path: root/fs/open.c
2005-09-07[PATCH] remove duplicated sys_open32() code from 64bit archsMiklos Szeredi
64 bit architectures all implement their own compatibility sys_open(), when in fact the difference is simply not forcing the O_LARGEFILE flag. So use the a common function instead. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Cc: <viro@parcelfarce.linux.theplanet.co.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] inotifyRobert Love
inotify is intended to correct the deficiencies of dnotify, particularly its inability to scale and its terrible user interface: * dnotify requires the opening of one fd per each directory that you intend to watch. This quickly results in too many open files and pins removable media, preventing unmount. * dnotify is directory-based. You only learn about changes to directories. Sure, a change to a file in a directory affects the directory, but you are then forced to keep a cache of stat structures. * dnotify's interface to user-space is awful. Signals? inotify provides a more usable, simple, powerful solution to file change notification: * inotify's interface is a system call that returns a fd, not SIGIO. You get a single fd, which is select()-able. * inotify has an event that says "the filesystem that the item you were watching is on was unmounted." * inotify can watch directories or files. Inotify is currently used by Beagle (a desktop search infrastructure), Gamin (a FAM replacement), and other projects. See Documentation/filesystems/inotify.txt. Signed-off-by: Robert Love <rml@novell.com> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] xip: fs/mm: execute in placeCarsten Otte
- generic_file* file operations do no longer have a xip/non-xip split - filemap_xip.c implements a new set of fops that require get_xip_page aop to work proper. all new fops are exported GPL-only (don't like to see whatever code use those except GPL modules) - __xip_unmap now uses page_check_address, which is no longer static in rmap.c, and defined in linux/rmap.h - mm/filemap.h is now much more clean, plainly having just Linus' inline funcs moved here from filemap.c - fix includes in filemap_xip to make it build cleanly on i386 Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] sys_open() cleanupTelemaque Ndizihiwe
Clean up tortured logic in sys_open(). Signed-off-by: Telemaque Ndizihiwe <telendiz@eircom.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] Remove f_error field from struct fileChristoph Lameter
The following patch removes the f_error field and all checks of f_error. Trond said: f_error was introduced for NFS, and made sense when we were guaranteed always to have a file pointer around when write errors occurred. Since then, we have (for various reasons) had to introduce the nfs_open_context in order to track the file read/write state, and it made sense to move our f_error tracking there too. Signed-off-by: Christoph Lameter <christoph@lameter.com> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] Don't force O_LARGEFILE for 32 bit processes on ia64Yoav Zach
In ia64 kernel, the O_LARGEFILE flag is forced when opening a file. This is problematic for execution of 32 bit processes, which are not largefile aware, either by SW emulation or by HW execution. For such processes, the problem is two-fold: 1) When trying to open a file that is larger than 4G the operation should fail, but it's not 2) Writing to offset larger than 4G should fail, but it's not The proposed patch takes advantage of the way 32 bit processes are identified in ia64 systems. Such processes have PER_LINUX32 for their personality. With the patch, the ia64 kernel will not enforce the O_LARGEFILE flag if the current process has PER_LINUX32 set. The behavior for all other architectures remains unchanged. Signed-off-by: Yoav Zach <yoav.zach@intel.com> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
