path: root/fs/ufs/file.c
2009-06-11switch ufs to simple_fsync()Al Viro
2009-05-09switch ufs directories to ufs_sync_file()Al Viro
2008-02-08drop linux/ufs_fs.h from userspace export and relocate it to fs/ufs/ufs_fs.hMike Frysinger
Per previous discussions about cleaning up ufs_fs.h, people just want this straight up dropped from userspace export. The only remaining consumer (silo) has been fixed a while ago to not rely on this header. This allows use to move it completely from include/linux/ to fs/ufs/ seeing as how the only in-kernel consumer is fs/ufs/. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Jan Kara <jack@ucw.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ufs: move non-layout parts of ufs_fs.h to fs/ufs/Christoph Hellwig
Move prototypes and in-core structures to fs/ufs/ similar to what most other filesystems already do. I made little modifications: move also ufs debug macros and mount options constants into fs/ufs/ufs.h, this stuff also private for ufs. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] ufs: truncate should allocate block for last byteEvgeniy Dushistov
This patch fixes buggy behaviour of UFS in such kind of scenario: open(, O_TRUNC...) ftruncate(, 1024) ftruncate(, 0) Such a scenario causes ufs_panic and remount read-only. This happen because of according to specification UFS should always allocate block for last byte, and many parts of our implementation rely on this, but `ufs_truncate' doesn't care about this. To make possible return error code and to know about old size, this patch removes `truncate' from ufs inode_operations and uses `setattr' method to call ufs_truncate. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: fsync implementationEvgeniy Dushistov
Presently ufs doesn't support "fsync", this make some applications unhappy, for example vim. This patch fixes this situation. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] fs/ufs/file.c: drop insane header dependenciesAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
