path: root/fs/reiserfs
2006-12-02[NET]: Kill direct includes of asm/checksum.hAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-30Fix misc .c/.h comment typosMatt LaPlante
Fix various .c/.h typos in comments (no code changes). Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-25[PATCH] reiserfs: fmt bugfixAlexey Dobriyan
One reiserfs_warning() call uses %lu, but doesn't supply what to print. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] reiserfs: reset errval after initializing bitmap cacheJeff Mahoney
Callers after reiserfs_init_bitmap_cache() expect errval to contain -EINVAL until much later. If a condition fails before errval is reset later, reiserfs_fill_super() will mistakenly return 0, causing an Oops in do_add_mount(). This patch resets errval to -EINVAL after the call. I view this as a temporary fix and real error codes should be used throughout reiserfs_fill_super(). Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] separate bdi congestion functions from queue congestion functionsAndrew Morton
Separate out the concept of "queue congestion" from "backing-dev congestion". Congestion is a backing-dev concept, not a queue concept. The blk_* congestion functions are retained, as wrappers around the core backing-dev congestion functions. This proper layering is needed so that NFS can cleanly use the congestion functions, and so that CONFIG_BLOCK=n actually links. Cc: "Thomas Maier" <balagi@justmail.de> Cc: "Jens Axboe" <jens.axboe@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: David Howells <dhowells@redhat.com> Cc: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ReiserFS: Make sure all dentries refs are released before calling ↵David Howells
kill_block_super() Make sure all dentries refs are released before calling kill_block_super() so that the assumption that generic_shutdown_super() can completely destroy the dentry tree for there will be no external references holds true. What was being done in the put_super() superblock op, is now done in the kill_sb() filesystem op instead, prior to calling kill_block_super(). Changes made in [try #2]: (*) reiserfs_kill_sb() now checks that the superblock FS info pointer is set before trying to dereference it. Signed-off-by: David Howells <dhowells@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-07[PATCH] reiserfs: null pointer dereferencing in reiserfs_read_bitmap_blockEric Eric Sesterhenn
null pointer dereferencing in reiserfs_read_bitmap_block. Signed-off-by: Alexander Zarochentsev <zam@namesys.com> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/confighLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/configh: Remove all inclusions of <linux/config.h> Manually resolved trivial path conflicts due to removed files in the sound/oss/ subdirectory.
2006-10-04[PATCH] Remove unnecessary check in fs/reiserfs/inode.cEric Sesterhenn
Since all callers dereference dir, we dont need this check. Coverity id #337. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Cc: Jeff Mahoney <jeffm@suse.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-10-03BUG_ON conversion for fs/reiserfsEric Sesterhenn
This patch converts several if () BUG(); construct to BUG_ON(); which occupies less space, uses unlikely and is safer when BUG() is disabled. S_ISREG() has no side effects, so the conversion is safe. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03[PATCH] VFS: Make filldir_t and struct kstat deal in 64-bit inode numbersDavid Howells
These patches make the kernel pass 64-bit inode numbers internally when communicating to userspace, even on a 32-bit system. They are required because some filesystems have intrinsic 64-bit inode numbers: NFS3+ and XFS for example. The 64-bit inode numbers are then propagated to userspace automatically where the arch supports it. Problems have been seen with userspace (eg: ld.so) using the 64-bit inode number returned by stat64() or getdents64() to differentiate files, and failing because the 64-bit inode number space was compressed to 32-bits, and so overlaps occur. This patch: Make filldir_t take a 64-bit inode number and struct kstat carry a 64-bit inode number so that 64-bit inode numbers can be passed back to userspace. The stat functions then returns the full 64-bit inode number where available and where possible. If it is not possible to represent the inode number supplied by the filesystem in the field provided by userspace, then error EOVERFLOW will be issued. Similarly, the getdents/readdir functions now pass the full 64-bit inode number to userspace where possible, returning EOVERFLOW instead when a directory entry is encountered that can't be properly represented. Note that this means that some inodes will not be stat'able on a 32-bit system with old libraries where they were before - but it does mean that there will be no ambiguity over what a 32-bit inode number refers to. Note similarly that directory scans may be cut short with an error on a 32-bit system with old libraries where the scan would work before for the same reasons. It is judged unlikely that this situation will occur because modern glibc uses 64-bit capable versions of stat and getdents class functions exclusively, and that older systems are unlikely to encounter unrepresentable inode numbers anyway. [akpm: alpha build fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: monitor zeroing of i_nlinkDave Hansen
Some filesystems, instead of simply decrementing i_nlink, simply zero it during an unlink operation. We need to catch these in addition to the decrement operations. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: unlink: monitor i_nlinkDave Hansen
When a filesystem decrements i_nlink to zero, it means that a write must be performed in order to drop the inode from the filesystem. We're shortly going to have keep filesystems from being remounted r/o between the time that this i_nlink decrement and that write occurs. So, add a little helper function to do the decrements. We'll tie into it in a bit to note when i_nlink hits zero. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Vectorize aio_read/aio_write fileop methodsBadari Pulavarty
This patch vectorizes aio_read() and aio_write() methods to prepare for collapsing all aio & vectored operations into one interface - which is aio_read()/aio_write(). Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Michael Holzheu <HOLZHEU@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] reiserfs: eliminate minimum window size for bitmap searchingJeff Mahoney
When a file system becomes fragmented (using MythTV, for example), the bigalloc window searching ends up causing huge performance problems. In a file system presented by a user experiencing this bug, the file system was 90% free, but no 32-block free windows existed on the entire file system. This causes the allocator to scan the entire file system for each 128k write before backing down to searching for individual blocks. In the end, finding a contiguous window for all the blocks in a write is an advantageous special case, but one that can be found naturally when such a window exists anyway. This patch removes the bigalloc window searching, and has been proven to fix the test case described above. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] reiserfs: use generic_file_open for open() checksJeff Mahoney
The other common disk-based file systems (I checked ext[23], xfs, jfs) check to ensure that opens of files > 2 GB fail unless O_LARGEFILE is specified. They check via generic_file_open or their own open routine. ReiserFS doesn't have an f_op->open defined, and as such, it's possible to open files > 2 GB without O_LARGEFILE. This patch adds the f_op->open member to conform with the expected behavior. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] reiserfs: on-demand bitmap loadingJeff Mahoney
This is the patch the three previous ones have been leading up to. It changes the behavior of ReiserFS from loading and caching all the bitmaps as special, to treating the bitmaps like any other bit of metadata and just letting the system-wide caches figure out what to hang on to. Buffer heads are allocated on the fly, so there is no need to retain pointers to all of them. The caching of the metadata occurs when the data is read and updated, and is considered invalid and uncached until then. I needed to remove the vs-4040 check for performing a duplicate operation on a particular bit. The reason is that while the other sites for working with bitmaps are allowed to schedule, is_reusable() is called from do_balance(), which will panic if a schedule occurs in certain places. The benefit of on-demand bitmaps clearly outweighs a sanity check that depends on a compile-time option that is discouraged. [akpm@osdl.org: warning fix] Signed-off-by: Jeff Mahoney <jeffm@suse.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] reiserfs: reorganize bitmap loading functionsJeff Mahoney
This patch moves the bitmap loading code from super.c to bitmap.c The code is also restructured somewhat. The only difference between new format bitmaps and old format bitmaps is where they are. That's a two liner before loading the block to use the correct one. There's no need for an entirely separate code path. The load path is generally the same, with the pattern being to throw out a bunch of requests and then wait for them, then cache the metadata from the contents. Again, like the previous patches, the purpose is to set up for later ones. Update: There was a bug in the previously posted version of this that resulted in corruption. The problem was that bitmap 0 on new format file systems must be treated specially, and wasn't. A stupid bug with an easy fix. This is hopefully the last fix for the disaster that is the reiserfs bitmap patch set. If a bitmap block was full, first_zero_hint would end up at zero since it would never be changed from it's zeroed out value. This just sets it beyond the end of the bitmap block. If any bits are freed, it will be reset to a valid bit. When info->free_count = 0, then we already know it's full. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] reiserfs: clean up bitmap block buffer head referencesJeff Mahoney
Similar to the SB_JOURNAL cleanup that was accepted a while ago, this patch uses a temporary variable for buffer head references from the bitmap info array. This makes the code much more readable in some areas. It also uses proper reference counting, doing a get_bh() after using the pointer from the array and brelse()'ing it later. This may seem silly, but a later patch will replace the simple temporary variables with an actual read, so the reference freeing will be used then. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] reiserfs: fix is_reusable bitmap check to not traverse the bitmap ↵Jeff Mahoney
info array There is a check in is_reusable to determine if a particular block is a bitmap block. It verifies this by going through the array of bitmap block buffer heads and comparing the block number to each one. Bitmap blocks are at defined locations on the disk in both old and current formats. Simply checking against the known good values is enough. This is a trivial optimization for a non-production codepath, but this is the first in a series of patches that will ultimately remove the buffer heads from that array. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Move the ReiserFS device ioctl compat stuff to the ReiserFS ↵David Howells
driver [try #6] Move the ReiserFS device ioctl compat stuff from fs/compat_ioctl.c to the ReiserFS driver so that the ReiserFS header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-29[PATCH] reiserfs: ifdef ACL stuff from inodeAlexey Dobriyan
Shrink reiserfs inode more (by 8 bytes) for ACL non-users: -reiser_inode_cache 344 11 +reiser_inode_cache 336 11 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] reiserfs: ifdef xattr_semAlexey Dobriyan
Shrink reiserfs inode by 12 bytes for xattr non-users (me). -reiser_inode_cache 356 11 +reiser_inode_cache 344 11 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Fix reiserfs latencies caused by data=orderedChris Mason
ReiserFS does periodic cleanup of old transactions in order to limit the length of time a journal replay may take after a crash. Sometimes, writing metadata from an old (already committed) transaction may require committing a newer transaction, which also requires writing all data=ordered buffers. This can cause very long stalls on journal_begin. This patch makes sure new transactions will not need to be committed before trying a periodic reclaim of an old transaction. It is low risk because if a bad decision is made, it just means a slightly longer journal replay after a crash. Signed-off-by: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] reiserfs_fsync should only use barriers when they are enabledChris Mason
make sure that reiserfs_fsync only triggers barriers when mounted with -o barrier=flush Signed-off-by: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] use gcc -O1 in fs/reiserfs only for ancient gcc versionsOlaf Hering
Only compile with -O1 if the (very old) compiler is broken. We use reiserfs alot since SLES9 on ppc64, and it was never seen with gcc33. Assume the broken gcc is gcc-3.4 or older. Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] reiserfs: warn about the useless nolargeio optionAdrian Bunk
Since the nolargeio option no longer has any effect, print a warning instead of setting a write-only variable. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <mason@suse.com> Cc: Hans Reiser <reiser@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Really ignore kmem_cache_destroy return valueAlexey Dobriyan
* Rougly half of callers already do it by not checking return value * Code in drivers/acpi/osl.c does the following to be sure: (void)kmem_cache_destroy(cache); * Those who check it printk something, however, slab_error already printed the name of failed cache. * XFS BUGs on failed kmem_cache_destroy which is not the decision low-level filesystem driver should make. Converted to ignore. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27[PATCH] lockdep: annotate reiserfsIngo Molnar
reiserfs seems to have another locking level layer for the i_mutex due to the xattrs-are-a-directory thing. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] reiserfs_write_full_page() should not get_block past eofChris Mason
reiserfs_write_full_page does zero bytes in the file past eof, but it may call get_block on those buffers as well. On machines where the page size is larger than the blocksize, this can result in mmaped files incorrectly growing up to a block boundary during writepage. The fix is to avoid calling get_block for any blocks that are entirely past eof Signed-off-by: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] fix reiserfs lock inversion of bkl vs inode semaphoreChris Mason
The correct lock ordering is inode lock -> BKL Signed-off-by: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] i_mutex does not need to be locked in reiserfs_delete_inode()Alexander Zarochentsev
Fixes an i_mutex-inside-i_mutex lockdep nasty. Signed-off-by: Alexander Zarochentsev <zam@namesys.com> Cc: <reiserfs-dev@namesys.com> Cc: Hans Reiser <reiser@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] reiserfs: fix handling of device names with /'s in themJeff Mahoney
On systems with block devices containing a slash (virtual dasd, cciss, etc), reiserfs will fail to initialize /proc/fs/reiserfs/<dev> due to it being interpreted as a subdirectory. The generic block device code changes the / to ! for use in the sysfs tree. This patch uses that convention. Tested by making dm devices use dm/<number> rather than dm-<number> [akpm@osdl.org: name variables consistently] Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] reiserfs: fix journaling issue regarding fsync()Hisashi Hifumi
When write() extends a file(i_size is increased) and fsync() is called, change of inode must be written to journaling area through fsync(). But,currently the i_trans_id is not correctly updated when i_size is increased. So fsync() does not kick the journal writer. Reiserfs_file_write() already updates the transaction when blocks are allocated, but the case when i_size increases and new blocks are not added is not correctly treated. Following patch fix this bug. Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <mason@suse.com> Cc: Hans Reiser <reiser@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: annotate the quota codeArjan van de Ven
The quota code plays interesting games with the lock ordering; to quote Jan: | i_mutex of inode containing quota file is acquired after all other | quota locks. i_mutex of all other inodes is acquired before quota | locks. Quota code makes sure (by resetting inode operations and | setting special flag on inode) that noone tries to enter quota code | while holding i_mutex on a quota file... The good news is that all of this special case i_mutex grabbing happens in the (per filesystem) low level quota write function. For this special case we need a new I_MUTEX_* nesting level, since this just entirely outside any of the regular VFS locking rules for i_mutex. I trust Jan on his blue eyes that this is not ever going to deadlock; and based on that the patch below is what it takes to inform lockdep of these very interesting new locking rules. The new locking rule for the I_MUTEX_QUOTA nesting level is that this is the deepest possible level of nesting for i_mutex, and that this only should be used in quota write (and possibly read) function of filesystems. This makes the lock ordering of the I_MUTEX_* levels: I_MUTEX_PARENT -> I_MUTEX_CHILD -> I_MUTEX_NORMAL -> I_MUTEX_QUOTA Has no effect on non-lockdep kernels. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] reiserfs: update ctime and mtime on expanding truncateVladimir Saveliev
Reiserfs does not update ctime and mtime on expanding truncate via truncate(). This patch fixes it. Signed-off-by: Vladimir Saveliev <vs@namesys.com> Cc: Hans Reiser <reiser@namesys.com> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] reiserfs: remove reiserfs_aio_write()Alexey Dobriyan
2006-06-26[PATCH] fs: use list_move()Akinobu Mita
This patch converts the combination of list_del(A) and list_add(A, B) to list_move(A, B) under fs/. Cc: Ian Kent <raven@themaw.net> Acked-by: Joel Becker <joel.becker@oracle.com> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Hans Reiser <reiserfs-dev@namesys.com> Cc: Urban Widmark <urban@teststation.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] read_mapping_page for address spacePekka Enberg
Add read_mapping_page() which is used for callers that pass mapping->a_ops->readpage as the filler for read_cache_page. This removes some duplication from filesystem code. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] Fix reiserfs deadlockJan Kara
reiserfs_cache_default_acl() should return whether we successfully found the acl or not. We have to return correct value even if reiserfs_get_acl() returns error code and not just 0. Otherwise callers such as reiserfs_mkdir() can unnecessarily lock the xattrs and later functions such as reiserfs_new_inode() fail to notice that we have already taken the lock and try to take it again with obvious consequences. Signed-off-by: Jan Kara <jack@suse.cz> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-30[PATCH] Introduce sys_splice() system callJens Axboe
This adds support for the sys_splice system call. Using a pipe as a transport, it can connect to files or sockets (latter as output only). From the splice.c comments: "splice": joining two ropes together by interweaving their strands. This is the "extended pipe" functionality, where a pipe is used as an arbitrary in-memory buffer. Think of a pipe as a small kernel buffer that you can use to transfer data from one end to the other. The traditional unix read/write is extended with a "splice()" operation that transfers data buffers to or from a pipe buffer. Named by Larry McVoy, original implementation from Linus, extended by Jens to support splicing to files and fixing the initial implementation bugs. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] remove ->get_blocks() supportBadari Pulavarty
Now that get_block() can handle mapping multiple disk blocks, no need to have ->get_blocks(). This patch removes fs specific ->get_blocks() added for DIO and makes it users use get_block() instead. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
