Reviewed-by: Dave Chinner <david@fromorbit.com>
Signed-off-by: Niv Sardi <xaiki@sgi.com>
No need to parse the mount option into a structure before applying it to
struct xfs_mount.
The content of xfs_start_flags gets merged into xfs_parseargs. Calls
inbetween don't care and can use mount members instead of the args struct.
This patch uncovered that the mount option for shared filesystems wasn't
ever exposed on Linux. The code to handle it is #if 0'ed in this patch
pending a decision on this feature. I'll send a writeup about it to the
list soon.
SGI-PV: 987246
SGI-Modid: xfs-linux-melb:xfs-kern:32371a
Signed-off-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Donald Douwsma <donaldd@sgi.com>
Signed-off-by: David Chinner <david@fromorbit.com>
Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
Remove all the useless flags and code keyed off it in xfs_mountfs.
SGI-PV: 981498
SGI-Modid: xfs-linux-melb:xfs-kern:31831a
Remove macro-to-small-function indirection from xfs_sb.h, and remove some
which are completely unused.
SGI-PV: 976035
SGI-Modid: xfs-linux-melb:xfs-kern:30528a
Signed-off-by: Eric Sandeen <sandeen@sandeen.net>
Mount options are now parsed by the main XFS module and rejected if quota
support is not available, and there are some new quota operation for the
quotactl syscall and calls to quote in the mount, unmount and sync
callchains.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29503a
Signed-off-by: David Chinner <dgc@sgi.com>
Signed-off-by: Tim Shimmin <tes@sgi.com>
Now that struct bhv_vnode is empty we can just kill it. Retain bhv_vnode_t
as a typedef for struct inode for the time being until all the fallout is
cleaned up.
SGI-PV: 969608
SGI-Modid: xfs-linux-melb:xfs-kern:29500a
xfs_mac.h and xfs_cap.h provide definitions and macros that aren't used
anywhere in XFS at all. They are left-overs from "to be implement at some
point in the future" functionality that Irix XFS has. If this
functionality ever goes into Linux, it will be provided at a different
layer, most likely through the security hooks in the kernel so we will
never need this functionality in XFS.
Patch provided by Eric Sandeen (sandeen@sandeen.net).
SGI-PV: 960895
SGI-Modid: xfs-linux-melb:xfs-kern:28036a
gcc-4.1 and more recent aggressively inline static functions which
increases XFS stack usage by ~15% in critical paths. Prevent this from
occurring by adding noinline to the STATIC definition.
Also uninline some functions that are too large to be inlined and were
causing problems with CONFIG_FORCED_INLINING=y.
Finally, clean up all the different users of inline, __inline and
__inline__ and put them under one STATIC_INLINE macro. For debug kernels
the STATIC_INLINE macro uninlines those functions.
SGI-PV: 957159
SGI-Modid: xfs-linux-melb:xfs-kern:27585a
Signed-off-by: David Chatterton <chatz@sgi.com>
SGI-PV: 955993
SGI-Modid: xfs-linux-melb:xfs-kern:26934a
Signed-off-by: Nathan Scott <nathans@sgi.com>
Before putting them into struct statfs they should be endian-swapped.
SGI-PV: 954580
SGI-Modid: xfs-linux-melb:xfs-kern:26550a
pure bloat.
SGI-PV: 952969
SGI-Modid: xfs-linux-melb:xfs-kern:26251a
porters.
SGI-PV: 953338
SGI-Modid: xfs-linux-melb:xfs-kern:26108a
SGI-PV: 953338
SGI-Modid: xfs-linux-melb:xfs-kern:26107a
SGI-PV: 9533338
SGI-Modid: xfs-linux-melb:xfs-kern:26106a
originally by Glen.
SGI-PV: 932952
SGI-Modid: xfs-linux-melb:xfs-kern:26105a
Engelhardt.
SGI-PV: 947038
SGI-Modid: xfs-linux-melb:xfs-kern:25529a
This patch switches XFS over to use the new mutex code directly as
opposed to the previous workaround patch I posted earlier that avoided
the namespace clash by forcing it back to semaphores. This falls in the
'works for me<tm>' category.
Signed-off-by: Jes Sorensen <jes@trained-monkey.org>
boilerplate.
SGI-PV: 913862
SGI-Modid: xfs-linux:xfs-kern:23917a
SGI-PV: 943122
SGI-Modid: xfs-linux:xfs-kern:23901a
having previously mounted with quotas.
SGI-PV: 940491
SGI-Modid: xfs-linux:xfs-kern:23388a
SGI-PV: 932952
SGI-Modid: xfs-linux:xfs-kern:22805a
SGI-PV: 936255
SGI-Modid: xfs-linux:xfs-kern:192760a
Signed-off-by: Christoph Hellwig <hch@sgi.com>
infrastructure for it.
Let it rip!
