path: root/fs/reiserfs
2006-07-01[PATCH] reiserfs: update ctime and mtime on expanding truncateVladimir Saveliev
Reiserfs does not update ctime and mtime on expanding truncate via truncate(). This patch fixes it. Signed-off-by: Vladimir Saveliev <vs@namesys.com> Cc: Hans Reiser <reiser@namesys.com> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] reiserfs: remove reiserfs_aio_write()Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] fs: use list_move()Akinobu Mita
This patch converts the combination of list_del(A) and list_add(A, B) to list_move(A, B) under fs/. Cc: Ian Kent <raven@themaw.net> Acked-by: Joel Becker <joel.becker@oracle.com> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Hans Reiser <reiserfs-dev@namesys.com> Cc: Urban Widmark <urban@teststation.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] read_mapping_page for address spacePekka Enberg
Add read_mapping_page() which is used for callers that pass mapping->a_ops->readpage as the filler for read_cache_page. This removes some duplication from filesystem code. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] Fix reiserfs deadlockJan Kara
reiserfs_cache_default_acl() should return whether we successfully found the acl or not. We have to return correct value even if reiserfs_get_acl() returns error code and not just 0. Otherwise callers such as reiserfs_mkdir() can unnecessarily lock the xattrs and later functions such as reiserfs_new_inode() fail to notice that we have already taken the lock and try to take it again with obvious consequences. Signed-off-by: Jan Kara <jack@suse.cz> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-30[PATCH] Introduce sys_splice() system callJens Axboe
This adds support for the sys_splice system call. Using a pipe as a transport, it can connect to files or sockets (latter as output only). From the splice.c comments: "splice": joining two ropes together by interweaving their strands. This is the "extended pipe" functionality, where a pipe is used as an arbitrary in-memory buffer. Think of a pipe as a small kernel buffer that you can use to transfer data from one end to the other. The traditional unix read/write is extended with a "splice()" operation that transfers data buffers to or from a pipe buffer. Named by Larry McVoy, original implementation from Linus, extended by Jens to support splicing to files and fixing the initial implementation bugs. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] remove ->get_blocks() supportBadari Pulavarty
Now that get_block() can handle mapping multiple disk blocks, no need to have ->get_blocks(). This patch removes fs specific ->get_blocks() added for DIO and makes it users use get_block() instead. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] change buffer_head.b_size to size_tBadari Pulavarty
Increase the size of the buffer_head b_size field (only) for 64 bit platforms. Update some old and moldy comments in and around the structure as well. The b_size increase allows us to perform larger mappings and allocations for large I/O requests from userspace, which tie in with other changes allowing the get_block_t() interface to map multiple blocks at once. Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] Make address_space_operations->invalidatepage return voidNeilBrown
The return value of this function is never used, so let's be honest and declare it as void. Some places where invalidatepage returned 0, I have inserted comments suggesting a BUG_ON. [akpm@osdl.org: JBD BUG fix] [akpm@osdl.org: rework for git-nfs] [akpm@osdl.org: don't go BUG in block_invalidate_page()] Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] indirect_print_item() warning fixBenoit Boissinot
fs/reiserfs/item_ops.c: In function 'indirect_print_item': fs/reiserfs/item_ops.c:278: warning: 'num' may be used uninitialized in this function (akpm: this is probably just gcc being dumb) Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.fr> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] reiserfs/xattr_acl.c:reiserfs_get_acl(): make size an intAdrian Bunk
The Coverity checker wasn't happy seeing a size_t compared with -ENODATA and -ENOSYS. Since the only place where size is set is through the result of reiserfs_xattr_get() which is an int, we could simply make size an int. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <mason@suse.com> Cc: Hans Reiser <reiser@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] reiserfs: use balance_dirty_pages_ratelimited_nr in ↵Alexander Zarochentsev
reiserfs_file_write() Use the new balance_dirty_pages_ratelimited_nr in reiserfs "largeio" file write. Signed-off-by: Hans Reiser <reiser@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] reiserfs: cleanupsVladimir V. Saveliev
Clean up several places where gcc issues warnings when -W is specified. Thanks to Neil for finding that. Signed-off-by: Vladimir V. Saveliev <vs@namesys.com> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Hans Reiser <reiser@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] reiserfs: reiserfs_file_write() will lose error code when a 0-length ↵Jeff Mahoney
write occurs w/ O_SYNC When an error occurs in reiserfs_file_write before any data is written, and O_SYNC is set, the return code of generic_osync_write will overwrite the error code, losing it. This patch ensures that generic_osync_inode() doesn't run under an error condition, losing the error. This duplicates the logic from generic_file_buffered_write(). Signed-off-by: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Alexander Zarochentsev <zam@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] reiserfs: handle trans_id overflowAlexander Zarochentsev
Reiserfs does not handle transaction ID overflow correctly. Transaction ID == 0 causes reiserfs to crash. The patch fixes all places where the transaction ID is incremented. Signed-off-by: Alexander Zarochentsev <zam@namesys.com> Signed-off-by: Hans Reiser <reiser@namesys.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] reiserfs: fix transaction overflowingAlexander Zarochentzev
This patch fixes a bug in reiserfs truncate. A transaction might overflow when truncating long highly fragmented file. The fix is to split truncation into several transactions to avoid overflowing. Signed-off-by: Vladimir V. Saveliev <vs@namesys.com> Cc; Charles McColgan <cm@chuck.net> Cc: Alexander Zarochentsev <zam@namesys.com> Cc: Hans Reiser <reiser@namesys.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache formatPaul Jackson
Rewrap the overly long source code lines resulting from the previous patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch contains only formatting changes, and no function change. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] fs: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a duplicate of ARRAY_SIZE. Some trailing whitespaces are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: David Howells <dhowells@redhat.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-02[PATCH] reiserfs: fix unaligned bitmap usageJeff Mahoney
The bitmaps associated with generation numbers for directory entries are declared as an array of ints. On some platforms, this causes alignment exceptions. The following patch uses the standard bitmap declaration macros to declare the bitmaps, fixing the problem. Originally from Takashi Iwai. Signed-off-by: Takashi Iwai <tiwai@suse.de> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-02[PATCH] reiserfs: do not check if unsigned < 0Vladimir V. Saveliev
This patch fixes bugs in reiserfs where unsigned integers were checked whether they are less then 0. Signed-off-by: Vladimir V. Saveliev <vs@namesys.com> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Hans Reiser <reiser@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-13[PATCH] reiserfs: fix potential (unlikely) oops in reiserfs_get_aclJeff Mahoney
This fixes a potential oops if there is an error reported by posix_acl_from_disk(). This is mostly theoretical due to the use of magics and checksums in xattrs, but is still possible. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-12[PATCH] reiserfs: disable automatic enabling of reiserfs inode attributesJeff Mahoney
Unfortunately, the reiserfs_attrs_cleared bit in the superblock flag can lie. File systems have been observed with the bit set, yet still contain garbage in the stat data field, causing unpredictable results. This patch backs out the enable-by-default behavior. It eliminates the changes from: d50a5cd860ce721dbeac6a4f3c6e42abcde68cd8, and ef5e5414e7a83eb9b4295bbaba5464410b11e030. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] remove bogus asm/bug.h includes.Al Viro
A bunch of asm/bug.h includes are both not needed (since it will get pulled anyway) and bogus (since they are done too early). Removed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-02-03[PATCH] someone broke reiserfs V3 mount options, this fixes itVitaly Fertman
Signed-off-by: Hans Reiser <reiser@namesys.com> Signed-off-by: Vitaly Fertman <vitaly@namesys.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: reiserfs: check for files > 2GB on 3.5.x disksJeff Mahoney
When a filesystem has been converted from 3.5.x to 3.6.x, we need an extra check during file write to make sure we are not trying to make a 3.5.x file > 2GB. Signed-off-by: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: reiserfs fix journal accounting in ↵Chris Mason
journal_transaction_should_end reiserfs: journal_transaction_should_end should increase the count of blocks allocated so the transaction subsystem can keep new writers from creating a transaction that is too large. Signed-off-by: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: reiserfs write_ordered_buffers should not oops on dirty ↵Chris Mason
non-uptodate bh write_ordered_buffers should handle dirty non-uptodate buffers without a BUG() Signed-off-by: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: reiserfs hang and performance fix for data=journal modeChris Mason
In data=journal mode, reiserfs writepage needs to make sure not to trigger transactions while being run under PF_MEMALLOC. This patch makes sure to redirty the page instead of forcing a transaction start in this case. Also, calling filemap_fdata* in order to trigger io on the block device can cause lock inversions on the page lock. Instead, do simple batching from flush_commit_list. Signed-off-by: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] resierfs: fix reiserfs_invalidatepage race against data=orderedChris Mason
After a transaction has closed but before it has finished commit, there is a window where data=ordered mode requires invalidatepage to pin pages instead of freeing them. This patch fixes a race between the invalidatepage checks and data=ordered writeback, and it also adds a check to the reiserfs write_ordered_buffers routines to write any anonymous buffers that were dirtied after its first writeback loop. That bug works like this: proc1: transaction closes and a new one starts proc1: write_ordered_buffers starts processing data=ordered list proc1: buffer A is cleaned and written proc2: buffer A is dirtied by another process proc2: File is truncated to zero, page A goes through invalidatepage proc2: reiserfs_invalidatepage sees dirty buffer A with reiserfs journal head, pins it proc1: write_ordered_buffers frees the journal head on buffer A At this point, buffer A stays dirty forever Signed-off-by: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: use generic_permissionChristoph Hellwig
Use the generic_permission code with a proper wrapper and callback instead of having a local copy. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: remove reiserfs_permission_lockedChristoph Hellwig
This function is completely unused since the xattr permission checking changes. Remove it and fold __reiserfs_permission into reiserfs_permission. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: missing kmalloc failure checkDiego Calleja
According to http://bugzilla.kernel.org/show_bug.cgi?id=5778 fs/reiserfs/file.c is missing this check. Signed-off-by: Diego Calleja <diegocg@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: use __GFP_NOFAIL instead of yield and retry loop for ↵Pekka Enberg
allocation This patch replaces yield and retry loop with __GFP_NOFAIL in alloc_journal_list(). Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: remove kmalloc wrapperPekka Enberg
Remove kmalloc() wrapper from fs/reiserfs/. Please note that a reiserfs /proc entry format is changed because kmalloc statistics is removed. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] reiserfs: remove d_splice_alias NULL check from reiserfs_lookupPekka Enberg
Remove redundant NULL check in reiserfs_lookup() as d_splice_alias() can take NULL inode as input. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] reiserfs: fix assertion failure in reiserfs+journaled quotasJan Kara
Sometimes we call do_journal_end() with t_refcount == 0. If quota is turned on and we happen to have some inode with preallocation bad things happen as we try to use the current handle for quota operations. Checks for t_refcount in journal_begin() fail and we Oops. We raise t_refcount to make those checks happy. We should not cause any bad as all the needed quota blocks should be already attached to the transaction (they were attached to the transaction when we allocated those preallocation blocks). Signed-off-by: Jan Kara <jack@suse.cz> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] replace inode_update_time with file_update_timeChristoph Hellwig
To allow various options to work per-mount instead of per-sb we need a struct vfsmount when updating ctime and mtime. This preparation patch replaces the inode_update_time routine with a file_update_atime routine so we can easily get at the vfsmount. (and the file makes more sense in this context anyway). Also get rid of the unused second argument - we always want to update the ctime when calling this routine. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] remove reiserfs xattr permission checksChristoph Hellwig
remove checks now in the VFS Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-03s/retreiv/retriev/gMatt Mackall
As everyone knows, the rule is: "i before e.. um.. always." Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-12-14[PATCH] reiserfs: close open transactions on error pathJeff Mahoney
The following patch fixes a bug where if the journal is aborted, it can leave a transaction open. The result will be a BUG when another code path attempts to start a transaction and will get a "nesting into different fs" error, since current->journal_info will be left non-NULL. Original fix against SUSE kernel by Chris Mason <mason@suse.com> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-14[PATCH] reiserfs: skip commit on io errorJeff Mahoney
This should have been part of the original io error patch, but got dropped somewhere along the way. It's extremely important when handling the i/o error in the journal to not commit the transaction with corrupt data. This patch adds that code back in. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-29[PATCH] reiserfs: handle cnode allocation failure gracefullyJeff Mahoney
If an external device is used for a journal, by default it will use the entire device. The reiserfs journal code allocates structures per journal block when it mounts the file system. If the journal device is too large, and memory cannot be allocated for the structures, it will continue and ultimately panic when it can't pull one off the free list. This patch handles the allocation failure gracefully and prints an error message at mount time. Changes: Updated error message to be more descriptive to the user. Discussed and approved on ReiserFS Mailing List, Nov 28. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
