This patch (as1420) adds sysfs_merge_group() and sysfs_unmerge_group()
functions, allowing drivers easily to add and remove sets of
attributes to a pre-existing attribute group directory.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
The problem. When implementing a network namespace I need to be able
to have multiple network devices with the same name. Currently this
is a problem for /sys/class/net/*, /sys/devices/virtual/net/*, and
potentially a few other directories of the form /sys/ ... /net/*.
What this patch does is to add an additional tag field to the
sysfs dirent structure. For directories that should show different
contents depending on the context such as /sys/class/net/, and
/sys/devices/virtual/net/ this tag field is used to specify the
context in which those directories should be visible. Effectively
this is the same as creating multiple distinct directories with
the same name but internally to sysfs the result is nicer.
I am calling the concept of a single directory that looks like multiple
directories all at the same path in the filesystem tagged directories.
For the networking namespace the set of directories whose contents I need
to filter with tags can depend on the presence or absence of hotplug
hardware or which modules are currently loaded. Which means I need
a simple race free way to setup those directories as tagged.
To achieve a reace free design all tagged directories are created
and managed by sysfs itself.
Users of this interface:
- define a type in the sysfs_tag_type enumeration.
- call sysfs_register_ns_types with the type and it's operations
- sysfs_exit_ns when an individual tag is no longer valid
- Implement mount_ns() which returns the ns of the calling process
so we can attach it to a sysfs superblock.
- Implement ktype.namespace() which returns the ns of a syfs kobject.
Everything else is left up to sysfs and the driver layer.
For the network namespace mount_ns and namespace() are essentially
one line functions, and look to remain that.
Tags are currently represented a const void * pointers as that is
both generic, prevides enough information for equality comparisons,
and is trivial to create for current users, as it is just the
existing namespace pointer.
The work needed in sysfs is more extensive. At each directory
or symlink creating I need to check if the directory it is being
created in is a tagged directory and if so generate the appropriate
tag to place on the sysfs_dirent. Likewise at each symlink or
directory removal I need to check if the sysfs directory it is
being removed from is a tagged directory and if so figure out
which tag goes along with the name I am deleting.
Currently only directories which hold kobjects, and
symlinks are supported. There is not enough information
in the current file attribute interfaces to give us anything
to discriminate on which makes it useless, and there are
no potential users which makes it an uninteresting problem
to solve.
Signed-off-by: Benjamin Thery <benjamin.thery@bull.net>
Use WARN() instead of a printk+WARN_ON() pair; this way the message becomes
part of the warning section for better reporting/collection. Also, with this,
one fo the if() sections collapses entirely into the WARN().
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
We have a problem in scsi_transport_spi in that we need to customise
not only the visibility of the attributes, but also their mode. Fix
this by making the is_visible() callback return a mode, with 0
indicating is not visible.
Also add a sysfs_update_group() API to allow us to change either the
visibility or mode of the files at any time on the fly.
Acked-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
It's possible that the caller of sysfs_remove_group messed up and passed in an attribute group that was not really registered to this kobject. But don't panic for such a foolish error, spit out a warning about what happened, and continue on our way safely.
Cc: Roland Dreier <rdreier@cisco.com>
Cc: Tejun Heo <htejun@gmail.com>
This patch allows the various users of attribute_groups to selectively
allow the appearance of group attributes. The primary consumer of
this will be the transport classes in which we currently have
elaborate attribute selection algorithms to do this same thing.
Acked-by: Greg KH <greg@kroah.com>
While shadow directories appear to be a good idea, the current scheme
of controlling their creation and destruction outside of sysfs appears
to be a locking and maintenance nightmare in the face of sysfs
directories dynamically coming and going. Which can now occur for
directories containing network devices when CONFIG_SYSFS_DEPRECATED is
not set.
This patch removes everything from the initial shadow directory support
that allowed the shadow directory creation to be controlled at a higher
level. So except for a few bits of sysfs_rename_dir everything from
commit b592fcfe7f06c15ec11774b5be7ce0de3aa86e73 is now gone.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Cleanup semaphore.h
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
As kobj sysfs dentries and inodes are gonna be made reclaimable,
dentry can't be used as naming token for sysfs file/directory, replace
kobj->dentry with kobj->sd. The only external interface change is
shadow directory handling. All other changes are contained in kobj
and sysfs.
Prevent permission checking from being performed when the kernel wants to
unconditionally remove a sysfs group, by introducing an kernel-only variant
of lookup_one_len(), lookup_one_len_kern().
Additionally, as sysfs_remove_group() does not check the return value of
the lookup before using it, a BUG_ON has been added to pinpoint the cause
of any problems potentially caused by this (and as a form of annotation).
Signed-off-by: James Morris <jmorris@namei.org>
Cc: Nagendra Singh Tomar <nagendra_tomar@adaptec.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Eric Paris <eparis@redhat.com>
is a problem for /sys/class/net/*.
What I want is a separate /sys/class/net directory in sysfs for each
network namespace, and I want to name each of them /sys/class/net.
I looked and the VFS actually allows that. All that is needed is
for /sys/class/net to implement a follow link method to redirect
lookups to the real directory you want.
Implementing a follow link method that is sensitive to the current
network namespace turns out to be 3 lines of code so it looks like a
clean approach. Modifying sysfs so it doesn't get in my was is a bit
trickier.
I am calling the concept of multiple directories all at the same path
in the filesystem shadow directories. With the directory entry really
at that location the shadow master.
The following patch modifies sysfs so it can handle a directory
structure slightly different from the kobject tree so I can implement
the shadow directories for handling /sys/class/net/.
Cc: Maneesh Soni <maneesh@in.ibm.com>
This patch prevents a race between IO and removing a file from sysfs.
It introduces a list of sysfs_buffers associated with a file at the inode.
Upon removal of a file the list is walked and the buffers marked orphaned.
IO to orphaned buffers fails with -ENODEV. The driver can safely free
associated data structures or be unloaded.
Signed-off-by: Oliver Neukum <oliver@neukum.name>
Acked-by: Maneesh Soni <maneesh@in.ibm.com>
Various filesystem drivers have grown a get_dentry() function that's a
duplicate of lookup_one_len, except that it doesn't take a maximum length
argument and doesn't check for \0 or / in the passed in filename.
Switch all these places to use lookup_one_len.
Cc: Greg KH <greg@kroah.com>
Cc: Paul Jackson <pj@sgi.com>
infrastructure for it.
Let it rip!
