commit 6b0d144fa758869bdd652c50aa41aaf601232550 upstream.
There were 3 remaining users; in two of them we took ->s_lock immediately
after lock_ufs() and held it until just before unlock_ufs(); the third
one (statfs) could not be called from itself or from other two (remount
and sync_fs). Just use ->s_lock in statfs and don't bother with lock_ufs
at all.
* stores to block pointers are under per-inode seqlock (meta_lock) and
mutex (truncate_mutex)
* fetches of block pointers are either under truncate_mutex, or wrapped
into seqretry loop on meta_lock
* all changes of ->i_size are under truncate_mutex and i_mutex
* all changes of ->i_lastfrag are under truncate_mutex
It's similar to what ext2 is doing; the main difference is that unlike
ext2 we can't rely upon the atomicity of stores into block pointers -
on UFS2 they are 64bit. So we can't cut the corner when switching
a pointer from NULL to non-NULL as we could in ext2_splice_branch()
and need to use meta_lock on all modifications.
We use seqlock where ext2 uses rwlock; ext2 could probably also benefit
from such change...
Another non-trivial difference is that with UFS we *cannot* have reader
grab truncate_mutex in case of race - it has to keep retrying. That
might be possible to change, but not until we lift tail unpacking
several levels up in call chain.
After that commit we do *NOT* hold fs-wide serialization on accesses
to block pointers anymore. Moreover, lock_ufs() can become a normal
mutex now - it's only used on statfs, remount and sync_fs and none
of those uses are recursive. As the matter of fact, *now* it can be
collapsed with ->s_lock, and be eventually replaced with saner
per-cylinder-group spinlocks, but that's a separate story.
Pull more vfs updates from Al Viro:
"Assorted VFS fixes and related cleanups (IMO the most interesting in
that part are f_path-related things and Eric's descriptor-related
stuff). UFS regression fixes (it got broken last cycle). 9P fixes.
fs-cache series, DAX patches, Jan's file_remove_suid() work"
[ I'd say this is much more than "fixes and related cleanups". The
file_table locking rule change by Eric Dumazet is a rather big and
fundamental update even if the patch isn't huge. - Linus ]
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits)
9p: cope with bogus responses from server in p9_client_{read,write}
p9_client_write(): avoid double p9_free_req()
9p: forgetting to cancel request on interrupted zero-copy RPC
dax: bdev_direct_access() may sleep
block: Add support for DAX reads/writes to block devices
dax: Use copy_from_iter_nocache
dax: Add block size note to documentation
fs/file.c: __fget() and dup2() atomicity rules
fs/file.c: don't acquire files->file_lock in fd_install()
fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation
vfs: avoid creation of inode number 0 in get_next_ino
namei: make set_root_rcu() return void
make simple_positive() public
ufs: use dir_pages instead of ufs_dir_pages()
pagemap.h: move dir_pages() over there
remove the pointless include of lglock.h
fs: cleanup slight list_entry abuse
xfs: Correctly lock inode when removing suid and file capabilities
fs: Call security_ops->inode_killpriv on truncate
fs: Provide function telling whether file_remove_privs() will do anything
Add last missing line in commit "cdd9eefdf905"
("fs/ufs: restore s_lock mutex")
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Commit 0244756edc4b98c ("ufs: sb mutex merge + mutex_destroy") generated
deadlocks in read/write mode on mkdir.
This patch partially reverts it keeping fixes by Andrew Morton and
mutex_destroy()
[AV: fixed a missing bit in ufs_remount()]
Reported-by: Ian Campbell <ian.campbell@citrix.com>
Suggested-by: Jan Kara <jack@suse.cz>
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Evgeniy Dushistov <dushistov@mail.ru>
Cc: Alexey Khoroshilov <khoroshilov@ispras.ru>
Cc: Roger Pau Monne <roger.pau@citrix.com>
Cc: Ian Jackson <Ian.Jackson@eu.citrix.com>
Cc: <stable@vger.kernel.org>
With the planned cgroup writeback support, backing-dev related
declarations will be more widely used across block and cgroup;
unfortunately, including backing-dev.h from include/linux/blkdev.h
makes cyclic include dependency quite likely.
This patch separates out backing-dev-defs.h which only has the
essential definitions and updates blkdev.h to include it. c files
which need access to more backing-dev details now include
backing-dev.h directly. This takes backing-dev.h off the common
include dependency chain making it a lot easier to use it across block
and cgroup.
v2: fs/fat build failure fixed.
Signed-off-by: Jens Axboe <axboe@fb.com>
that's the bulk of filesystem drivers dealing with inodes of their own
Let locking subsystem decide on mutex management. As reported by Andrew
Morton this patch fixes a bug:
: lock_ufs() is assuming that on non-preempt uniprocessor, the calling
: code will run atomically up to the matching unlock_ufs().
: But that isn't true. The very first site I looked at (ufs_frag_map)
: does sb_bread() under lock_ufs(). And sb_bread() will call schedule(),
: very commonly.
: The ->mutex_owner stuff is a bit hacky but should work OK.
Fix the following coccinelle warning:
fs/ufs/super.c:1418:7-28: WARNING: casting value returned by memory allocation function to (struct ufs_inode_info *) is useless.
Cc: Joe Perches <joe@perches.com>
Convert no level printk to pr_debug in UFSD. DEBUG is defined with
CONFIG_UFS_DEBUG so pr_debug are emitted here.
Also fixing call to UFSD (add;)
Remove error_buffer and use %pV
Replace approximate function name by __func__ using standard format
"function():"
Replace UFS-fs, UFS-fs: and UFS: by pr_fmt with module name "ufs: "
Use current logging functions.
- no level printk under CONFIG_UFS_DEBUG converted to pr_debug
- no level printk elsewhere converted to pr_err
- add DDEBUG flag in Makefile
- coalesce formats
Commit 788257d6101d ("ufs: remove the BKL") replaced BKL with mutex
protection using functions lock_ufs, unlock_ufs and struct mutex 'mutex'
in sb_info.
Commit b6963327e052 ("ufs: drop lock/unlock super") removed lock/unlock
super and added struct mutex 's_lock' in sb_info.
Those 2 mutexes are generally locked/unlocked at the same time except in
allocation (balloc, ialloc).
This patch merges the 2 mutexes and propagates first commit solution.
It also adds mutex destruction before kfree during ufs_fill_super
failure and ufs_put_super.
[akpm@linux-foundation.org: avoid ifdefs, return -EROFS not -EINVAL]
Cc: "Chen, Jet" <jet.chen@intel.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Pointer 'usb3' to struct ufs_super_block_third acquired via
ubh_get_usb_third() is never used in function
ufs_read_cylinder_structures(). Thus remove it.
Detected by Coverity: CID 139939.
Signed-off-by: Christian Engelmayer <cengelma@gmx.at>
Pointer 'usb2' to struct ufs_super_block_second acquired via
ubh_get_usb_second() is never used in function ufs_statfs(). Thus
remove it.
Detected by Coverity: CID 139940.
Remove occurences of unused pointers to struct ufs_super_block_first
that were acquired via ubh_get_usb_first().
Detected by Coverity: CID 139929 - CID 139936, CID 139940.
init_inodecache is only called by __init init_ufs_fs.
Previously, the no-op "mount -o mount /dev/xxx" operation when the
file system is already mounted read-write causes an implied,
unconditional syncfs(). This seems pretty stupid, and it's certainly
documented or guaraunteed to do this, nor is it particularly useful,
except in the case where the file system was mounted rw and is getting
remounted read-only.
However, it's possible that there might be some file systems that are
actually depending on this behavior. In most file systems, it's
probably fine to only call sync_filesystem() when transitioning from
read-write to read-only, and there are some file systems where this is
not needed at all (for example, for a pseudo-filesystem or something
like romfs).
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: linux-fsdevel@vger.kernel.org
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Jan Kara <jack@suse.cz>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Anders Larsen <al@alarsen.net>
Cc: Phillip Lougher <phillip@squashfs.org.uk>
Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Cc: Petr Vandrovec <petr@vandrovec.name>
Cc: xfs@oss.sgi.com
Cc: linux-btrfs@vger.kernel.org
Cc: linux-cifs@vger.kernel.org
Cc: samba-technical@lists.samba.org
Cc: codalist@coda.cs.cmu.edu
Cc: linux-ext4@vger.kernel.org
Cc: linux-f2fs-devel@lists.sourceforge.net
Cc: fuse-devel@lists.sourceforge.net
Cc: cluster-devel@redhat.com
Cc: linux-mtd@lists.infradead.org
Cc: jfs-discussion@lists.sourceforge.net
Cc: linux-nfs@vger.kernel.org
Cc: linux-nilfs@vger.kernel.org
Cc: linux-ntfs-dev@lists.sourceforge.net
Cc: ocfs2-devel@oss.oracle.com
Cc: reiserfs-devel@vger.kernel.org
Modify the request_module to prefix the file system type with "fs-"
and add aliases to all of the filesystems that can be built as modules
to match.
A common practice is to build all of the kernel code and leave code
that is not commonly needed as modules, with the result that many
users are exposed to any bug anywhere in the kernel.
Looking for filesystems with a fs- prefix limits the pool of possible
modules that can be loaded by mount to just filesystems trivially
making things safer with no real cost.
Using aliases means user space can control the policy of which
filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf
with blacklist and alias directives. Allowing simple, safe,
well understood work-arounds to known problematic software.
This also addresses a rare but unfortunate problem where the filesystem
name is not the same as it's module name and module auto-loading
would not work. While writing this patch I saw a handful of such
cases. The most significant being autofs that lives in the module
autofs4.
This is relevant to user namespaces because we can reach the request
module in get_fs_type() without having any special permissions, and
people get uncomfortable when a user specified string (in this case
the filesystem type) goes all of the way to request_module.
After having looked at this issue I don't think there is any
particular reason to perform any filtering or permission checks beyond
making it clear in the module request that we want a filesystem
module. The common pattern in the kernel is to call request_module()
without regards to the users permissions. In general all a filesystem
module does once loaded is call register_filesystem() and go to sleep.
Which means there is not much attack surface exposed by loading a
filesytem module unless the filesystem is mounted. In a user
namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT,
which most filesystems do not set today.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Reported-by: Kees Cook <keescook@google.com>
Removed lock/unlock super. Added a new private s_lock mutex.
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
There's no reason to call rcu_barrier() on every
deactivate_locked_super(). We only need to make sure that all delayed rcu
free inodes are flushed before we destroy related cache.
Removing rcu_barrier() from deactivate_locked_super() affects some fast
paths. E.g. on my machine exit_group() of a last process in IPC
namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time.
This patch makes UFS stop using the VFS '->write_super()' method along with
the 's_dirt' superblock flag, because they are on their way out.
The way we implement this is that we schedule a delay job instead relying on
's_dirt' and '->write_super()'.
The whole "superblock write-out" VFS infrastructure is served by the
'sync_supers()' kernel thread, which wakes up every 5 (by default) seconds and
writes out all dirty superblocks using the '->write_super()' call-back. But the
problem with this thread is that it wastes power by waking up the system every
5 seconds, even if there are no diry superblocks, or there are no client
file-systems which would need this (e.g., btrfs does not use
'->write_super()'). So we want to kill it completely and thus, we need to make
file-systems to stop using the '->write_super()' VFS service, and then remove
it together with the kernel thread.
Tested using fsstress from the LTP project.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
This patch does not do any functional changes. It only moves 3 functions
in fs/ufs/super.c a little bit up in order to prepare for further changes
where I'll need this new arrangement to avoid forward declarations.
UFS calls 'ufs_write_super()' from 'ufs_put_super()' in order to write the
superblocks to the media. However, it is not needed because VFS calls
'->sync_fs()' before calling '->put_super()' - so by the time we are in
'ufs_write_super()', the superblocks are already synchronized.
This allows comparing hash and len in one operation on 64-bit
architectures. Right now only __d_lookup_rcu() takes advantage of this,
since that is the case we care most about.
The use of anonymous struct/unions hides the alternate 64-bit approach
from most users, the exception being a few cases where we initialize a
'struct qstr' with a static initializer. This makes the problematic
cases use a new QSTR_INIT() helper function for that (but initializing
just the name pointer with a "{ .name = xyzzy }" initializer remains
valid, as does just copying another qstr structure).
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
New field of struct super_block - ->s_max_links. Maximal allowed
value of ->i_nlink or 0; in the latter case all checks still need
to be done in ->link/->mkdir/->rename instances. Note that this
limit applies both to directoris and to non-directories.
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into
it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once();
the cost of taking it into inode_init_always() will be negligible for pipes
and sockets and negative for everything else. Not to mention the removal of
boilerplate code from ->destroy_inode() instances...
This introduces a new per-superblock mutex in UFS to replace
the big kernel lock. I have been careful to avoid nested
calls to lock_ufs and to get the lock order right with
respect to other mutexes, in particular lock_super.
I did not make any attempt to prove that the big kernel
lock is not needed in a particular place in the code,
which is very possible.
The mutex has a significant performance impact, so it is only
used on SMP or PREEMPT configurations.
As Nick Piggin noticed, any allocation inside of the lock
may end up deadlocking when we get to ufs_getfrag_block
in the reclaim task, so we now use GFP_NOFS.
Tested-by: Nick Bowler <nbowler@elliptictech.com>
Cc: Nick Piggin <npiggin@gmail.com>
RCU free the struct inode. This will allow:
- Subsequent store-free path walking patch. The inode must be consulted for
permissions when walking, so an RCU inode reference is a must.
- sb_inode_list_lock to be moved inside i_lock because sb list walkers who want
to take i_lock no longer need to take sb_inode_list_lock to walk the list in
the first place. This will simplify and optimize locking.
- Could remove some nested trylock loops in dcache code
- Could potentially simplify things a bit in VM land. Do not need to take the
page lock to follow page->mapping.
The downsides of this is the performance cost of using RCU. In a simple
creat/unlink microbenchmark, performance drops by about 10% due to inability to
reuse cache-hot slab objects. As iterations increase and RCU freeing starts
kicking over, this increases to about 20%.
In cases where inode lifetimes are longer (ie. many inodes may be allocated
during the average life span of a single inode), a lot of this cache reuse is
not applicable, so the regression caused by this patch is smaller.
The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU,
however this adds some complexity to list walking and store-free path walking,
so I prefer to implement this at a later date, if it is shown to be a win in
real situations. I haven't found a regression in any non-micro benchmark so I
doubt it will be a problem.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
... and switch of the obvious get_sb_bdev() users to ->mount()
This patch is a preparation necessary to remove the BKL from do_new_mount().
It explicitly adds calls to lock_kernel()/unlock_kernel() around
get_sb/fill_super operations for filesystems that still uses the BKL.
I've read through all the code formerly covered by the BKL inside
do_kern_mount() and have satisfied myself that it doesn't need the BKL
any more.
do_kern_mount() is already called without the BKL when mounting the rootfs
and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called
from various places without BKL: simple_pin_fs(), nfs_do_clone_mount()
through nfs_follow_mountpoint(), afs_mntpt_do_automount() through
afs_mntpt_follow_link(). Both later functions are actually the filesystems
follow_link inode operation. vfs_kern_mount() is calling the specified
get_sb function and lets the filesystem do its job by calling the given
fill_super function.
Therefore I think it is safe to push down the BKL from the VFS to the
low-level filesystems get_sb/fill_super operation.
[arnd: do not add the BKL to those file systems that already
don't use it elsewhere]
Signed-off-by: Jan Blunck <jblunck@infradead.org>
Cc: Matthew Wilcox <matthew@wil.cx>
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6:
quota: Convert quota statistics to generic percpu_counter
ext3 uses rb_node = NULL; to zero rb_root.
quota: Fixup dquot_transfer
reiserfs: Fix resuming of quotas on remount read-write
pohmelfs: Remove dead quota code
ufs: Remove dead quota code
udf: Remove dead quota code
quota: rename default quotactl methods to dquot_
quota: explicitly set ->dq_op and ->s_qcop
quota: drop remount argument to ->quota_on and ->quota_off
quota: move unmount handling into the filesystem
quota: kill the vfs_dq_off and vfs_dq_quota_on_remount wrappers
quota: move remount handling into the filesystem
ocfs2: Fix use after free on remount read-only
Fix up conflicts in fs/ext4/super.c and fs/ufs/file.c
I recently had to recover some files from an old broken machine that was
running BorderWare Document Gateway. It's basically a drop in web server
for sharing files. From the look of the init process and using strings on
of a few files it seems to be based on FreeBSD 3.3.
The process turned out to be more difficult than I imagined, but to cut a
long story short BorderWare in their wisdom use a nonstandard magic number
in their UFS (ufstype=44bsd) file systems. Thus Linux refuses to mount
the file systems in order to recover the data. After a bit of hunting I
was able to make a quick fix to fs/ufs/super.c in order to detect the new
magic number.
I assume that this number is the same for all installations. It's quite
easy to find out from ufs_fs.h. The superblock sits 8k into the block
device and the magic number its 1372 bytes into the superblock struct.
# dd if=/dev/sda5 skip=$(( 8192 + 1372 )) bs=1 count=4 2> /dev/null | hd
00000000 97 26 24 0f |.&$.|
Signed-off-by: Thomas Stewart <thomas@stewarts.org.uk>
UFS quota is non-functional at least since 2.6.12 because dq_op was set
to NULL. Since the filesystem exists mainly to allow cooperation with Solaris
and quota format isn't standard, just remove the dead code.
CC: Evgeniy Dushistov <dushistov@mail.ru>
Follow the dquot_* style used elsewhere in dquot.c.
[Jan Kara: Fixed up missing conversion of ext2]
Only set the quota operation vectors if the filesystem actually supports
quota instead of doing it for all filesystems in alloc_super().
[Jan Kara: Export dquot_operations and vfs_quotactl_ops]
Currently the VFS calls into the quotactl interface for unmounting
filesystems. This means filesystems with their own quota handling
can't easily distinguish between user-space originating quotaoff
and an unount. Instead move the responsibily of the unmount handling
into the filesystem to be consistent with all other dquot handling.
Note that we do call dquot_disable a lot later now, e.g. after
a sync_filesystem. But this is fine as the quota code does all its
writes via blockdev's mapping and that is synced even later.
Instead of having wrappers in the VFS namespace export the dquot_suspend
and dquot_resume helpers directly. Also rename vfs_quota_disable to
dquot_disable while we're at it.
[Jan Kara: Moved dquot_suspend to quotaops.h and made it inline]
Currently do_remount_sb calls into the dquot code to tell it about going
from rw to ro and ro to rw. Move this code into the filesystem to
not depend on the dquot code in the VFS - note ocfs2 already ignores
these calls and handles remount by itself. This gets rid of overloading
the quotactl calls and allows to unify the VFS and XFS codepaths in
that area later.
Recent releases of Solaris set the fs_clean state of an unmounted UFS file
system as FSLOG ("logging fs"). However, the Linux kernel currently does
not recognize the value which represents this state. Thus, attempting to
mount such a file system rw produces the message
kernel: ufs_read_super: can't grok fs_clean 0xfffffffd
and the file system is mounted read-only. This patch makes the kernel
recognize that value.
Signed-off-by: Alex Viskovatoff <viskovatoff@imap.cc>
Get rid of the drop dquot operation - it is now always called from
the filesystem and if a filesystem really needs it's own (which none
currently does) it can just call into it's own routine directly.
Rename the now static low-level dquot_drop helper to __dquot_drop
and vfs_dq_drop to dquot_drop to have a consistent namespace.
Currently clear_inode calls vfs_dq_drop directly. This means
we tie the quota code into the VFS. Get rid of that and make the
filesystem responsible for the drop inside the ->clear_inode
superblock operation.
