path: root/fs/proc/base.c
2011-11-09Revert "proc: fix races against execve() of /proc/PID/fd**"Linus Torvalds
This reverts commit aa6afca5bcaba8101f3ea09d5c3e4100b2b9f0e5. It escalates of some of the google-chrome SELinux problems with ptrace ("Check failed: pid_ > 0. Did not find zygote process"), and Andrew says that it is also causing mystery lockdep reports. Reported-by: Alex Villacís Lasso <a_villacis@palosanto.com> Requested-by: James Morris <jmorris@namei.org> Requested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02Merge branch 'akpm' (Andrew's incoming - part two)Linus Torvalds
Says Andrew: "60 patches. That's good enough for -rc1 I guess. I have quite a lot of detritus to be rechecked, work through maintainers, etc. - most of the remains of MM - rtc - various misc - cgroups - memcg - cpusets - procfs - ipc - rapidio - sysctl - pps - w1 - drivers/misc - aio" * akpm: (60 commits) memcg: replace ss->id_lock with a rwlock aio: allocate kiocbs in batches drivers/misc/vmw_balloon.c: fix typo in code comment drivers/misc/vmw_balloon.c: determine page allocation flag can_sleep outside loop w1: disable irqs in critical section drivers/w1/w1_int.c: multiple masters used same init_name drivers/power/ds2780_battery.c: fix deadlock upon insertion and removal drivers/power/ds2780_battery.c: add a nolock function to w1 interface drivers/power/ds2780_battery.c: create central point for calling w1 interface w1: ds2760 and ds2780, use ida for id and ida_simple_get() to get it pps gpio client: add missing dependency pps: new client driver using GPIO pps: default echo function include/linux/dma-mapping.h: add dma_zalloc_coherent() sysctl: make CONFIG_SYSCTL_SYSCALL default to n sysctl: add support for poll() RapidIO: documentation update drivers/net/rionet.c: fix ethernet address macros for LE platforms RapidIO: fix potential null deref in rio_setup_device() RapidIO: add mport driver for Tsi721 bridge ...
2011-11-02proc: fix races against execve() of /proc/PID/fd**Vasiliy Kulikov
fd* files are restricted to the task's owner, and other users may not get direct access to them. But one may open any of these files and run any setuid program, keeping opened file descriptors. As there are permission checks on open(), but not on readdir() and read(), operations on the kept file descriptors will not be checked. It makes it possible to violate procfs permission model. Reading fdinfo/* may disclosure current fds' position and flags, reading directory contents of fdinfo/ and fd/ may disclosure the number of opened files by the target task. This information is not sensible per se, but it can reveal some private information (like length of a password stored in a file) under certain conditions. Used existing (un)lock_trace functions to check for ptrace_may_access(), but instead of using EPERM return code from it use EACCES to be consistent with existing proc_pid_follow_link()/proc_pid_readlink() return code. If they differ, attacker can guess what fds exist by analyzing stat() return code. Patched handlers: stat() for fd/*, stat() and read() for fdindo/*, readdir() and lookup() for fd/ and fdinfo/. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: <stable@kernel.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-10-31oom: remove oom_disable_countDavid Rientjes
This removes mm->oom_disable_count entirely since it's unnecessary and currently buggy. The counter was intended to be per-process but it's currently decremented in the exit path for each thread that exits, causing it to underflow. The count was originally intended to prevent oom killing threads that share memory with threads that cannot be killed since it doesn't lead to future memory freeing. The counter could be fixed to represent all threads sharing the same mm, but it's better to remove the count since: - it is possible that the OOM_DISABLE thread sharing memory with the victim is waiting on that thread to exit and will actually cause future memory freeing, and - there is no guarantee that a thread is disabled from oom killing just because another thread sharing its mm is oom disabled. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Ying Han <yinghan@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-06vfs: show O_CLOEXE bit properly in /proc/<pid>/fdinfo/<fd> filesLinus Torvalds
The CLOEXE bit is magical, and for performance (and semantic) reasons we don't actually maintain it in the file descriptor itself, but in a separate bit array. Which means that when we show f_flags, the CLOEXE status is shown incorrectly: we show the status not as it is now, but as it was when the file was opened. Fix that by looking up the bit properly in the 'fdt->close_on_exec' bit array. Uli needs this in order to re-implement the pfiles program: "For normal file descriptors (not sockets) this was the last piece of information which wasn't available. This is all part of my 'give Solaris users no reason to not switch' effort. I intend to offer the code to the util-linux-ng maintainers." Requested-by: Ulrich Drepper <drepper@akkadia.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-06oom_ajd: don't use WARN_ONCE, just use printk_onceLinus Torvalds
WARN_ONCE() is very annoying, in that it shows the stack trace that we don't care about at all, and also triggers various user-level "kernel oopsed" logic that we really don't care about. And it's not like the user can do anything about the applications (sshd) in question, it's a distro issue. Requested-by: Andi Kleen <andi@firstfloor.org> (and many others) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26proc: fix a race in do_io_accounting()Vasiliy Kulikov
If an inode's mode permits opening /proc/PID/io and the resulting file descriptor is kept across execve() of a setuid or similar binary, the ptrace_may_access() check tries to prevent using this fd against the task with escalated privileges. Unfortunately, there is a race in the check against execve(). If execve() is processed after the ptrace check, but before the actual io information gathering, io statistics will be gathered from the privileged process. At least in theory this might lead to gathering sensible information (like ssh/ftp password length) that wouldn't be available otherwise. Holding task->signal->cred_guard_mutex while gathering the io information should protect against the race. The order of locking is similar to the one inside of ptrace_attach(): first goes cred_guard_mutex, then lock_task_sighand(). Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25oom: make deprecated use of oom_adj more verboseDavid Rientjes
/proc/pid/oom_adj is deprecated and scheduled for removal in August 2012 according to Documentation/feature-removal-schedule.txt. This patch makes the warning more verbose by making it appear as a more serious problem (the presence of a stack trace and being multiline should attract more attention) so that applications still using the old interface can get fixed. Very popular users of the old interface have been converted since the oom killer rewrite has been introduced. udevd switched to the /proc/pid/oom_score_adj interface for v162, kde switched in 4.6.1, and opensshd switched in 5.7p1. At the start of 2012, this should be changed into a WARN() to emit all such incidents and then finally remove the tunable in August 2012 as scheduled. Signed-off-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits) vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp isofs: Remove global fs lock jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory fix IN_DELETE_SELF on overwriting rename() on ramfs et.al. mm/truncate.c: fix build for CONFIG_BLOCK not enabled fs:update the NOTE of the file_operations structure Remove dead code in dget_parent() AFS: Fix silly characters in a comment switch d_add_ci() to d_splice_alias() in "found negative" case as well simplify gfs2_lookup() jfs_lookup(): don't bother with . or .. get rid of useless dget_parent() in btrfs rename() and link() get rid of useless dget_parent() in fs/btrfs/ioctl.c fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers drivers: fix up various ->llseek() implementations fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek Ext4: handle SEEK_HOLE/SEEK_DATA generically Btrfs: implement our own ->llseek fs: add SEEK_HOLE and SEEK_DATA flags reiserfs: make reiserfs default to barrier=flush ... Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new shrinker callout for the inode cache, that clashed with the xfs code to start the periodic workers later.
2011-07-22Merge branch 'ptrace' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/miscLinus Torvalds
* 'ptrace' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/misc: (39 commits) ptrace: do_wait(traced_leader_killed_by_mt_exec) can block forever ptrace: fix ptrace_signal() && STOP_DEQUEUED interaction connector: add an event for monitoring process tracers ptrace: dont send SIGSTOP on auto-attach if PT_SEIZED ptrace: mv send-SIGSTOP from do_fork() to ptrace_init_task() ptrace_init_task: initialize child->jobctl explicitly has_stopped_jobs: s/task_is_stopped/SIGNAL_STOP_STOPPED/ ptrace: make former thread ID available via PTRACE_GETEVENTMSG after PTRACE_EVENT_EXEC stop ptrace: wait_consider_task: s/same_thread_group/ptrace_reparented/ ptrace: kill real_parent_is_ptracer() in in favor of ptrace_reparented() ptrace: ptrace_reparented() should check same_thread_group() redefine thread_group_leader() as exit_signal >= 0 do not change dead_task->exit_signal kill task_detached() reparent_leader: check EXIT_DEAD instead of task_detached() make do_notify_parent() __must_check, update the callers __ptrace_detach: avoid task_detached(), check do_notify_parent() kill tracehook_notify_death() make do_notify_parent() return bool ptrace: s/tracehook_tracer_task()/ptrace_parent()/ ...
2011-07-20fs: seq_file - add event counter to simplify poll() supportKay Sievers
Moving the event counter into the dynamically allocated 'struc seq_file' allows poll() support without the need to allocate its own tracking structure. All current users are switched over to use the new counter. Requested-by: Andrew Morton akpm@linux-foundation.org Acked-by: NeilBrown <neilb@suse.de> Tested-by: Lucas De Marchi lucas.demarchi@profusion.mobi Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to ->permission()Al Viro
not used by the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to generic_permission()Al Viro
redundant; all callers get it duplicated in mask & MAY_NOT_BLOCK and none of them removes that bit. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20kill check_acl callback of generic_permission()Al Viro
its value depends only on inode and does not change; we might as well store it in ->i_op->check_acl and be done with that. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-28proc: restrict access to /proc/PID/ioVasiliy Kulikov
/proc/PID/io may be used for gathering private information. E.g. for openssh and vsftpd daemons wchars/rchars may be used to learn the precise password length. Restrict it to processes being able to ptrace the target process. ptrace_may_access() is needed to prevent keeping open file descriptor of "io" file, executing setuid binary and gathering io information of the setuid'ed process. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-22ptrace: s/tracehook_tracer_task()/ptrace_parent()/Tejun Heo
tracehook.h is on the way out. Rename tracehook_tracer_task() to ptrace_parent() and move it from tracehook.h to ptrace.h. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: John Johansen <john.johansen@canonical.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-06-20proc_fd_permission() is doesn't need to bail out in RCU modeAl Viro
nothing blocking except generic_permission() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile: more /proc and /sys file support
2011-05-27arch/tile: more /proc and /sys file supportChris Metcalf
This change introduces a few of the less controversial /proc and /proc/sys interfaces for tile, along with sysfs attributes for various things that were originally proposed as /proc/tile files. It also adjusts the "hardwall" proc API. Arnd Bergmann reviewed the initial arch/tile submission, which included a complete set of all the /proc/tile and /proc/sys/tile knobs that we had added in a somewhat ad hoc way during initial development, and provided feedback on where most of them should go. One knob turned out to be similar enough to the existing /proc/sys/debug/exception-trace that it was re-implemented to use that model instead. Another knob was /proc/tile/grid, which reported the "grid" dimensions of a tile chip (e.g. 8x8 processors = 64-core chip). Arnd suggested looking at sysfs for that, so this change moves that information to a pair of sysfs attributes (chip_width and chip_height) in the /sys/devices/system/cpu directory. We also put the "chip_serial" and "chip_revision" information from our old /proc/tile/board file as attributes in /sys/devices/system/cpu. Other information collected via hypervisor APIs is now placed in /sys/hypervisor. We create a /sys/hypervisor/type file (holding the constant string "tilera") to be parallel with the Xen use of /sys/hypervisor/type holding "xen". We create three top-level files, "version" (the hypervisor's own version), "config_version" (the version of the configuration file), and "hvconfig" (the contents of the configuration file). The remaining information from our old /proc/tile/board and /proc/tile/switch files becomes an attribute group appearing under /sys/hypervisor/board/. Finally, after some feedback from Arnd Bergmann for the previous version of this patch, the /proc/tile/hardwall file is split up into two conceptual parts. First, a directory /proc/tile/hardwall/ which contains one file per active hardwall, each file named after the hardwall's ID and holding a cpulist that says which cpus are enclosed by the hardwall. Second, a /proc/PID file "hardwall" that is either empty (for non-hardwall-using processes) or contains the hardwall ID. Finally, this change pushes the /proc/sys/tile/unaligned_fixup/ directory, with knobs controlling the kernel code for handling the fixup of unaligned exceptions. Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-05-26proc: put check_mem_permission after __get_free_page in mem_writeKOSAKI Motohiro
It whould be better if put check_mem_permission after __get_free_page in mem_write, to be same as function mem_read. Hugh Dickins explained the reason. check_mem_permission gets a reference to the mm. If we __get_free_page after check_mem_permission, imagine what happens if the system is out of memory, and the mm we're looking at is selected for killing by the OOM killer: while we wait in __get_free_page for more memory, no memory is freed from the selected mm because it cannot reach exit_mmap while we hold that reference. Reported-by: Jovi Zhang <bookjovi@gmail.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Reviewed-by: Stephen Wilson <wilsons@start.ca> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26fs/proc: convert to kstrtoX()Alexey Dobriyan
Convert fs/proc/ from strict_strto*() to kstrto*() functions. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26mm: extract exe_file handling from procfsJiri Slaby
Setup and cleanup of mm_struct->exe_file is currently done in fs/proc/. This was because exe_file was needed only for /proc/<pid>/exe. Since we will need the exe_file functionality also for core dumps (so core name can contain full binary path), built this functionality always into the kernel. To achieve that move that out of proc FS to the kernel/ where in fact it should belong. By doing that we can make dup_mm_exe_file static. Also we can drop linux/proc_fs.h inclusion in fs/exec.c and kernel/fork.c. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-10ns: proc files for namespace naming policy.Eric W. Biederman
Create files under /proc/<pid>/ns/ to allow controlling the namespaces of a process. This addresses three specific problems that can make namespaces hard to work with. - Namespaces require a dedicated process to pin them in memory. - It is not possible to use a namespace unless you are the child of the original creator. - Namespaces don't have names that userspace can use to talk about them. The namespace files under /proc/<pid>/ns/ can be opened and the file descriptor can be used to talk about a specific namespace, and to keep the specified namespace alive. A namespace can be kept alive by either holding the file descriptor open or bind mounting the file someplace else. aka: mount --bind /proc/self/ns/net /some/filesystem/path mount --bind /proc/self/fd/<N> /some/filesystem/path This allows namespaces to be named with userspace policy. It requires additional support to make use of these filedescriptors and that will be comming in the following patches. Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-04-18proc: do proper range check on readdir offsetLinus Torvalds
Rather than pass in some random truncated offset to the pid-related functions, check that the offset is in range up-front. This is just cleanup, the previous commit fixed the real problem. Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: deal with races in /proc/*/{syscall,stack,personality} proc: enable writing to /proc/pid/mem proc: make check_mem_permission() return an mm_struct on success proc: hold cred_guard_mutex in check_mem_permission() proc: disable mem_write after exec mm: implement access_remote_vm mm: factor out main logic of access_process_vm mm: use mm_struct to resolve gate vma's in __get_user_pages mm: arch: rename in_gate_area_no_task to in_gate_area_no_mm mm: arch: make in_gate_area take an mm_struct instead of a task_struct mm: arch: make get_gate_vma take an mm_struct instead of a task_struct x86: mark associated mm when running a task in 32 bit compatibility mode x86: add context tag to mark mm when running a task in 32-bit compatibility mode auxv: require the target to be tracable (or yourself) close race in /proc/*/environ report errors in /proc/*/*map* sanely pagemap: close races with suid execve make sessionid permissions in /proc/*/task/* match those in /proc/* fix leaks in path_lookupat() Fix up trivial conflicts in fs/proc/base.c
2011-03-23procfs: fix some wrong error code usageJovi Zhang
[root@wei 1]# cat /proc/1/mem cat: /proc/1/mem: No such process error code -ESRCH is wrong in this situation. Return -EPERM instead. Signed-off-by: Jovi Zhang <bookjovi@gmail.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23proc: hide kernel addresses via %pK in /proc/<pid>/stackKonstantin Khlebnikov
This file is readable for the task owner. Hide kernel addresses from unprivileged users, leave them function names and offsets. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: Kees Cook <kees.cook@canonical.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23deal with races in /proc/*/{syscall,stack,personality}Al Viro
All of those are rw-r--r-- and all are broken for suid - if you open a file before the target does suid-root exec, you'll be still able to access it. For personality it's not a big deal, but for syscall and stack it's a real problem. Fix: check that task is tracable for you at the time of read(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-23proc: enable writing to /proc/pid/memStephen Wilson
With recent changes there is no longer a security hazard with writing to /proc/pid/mem. Remove the #ifdef. Signed-off-by: Stephen Wilson <wilsons@start.ca> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-23proc: make check_mem_permission() return an mm_struct on successStephen Wilson
This change allows us to take advantage of access_remote_vm(), which in turn eliminates a security issue with the mem_write() implementation. The previous implementation of mem_write() was insecure since the target task could exec a setuid-root binary between the permission check and the actual write. Holding a reference to the target mm_struct eliminates this vulnerability. Signed-off-by: Stephen Wilson <wilsons@start.ca> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-23proc: hold cred_guard_mutex in check_mem_permission()Stephen Wilson
Avoid a potential race when task exec's and we get a new ->mm but check against the old credentials in ptrace_may_access(). Holding of the mutex is implemented by factoring out the body of the code into a helper function __check_mem_permission(). Performing this factorization now simplifies upcoming changes and minimizes churn in the diff's. Signed-off-by: Stephen Wilson <wilsons@start.ca> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-23proc: disable mem_write after execStephen Wilson
This change makes mem_write() observe the same constraints as mem_read(). This is particularly important for mem_write as an accidental leak of the fd across an exec could result in arbitrary modification of the target process' memory. IOW, /proc/pid/mem is implicitly close-on-exec. Signed-off-by: Stephen Wilson <wilsons@start.ca> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-23auxv: require the target to be tracable (or yourself)Al Viro
same as for environ, except that we didn't do any checks to prevent access after suid execve Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-23close race in /proc/*/environAl Viro
Switch to mm_for_maps(). Maybe we ought to make it r--r--r--, since we do checks on IO anyway... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-23report errors in /proc/*/*map* sanelyAl Viro
2011-03-23pagemap: close races with suid execveAl Viro
just use mm_for_maps() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-23make sessionid permissions in /proc/*/task/* match those in /proc/*Al Viro
2011-03-10/proc/self is never going to be invalidated...Al Viro
2011-01-13oom: allow a non-CAP_SYS_RESOURCE proces to oom_score_adj downMandeep Singh Baines
We'd like to be able to oom_score_adj a process up/down as it enters/leaves the foreground. Currently, it is not possible to oom_adj down without CAP_SYS_RESOURCE. This patch allows a task to decrease its oom_score_adj back to the value that a CAP_SYS_RESOURCE thread set it to or its inherited value at fork. Assuming the thread that has forked it has oom_score_adj of 0, each process could decrease it back from 0 upon activation unless a CAP_SYS_RESOURCE thread elevated it to something higher. Alternative considered: * a setuid binary * a daemon with CAP_SYS_RESOURCE Since you don't wan't all processes to be able to reduce their oom_adj, a setuid or daemon implementation would be complex. The alternatives also have much higher overhead. This patch updated from original patch based on feedback from David Rientjes. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Acked-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13proc: use single_open() correctlyJovi Zhang
single_open()'s third argument is for copying into seq_file->private. Use that, rather than open-coding it. Signed-off-by: Jovi Zhang <bookjovi@gmail.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Alexey Dobriyan <adobriyan@gmail.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13proc: use seq_puts()/seq_putc() where possibleAlexey Dobriyan
For string without format specifiers, use seq_puts(). For seq_printf("\n"), use seq_putc('\n'). text data bss dec hex filename 61866 488 112 62466 f402 fs/proc/proc.o 61729 488 112 62329 f379 fs/proc/proc.o ---------------------------------------------------- -139 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13fs/proc/base.c, kernel/latencytop.c: convert sprintf_symbol() to %psJoe Perches
Use temporary lr for struct latency_record for improved readability and fewer columns used. Removed trailing space from output. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Joe Perches <joe@perches.com> Cc: Jiri Kosina <trivial@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07Merge branch 'vfs-scale-working' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin * 'vfs-scale-working' of git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin: (57 commits) fs: scale mntget/mntput fs: rename vfsmount counter helpers fs: implement faster dentry memcmp fs: prefetch inode data in dcache lookup fs: improve scalability of pseudo filesystems fs: dcache per-inode inode alias locking fs: dcache per-bucket dcache hash locking bit_spinlock: add required includes kernel: add bl_list xfs: provide simple rcu-walk ACL implementation btrfs: provide simple rcu-walk ACL implementation ext2,3,4: provide simple rcu-walk ACL implementation fs: provide simple rcu-walk generic_check_acl implementation fs: provide rcu-walk aware permission i_ops fs: rcu-walk aware d_revalidate method fs: cache optimise dentry and inode for rcu-walk fs: dcache reduce branches in lookup path fs: dcache remove d_mounted fs: fs_struct use seqlock fs: rcu-walk for path lookup ...
2011-01-07fs: provide rcu-walk aware permission i_opsNick Piggin
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: rcu-walk aware d_revalidate methodNick Piggin
Require filesystems be aware of .d_revalidate being called in rcu-walk mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning -ECHILD from all implementations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_delete semanticsNick Piggin
Change d_delete from a dentry deletion notification to a dentry caching advise, more like ->drop_inode. Require it to be constant and idempotent, and not take d_lock. This is how all existing filesystems use the callback anyway. This makes fine grained dentry locking of dput and dentry lru scanning much simpler. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-12-08Merge branch 'linus' into sched/coreIngo Molnar
Merge reason: we want to queue up dependent cleanup Signed-off-by: Ingo Molnar <mingo@elte.hu>
