path: root/fs/ocfs2
2011-05-13ocfs2/dlm: Use negotiated o2dlm protocol versionSunil Mushran
Patch fixes a bug in the o2dlm protocol negotiation in that it is using the builtin version rather than the negotiated version during the domain join. This causes join errors when a node having kernel >= 2.6.37 joins a cluster with nodes having kernels < 2.6.37. This only affects the o2cb cluster stack. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Reported-by: Jacek Stepniewski <Jacek.Stepniewski@agora.pl> Acked-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-05-13ocfs2: skip existing hole when removing the last extent_rec in punching-hole ↵Tristan Ye
codes. In the case of removing a partial extent record which covers a hole, current punching-hole logic will try to remove more than the length of whole extent record, which leads to the failure of following assert(fs/ocfs2/alloc.c): 5507 BUG_ON(cpos < le32_to_cpu(rec->e_cpos) || trunc_range > rec_range); This patch tries to skip existing hole at the last attempt of removing a partial extent record, what's more, it also adds some necessary comments for better understanding of punching-hole codes. Signed-off-by: Tristan Ye <tristan.ye@oracle.com> Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-05-13ocfs2: Initialize data_ac (might be used uninitialized)Marcus Meissner
CLANG found that there is a path that has data_ac uninitialized, this place 2917 /* This gets us the dx_root */ 2918 ret = ocfs2_reserve_new_metadata_blocks(osb, 1, &meta_ac); 2919 if (ret) { 3 Taking true branch 2920 mlog_errno(ret); 2921 goto out; 4 Control jumps to line 3168 2922 } Goes to the out: label without data_ac being initialized. Ciao, Marcus Signed-Off-By: Marcus Meissner <meissner@suse.de> Signed-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-04-26Revert wrong fixes for common misspellingsLucas De Marchi
These changes were incorrectly fixed by codespell. They were now manually corrected. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-10treewide: remove extra semicolonsJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-28Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: (39 commits) Treat writes as new when holes span across page boundaries fs,ocfs2: Move o2net_get_func_run_time under CONFIG_OCFS2_FS_STATS. ocfs2/dlm: Move kmalloc() outside the spinlock ocfs2: Make the left masklogs compat. ocfs2: Remove masklog ML_AIO. ocfs2: Remove masklog ML_UPTODATE. ocfs2: Remove masklog ML_BH_IO. ocfs2: Remove masklog ML_JOURNAL. ocfs2: Remove masklog ML_EXPORT. ocfs2: Remove masklog ML_DCACHE. ocfs2: Remove masklog ML_NAMEI. ocfs2: Remove mlog(0) from fs/ocfs2/dir.c ocfs2: remove NAMEI from symlink.c ocfs2: Remove masklog ML_QUOTA. ocfs2: Remove mlog(0) from quota_local.c. ocfs2: Remove masklog ML_RESERVATIONS. ocfs2: Remove masklog ML_XATTR. ocfs2: Remove masklog ML_SUPER. ocfs2: Remove mlog(0) from fs/ocfs2/heartbeat.c ocfs2: Remove mlog(0) from fs/ocfs2/slot_map.c ... Fix up trivial conflict in fs/ocfs2/super.c
2011-03-28Treat writes as new when holes span across page boundariesGoldwyn Rodrigues
When a hole spans across page boundaries, the next write forces a read of the block. This could end up reading existing garbage data from the disk in ocfs2_map_page_blocks. This leads to non-zero holes. In order to avoid this, mark the writes as new when the holes span across page boundaries. Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.de> Signed-off-by: jlbec <jlbec@evilplan.org>
2011-03-28Merge branch 'mlog_replace_for_39' of git://repo.or.cz/taoma-kernel into ↵Joel Becker
ocfs2-merge-window-fix
2011-03-28fs,ocfs2: Move o2net_get_func_run_time under CONFIG_OCFS2_FS_STATS.Rakib Mullick
When CONFIG_DEBUG_FS=y and CONFIG_OCFS2_FS_STATS=n, we get the following warning: fs/ocfs2/cluster/tcp.c:213:16: warning: ‘o2net_get_func_run_time’ defined but not used Since o2net_get_func_run_time is only called from o2net_update_recv_stats, so move it under CONFIG_OCFS2_FS_STATS. Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Signed-off-by: jlbec <jlbec@evilplan.org>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-23userns: rename is_owner_or_cap to inode_owner_or_capableSerge E. Hallyn
And give it a kernel-doc comment. [akpm@linux-foundation.org: btrfs changed in linux-next] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23ocfs2: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Joel Becker <joel.becker@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-17fs: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. And change ntfs-objs to ntfs-y for cleaner conditional inclusion. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (33 commits) AppArmor: kill unused macros in lsm.c AppArmor: cleanup generated files correctly KEYS: Add an iovec version of KEYCTL_INSTANTIATE KEYS: Add a new keyctl op to reject a key with a specified error code KEYS: Add a key type op to permit the key description to be vetted KEYS: Add an RCU payload dereference macro AppArmor: Cleanup make file to remove cruft and make it easier to read SELinux: implement the new sb_remount LSM hook LSM: Pass -o remount options to the LSM SELinux: Compute SID for the newly created socket SELinux: Socket retains creator role and MLS attribute SELinux: Auto-generate security_is_socket_class TOMOYO: Fix memory leak upon file open. Revert "selinux: simplify ioctl checking" selinux: drop unused packet flow permissions selinux: Fix packet forwarding checks on postrouting selinux: Fix wrong checks for selinux_policycap_netpeer selinux: Fix check for xfrm selinux context algorithm ima: remove unnecessary call to ima_must_measure IMA: remove IMA imbalance checking ...
2011-03-16Merge branch 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix build failure introduced by s/freezeable/freezable/ workqueue: add system_freezeable_wq rds/ib: use system_wq instead of rds_ib_fmr_wq net/9p: replace p9_poll_task with a work net/9p: use system_wq instead of p9_mux_wq xfs: convert to alloc_workqueue() reiserfs: make commit_wq use the default concurrency level ocfs2: use system_wq instead of ocfs2_quota_wq ext4: convert to alloc_workqueue() scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path scsi/be2iscsi,qla2xxx: convert to alloc_workqueue() misc/iwmc3200top: use system_wq instead of dedicated workqueues i2o: use alloc_workqueue() instead of create_workqueue() acpi: kacpi*_wq don't need WQ_MEM_RECLAIM fs/aio: aio_wq isn't used in memory reclaim path input/tps6507x-ts: use system_wq instead of dedicated workqueue cpufreq: use system_wq instead of dedicated workqueues wireless/ipw2x00: use system_wq instead of dedicated workqueues arm/omap: use system_wq in mailbox workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
2011-03-16Merge branch 'next' into for-linusJames Morris
2011-03-14exportfs: Return the minimum required handle sizeAneesh Kumar K.V
The exportfs encode handle function should return the minimum required handle size. This helps user to find out the handle size by passing 0 handle size in the first step and then redoing to the call again with the returned handle size value. Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-14kill path_lookup()Al Viro
all remaining callers pass LOOKUP_PARENT to it, so flags argument can die; renamed to kern_path_parent() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10ocfs2: fix d_revalidate oopsen on NFS exportsAl Viro
can't blindly check nd->flags in ->d_revalidate() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10Merge branch 'for-2.6.39/stack-plug' into for-2.6.39/coreJens Axboe
Conflicts: block/blk-core.c block/blk-flush.c drivers/md/raid1.c drivers/md/raid10.c drivers/md/raid5.c fs/nilfs2/btnode.c fs/nilfs2/mdt.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-08Merge branch 'master' of git://git.infradead.org/users/eparis/selinux into nextJames Morris
2011-02-22ocfs2/dlm: Move kmalloc() outside the spinlockSunil Mushran
In dlm_query_region_handler(), move the kmalloc outside the spinlock. This allows us to use GFP_KERNEL instead of GFP_ATOMIC. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-02-21ocfs2: Make the left masklogs compat.Tao Ma
Since we have removed almost all of the masklogs in fs/ocfs2/*, make the left masklogs compat. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-21ocfs2: Remove masklog ML_AIO.Tao Ma
There is no user for masklog AIO, so remove it. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-24ocfs2: Remove masklog ML_UPTODATE.Tao Ma
Remove mlog(0,...) and mlog(ML_UPTODATE,...) from fs/ocfs2/uptodate.c and fs/ocfs2/buffer_head_io.c. The masklog UPTODATE is removed finally. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-24ocfs2: Remove masklog ML_BH_IO.Tao Ma
Remove mlog(0,...) and mlog(ML_BH_IO,...) from fs/ocfs2/buffer_head_io.c. The masklog BH_IO is removed finally. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-24ocfs2: Remove masklog ML_JOURNAL.Tao Ma
Remove mlog(0) from fs/ocfs2/journal.c and the masklog JOURNAL. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-24ocfs2: Remove masklog ML_EXPORT.Tao Ma
Remove mlog(0) from fs/ocfs2/export.c and the masklog EXPORT. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-23ocfs2: Remove masklog ML_DCACHE.Tao Ma
Remove mlog(0) from fs/ocfs2/dcache.c and the masklog DCACHE. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-23ocfs2: Remove masklog ML_NAMEI.Tao Ma
Remove mlog(0) from fs/ocfs2/namei.c and the masklog NAMEI finally. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-23ocfs2: Remove mlog(0) from fs/ocfs2/dir.cTao Ma
This is the 2nd step to remove the debug info of NAMEI. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-21ocfs2: remove NAMEI from symlink.cTao Ma
No mlog(0,...) in symlink.c, so just remove NAMEI. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-23ocfs2: Remove masklog ML_QUOTA.Tao Ma
Remove mlog(0) from fs/ocfs2/quota_global.c and the masklog QUOTA. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-23ocfs2: Remove mlog(0) from quota_local.c.Tao Ma
Remove mlog(0) from fs/ocfs2/quota_local.c. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-23ocfs2: Remove masklog ML_RESERVATIONS.Tao Ma
Remove mlog(0) from fs/ocfs2/reservations.c and the masklog RESERVATIONS. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-23ocfs2: Remove masklog ML_XATTR.Tao Ma
Remove mlog(0) from fs/ocfs2/xattr.c and the masklog ML_XATTR. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-23ocfs2: Remove masklog ML_SUPER.Tao Ma
Remove mlog(0) from fs/ocfs2/super.c and the masklog SUPER. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-23ocfs2: Remove mlog(0) from fs/ocfs2/heartbeat.cTao Ma
This is the 2nd step to remove the debug info of SUPER. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-22ocfs2: Remove mlog(0) from fs/ocfs2/slot_map.cTao Ma
This is the 1st step to remove the debug info of SUPER. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-22ocfs2: Remove masklog ML_EXTENT_MAP.Tao Ma
Remove mlog(0) from fs/ocfs2/extent_map.c and the masklog EXTENT_MAP. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-22ocfs2: Remove masklog ML_INODE.Tao Ma
Remove mlog(0) from fs/ocfs2/inode.c and the masklog INODE. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-21ocfs2: Little refactoring against ocfs2_iget.Tao Ma
ocfs2_iget is used to get/create inode. Only iget5_locked will give us an inode = NULL. So move this check ahead of ocfs2_read_locked_inode so that we don't need to check inode before we read and unlock inode. This is also helpful for trace event(see the next patch). Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-22ocfs2: Remove mlog(0) from fs/ocfs2/file.cTao Ma
This is the 2nd step to remove the debug info of INODE. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-21ocfs2: remove INODE from unused files.Tao Ma
As there are no such debug information in fs/ocfs2/ioctl.c, fs/ocfs2/locks.c and fs/ocfs2/sysfile.c, ML_INODE are also removed. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-22ocfs2: Remove FILE_IO from masklog.Tao Ma
Change all the "mlog(0," in fs/ocfs2/mmap.c to trace events. And finally remove masklog FILE_IO. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
