commit 8bb2ee192e482c5d500df9f2b1b26a560bd3026f upstream.
do_task_stat() accesses IP and SP of a task without bumping reference
count of a stack (which became an entity with independent lifetime at
some point).
Steps to reproduce:
#include <stdio.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <sys/time.h>
#include <sys/resource.h>
#include <unistd.h>
#include <sys/wait.h>
int main(void)
setrlimit(RLIMIT_CORE, &(struct rlimit){});
while (1) {
char buf[64];
char buf2[4096];
pid_t pid;
int fd;
pid = fork();
if (pid == 0) {
*(volatile int *)0 = 0;
snprintf(buf, sizeof(buf), "/proc/%u/stat", pid);
fd = open(buf, O_RDONLY);
read(fd, buf2, sizeof(buf2));
close(fd);
waitpid(pid, NULL, 0);
return 0;
BUG: unable to handle kernel paging request at 0000000000003fd8
IP: do_task_stat+0x8b4/0xaf0
PGD 800000003d73e067 P4D 800000003d73e067 PUD 3d558067 PMD 0
Oops: 0000 [#1] PREEMPT SMP PTI
CPU: 0 PID: 1417 Comm: a.out Not tainted 4.15.0-rc8-dirty #2
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1.fc27 04/01/2014
RIP: 0010:do_task_stat+0x8b4/0xaf0
Call Trace:
proc_single_show+0x43/0x70
seq_read+0xe6/0x3b0
__vfs_read+0x1e/0x120
vfs_read+0x84/0x110
SyS_read+0x3d/0xa0
entry_SYSCALL_64_fastpath+0x13/0x6c
RIP: 0033:0x7f4d7928cba0
RSP: 002b:00007ffddb245158 EFLAGS: 00000246
Code: 03 b7 a0 01 00 00 4c 8b 4c 24 70 4c 8b 44 24 78 4c 89 74 24 18 e9 91 f9 ff ff f6 45 4d 02 0f 84 fd f7 ff ff 48 8b 45 40 48 89 ef <48> 8b 80 d8 3f 00 00 48 89 44 24 20 e8 9b 97 eb ff 48 89 44 24
RIP: do_task_stat+0x8b4/0xaf0 RSP: ffffc90000607cc8
CR2: 0000000000003fd8
John Ogness said: for my tests I added an else case to verify that the
race is hit and correctly mitigated.
Link: http://lkml.kernel.org/r/20180116175054.GA11513@avx2
Reported-by: "Kohli, Gaurav" <gkohli@codeaurora.org>
Tested-by: John Ogness <john.ogness@linutronix.de>
commit fd7d56270b526ca3ed0c224362e3c64a0f86687a upstream.
Commit 0a1eb2d474ed ("fs/proc: Stop reporting eip and esp in
/proc/PID/stat") stopped reporting eip/esp because it is
racy and dangerous for executing tasks. The comment adds:
As far as I know, there are no use programs that make any
material use of these fields, so just get rid of them.
However, existing userspace core-dump-handler applications (for
example, minicoredumper) are using these fields since they
provide an excellent cross-platform interface to these valuable
pointers. So that commit introduced a user space visible
regression.
Partially revert the change and make the readout possible for
tasks with the proper permissions and only if the target task
has the PF_DUMPCORE flag set.
Fixes: 0a1eb2d474ed ("fs/proc: Stop reporting eip and esp in> /proc/PID/stat")
Reported-by: Marco Felsch <marco.felsch@preh.de>
Signed-off-by: John Ogness <john.ogness@linutronix.de>
Reviewed-by: Andy Lutomirski <luto@kernel.org>
Cc: Tycho Andersen <tycho.andersen@canonical.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Cc: Linux API <linux-api@vger.kernel.org>
Link: http://lkml.kernel.org/r/87poatfwg6.fsf@linutronix.de
Reporting these fields on a non-current task is dangerous. If the
task is in any state other than normal kernel code, they may contain
garbage or even kernel addresses on some architectures. (x86_64
used to do this. I bet lots of architectures still do.) With
CONFIG_THREAD_INFO_IN_TASK=y, it can OOPS, too.
As far as I know, there are no use programs that make any material
Reported-by: Jann Horn <jann@thejh.net>
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Link: http://lkml.kernel.org/r/a5fed4c3f4e33ed25d4bb03567e329bc5a712bcc.1475257877.git.luto@kernel.org
Current supplementary groups code can massively overallocate memory and
is implemented in a way so that access to individual gid is done via 2D
array.
If number of gids is <= 32, memory allocation is more or less tolerable
(140/148 bytes). But if it is not, code allocates full page (!)
regardless and, what's even more fun, doesn't reuse small 32-entry
array.
2D array means dependent shifts, loads and LEAs without possibility to
optimize them (gid is never known at compile time).
All of the above is unnecessary. Switch to the usual
trailing-zero-len-array scheme. Memory is allocated with
kmalloc/vmalloc() and only as much as needed. Accesses become simpler
(LEA 8(gi,idx,4) or even without displacement).
Maximum number of gids is 65536 which translates to 256KB+8 bytes. I
think kernel can handle such allocation.
On my usual desktop system with whole 9 (nine) aux groups, struct
group_info shrinks from 148 bytes to 44 bytes, yay!
Nice side effects:
- "gi->gid[i]" is shorter than "GROUP_AT(gi, i)", less typing,
- fix little mess in net/ipv4/ping.c
should have been using GROUP_AT macro but this point becomes moot,
- aux group allocation is persistent and should be accounted as such.
Link: http://lkml.kernel.org/r/20160817201927.GA2096@p183.telecom.by
Cc: Vasily Kulikov <segoon@openwall.com>
Allow some seq_puts removals by taking a string instead of a single
char.
[akpm@linux-foundation.org: update vmstat_show(), per Joe]
Link: http://lkml.kernel.org/r/667e1cf3d436de91a5698170a1e98d882905e956.1470704995.git.joe@perches.com
Cc: Joe Perches <joe@perches.com>
top(1) opens the following files for every PID:
/proc/*/stat
/proc/*/statm
/proc/*/status
This patch switches /proc/*/status away from seq_printf().
The result is 13.5% speedup.
Benchmark is open("/proc/self/status")+read+close 1.000.000 million times.
BEFORE
$ perf stat -r 10 taskset -c 3 ./proc-self-status
Performance counter stats for 'taskset -c 3 ./proc-self-status' (10 runs):
10748.474301 task-clock (msec) # 0.954 CPUs utilized ( +- 0.91% )
12 context-switches # 0.001 K/sec ( +- 1.09% )
1 cpu-migrations # 0.000 K/sec
104 page-faults # 0.010 K/sec ( +- 0.45% )
37,424,127,876 cycles # 3.482 GHz ( +- 0.04% )
8,453,010,029 stalled-cycles-frontend # 22.59% frontend cycles idle ( +- 0.12% )
3,747,609,427 stalled-cycles-backend # 10.01% backend cycles idle ( +- 0.68% )
65,632,764,147 instructions # 1.75 insn per cycle
# 0.13 stalled cycles per insn ( +- 0.00% )
13,981,324,775 branches # 1300.773 M/sec ( +- 0.00% )
138,967,110 branch-misses # 0.99% of all branches ( +- 0.18% )
11.263885428 seconds time elapsed ( +- 0.04% )
AFTER
9010.521776 task-clock (msec) # 0.925 CPUs utilized ( +- 1.54% )
11 context-switches # 0.001 K/sec ( +- 1.54% )
1 cpu-migrations # 0.000 K/sec ( +- 11.11% )
103 page-faults # 0.011 K/sec ( +- 0.60% )
32,352,310,603 cycles # 3.591 GHz ( +- 0.07% )
7,849,199,578 stalled-cycles-frontend # 24.26% frontend cycles idle ( +- 0.27% )
3,269,738,842 stalled-cycles-backend # 10.11% backend cycles idle ( +- 0.73% )
56,012,163,567 instructions # 1.73 insn per cycle
# 0.14 stalled cycles per insn ( +- 0.00% )
11,735,778,795 branches # 1302.453 M/sec ( +- 0.00% )
98,084,459 branch-misses # 0.84% of all branches ( +- 0.28% )
9.741247736 seconds time elapsed ( +- 0.07% )
Link: http://lkml.kernel.org/r/20160806125608.GB1187@p183.telecom.by
It's not possible to read the process umask without also modifying it,
which is what umask(2) does. A library cannot read umask safely,
especially if the main program might be multithreaded.
Add a new status line ("Umask") in /proc/<PID>/status. It contains the
file mode creation mask (umask) in octal. It is only shown for tasks
which have task->fs.
This patch is adapted from one originally written by Pierre Carrier.
The use case is that we have endless trouble with people setting weird
umask() values (usually on the grounds of "security"), and then
everything breaking. I'm on the hook to fix these. We'd like to add
debugging to our program so we can dump out the umask in debug reports.
Previous versions of the patch used a syscall so you could only read
your own umask. That's all I need. However there was quite a lot of
push-back from those, so this new version exports it in /proc.
See:
https://lkml.org/lkml/2016/4/13/704 [umask2]
https://lkml.org/lkml/2016/4/13/487 [getumask]
Signed-off-by: Richard W.M. Jones <rjones@redhat.com>
Acked-by: Konstantin Khlebnikov <koct9i@gmail.com>
Acked-by: Jerome Marchand <jmarchan@redhat.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Pierre Carrier <pierre@spotify.com>
By checking the effective credentials instead of the real UID / permitted
capabilities, ensure that the calling process actually intended to use its
credentials.
To ensure that all ptrace checks use the correct caller credentials (e.g.
in case out-of-tree code or newly added code omits the PTRACE_MODE_*CREDS
flag), use two new flags and require one of them to be set.
The problem was that when a privileged task had temporarily dropped its
privileges, e.g. by calling setreuid(0, user_uid), with the intent to
perform following syscalls with the credentials of a user, it still passed
ptrace access checks that the user would not be able to pass.
While an attacker should not be able to convince the privileged task to
perform a ptrace() syscall, this is a problem because the ptrace access
check is reused for things in procfs.
In particular, the following somewhat interesting procfs entries only rely
on ptrace access checks:
/proc/$pid/stat - uses the check for determining whether pointers
should be visible, useful for bypassing ASLR
/proc/$pid/maps - also useful for bypassing ASLR
/proc/$pid/cwd - useful for gaining access to restricted
directories that contain files with lax permissions, e.g. in
this scenario:
lrwxrwxrwx root root /proc/13020/cwd -> /root/foobar
drwx------ root root /root
drwxr-xr-x root root /root/foobar
-rw-r--r-- root root /root/foobar/secret
Therefore, on a system where a root-owned mode 6755 binary changes its
effective credentials as described and then dumps a user-specified file,
this could be used by an attacker to reveal the memory layout of root's
processes or reveal the contents of files he is not allowed to access
(through /proc/$pid/cwd).
[akpm@linux-foundation.org: fix warning]
Signed-off-by: Jann Horn <jann@thejh.net>
Cc: Casey Schaufler <casey@schaufler-ca.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: "Serge E. Hallyn" <serge.hallyn@ubuntu.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Willy Tarreau <w@1wt.eu>
For now in task_name() we ignore the return code of string_escape_str()
call. This is not good if buffer suddenly becomes not big enough. Do the
proper error handling there.
So the /proc/PID/stat 'wchan' field (the 30th field, which contains
the absolute kernel address of the kernel function a task is blocked in)
leaks absolute kernel addresses to unprivileged user-space:
seq_put_decimal_ull(m, ' ', wchan);
The absolute address might also leak via /proc/PID/wchan as well, if
KALLSYMS is turned off or if the symbol lookup fails for some reason:
static int proc_pid_wchan(struct seq_file *m, struct pid_namespace *ns,
struct pid *pid, struct task_struct *task)
unsigned long wchan;
char symname[KSYM_NAME_LEN];
wchan = get_wchan(task);
if (lookup_symbol_name(wchan, symname) < 0) {
if (!ptrace_may_access(task, PTRACE_MODE_READ))
return 0;
seq_printf(m, "%lu", wchan);
} else {
seq_printf(m, "%s", symname);
return 0;
This isn't ideal, because for example it trivially leaks the KASLR offset
to any local attacker:
fomalhaut:~> printf "%016lx\n" $(cat /proc/$$/stat | cut -d' ' -f35)
ffffffff8123b380
Most real-life uses of wchan are symbolic:
ps -eo pid:10,tid:10,wchan:30,comm
and procps uses /proc/PID/wchan, not the absolute address in /proc/PID/stat:
triton:~/tip> strace -f ps -eo pid:10,tid:10,wchan:30,comm 2>&1 | grep wchan | tail -1
open("/proc/30833/wchan", O_RDONLY) = 6
There's one compatibility quirk here: procps relies on whether the
absolute value is non-zero - and we can provide that functionality
by outputing "0" or "1" depending on whether the task is blocked
(whether there's a wchan address).
These days there appears to be very little legitimate reason
user-space would be interested in the absolute address. The
absolute address is mostly historic: from the days when we
didn't have kallsyms and user-space procps had to do the
decoding itself via the System.map.
So this patch sets all numeric output to "0" or "1" and keeps only
symbolic output, in /proc/PID/wchan.
( The absolute sleep address can generally still be profiled via
perf, by tasks with sufficient privileges. )
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: <stable@vger.kernel.org>
Cc: Alexander Potapenko <glider@google.com>
Cc: Andrey Konovalov <andreyknvl@google.com>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Kostya Serebryany <kcc@google.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: kasan-dev <kasan-dev@googlegroups.com>
Link: http://lkml.kernel.org/r/20150930135917.GA3285@gmail.com
Credit where credit is due: this idea comes from Christoph Lameter with
a lot of valuable input from Serge Hallyn. This patch is heavily based
on Christoph's patch.
===== The status quo =====
On Linux, there are a number of capabilities defined by the kernel. To
perform various privileged tasks, processes can wield capabilities that
they hold.
Each task has four capability masks: effective (pE), permitted (pP),
inheritable (pI), and a bounding set (X). When the kernel checks for a
capability, it checks pE. The other capability masks serve to modify
what capabilities can be in pE.
Any task can remove capabilities from pE, pP, or pI at any time. If a
task has a capability in pP, it can add that capability to pE and/or pI.
If a task has CAP_SETPCAP, then it can add any capability to pI, and it
can remove capabilities from X.
Tasks are not the only things that can have capabilities; files can also
have capabilities. A file can have no capabilty information at all [1].
If a file has capability information, then it has a permitted mask (fP)
and an inheritable mask (fI) as well as a single effective bit (fE) [2].
File capabilities modify the capabilities of tasks that execve(2) them.
A task that successfully calls execve has its capabilities modified for
the file ultimately being excecuted (i.e. the binary itself if that
binary is ELF or for the interpreter if the binary is a script.) [3] In
the capability evolution rules, for each mask Z, pZ represents the old
value and pZ' represents the new value. The rules are:
pP' = (X & fP) | (pI & fI)
pI' = pI
pE' = (fE ? pP' : 0)
X is unchanged
For setuid binaries, fP, fI, and fE are modified by a moderately
complicated set of rules that emulate POSIX behavior. Similarly, if
euid == 0 or ruid == 0, then fP, fI, and fE are modified differently
(primary, fP and fI usually end up being the full set). For nonroot
users executing binaries with neither setuid nor file caps, fI and fP
are empty and fE is false.
As an extra complication, if you execute a process as nonroot and fE is
set, then the "secure exec" rules are in effect: AT_SECURE gets set,
LD_PRELOAD doesn't work, etc.
This is rather messy. We've learned that making any changes is
dangerous, though: if a new kernel version allows an unprivileged
program to change its security state in a way that persists cross
execution of a setuid program or a program with file caps, this
persistent state is surprisingly likely to allow setuid or file-capped
programs to be exploited for privilege escalation.
===== The problem =====
Capability inheritance is basically useless.
If you aren't root and you execute an ordinary binary, fI is zero, so
your capabilities have no effect whatsoever on pP'. This means that you
can't usefully execute a helper process or a shell command with elevated
capabilities if you aren't root.
On current kernels, you can sort of work around this by setting fI to
the full set for most or all non-setuid executable files. This causes
pP' = pI for nonroot, and inheritance works. No one does this because
it's a PITA and it isn't even supported on most filesystems.
If you try this, you'll discover that every nonroot program ends up with
secure exec rules, breaking many things.
This is a problem that has bitten many people who have tried to use
capabilities for anything useful.
===== The proposed change =====
This patch adds a fifth capability mask called the ambient mask (pA).
pA does what most people expect pI to do.
pA obeys the invariant that no bit can ever be set in pA if it is not
set in both pP and pI. Dropping a bit from pP or pI drops that bit from
pA. This ensures that existing programs that try to drop capabilities
still do so, with a complication. Because capability inheritance is so
broken, setting KEEPCAPS, using setresuid to switch to nonroot uids, and
then calling execve effectively drops capabilities. Therefore,
setresuid from root to nonroot conditionally clears pA unless
SECBIT_NO_SETUID_FIXUP is set. Processes that don't like this can
re-add bits to pA afterwards.
The capability evolution rules are changed:
pA' = (file caps or setuid or setgid ? 0 : pA)
pP' = (X & fP) | (pI & fI) | pA'
pI' = pI
pE' = (fE ? pP' : pA')
X is unchanged
If you are nonroot but you have a capability, you can add it to pA. If
you do so, your children get that capability in pA, pP, and pE. For
example, you can set pA = CAP_NET_BIND_SERVICE, and your children can
automatically bind low-numbered ports. Hallelujah!
Unprivileged users can create user namespaces, map themselves to a
nonzero uid, and create both privileged (relative to their namespace)
and unprivileged process trees. This is currently more or less
impossible. Hallelujah!
You cannot use pA to try to subvert a setuid, setgid, or file-capped
program: if you execute any such program, pA gets cleared and the
resulting evolution rules are unchanged by this patch.
Users with nonzero pA are unlikely to unintentionally leak that
capability. If they run programs that try to drop privileges, dropping
privileges will still work.
It's worth noting that the degree of paranoia in this patch could
possibly be reduced without causing serious problems. Specifically, if
we allowed pA to persist across executing non-pA-aware setuid binaries
and across setresuid, then, naively, the only capabilities that could
leak as a result would be the capabilities in pA, and any attacker
*already* has those capabilities. This would make me nervous, though --
setuid binaries that tried to privilege-separate might fail to do so,
and putting CAP_DAC_READ_SEARCH or CAP_DAC_OVERRIDE into pA could have
unexpected side effects. (Whether these unexpected side effects would
be exploitable is an open question.) I've therefore taken the more
paranoid route. We can revisit this later.
An alternative would be to require PR_SET_NO_NEW_PRIVS before setting
ambient capabilities. I think that this would be annoying and would
make granting otherwise unprivileged users minor ambient capabilities
(CAP_NET_BIND_SERVICE or CAP_NET_RAW for example) much less useful than
it is with this patch.
===== Footnotes =====
[1] Files that are missing the "security.capability" xattr or that have
unrecognized values for that xattr end up with has_cap set to false.
The code that does that appears to be complicated for no good reason.
[2] The libcap capability mask parsers and formatters are dangerously
misleading and the documentation is flat-out wrong. fE is *not* a mask;
it's a single bit. This has probably confused every single person who
has tried to use file capabilities.
[3] Linux very confusingly processes both the script and the interpreter
if applicable, for reasons that elude me. The results from thinking
about a script's file capabilities and/or setuid bits are mostly
discarded.
Preliminary userspace code is here, but it needs updating:
https://git.kernel.org/cgit/linux/kernel/git/luto/util-linux-playground.git/commit/?h=cap_ambient&id=7f5afbd175d2
Here is a test program that can be used to verify the functionality
(from Christoph):
* Test program for the ambient capabilities. This program spawns a shell
* that allows running processes with a defined set of capabilities.
* (C) 2015 Christoph Lameter <cl@linux.com>
* Released under: GPL v3 or later.
* Compile using:
* gcc -o ambient_test ambient_test.o -lcap-ng
* This program must have the following capabilities to run properly:
* Permissions for CAP_NET_RAW, CAP_NET_ADMIN, CAP_SYS_NICE
* A command to equip the binary with the right caps is:
* setcap cap_net_raw,cap_net_admin,cap_sys_nice+p ambient_test
* To get a shell with additional caps that can be inherited by other processes:
* ./ambient_test /bin/bash
* Verifying that it works:
* From the bash spawed by ambient_test run
* cat /proc/$$/status
* and have a look at the capabilities.
#include <stdlib.h>
#include <stdio.h>
#include <errno.h>
#include <cap-ng.h>
#include <sys/prctl.h>
#include <linux/capability.h>
* Definitions from the kernel header files. These are going to be removed
* when the /usr/include files have these defined.
#define PR_CAP_AMBIENT 47
#define PR_CAP_AMBIENT_IS_SET 1
#define PR_CAP_AMBIENT_RAISE 2
#define PR_CAP_AMBIENT_LOWER 3
#define PR_CAP_AMBIENT_CLEAR_ALL 4
static void set_ambient_cap(int cap)
int rc;
capng_get_caps_process();
rc = capng_update(CAPNG_ADD, CAPNG_INHERITABLE, cap);
if (rc) {
printf("Cannot add inheritable cap\n");
exit(2);
capng_apply(CAPNG_SELECT_CAPS);
/* Note the two 0s at the end. Kernel checks for these */
if (prctl(PR_CAP_AMBIENT, PR_CAP_AMBIENT_RAISE, cap, 0, 0)) {
perror("Cannot set cap");
exit(1);
int main(int argc, char **argv)
int rc;
set_ambient_cap(CAP_NET_RAW);
set_ambient_cap(CAP_NET_ADMIN);
set_ambient_cap(CAP_SYS_NICE);
printf("Ambient_test forking shell\n");
if (execv(argv[1], argv + 1))
perror("Cannot exec");
return 0;
Signed-off-by: Christoph Lameter <cl@linux.com> # Original author
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Aaron Jones <aaronmdjones@gmail.com>
Cc: Ted Ts'o <tytso@mit.edu>
Cc: Andrew G. Morgan <morgan@kernel.org>
Cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
Cc: Austin S Hemmelgarn <ahferroin7@gmail.com>
Cc: Markku Savela <msa@moth.iki.fi>
Cc: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Commit 818411616baf ("fs, proc: introduce /proc/<pid>/task/<tid>/children
entry") introduced the children entry for checkpoint restore and the
file is only available on kernels configured with CONFIG_EXPERT and
CONFIG_CHECKPOINT_RESTORE.
This is available in most distributions (Fedora, Debian, Ubuntu, CoreOS)
because they usually enable CONFIG_EXPERT and CONFIG_CHECKPOINT_RESTORE.
But Arch does not enable CONFIG_EXPERT or CONFIG_CHECKPOINT_RESTORE.
However, the children proc file is useful outside of checkpoint restore.
I would like to use it in rkt. The rkt process exec() another program
it does not control, and that other program will fork()+exec() a child
process. I would like to find the pid of the child process from an
external tool without iterating in /proc over all processes to find
which one has a parent pid equal to rkt.
This commit introduces CONFIG_PROC_CHILDREN and makes
CONFIG_CHECKPOINT_RESTORE select it. This allows enabling
/proc/<pid>/task/<tid>/children without needing to enable
CONFIG_CHECKPOINT_RESTORE and CONFIG_EXPERT.
Alban tested that /proc/<pid>/task/<tid>/children is present when the
kernel is configured with CONFIG_PROC_CHILDREN=y but without
Signed-off-by: Iago López Galeiras <iago@endocode.com>
Tested-by: Alban Crequy <alban@endocode.com>
Reviewed-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Serge Hallyn <serge.hallyn@canonical.com>
Cc: Djalal Harouni <djalal@endocode.com>
Allowing watchdog threads to be parked means that we now have the
opportunity of actually seeing persistent parked threads in the output
of /proc/<pid>/stat and /proc/<pid>/status. The existing code reported
such threads as "Running", which is kind-of true if you think of the
case where we park them as part of taking cpus offline. But if we allow
parking them indefinitely, "Running" is pretty misleading, so we report
them as "Sleeping" instead.
We could simply report them with a new string, "Parked", but it feels
like it's a bit risky for userspace to see unexpected new values; the
output is already documented in Documentation/filesystems/proc.txt, and
it seems like a mistake to change that lightly.
The scheduler does report parked tasks with a "P" in debugging output
from sched_show_task() or dump_cpu_task(), but that's a different API.
Similarly, the trace_ctxwake_* routines report a "P" for parked tasks,
but again, different API.
This change seemed slightly cleaner than updating the task_state_array
to have additional rows. TASK_DEAD should be subsumed by the exit_state
bits; TASK_WAKEKILL is just a modifier; and TASK_WAKING can very
reasonably be reported as "Running" (as it is now). Only TASK_PARKED
shows up with unreasonable output here.
Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Don Zickus <dzickus@redhat.com>
Cc: Ulrich Obergfell <uobergfe@redhat.com>
The seq_printf return value, because it's frequently misused,
will eventually be converted to void.
See: commit 1f33c41c03da ("seq_file: Rename seq_overflow() to
seq_has_overflowed() and make public")
The current semantics of string_escape_mem are inadequate for one of its
current users, vsnprintf(). If that is to honour its contract, it must
know how much space would be needed for the entire escaped buffer, and
string_escape_mem provides no way of obtaining that (short of allocating a
large enough buffer (~4 times input string) to let it play with, and
that's definitely a big no-no inside vsnprintf).
So change the semantics for string_escape_mem to be more snprintf-like:
Return the size of the output that would be generated if the destination
buffer was big enough, but of course still only write to the part of dst
it is allowed to, and (contrary to snprintf) don't do '\0'-termination.
It is then up to the caller to detect whether output was truncated and to
append a '\0' if desired. Also, we must output partial escape sequences,
otherwise a call such as snprintf(buf, 3, "%1pE", "\123") would cause
printf to write a \0 to buf[2] but leaving buf[0] and buf[1] with whatever
they previously contained.
This also fixes a bug in the escaped_string() helper function, which used
to unconditionally pass a length of "end-buf" to string_escape_mem();
since the latter doesn't check osz for being insanely large, it would
happily write to dst. For example, kasprintf(GFP_KERNEL, "something and
then %pE", ...); is an easy way to trigger an oops.
In test-string_helpers.c, the -ENOMEM test is replaced with testing for
getting the expected return value even if the buffer is too small. We
also ensure that nothing is written (by relying on a NULL pointer deref)
if the output size is 0 by passing NULL - this has to work for
kasprintf("%pE") to work.
In net/sunrpc/cache.c, I think qword_add still has the same semantics.
Someone should definitely double-check this.
In fs/proc/array.c, I made the minimum possible change, but longer-term it
should stop poking around in seq_file internals.
[andriy.shevchenko@linux.intel.com: simplify qword_add]
[andriy.shevchenko@linux.intel.com: add missed curly braces]
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
If some issues occurred inside a container guest, host user could not know
which process is in trouble just by guest pid: the users of container
guest only knew the pid inside containers. This will bring obstacle for
trouble shooting.
This patch adds four fields: NStgid, NSpid, NSpgid and NSsid:
a) In init_pid_ns, nothing changed;
b) In one pidns, will tell the pid inside containers:
NStgid: 21776 5 1
NSpid: 21776 5 1
NSpgid: 21776 5 1
NSsid: 21729 1 0
** Process id is 21776 in level 0, 5 in level 1, 1 in level 2.
c) If pidns is nested, it depends on which pidns are you in.
NStgid: 5 1
NSpid: 5 1
NSpgid: 5 1
NSsid: 1 0
** Views from level 1
[akpm@linux-foundation.org: add CONFIG_PID_NS ifdef]
Signed-off-by: Chen Hanxiao <chenhanxiao@cn.fujitsu.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Tested-by: Serge Hallyn <serge.hallyn@canonical.com>
Tested-by: Nathan Scott <nathans@redhat.com>
printk and friends can now format bitmaps using '%*pb[l]'. cpumask
and nodemask also provide cpumask_pr_args() and nodemask_pr_args()
respectively which can be used to generate the two printf arguments
necessary to format the specified cpu/nodemask.
Instead of custom approach let's use string_escape_str() to escape a given
string (task_name in this case).
p->ptrace != 0 means that release_task(p) was not called, so pid_alive()
buys nothing and we can remove this check. Other callers already use it
directly without additional checks.
Note: with or without this patch ptrace_parent() can return the pointer to
the freed task, this will be explained/fixed later.
Cc: Aaron Tomlin <atomlin@redhat.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>,
Cc: Sterling Alexander <stalexan@redhat.com>
Cc: Roland McGrath <roland@hack.frob.com>
task_state() does seq_printf() under rcu_read_lock(), but this is only
needed for task_tgid_nr_ns() and task_numa_group_id(). We can calculate
tgid/ngid and drop rcu lock.
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
1. The usage of fdt looks very ugly, it can't be NULL if ->files is
not NULL. We can use "unsigned int max_fds" instead.
2. This also allows to move seq_printf(max_fds) outside of task_lock()
and join it with the previous seq_printf(). See also the next patch.
task_state() reads cred->group_info under task_lock() because a long ago
it was task_struct->group_info and it was actually protected by
task->alloc_lock. Today this task_unlock() after rcu_read_unlock() just
adds the confusion, move task_unlock() up.
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"In this release:
- PKCS#7 parser for the key management subsystem from David Howells
- appoint Kees Cook as seccomp maintainer
- bugfixes and general maintenance across the subsystem"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (94 commits)
X.509: Need to export x509_request_asymmetric_key()
netlabel: shorter names for the NetLabel catmap funcs/structs
netlabel: fix the catmap walking functions
netlabel: fix the horribly broken catmap functions
netlabel: fix a problem when setting bits below the previously lowest bit
PKCS#7: X.509 certificate issuer and subject are mandatory fields in the ASN.1
tpm: simplify code by using %*phN specifier
tpm: Provide a generic means to override the chip returned timeouts
tpm: missing tpm_chip_put in tpm_get_random()
tpm: Properly clean sysfs entries in error path
tpm: Add missing tpm_do_selftest to ST33 I2C driver
PKCS#7: Use x509_request_asymmetric_key()
Revert "selinux: fix the default socket labeling in sock_graft()"
X.509: x509_request_asymmetric_keys() doesn't need string length arguments
PKCS#7: fix sparse non static symbol warning
KEYS: revert encrypted key change
ima: add support for measuring and appraising firmware
firmware_class: perform new LSM checks
security: introduce kernel_fw_from_file hook
PKCS#7: Missing inclusion of linux/err.h
This is effectively a revert of 7b9a7ec565505699f503b4fcf61500dceb36e744
plus fixing it a different way...
We found, when trying to run an application from an application which
had dropped privs that the kernel does security checks on undefined
capability bits. This was ESPECIALLY difficult to debug as those
undefined bits are hidden from /proc/$PID/status.
Consider a root application which drops all capabilities from ALL 4
capability sets. We assume, since the application is going to set
eff/perm/inh from an array that it will clear not only the defined caps
less than CAP_LAST_CAP, but also the higher 28ish bits which are
undefined future capabilities.
The BSET gets cleared differently. Instead it is cleared one bit at a
time. The problem here is that in security/commoncap.c::cap_task_prctl()
we actually check the validity of a capability being read. So any task
which attempts to 'read all things set in bset' followed by 'unset all
things set in bset' will not even attempt to unset the undefined bits
higher than CAP_LAST_CAP.
So the 'parent' will look something like:
CapInh: 0000000000000000
CapPrm: 0000000000000000
CapEff: 0000000000000000
CapBnd: ffffffc000000000
All of this 'should' be fine. Given that these are undefined bits that
aren't supposed to have anything to do with permissions. But they do...
So lets now consider a task which cleared the eff/perm/inh completely
and cleared all of the valid caps in the bset (but not the invalid caps
it couldn't read out of the kernel). We know that this is exactly what
the libcap-ng library does and what the go capabilities library does.
They both leave you in that above situation if you try to clear all of
you capapabilities from all 4 sets. If that root task calls execve()
the child task will pick up all caps not blocked by the bset. The bset
however does not block bits higher than CAP_LAST_CAP. So now the child
task has bits in eff which are not in the parent. These are
'meaningless' undefined bits, but still bits which the parent doesn't
have.
The problem is now in cred_cap_issubset() (or any operation which does a
subset test) as the child, while a subset for valid cap bits, is not a
subset for invalid cap bits! So now we set durring commit creds that
the child is not dumpable. Given it is 'more priv' than its parent. It
also means the parent cannot ptrace the child and other stupidity.
The solution here:
1) stop hiding capability bits in status
This makes debugging easier!
2) stop giving any task undefined capability bits. it's simple, it you
don't put those invalid bits in CAP_FULL_SET you won't get them in init
and you won't get them in any other task either.
This fixes the cap_issubset() tests and resulting fallout (which
made the init task in a docker container untraceable among other
things)
3) mask out undefined bits when sys_capset() is called as it might use
~0, ~0 to denote 'all capabilities' for backward/forward compatibility.
This lets 'capsh --caps="all=eip" -- -c /bin/bash' run.
4) mask out undefined bit when we read a file capability off of disk as
again likely all bits are set in the xattr for forward/backward
compatibility.
This lets 'setcap all+pe /bin/bash; /bin/bash' run
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: Andrew Vagin <avagin@openvz.org>
Cc: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Steve Grubb <sgrubb@redhat.com>
Cc: Dan Walsh <dwalsh@redhat.com>
Cc: stable@vger.kernel.org
Signed-off-by: James Morris <james.l.morris@oracle.com>
Simplify the only user of this data by removing the timespec
conversion.
Signed-off-by: John Stultz <john.stultz@linaro.org>
get_task_state() uses the most significant bit to report the state to
user-space, this means that EXIT_ZOMBIE->EXIT_TRACE->EXIT_DEAD transition
can be noticed via /proc as Z -> X -> Z change. Note that this was
possible even before EXIT_TRACE was introduced.
This is not really bad but imho it make sense to hide EXIT_TRACE from
user-space completely. So the patch simply swaps EXIT_ZOMBIE and
EXIT_DEAD, this way EXIT_TRACE will be seen as EXIT_ZOMBIE by user-space.
Cc: Jan Kratochvil <jan.kratochvil@redhat.com>
Cc: Michal Schmidt <mschmidt@redhat.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Lennart Poettering <lpoetter@redhat.com>
Cc: Tejun Heo <tj@kernel.org>
Change the remaining next_thread (ab)users to use while_each_thread().
The last user which should be changed is next_tid(), but we can't do this
now.
__exit_signal() and complete_signal() are fine, they actually need
next_thread() logic.
This patch (of 3):
do_task_stat() can use while_each_thread(), no changes in
the compiled code.
Reviewed-by: Sameer Nanda <snanda@chromium.org>
get_task_state() and task_state_array[] look confusing and suboptimal, it
is not clear what it can actually report to user-space and
task_state_array[] blows .data for no reason.
1. state = (tsk->state & TASK_REPORT) | tsk->exit_state is not
clear. TASK_REPORT is self-documenting but it is not clear
what ->exit_state can add.
Move the potential exit_state's (EXIT_ZOMBIE and EXIT_DEAD)
into TASK_REPORT and use it to calculate the final result.
2. With the change above it is obvious that task_state_array[]
has the unused entries just to make BUILD_BUG_ON() happy.
Change this BUILD_BUG_ON() to use TASK_REPORT rather than
TASK_STATE_MAX and shrink task_state_array[].
3. Turn the "while (state)" loop into fls(state).
Cc: David Laight <David.Laight@ACULAB.COM>
It is desirable to model from userspace how the scheduler groups tasks
over time. This patch adds an ID to the numa_group and reports it via
/proc/PID/status.
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1381141781-10992-45-git-send-email-mgorman@suse.de
The smpboot threads rely on the park/unpark mechanism which binds per
cpu threads on a particular core. Though the functionality is racy:
CPU0 CPU1 CPU2
unpark(T) wake_up_process(T)
clear(SHOULD_PARK) T runs
leave parkme() due to !SHOULD_PARK
bind_to(CPU2) BUG_ON(wrong CPU)
We cannot let the tasks move themself to the target CPU as one of
those tasks is actually the migration thread itself, which requires
that it starts running on the target cpu right away.
The solution to this problem is to prevent wakeups in park mode which
are not from unpark(). That way we can guarantee that the association
of the task to the target cpu is working correctly.
Add a new task state (TASK_PARKED) which prevents other wakeups and
use this state explicitly for the unpark wakeup.
Peter noticed: Also, since the task state is visible to userspace and
all the parked tasks are still in the PID space, its a good hint in ps
and friends that these tasks aren't really there for the moment.
The migration thread has another related issue.
CPU0 CPU1
Bring up CPU2
create_thread(T)
park(T)
wait_for_completion()
parkme()
complete()
sched_set_stop_task()
schedule(TASK_PARKED)
The sched_set_stop_task() call is issued while the task is on the
runqueue of CPU1 and that confuses the hell out of the stop_task class
on that cpu. So we need the same synchronizaion before
sched_set_stop_task().
Reported-by: Dave Jones <davej@redhat.com>
Reported-and-tested-by: Dave Hansen <dave@sr71.net>
Reported-and-tested-by: Borislav Petkov <bp@alien8.de>
Acked-by: Peter Ziljstra <peterz@infradead.org>
Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: dhillf@gmail.com
Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1304091635430.21884@ionos
This is in preparation for the full dynticks feature. While
remotely reading the cputime of a task running in a full
dynticks CPU, we'll need to do some extra-computation. This
way we can account the time it spent tickless in userspace
since its last cputime snapshot.
Cc: Li Zhong <zhong@linux.vnet.ibm.com>
Cc: Namhyung Kim <namhyung.kim@lge.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Merge misc patches from Andrew Morton:
"Incoming:
- lots of misc stuff
- backlight tree updates
- lib/ updates
- Oleg's percpu-rwsem changes
- checkpatch
- rtc
- aoe
- more checkpoint/restart support
I still have a pile of MM stuff pending - Pekka should be merging
later today after which that is good to go. A number of other things
are twiddling thumbs awaiting maintainer merges."
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (180 commits)
scatterlist: don't BUG when we can trivially return a proper error.
docs: update documentation about /proc/<pid>/fdinfo/<fd> fanotify output
fs, fanotify: add @mflags field to fanotify output
docs: add documentation about /proc/<pid>/fdinfo/<fd> output
fs, notify: add procfs fdinfo helper
fs, exportfs: add exportfs_encode_inode_fh() helper
fs, exportfs: escape nil dereference if no s_export_op present
fs, epoll: add procfs fdinfo helper
fs, eventfd: add procfs fdinfo helper
procfs: add ability to plug in auxiliary fdinfo providers
tools/testing/selftests/kcmp/kcmp_test.c: print reason for failure in kcmp_test
breakpoint selftests: print failure status instead of cause make error
kcmp selftests: print fail status instead of cause make error
kcmp selftests: make run_tests fix
mem-hotplug selftests: print failure status instead of cause make error
cpu-hotplug selftests: print failure status instead of cause make error
mqueue selftests: print failure status instead of cause make error
vm selftests: print failure status instead of cause make error
ubifs: use prandom_bytes
mtd: nandsim: use prandom_bytes
This allows us to print out eventpoll target file descriptor, events and
data, the /proc/pid/fdinfo/fd consists of
| pos: 0
| flags: 02
| tfd: 5 events: 1d data: ffffffffffffffff enabled: 1
[avagin@: fix for unitialized ret variable]
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Acked-by: Pavel Emelyanov <xemul@parallels.com>
Cc: Andrey Vagin <avagin@openvz.org>
Cc: James Bottomley <jbottomley@parallels.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Matthew Helsley <matt.helsley@gmail.com>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Tvrtko Ursulin <tvrtko.ursulin@onelan.co.uk>
We display a list of supplementary group for each process in
/proc/<pid>/status. However, we show only the first 32 groups, not all of
them.
Although this is rare, but sometimes processes do have more than 32
supplementary groups, and this kernel limitation breaks user-space apps
that rely on the group list in /proc/<pid>/status.
Number 32 comes from the internal NGROUPS_SMALL macro which defines the
length for the internal kernel "small" groups buffer. There is no
apparent reason to limit to this value.
This patch removes the 32 groups printing limit.
The Linux kernel limits the amount of supplementary groups by NGROUPS_MAX,
which is currently set to 65536. And this is the maximum count of groups
we may possibly print.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
It is currently impossible to examine the state of seccomp for a given
process. While attaching with gdb and attempting "call
prctl(PR_GET_SECCOMP,...)" will work with some situations, it is not
reliable. If the process is in seccomp mode 1, this query will kill the
process (prctl not allowed), if the process is in mode 2 with prctl not
allowed, it will similarly be killed, and in weird cases, if prctl is
filtered to return errno 0, it can look like seccomp is disabled.
When reviewing the state of running processes, there should be a way to
externally examine the seccomp mode. ("Did this build of Chrome end up
using seccomp?" "Did my distro ship ssh with seccomp enabled?")
This adds the "Seccomp" line to /proc/$pid/status.
Without this patch it is really hard to interpret a bounding set, if
CAP_LAST_CAP is unknown for a current kernel.
Non-existant capabilities can not be deleted from a bounding set with help
of prctl.
E.g.: Here are two examples without/with this patch.
CapBnd: ffffffe0fdecffff
CapBnd: 00000000fdecffff
I suggest to hide non-existent capabilities. Here is two reasons.
* It's logically and easier for using.
* It helps to checkpoint-restore capabilities of tasks, because tasks
can be restored on another kernel, where CAP_LAST_CAP is bigger.
Signed-off-by: Andrew Vagin <avagin@openvz.org>
Reviewed-by: Serge E. Hallyn <serge.hallyn@canonical.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace changes from Eric Biederman:
"While small this set of changes is very significant with respect to
containers in general and user namespaces in particular. The user
space interface is now complete.
This set of changes adds support for unprivileged users to create user
namespaces and as a user namespace root to create other namespaces.
The tyranny of supporting suid root preventing unprivileged users from
using cool new kernel features is broken.
This set of changes completes the work on setns, adding support for
the pid, user, mount namespaces.
This set of changes includes a bunch of basic pid namespace
cleanups/simplifications. Of particular significance is the rework of
the pid namespace cleanup so it no longer requires sending out
tendrils into all kinds of unexpected cleanup paths for operation. At
least one case of broken error handling is fixed by this cleanup.
The files under /proc/<pid>/ns/ have been converted from regular files
to magic symlinks which prevents incorrect caching by the VFS,
ensuring the files always refer to the namespace the process is
currently using and ensuring that the ptrace_mayaccess permission
checks are always applied.
The files under /proc/<pid>/ns/ have been given stable inode numbers
so it is now possible to see if different processes share the same
namespaces.
Through the David Miller's net tree are changes to relax many of the
permission checks in the networking stack to allowing the user
namespace root to usefully use the networking stack. Similar changes
for the mount namespace and the pid namespace are coming through my
tree.
Two small changes to add user namespace support were commited here adn
in David Miller's -net tree so that I could complete the work on the
/proc/<pid>/ns/ files in this tree.
Work remains to make it safe to build user namespaces and 9p, afs,
ceph, cifs, coda, gfs2, ncpfs, nfs, nfsd, ocfs2, and xfs so the
Kconfig guard remains in place preventing that user namespaces from
being built when any of those filesystems are enabled.
Future design work remains to allow root users outside of the initial
user namespace to mount more than just /proc and /sys."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (38 commits)
proc: Usable inode numbers for the namespace file descriptors.
proc: Fix the namespace inode permission checks.
proc: Generalize proc inode allocation
userns: Allow unprivilged mounts of proc and sysfs
userns: For /proc/self/{uid,gid}_map derive the lower userns from the struct file
procfs: Print task uids and gids in the userns that opened the proc file
userns: Implement unshare of the user namespace
userns: Implent proc namespace operations
userns: Kill task_user_ns
userns: Make create_new_namespaces take a user_ns parameter
userns: Allow unprivileged use of setns.
userns: Allow unprivileged users to create new namespaces
userns: Allow setting a userns mapping to your current uid.
userns: Allow chown and setgid preservation
userns: Allow unprivileged users to create user namespaces.
userns: Ignore suid and sgid on binaries if the uid or gid can not be mapped
userns: fix return value on mntns_install() failure
vfs: Allow unprivileged manipulation of the mount namespace.
vfs: Only support slave subtrees across different user namespaces
vfs: Add a user namespace reference from struct mnt_namespace
We have thread_group_cputime() and thread_group_times(). The naming
doesn't provide enough information about the difference between
these two APIs.
To lower the confusion, rename thread_group_times() to
thread_group_cputime_adjusted(). This name better suggests that
it's a version of thread_group_cputime() that does some stabilization
on the raw cputime values. ie here: scale on top of CFS runtime
stats and bound lower value for monotonicity.
Instead of using current_userns() use the userns of the opener
of the file so that if the file is passed between processes
the contents of the file do not change.
/proc/$pid/stat
We would like to have an ability to restore command line arguments and
program environment pointers but first we need to obtain them somehow.
Thus we put these values into /proc/$pid/stat. The exit_code is needed to
restore zombie tasks.
Cc: Vasiliy Kulikov <segoon@openwall.com>
When we do checkpoint of a task we need to know the list of children the
task, has but there is no easy and fast way to generate reverse
parent->children chain from arbitrary <pid> (while a parent pid is
provided in "PPid" field of /proc/<pid>/status).
So instead of walking over all pids in the system (creating one big
process tree in memory, just to figure out which children a task has) --
we add explicit /proc/<pid>/task/<tid>/children entry, because the kernel
already has this kind of information but it is not yet exported.
This is a first level children, not the whole process tree.
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
- use int fpr priority and nice, since task_nice()/task_prio() return that
- field 24: get_mm_rss() returns unsigned long
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
As a first step to converting struct cred to be all kuid_t and kgid_t
values convert the group values stored in group_info to always be
kgid_t values. Unless user namespaces are used this change should
have no effect.
bda7bad62bc4 ("procfs: speed up /proc/pid/stat, statm") broke /proc/statm
- 'text' is printed twice by mistake.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reported-by: Ulrich Drepper <drepper@gmail.com>
Process accounting applications as top, ps visit some files under
/proc/<pid>. With seq_put_decimal_ull(), we can optimize /proc/<pid>/stat
and /proc/<pid>/statm files.
This patch adds
- seq_put_decimal_ll() for signed values.
- allow delimiter == 0.
- convert seq_printf() to seq_put_decimal_ull/ll in /proc/stat, statm.
Test result on a system with 2000+ procs.
Before patch:
[kamezawa@bluextal test]$ top -b -n 1 | wc -l
2223
[kamezawa@bluextal test]$ time top -b -n 1 > /dev/null
real 0m0.675s
user 0m0.044s
sys 0m0.121s
[kamezawa@bluextal test]$ time ps -elf > /dev/null
real 0m0.236s
user 0m0.056s
sys 0m0.176s
After patch:
kamezawa@bluextal ~]$ time top -b -n 1 > /dev/null
real 0m0.657s
user 0m0.052s
sys 0m0.100s
[kamezawa@bluextal ~]$ time ps -elf > /dev/null
real 0m0.198s
user 0m0.050s
sys 0m0.145s
Considering top, ps tend to scan /proc periodically, this will reduce cpu
consumption by top/ps to some extent.
[akpm@linux-foundation.org: checkpatch fixes]
* 'for-linus' of git://selinuxproject.org/~jmorris/linux-security:
capabilities: remove __cap_full_set definition
security: remove the security_netlink_recv hook as it is equivalent to capable()
ptrace: do not audit capability check when outputing /proc/pid/stat
capabilities: remove task_ns_* functions
capabitlies: ns_capable can use the cap helpers rather than lsm call
capabilities: style only - move capable below ns_capable
capabilites: introduce new has_ns_capabilities_noaudit
capabilities: call has_ns_capability from has_capability
capabilities: remove all _real_ interfaces
capabilities: introduce security_capable_noaudit
capabilities: reverse arguments to security_capable
capabilities: remove the task from capable LSM hook entirely
selinux: sparse fix: fix several warnings in the security server cod
selinux: sparse fix: fix warnings in netlink code
selinux: sparse fix: eliminate warnings for selinuxfs
selinux: sparse fix: declare selinux_disable() in security.h
selinux: sparse fix: move selinux_complete_init
selinux: sparse fix: make selinux_secmark_refcount static
SELinux: Fix RCU deref check warning in sel_netport_insert()
Manually fix up a semantic mis-merge wrt security_netlink_recv():
- the interface was removed in commit fd7784615248 ("security: remove
the security_netlink_recv hook as it is equivalent to capable()")
- a new user of it appeared in commit a38f7907b926 ("crypto: Add
userspace configuration API")
causing no automatic merge conflict, but Eric Paris pointed out the
issue.
The mm->start_code/end_code, mm->start_data/end_data, mm->start_brk are
involved into calculation of program text/data segment sizes (which might
be seen in /proc/<pid>/statm) and into brk() call final address.
For restore we need to know all these values. While
mm->start_code/end_code already present in /proc/$pid/stat, the rest
members are not, so this patch brings them in.
The restore procedure of these members is addressed in another patch using
prctl().
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reading /proc/pid/stat of another process checks if one has ptrace permissions
on that process. If one does have permissions it outputs some data about the
process which might have security and attack implications. If the current
task does not have ptrace permissions the read still works, but those fields
are filled with inocuous (0) values. Since this check and a subsequent denial
is not a violation of the security policy we should not audit such denials.
This can be quite useful to removing ptrace broadly across a system without
flooding the logs when ps is run or something which harmlessly walks proc.
Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Make cputime_t and cputime64_t nocast to enable sparse checking to
detect incorrect use of cputime. Drop the cputime macros for simple
scalar operations. The conversion macros are still needed.
