector. Change all calls that may modify the in-core extent map for the data fork to go through the ioops vector. This allows a cache of extent map data to be kept in sync. SGI-PV: 947615 SGI-Modid: xfs-linux-melb:xfs-kern:209226a Signed-off-by: Olaf Weber <olaf@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-29[XFS] We really suck at spulling. Thanks to Chris Pascoe for fixing allNathan Scott
these typos. SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:25539a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_da_node_hdr_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25505a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_da_node_entry_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25504a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_attr_leaf_entry_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25498a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_attr_leaf_hdr_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25497a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_da_blkinfo_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25495a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] Complete transition away from linvfs naming convention, finally.Nathan Scott
SGI-PV: 947038 SGI-Modid: xfs-linux-melb:xfs-kern:25474a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] remove xfs xattr permission checksChristoph Hellwig
remove checks now in the VFS XFS has an additional xattr interface through obscure ioctl. it requires raised capabilities but we need to add some read-only/immutable checks anyway Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Make some extended attributes routines take const parameters, forNathan Scott
the FreeBSD porters. SGI-PV: 942906 SGI-Modid: xfs-linux:xfs-kern:23845a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Ondisk format extension for extended attributes (attr2). Basically,Nathan Scott
the data/attr forks now grow up/down from either end of the literal area, rather than dividing the literal area into two chunks and growing both upward. Means we can now make much more efficient use of the attribute space, incl. fitting DMF attributes inline in 256 byte inodes, and large jumps in dbench3 performance numbers. It is self enabling, but can be forced on/off via the attr2/noattr2 mount options. SGI-PV: 941645 SGI-Modid: xfs-linux:xfs-kern:23835a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Move some code around to prepare for the upcoming extendedNathan Scott
attributes format change (attr2). SGI-PV: 941645 SGI-Modid: xfs-linux:xfs-kern:23833a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-06-21[XFS] mark various symbols static Patch from Adrian BunkChristoph Hellwig
SGI-PV: 936255 SGI-Modid: xfs-linux:xfs-kern:192760a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
