path: root/fs/udf/misc.c
2007-07-21UDF: coding style conversion - lindent fixupsCyrill Gorcunov
This patch fixes up sources after conversion by Lindent. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19UDF: coding style conversion - lindentCyrill Gorcunov
This patch converts UDF coding style to kernel coding style using Lindent. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08udf: use get_bh()Jan Kara
Make UDF use get_bh() instead of directly accessing b_count and use brelse() instead of udf_release_data() which does just brelse()... Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-03remove pointers to the defunct UDF mailing listAdrian Bunk
This patch removes pointers to the defunct UDF mailing list. Signed-off-by: Adrian Bunk <bunk@stusta.de>
