path: root/fs/ocfs2
2007-05-07mm: make read_cache_page synchronousNick Piggin
Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2: ocfs2: Force use of GFP_NOFS in ocfs2_write() ocfs2: fix sparse warnings in fs/ocfs2/cluster ocfs2: fix sparse warnings in fs/ocfs2/dlm ocfs2: fix sparse warnings in fs/ocfs2 [PATCH] Copy i_flags to ocfs2 inode flags on write [PATCH] ocfs2: use __set_current_state() ocfs2: Wrap access of directory allocations with ip_alloc_sem. [PATCH] fs/ocfs2/: make 3 functions static ocfs2: Implement compat_ioctl()
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02ocfs2: Force use of GFP_NOFS in ocfs2_write()Mark Fasheh
We can otherwise recurse into the file system. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-05-02ocfs2: fix sparse warnings in fs/ocfs2/clusterMark Fasheh
2007-05-02ocfs2: fix sparse warnings in fs/ocfs2/dlmMark Fasheh
2007-05-02ocfs2: fix sparse warnings in fs/ocfs2Mark Fasheh
None of these are actually harmful, but the noise makes looking for real problems difficult. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-05-02[PATCH] Copy i_flags to ocfs2 inode flags on writeJan Kara
Propagate flags such as S_APPEND, S_IMMUTABLE, etc. from i_flags into ocfs2-specific ip_attr. Hence, when someone sets these flags via a different interface than ioctl, they are stored correctly. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-05-02[PATCH] ocfs2: use __set_current_state()Milind Arun Choudhary
use __set_current_state(TASK_*) instead of current->state = TASK_*, in fs/ocfs2 Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-05-02ocfs2: Wrap access of directory allocations with ip_alloc_sem.Joel Becker
OCFS2_I(inode)->ip_alloc_sem is a read-write semaphore protecting local concurrent access of ocfs2 inodes. However, ocfs2 directories were not taking the semaphore while they accessed or modified the allocation tree. ocfs2_extend_dir() needs to take the semaphore in a write mode when it adds to the allocation. All other directory users get there via ocfs2_bread(), which takes the semaphore in read mode. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-05-02[PATCH] fs/ocfs2/: make 3 functions staticAdrian Bunk
This patch makes the following needlessly global functions static: - aops.c: ocfs2_write_data_page() - dlmglue.c: ocfs2_dump_meta_lvb_info() - file.c: ocfs2_set_inode_size() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-05-02ocfs2: Implement compat_ioctl()Mark Fasheh
We need this to support 32 bit system calls on 64 bit kernels. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Cache extent recordsMark Fasheh
The extent map code was ripped out earlier because of an inability to deal with holes. This patch adds back a simpler caching scheme requiring far less code. Our old extent map caching was designed back when meta data block caching in Ocfs2 didn't work very well, resulting in many disk reads. These days our metadata caching is much better, resulting in no un-necessary disk reads. As a result, extent caching doesn't have to be as fancy, nor does it have to cache as many extents. Keeping the last 3 extents seen should be sufficient to give us a small performance boost on some streaming workloads. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Remember rw lock level during direct ioMark Fasheh
Cluster locking might have been redone because a direct write won't complete, so this needs to be reflected in the iocb. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Fix up i_blocks calculation to know about holesMark Fasheh
Older file systems which didn't support holes did a dumb calculation of i_blocks based on i_size. This is no longer accurate, so fix things up to take actual allocation into account. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Fix extent lookup to return true size of holesMark Fasheh
Initially, we had wired things to return a size '1' of holes. Cook up a small amount of code to find the next extent and calculate the number of clusters between the virtual offset and the next allocated extent. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Read from an unwritten extent returns zerosMark Fasheh
Return an optional extent flags field from our lookup functions and wire up callers to treat unwritten regions as holes for the purpose of returning zeros to the user. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: make room for unwritten extents flagMark Fasheh
Due to the size of our group bitmaps, we'll never have a leaf node extent record with more than 16 bits worth of clusters. Split e_clusters up so that leaf nodes can get a flags field where we can mark unwritten extents. Interior nodes whose length references all the child nodes beneath it can't split their e_clusters field, so we use a union to preserve sizing there. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Use own splice write actorMark Fasheh
We need to fill holes during a splice write. Provide our own splice write actor which can call ocfs2_file_buffered_write() with a splice-specific callback. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Use do_sync_mapping_range() in ocfs2_zero_tail_for_truncate()Mark Fasheh
Do this instead of filemap_fdatawrite() - this way we sync only the range between i_size and the cluster boundary. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: zero tail of sparse files on truncateMark Fasheh
Since we don't zero on extend anymore, truncate needs to be fixed up to zero the part of a file between i_size and and end of it's cluster. Otherwise a subsequent extend could expose bad data. This introduced a new helper, which can be used in ocfs2_write(). Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Teach ocfs2_get_block() about holesMark Fasheh
ocfs2_get_block() didn't understand sparse files, fix that. Also remove some code that isn't really useful anymore. We can fix up ocfs2_direct_IO_get_blocks() at the same time. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: remove ocfs2_prepare_write() and ocfs2_commit_write()Mark Fasheh
These are no longer used, and can't handle file systems with sparse file allocation. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: teach ocfs2_file_aio_write() about sparse filesMark Fasheh
Unfortunately, ocfs2 can no longer make use of generic_file_aio_write_nlock() because allocating writes will require zeroing of pages adjacent to the I/O for cluster sizes greater than page size. Implement a custom file write here, which can order page locks for zeroing. This also has the advantage that cluster locks can easily be ordered outside of the page locks. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Turn off shared writeable mmap for local files systems with holes.Mark Fasheh
This will be turned back on once we can do allocation in ->page_mkwrite(). Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: abstract out allocation lockingMark Fasheh
Right now, file allocation for ocfs2 is done within ocfs2_extend_file(), which is either called from ->setattr() (for an i_size change), or at the top of ocfs2_file_aio_write(). Inodes on file systems with sparse file support will want to do their allocation during the actual write call. In either case the cluster locking decisions are the same. We abstract out that code into a new function, ocfs2_lock_allocators() which will be used by a later patch to enable writing to sparse files. This also provides a nice cleanup of ocfs2_extend_allocation(). Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: teach extend/truncate about sparse filesMark Fasheh
For ocfs2_truncate_file(), we eliminate the "simple" truncate case which no longer exists since i_size is not tied to i_clusters. In ocfs2_extend_file(), we skip the allocation / page zeroing code for file systems which understand sparse files. The core truncate code is changed to do a bottom up tree traversal. This gets abstracted out into it's own function. To make things more readable, most of the special case handling for in-inode extents from ocfs2_do_truncate() is also removed. Though write support for sparse files comes in a later patch, we at least update ocfs2_prepare_inode_for_write() to skip allocation for sparse files. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: temporarily remove extent map cachingMark Fasheh
The code in extent_map.c is not prepared to deal with a subtree being rotated between lookups. This can happen when filling holes in sparse files. Instead of a lengthy patch to update the code (which would likely lose the benefit of caching subtree roots), we remove most of the algorithms and implement a simple path based lookup. A less ambitious extent caching scheme will be added in a later patch. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: sparse b-tree supportMark Fasheh
Introduce tree rotations into the b-tree code. This will allow ocfs2 to support sparse files. Much of the added code is designed to be generic (in the ocfs2 sense) so that it can later be re-used to implement large extended attributes. This patch only adds the rotation code and does minimal updates to callers of the extent api. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: small cleanup of ocfs2_request_delete()Mark Fasheh
There are two checks in there (one for inode newness, one for other mounted nodes) which are unnecessary, so remove them. The DLM will allow the trylock in either case without any messaging overhead. Removing these makes ocfs2_request_delete() a one liner function, so just move the trylock out one level into ocfs2_query_inode_wipe(). Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: remove unused codeTiger Yang
Remove node messaging code that becomes unused with the delete inode vote removal. [Removed even more cruft which I spotted during review --Mark] Signed-off-by: Tiger Yang <tiger.yang@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Remove delete inode voteTiger Yang
Ocfs2 currently does cluster-wide node messaging to check the open state of an inode during delete. This patch removes that mechanism in favor of an inode cluster lock which is taken at shared read when an inode is first read and dropped in clear_inode(). This allows a deleting node to test the liveness of an inode by attempting to take an exclusive lock. Signed-off-by: Tiger Yang <tiger.yang@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: filter more error printsMark Fasheh
We don't want to print anything at all in ocfs2_lookup() when getting an error from ocfs2_iget() - it could be something as innocuous as a signal being detected in the dlm. ocfs2_permission() should filter on -ENOENT which ocfs2_meta_lock() can return if the inode was deleted on another node. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Replace panic() with emergency_restart() when fencingSunil Mushran
We have noticed panic() hanging leading us to a situation in which the node, while otherwise dead, is still disk heartbeating. This leads to a hung cluster as the other nodes are waiting for this node to stop disk heartbeating. This situation is only resolved by power resetting the box. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Silence compiler warningsSunil Mushran
2007-04-26ocfs2: Local mounts should skip inode updatesMark Fasheh
We don't want the extent map and uptodate cache destruction in ocfs2_meta_lock_update() on a local mount, so skip that. This fixes several bugs with uptodate being cleared on buffers and extent maps being corrupted. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2_dlm: Call cond_resched_lock() once per hash bucket scanSunil Mushran
In dlm_migrate_all_locks(), we currently call cond_resched_lock() after processing each lockres in a hash bucket. Move it outside the loop so as to call it only after the entire hash bucket has been processed. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2_dlm: fix race in dlm_remaster_locksSrinivas Eeda
There is a possibility that dlm_remaster_locks could overwride node->state with DLM_RECO_NODE_DATA_REQUESTED after dlm_reco_data_done_handler sets the node->state to DLM_RECO_NODE_DATA_DONE. This could lead to recovery getting stuck and requires a cluster reboot. Synchronize with dlm_reco_state_lock spinlock. Signed-off-by: Srinivas Eeda <srinivas.eeda@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-03-26ocfs2_dlm: Check for migrateable lockres in dlm_empty_lockres()Sunil Mushran
In dlm_migrate_lockres(), we check upfront whether the lockres is a candidate for migration. This patch encapsulates that code in a separate function so that dlm_empty_lockres() can also use it during umount. This patch addresses the umount process spinning problem. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-03-26ocfs2_dlm: Fix lockres ref counting bugSunil Mushran
During umount, the umount thread migrates the lockres' and the dlm_thread frees the empty lockres'. Due to a race, the reference counting on the lockres goes awry leading to extra puts. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-03-14ocfs2_dlm: Add missing locks in dlm_empty_lockresSunil Mushran
__dlm_lockres_unused() expects the caller to take the lockres spinlock. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-03-14ocfs2_dlm: Missing get/put lockres in dlm_run_purge_lockresSunil Mushran
In some circumstances, this was causing us to reference freed memory. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-03-14ocfs2: add some missing address space callbacksJoel Becker
Under load, OCFS2 would crash in invalidate_inode_pages2_range() because invalidate_complete_page2() was unable to invalidate a page. It would appear that JBD is holding on to the page. ext3 has a specific ->releasepage() handler to cover this case. Steal ext3's ->releasepage(), ->invalidatepage(), and ->migratepage(), as they appear completely appropriate for OCFS2. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-03-14ocfs2: Concurrent access of o2hb_region->hr_task was not lockedJoel Becker
This means that a build-up and a teardown could race which would result in a double-kthread_stop(). Protect the setting and clearing of hr_task with o2hb_live_lock, as it's not a common thing and not performance critical. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-03-14ocfs2: Proper cleanup in case of error in ocfs2_register_hb_callbacks()Joel Becker
If ocfs2_register_hb_callbacks() succeeds on its first callback but fails its second, it doesn't release the first on the way out. Fix that. While we're at it, o2hb_unregister_callback() never returns anything but 0, so let's make it void. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-02-17Fix typos concerning hierarchyUwe Kleine-König
heirarchical, hierachical -> hierarchical heirarchy, hierachy -> hierarchy Signed-off-by: Uwe Kleine-König <zeisberg@informatik.uni-freiburg.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: register the ocfs2 sysctl numbersEric W. Biederman
ocfs2 was did not have the binary number it uses under CTL_FS registered in sysctl.h. Register it to avoid future conflicts, and change the name of the definition to be in line with the rest of the sysctl numbers. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
