path: root/fs/udf/udfdecl.h
2010-04-08udf: add speciffic ->setattr callbackDmitry Monakhov
generic setattr not longer responsible for quota transfer. use udf_setattr for all udf's inodes. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11switch udf to simple_fsync()Al Viro
2009-04-02udf: Don't write integrity descriptor too oftenJan Kara
We update information in logical volume integrity descriptor after each allocation (as LVID contains free space, number of directories and files on disk etc.). If the filesystem is on some phase change media, this leads to its quick degradation as such media is able to handle only 10000 overwrites or so. We solve the problem by writing new information into LVID only on umount, remount-ro and sync. This solves the problem at the price of longer media inconsistency (previously media became consistent after pdflush flushed dirty LVID buffer) but that should be acceptable. Report by and patch written in cooperation with Rich Coe <Richard.Coe@med.ge.com>. Signed-off-by: Jan Kara <jack@suse.cz>
2009-04-02Fix the udf code not to pass structs on stack where possible.Pekka Enberg
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Jan Kara <jack@suse.cz>
2009-04-02Remove struct typedefs from fs/udf/ecma_167.h et al.Pekka Enberg
2008-06-16udf: restore UDFFS_DEBUG to being undefined by defaultPaul Collins
Commit 706047a79725b585cf272fdefc234b31b6545c72, "udf: Fix compilation warnings when UDF debug is on" inadvertently (I assume) enabled debugging messages by default for UDF. This patch disables them again. Signed-off-by: Paul Collins <paul@ondioline.org> Signed-off-by: Jan Kara <jack@suse.cz>
2008-05-07udf: Make udf exportableRasmus Rohde
Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Rasmus Rohde <rohde@duff.dk> Signed-off-by: Jan Kara <jack@suse.cz>
2008-04-17udf: use crc_itu_t from lib instead of udf_crcBob Copeland
As pointed out by Sergey Vlasov, UDF implements its own version of the CRC ITU-T V.41. Convert it to use the one in the library. Signed-off-by: Bob Copeland <me@bobcopeland.com> Cc: Sergey Vlasov <vsu@altlinux.ru> Signed-off-by: Jan Kara <jack@suse.cz>
2008-04-17udf: Fix compilation warnings when UDF debug is onSebastian Manciulea
Fix two compilation warnings (and actual bugs in message formatting) when UDF debugging is turned on. Signed-off-by: Sebastian Manciulea <manciuleas@yahoo.com> Signed-off-by: Jan Kara <jack@suse.cz>
2008-04-17udf: Add read-only support for 2.50 UDF mediaJan Kara
This patch implements parsing of metadata partitions and reading of Metadata File thus allowing to read UDF 2.50 media. Error resilience is implemented through accessing the Metadata Mirror File in case the data the Metadata File cannot be read. The patch is based on the original patch by Sebastian Manciulea <manciuleas@yahoo.com> and Mircea Fedoreanu <mirceaf_spl@yahoo.com>. Signed-off-by: Sebastian Manciulea <manciuleas@yahoo.com> Signed-off-by: Mircea Fedoreanu <mirceaf_spl@yahoo.com> Signed-off-by: Jan Kara <jack@suse.cz>
2008-04-17udf: convert udf_stamp_to_time and udf_time_to_stamp to use timestampsMarcin Slusarz
* kernel_timestamp type was almost unused - only callers of udf_stamp_to_time and udf_time_to_stamp used it, so let these functions handle endianness internally and don't clutter code with conversions * rename udf_stamp_to_time to udf_disk_stamp_to_time and udf_time_to_stamp to udf_time_to_disk_stamp Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2008-04-17udf: convert udf_stamp_to_time to return struct timespecmarcin.slusarz@gmail.com
2008-04-17udf: replace udf_*_offset macros with functionsmarcin.slusarz@gmail.com
- translate udf_file_entry_alloc_offset macro into function - translate udf_ext0_offset macro into function - add comment about crypticly named fields in struct udf_inode_info Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2008-04-17udf: constify crcmarcin.slusarz@gmail.com
- constify internal crc table - mark udf_crc "in" parameter as const Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2008-04-17udf: udf_CS0toUTF8 cleanupmarcin.slusarz@gmail.com
- fix error handling - always zero output variable - don't zero explicitely fields zeroed by memset - mark "in" paramater as const - remove outdated comment Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2008-04-17make udf_error() staticAdrian Bunk
This patch makes the needlessly global udf_error() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jan Kara <jack@suse.cz>
2008-04-17udf: move headers out include/linux/Christoph Hellwig
There's really no reason to keep udf headers in include/linux as they're not used by anything but fs/udf/. This patch merges most of include/linux/udf_fs_i.h into fs/udf/udf_i.h, include/linux/udf_fs_sb.h into fs/udf/udf_sb.h and include/linux/udf_fs.h into fs/udf/udfdecl.h. The only thing remaining in include/linux/ is a stub of udf_fs_i.h defining the four user-visible udf ioctls. It's also moved from unifdef-y to headers-y because it can be included unconditionally now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2008-02-08udf: fix 3 signedness & 1 unitialized variable warningsMarcin Slusarz
sparse generated: fs/udf/inode.c:324:41: warning: incorrect type in argument 4 (different signedness) fs/udf/inode.c:324:41: expected long *<noident> fs/udf/inode.c:324:41: got unsigned long *<noident> inode_getblk always set 4th argument to uint32_t value 3rd parameter of map_bh is sector_t (which is unsigned long or u64) so convert phys value to sector_t fs/udf/inode.c:1818:47: warning: incorrect type in argument 3 (different signedness) fs/udf/inode.c:1818:47: expected int *<noident> fs/udf/inode.c:1818:47: got unsigned int *<noident> fs/udf/inode.c:1826:46: warning: incorrect type in argument 3 (different signedness) fs/udf/inode.c:1826:46: expected int *<noident> fs/udf/inode.c:1826:46: got unsigned int *<noident> udf_get_filelongad and udf_get_shortad are called always for uint32_t values (struct extent_position->offset), so it's safe to convert offset parameter to uint32_t gcc warned: fs/udf/inode.c: In function 'udf_get_block': fs/udf/inode.c:299: warning: 'phys' may be used uninitialized in this function initialize it to 0 (if someday someone will break inode_getblk we will catch it immediately) Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Ben Fennema <bfennema@falcon.csc.calpoly.edu> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: remove UDF_I_* macros and open code themMarcin Slusarz
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: create common function for tag checksummingMarcin Slusarz
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21UDF: coding style conversion - lindent fixupsCyrill Gorcunov
This patch fixes up sources after conversion by Lindent. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19UDF: coding style conversion - lindentCyrill Gorcunov
This patch converts UDF coding style to kernel coding style using Lindent. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-16udf: fix possible leakage of blocksJan Kara
We have to take care that when we call udf_discard_prealloc() from udf_clear_inode() we have to write inode ourselves afterwards (otherwise, some changes might be lost leading to leakage of blocks, use of free blocks or improperly aligned extents). Also udf_discard_prealloc() does two different things - it removes preallocated blocks and truncates the last extent to exactly match i_size. We move the latter functionality to udf_truncate_tail_extent(), call udf_discard_prealloc() when last reference to a file is dropped and call udf_truncate_tail_extent() when inode is being removed from inode cache (udf_clear_inode() call). We cannot call udf_truncate_tail_extent() earlier as subsequent open+write would find the last block of the file mapped and happily write to the end of it, although the last extent says it's shorter. [akpm@linux-foundation.org: Make checkpatch.pl happier] Signed-off-by: Jan Kara <jack@suse.cz> Cc: Eric Sandeen <sandeen@sandeen.net> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08udf: use get_bh()Jan Kara
Make UDF use get_bh() instead of directly accessing b_count and use brelse() instead of udf_release_data() which does just brelse()... Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08UDF: introduce struct extent_positionJan Kara
Introduce a structure extent_position to store a position of an extent and the corresponding buffer_head in one place. Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08udf: use sector_t and loff_t for file offsetsJan Kara
Use sector_t and loff_t for file offsets in UDF filesystem. Otherwise an overflow may occur for long files. Also make inode_bmap() return offset in the extent in number of blocks instead of number of bytes - for most callers this is more convenient. Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 3Arjan van de Ven
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
