path: root/fs/udf/ialloc.c
2007-07-21UDF: coding style conversion - lindent fixupsCyrill Gorcunov
This patch fixes up sources after conversion by Lindent. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19UDF: coding style conversion - lindentCyrill Gorcunov
This patch converts UDF coding style to kernel coding style using Lindent. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16UDF: check for allocated memory for data of new inodesCyrill Gorcunov
Add checking for granted memory for inode data at the moment of its creation. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-27[PATCH] fs: Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to kzalloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] udf: initialize parts of inode earlier in createEric Sandeen
I saw an oops down this path when trying to create a new file on a UDF filesystem which was internally marked as readonly, but mounted rw: udf_create udf_new_inode new_inode alloc_inode udf_alloc_inode udf_new_block returns EIO due to readonlyness iput (on error) udf_put_inode udf_discard_prealloc udf_next_aext udf_current_aext udf_get_fileshortad OOPS the udf_discard_prealloc() path was examining uninitialized fields of the udf inode. udf_discard_prealloc() already has this code to short-circuit the discard path if no extents are preallocated: if (UDF_I_ALLOCTYPE(inode) == ICBTAG_FLAG_AD_IN_ICB || inode->i_size == UDF_I_LENEXTENTS(inode)) { return; } so if we initialize UDF_I_LENEXTENTS(inode) = 0 earlier in udf_new_inode, we won't try to free the (not) preallocated blocks, since this will match the i_size = 0 set when the inode was initialized. Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: UDFIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03remove pointers to the defunct UDF mailing listAdrian Bunk
This patch removes pointers to the defunct UDF mailing list. Signed-off-by: Adrian Bunk <bunk@stusta.de>
