path: root/fs/proc/inode.c
2008-02-08proc: remove MODULE_LICENSEAlexey Dobriyan
proc is not modular, so MODULE_LICENSE just expands to empty space. proc without doubts remains GPLed. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop PROCFS from using iget() and read_inode()David Howells
Stop the PROCFS filesystem from using iget() and read_inode(). Merge procfs_read_inode() into procfs_get_inode(), and have that call iget_locked() instead of iget(). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05proc: fix proc_dir_entry refcountingAlexey Dobriyan
Creating PDEs with refcount 0 and "deleted" flag has problems (see below). Switch to usual scheme: * PDE is created with refcount 1 * every de_get does +1 * every de_put() and remove_proc_entry() do -1 * once refcount reaches 0, PDE is freed. This elegantly fixes at least two following races (both observed) without introducing new locks, without abusing old locks, without spreading lock_kernel(): 1) PDE leak remove_proc_entry de_put ----------------- ------ [refcnt = 1] if (atomic_read(&de->count) == 0) if (atomic_dec_and_test(&de->count)) if (de->deleted) /* also not taken! */ free_proc_entry(de); else de->deleted = 1; [refcount=0, deleted=1] 2) use after free remove_proc_entry de_put ----------------- ------ [refcnt = 1] if (atomic_dec_and_test(&de->count)) if (atomic_read(&de->count) == 0) free_proc_entry(de); /* boom! */ if (de->deleted) free_proc_entry(de); BUG: unable to handle kernel paging request at virtual address 6b6b6b6b printing eip: c10acdda *pdpt = 00000000338f8001 *pde = 0000000000000000 Oops: 0000 [#1] PREEMPT SMP Modules linked in: af_packet ipv6 cpufreq_ondemand loop serio_raw psmouse k8temp hwmon sr_mod cdrom Pid: 23161, comm: cat Not tainted (2.6.24-rc2-8c0863403f109a43d7000b4646da4818220d501f #4) EIP: 0060:[<c10acdda>] EFLAGS: 00210097 CPU: 1 EIP is at strnlen+0x6/0x18 EAX: 6b6b6b6b EBX: 6b6b6b6b ECX: 6b6b6b6b EDX: fffffffe ESI: c128fa3b EDI: f380bf34 EBP: ffffffff ESP: f380be44 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process cat (pid: 23161, ti=f380b000 task=f38f2570 task.ti=f380b000) Stack: c10ac4f0 00000278 c12ce000 f43cd2a8 00000163 00000000 7da86067 00000400 c128fa20 00896b18 f38325a8 c128fe20 ffffffff 00000000 c11f291e 00000400 f75be300 c128fa20 f769c9a0 c10ac779 f380bf34 f7bfee70 c1018e6b f380bf34 Call Trace: [<c10ac4f0>] vsnprintf+0x2ad/0x49b [<c10ac779>] vscnprintf+0x14/0x1f [<c1018e6b>] vprintk+0xc5/0x2f9 [<c10379f1>] handle_fasteoi_irq+0x0/0xab [<c1004f44>] do_IRQ+0x9f/0xb7 [<c117db3b>] preempt_schedule_irq+0x3f/0x5b [<c100264e>] need_resched+0x1f/0x21 [<c10190ba>] printk+0x1b/0x1f [<c107c8ad>] de_put+0x3d/0x50 [<c107c8f8>] proc_delete_inode+0x38/0x41 [<c107c8c0>] proc_delete_inode+0x0/0x41 [<c1066298>] generic_delete_inode+0x5e/0xc6 [<c1065aa9>] iput+0x60/0x62 [<c1063c8e>] d_kill+0x2d/0x46 [<c1063fa9>] dput+0xdc/0xe4 [<c10571a1>] __fput+0xb0/0xcd [<c1054e49>] filp_close+0x48/0x4f [<c1055ee9>] sys_close+0x67/0xa5 [<c10026b6>] sysenter_past_esp+0x5f/0x85 ======================= Code: c9 74 0c f2 ae 74 05 bf 01 00 00 00 4f 89 fa 5f 89 d0 c3 85 c9 57 89 c7 89 d0 74 05 f2 ae 75 01 4f 89 f8 5f c3 89 c1 89 c8 eb 06 <80> 38 00 74 07 40 4a 83 fa ff 75 f4 29 c8 c3 90 90 90 57 83 c9 EIP: [<c10acdda>] strnlen+0x6/0x18 SS:ESP 0068:f380be44 Also, remove broken usage of ->deleted from reiserfs: if sget() succeeds, module is already pinned and remove_proc_entry() can't happen => nobody can mark PDE deleted. Dummy proc root in netns code is not marked with refcount 1. AFAICS, we never get it, it's just for proper /proc/net removal. I double checked CLONE_NETNS continues to work. Patch survives many hours of modprobe/rmmod/cat loops without new bugs which can be attributed to refcounting. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: make proc have multiple superblocks - one for each namespacePavel Emelyanov
Each pid namespace have to be visible through its own proc mount. Thus we need to have per-namespace proc trees with their own superblocks. We cannot easily show different pid namespace via one global proc tree, since each pid refers to different tasks in different namespaces. E.g. pid 1 refers to the init task in the initial namespace and to some other task when seeing from another namespace. Moreover - pid, exisintg in one namespace may not exist in the other. This approach has one move advantage is that the tasks from the init namespace can see what tasks live in another namespace by reading entries from another proc tree. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17SLAB_PANIC more (proc, posix-timers, shmem)Alexey Dobriyan
These aren't modular, so SLAB_PANIC is OK. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-11Fix select on /proc files without ->pollAlexey Dobriyan
Taneli Vähäkangas <vahakang@cs.helsinki.fi> reported that commit 786d7e1612f0b0adb6046f19b906609e4fe8b1ba aka "Fix rmmod/read/write races in /proc entries" broke SBCL + SLIME combo. The old code in do_select() used DEFAULT_POLLMASK, if couldn't find ->poll handler. The new code makes ->poll always there and returns 0 by default, which is not correct. Return DEFAULT_POLLMASK instead. Steps to reproduce: install emacs, SBCL, SLIME emacs M-x slime in *inferior-lisp* buffer [watch it doing "Connecting to Swank on port X.."] Please, apply before 2.6.23. P.S.: why SBCL can't just read(2) /proc/cpuinfo is a mystery. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: T Taneli Vahakangas <vahakang@cs.helsinki.fi> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-28Fix procfs compat_ioctl regressionDavid Miller
It is important to only provide the compat_ioctl method if the downstream de->proc_fops does too, otherwise this utterly confuses the logic in fs/compat_ioctl.c and we end up doing the wrong thing. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Fix rmmod/read/write races in /proc entriesAlexey Dobriyan
Fix following races: =========================================== 1. Write via ->write_proc sleeps in copy_from_user(). Module disappears meanwhile. Or, more generically, system call done on /proc file, method supplied by module is called, module dissapeares meanwhile. pde = create_proc_entry() if (!pde) return -ENOMEM; pde->write_proc = ... open write copy_from_user pde = create_proc_entry(); if (!pde) { remove_proc_entry(); return -ENOMEM; /* module unloaded */ } *boom* ========================================== 2. bogo-revoke aka proc_kill_inodes() remove_proc_entry vfs_read proc_kill_inodes [check ->f_op validness] [check ->f_op->read validness] [verify_area, security permissions checks] ->f_op = NULL; if (file->f_op->read) /* ->f_op dereference, boom */ NOTE, NOTE, NOTE: file_operations are proxied for regular files only. Let's see how this scheme behaves, then extend if needed for directories. Directories creators in /proc only set ->owner for them, so proxying for directories may be unneeded. NOTE, NOTE, NOTE: methods being proxied are ->llseek, ->read, ->write, ->poll, ->unlocked_ioctl, ->ioctl, ->compat_ioctl, ->open, ->release. If your in-tree module uses something else, yell on me. Full audit pending. [akpm@linux-foundation.org: build fix] Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08proc: remove pathetic ->deleted WARN_ONAlexey Dobriyan
WARN_ON(de && de->deleted); is sooo unreliable. Why? proc_lookup remove_proc_entry =========== ================= lock_kernel(); spin_lock(&proc_subdir_lock); [find proc entry] spin_unlock(&proc_subdir_lock); spin_lock(&proc_subdir_lock); [find proc entry] proc_get_inode ============== WARN_ON(de && de->deleted); ... if (!atomic_read(&de->count)) free_proc_entry(de); else de->deleted = 1; So, if you have some strange oops [1], and doesn't see this WARN_ON it means nothing. [1] try_module_get() of module which doesn't exist, two lines below should suffice, or not? Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix race between proc_get_inode() and remove_proc_entry()Alexey Dobriyan
proc_lookup remove_proc_entry =========== ================= lock_kernel(); spin_lock(&proc_subdir_lock); [find PDE with refcount 0] spin_unlock(&proc_subdir_lock); spin_lock(&proc_subdir_lock); [find PDE with refcount 0] [check refcount and free PDE] spin_unlock(&proc_subdir_lock); proc_get_inode: de_get(de); /* boom */ Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: reimplement the sysctl proc supportEric W. Biederman
With this change the sysctl inodes can be cached and nothing needs to be done when removing a sysctl table. For a cost of 2K code we will save about 4K of static tables (when we remove de from ctl_table) and 70K in proc_dir_entries that we will not allocate, or about half that on a 32bit arch. The speed feels about the same, even though we can now cache the sysctl dentries :( We get the core advantage that we don't need to have a 1 to 1 mapping between ctl table entries and proc files. Making it possible to have /proc/sys vary depending on the namespace you are in. The currently merged namespaces don't have an issue here but the network namespace under /proc/sys/net needs to have different directories depending on which network adapters are visible. By simply being a cache different directories being visible depending on who you are is trivial to implement. [akpm@osdl.org: fix uninitialised var] [akpm@osdl.org: fix ARM build] [bunk@stusta.de: make things static] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-15Mark /proc MS_NOSUID and MS_NOEXECLinus Torvalds
Not that we really need this any more, but at the same time there's no reason not to do this. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] proc: Use struct pid not struct task_refEric W. Biederman
Incrementally update my proc-dont-lock-task_structs-indefinitely patches so that they work with struct pid instead of struct task_ref. Mostly this is a straight 1-1 substitution. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] proc: don't lock task_structs indefinitelyEric W. Biederman
Every inode in /proc holds a reference to a struct task_struct. If a directory or file is opened and remains open after the the task exits this pinning continues. With 8K stacks on a 32bit machine the amount pinned per file descriptor is about 10K. Normally I would figure a reasonable per user process limit is about 100 processes. With 80 processes, with a 1000 file descriptors each I can trigger the 00M killer on a 32bit kernel, because I have pinned about 800MB of useless data. This patch replaces the struct task_struct pointer with a pointer to a struct task_ref which has a struct task_struct pointer. The so the pinning of dead tasks does not happen. The code now has to contend with the fact that the task may now exit at any time. Which is a little but not muh more complicated. With this change it takes about 1000 processes each opening up 1000 file descriptors before I can trigger the OOM killer. Much better. [mlp@google.com: task_mmu small fixes] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Paul Jackson <pj@sgi.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Albert Cahalan <acahalan@gmail.com> Signed-off-by: Prasanna Meda <mlp@google.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] proc: Replace proc_inode.type with proc_inode.fdEric W. Biederman
The sole renaming use of proc_inode.type is to discover the file descriptor number, so just store the file descriptor number and don't wory about processing this field. This removes any /proc limits on the maximum number of file descriptors, and clears the path to make the hard coded /proc inode numbers go away. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache formatPaul Jackson
Rewrap the overly long source code lines resulting from the previous patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch contains only formatting changes, and no function change. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-18[PATCH] fix handling of st_nlink on procfs rootAl Viro
1) it should use nr_processes(), not nr_threads; otherwise we are getting very confused find(1) and friends, among other things. 2) better do that at stat() time than at every damn lookup in procfs root. Patch had been sitting in FC4 kernels for many months now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-01-08[PATCH] fs/proc/: function prototypes belong in header filesAdrian Bunk
Function prototypes belong into header files. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] proc: fix of error path in proc_get_inode()Kirill Korotaev
This patch fixes incorrect error path in proc_get_inode(), when module can't be get due to being unloaded. When try_module_get() fails, this function puts de(!) and still returns inode with non-getted de. There are still unresolved known bugs in proc yet to be fixed: - proc_dir_entry tree is managed without any serialization - create_proc_entry() doesn't setup de->owner anyhow, so setting it later manually is inatomic. - looks like almost all modules do not care whether it's de->owner is set... Signed-Off-By: Denis Lunev <den@sw.ru> Signed-Off-By: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] update filesystems for new delete_inode behaviorMark Fasheh
Update the file systems in fs/ implementing a delete_inode() callback to call truncate_inode_pages(). One implementation note: In developing this patch I put the calls to truncate_inode_pages() at the very top of those filesystems delete_inode() callbacks in order to retain the previous behavior. I'm guessing that some of those could probably be optimized. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
