path: root/fs/ocfs2/file.c
2015-06-25Merge branch 'for-4.2/writeback' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull cgroup writeback support from Jens Axboe: "This is the big pull request for adding cgroup writeback support. This code has been in development for a long time, and it has been simmering in for-next for a good chunk of this cycle too. This is one of those problems that has been talked about for at least half a decade, finally there's a solution and code to go with it. Also see last weeks writeup on LWN: http://lwn.net/Articles/648292/" * 'for-4.2/writeback' of git://git.kernel.dk/linux-block: (85 commits) writeback, blkio: add documentation for cgroup writeback support vfs, writeback: replace FS_CGROUP_WRITEBACK with SB_I_CGROUPWB writeback: do foreign inode detection iff cgroup writeback is enabled v9fs: fix error handling in v9fs_session_init() bdi: fix wrong error return value in cgwb_create() buffer: remove unusued 'ret' variable writeback: disassociate inodes from dying bdi_writebacks writeback: implement foreign cgroup inode bdi_writeback switching writeback: add lockdep annotation to inode_to_wb() writeback: use unlocked_inode_to_wb transaction in inode_congested() writeback: implement unlocked_inode_to_wb transaction and use it for stat updates writeback: implement [locked_]inode_to_wb_and_lock_list() writeback: implement foreign cgroup inode detection writeback: make writeback_control track the inode being written back writeback: relocate wb[_try]_get(), wb_put(), inode_{attach|detach}_wb() mm: vmscan: disable memcg direct reclaim stalling if cgroup writeback support is in use writeback: implement memcg writeback domain based throttling writeback: reset wb_domain->dirty_limit[_tstmp] when memcg domain size changes writeback: implement memcg wb_domain writeback: update wb_over_bg_thresh() to use wb_domain aware operations ...
2015-06-24ocfs2: remove OCFS2_IOCB_SEM lock type in direct ioWeiWei Wang
In ocfs2 direct read/write, OCFS2_IOCB_SEM lock type is used to protect inode->i_alloc_sem rw semaphore lock in the earlier kernel version. However, in the latest kernel, inode->i_alloc_sem rw semaphore lock is not used at all, so OCFS2_IOCB_SEM lock type needs to be removed. Signed-off-by: Weiwei Wang <wangww631@huawei.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Reviewed-by: Junxiao Bi <junxiao.bi@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-02writeback: separate out include/linux/backing-dev-defs.hTejun Heo
With the planned cgroup writeback support, backing-dev related declarations will be more widely used across block and cgroup; unfortunately, including backing-dev.h from include/linux/blkdev.h makes cyclic include dependency quite likely. This patch separates out backing-dev-defs.h which only has the essential definitions and updates blkdev.h to include it. c files which need access to more backing-dev details now include backing-dev.h directly. This takes backing-dev.h off the common include dependency chain making it a lot easier to use it across block and cgroup. v2: fs/fat build failure fixed. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11ocfs2: use __generic_file_write_iter()Al Viro
we can do that now - all we need is to clear IOCB_DIRECT from ->ki_flags in "can't do dio" case. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11mirror O_APPEND and O_DIRECT into iocb->ki_flagsAl Viro
... avoiding write_iter/fcntl races. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11switch generic_write_checks() to iocb and iterAl Viro
... returning -E... upon error and amount of data left in iter after (possible) truncation upon success. Note, that normal case gives a non-zero (positive) return value, so any tests for != 0 _must_ be updated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Conflicts: fs/ext4/file.c
2015-04-11ocfs2: move generic_write_checks() before the alignment checksAl Viro
Alignment checks for dio depend upon the range truncation done by generic_write_checks(). They can be done as soon as we got ocfs2_rw_lock() and that actually makes ocfs2_prepare_inode_for_write() simpler. The only thing to watch out for is restoring the original count in "unlock and redo without dio" case. Position doesn't need to be restored, since we change it only in O_APPEND case and in that case it will be reassigned anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11ocfs2_file_write_iter: stop messing with pposAl Viro
it's &iocb->ki_pos; no need to obfuscate. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11Merge branch 'for-linus' into for-nextAl Viro
2015-04-11generic_write_checks(): drop isblk argumentAl Viro
all remaining callers are passing 0; some just obscure that fact. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11make new_sync_{read,write}() staticAl Viro
All places outside of core VFS that checked ->read and ->write for being NULL or called the methods directly are gone now, so NULL {read,write} with non-NULL {read,write}_iter will do the right thing in all cases. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-09ocfs2: _really_ sync the right rangeAl Viro
"ocfs2 syncs the wrong range" had been broken; prior to it the code was doing the wrong thing in case of O_APPEND, all right, but _after_ it we were syncing the wrong range in 100% cases. *ppos, aka iocb->ki_pos is incremented prior to that point, so we are always doing sync on the area _after_ the one we'd written to. Spotted by Joseph Qi <joseph.qi@huawei.com> back in January; unfortunately, I'd missed his mail back then ;-/ Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-08ocfs2_file_write_iter: keep return value and current position update in syncAl Viro
2015-04-08[regression] ocfs2: do *not* increment ->ki_pos twiceAl Viro
generic_file_direct_write() already does that. Broken by "ocfs2: do not fallback to buffer I/O write if appending" Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-03-12fs: remove ki_nbytesChristoph Hellwig
There is no need to pass the total request length in the kiocb, as we already get passed in through the iov_iter argument. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-16ocfs2: set append dio as a ro compat featureJoseph Qi
Intruduce a bit OCFS2_FEATURE_RO_COMPAT_APPEND_DIO and check it in write flow. If the bit is not set, fall back to the old way. Signed-off-by: Joseph Qi <joseph.qi@huawei.com> Cc: Weiwei Wang <wangww631@huawei.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Junxiao Bi <junxiao.bi@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Xuejiufei <xuejiufei@huawei.com> Cc: alex chen <alex.chen@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-16ocfs2: complete the rest request through buffer ioJoseph Qi
Complte the rest request thourgh buffer io after direct write performed. Signed-off-by: Joseph Qi <joseph.qi@huawei.com> Cc: Weiwei Wang <wangww631@huawei.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Junxiao Bi <junxiao.bi@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Xuejiufei <xuejiufei@huawei.com> Cc: alex chen <alex.chen@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-16ocfs2: do not fallback to buffer I/O write if appendingJoseph Qi
Now we can do direct io and do not fallback to buffered IO any more in case of append O_DIRECT write. Signed-off-by: Joseph Qi <joseph.qi@huawei.com> Cc: Weiwei Wang <wangww631@huawei.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Junxiao Bi <junxiao.bi@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Xuejiufei <xuejiufei@huawei.com> Cc: alex chen <alex.chen@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-16ocfs2: prepare some interfaces used in append direct ioJoseph Qi
Currently in case of append O_DIRECT write (block not allocated yet), ocfs2 will fall back to buffered I/O. This has some disadvantages. Firstly, it is not the behavior as expected. Secondly, it will consume huge page cache, e.g. in mass backup scenario. Thirdly, modern filesystems such as ext4 support this feature. In this patch set, the direct I/O write doesn't fallback to buffer I/O write any more because the allocate blocks are enabled in direct I/O now. This patch (of 9): Prepare some interfaces which will be used in append O_DIRECT write. Signed-off-by: Joseph Qi <joseph.qi@huawei.com> Cc: Weiwei Wang <wangww631@huawei.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Xuejiufei <xuejiufei@huawei.com> Cc: Junxiao Bi <junxiao.bi@oracle.com> Cc: alex chen <alex.chen@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12Merge branch 'for-3.20/bdi' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull backing device changes from Jens Axboe: "This contains a cleanup of how the backing device is handled, in preparation for a rework of the life time rules. In this part, the most important change is to split the unrelated nommu mmap flags from it, but also removing a backing_dev_info pointer from the address_space (and inode), and a cleanup of other various minor bits. Christoph did all the work here, I just fixed an oops with pages that have a swap backing. Arnd fixed a missing export, and Oleg killed the lustre backing_dev_info from staging. Last patch was from Al, unexporting parts that are now no longer needed outside" * 'for-3.20/bdi' of git://git.kernel.dk/linux-block: Make super_blocks and sb_lock static mtd: export new mtd_mmap_capabilities fs: make inode_to_bdi() handle NULL inode staging/lustre/llite: get rid of backing_dev_info fs: remove default_backing_dev_info fs: don't reassign dirty inodes to default_backing_dev_info nfs: don't call bdi_unregister ceph: remove call to bdi_unregister fs: remove mapping->backing_dev_info fs: export inode_to_bdi and use it in favor of mapping->backing_dev_info nilfs2: set up s_bdi like the generic mount_bdev code block_dev: get bdev inode bdi directly from the block device block_dev: only write bdev inode on close fs: introduce f_op->mmap_capabilities for nommu mmap support fs: kill BDI_CAP_SWAP_BACKED fs: deduplicate noop_backing_dev_info
2015-02-10ocfs2: fix uninitialized variable accessJunxiao Bi
Variable "why" is not yet initialized at line 615, fix it. Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-20fs: export inode_to_bdi and use it in favor of mapping->backing_dev_infoChristoph Hellwig
Now that we got rid of the bdi abuse on character devices we can always use sb->s_bdi to get at the backing_dev_info for a file, except for the block device special case. Export inode_to_bdi and replace uses of mapping->backing_dev_info with it to prepare for the removal of mapping->backing_dev_info. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-12-18ocfs2: reflink: fix slow unlink for refcounted fileJunxiao Bi
When running ocfs2 test suite multiple nodes reflink stress test, for a 4 nodes cluster, every unlink() for refcounted file needs about 700s. The slow unlink is caused by the contention of refcount tree lock since all nodes are unlink files using the same refcount tree. When the unlinking file have many extents(over 1600 in our test), most of the extents has refcounted flag set. In ocfs2_commit_truncate(), it will execute the following call trace for every extents. This means it needs get and released refcount tree lock about 1600 times. And when several nodes are do this at the same time, the performance will be very low. ocfs2_remove_btree_range() -- ocfs2_lock_refcount_tree() ---- ocfs2_refcount_lock() ------ __ocfs2_cluster_lock() ocfs2_refcount_lock() is costly, move it to ocfs2_commit_truncate() to do lock/unlock once can improve a lot performance. Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Cc: Wengang <wen.gang.wang@oracle.com> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-10ocfs2: remove filesize checks for sync I/O journal commitGoldwyn Rodrigues
Filesize is not a good indication that the file needs to be synced. An example where this breaks is: 1. Open the file in O_SYNC|O_RDWR 2. Read a small portion of the file (say 64 bytes) 3. Lseek to starting of the file 4. Write 64 bytes If the node crashes, it is not written out to disk because this was not committed in the journal and the other node which reads the file after recovery reads stale data (even if the write on the other node was successful) Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.de> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-11Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull UDF and quota updates from Jan Kara: "A few UDF fixes and also a few patches which are preparing filesystems for support of project quotas in VFS" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: udf: Fix loading of special inodes ocfs2: Back out change to use OCFS2_MAXQUOTAS in ocfs2_setattr() udf: remove redundant sys_tz declaration ocfs2: Don't use MAXQUOTAS value reiserfs: Don't use MAXQUOTAS value ext3: Don't use MAXQUOTAS value udf: Fix race between write(2) and close(2)
2014-10-09ocfs2: fix deadlock due to wrong locking orderJunxiao Bi
For commit ocfs2 journal, ocfs2 journal thread will acquire the mutex osb->journal->j_trans_barrier and wake up jbd2 commit thread, then it will wait until jbd2 commit thread done. In order journal mode, jbd2 needs flushing dirty data pages first, and this needs get page lock. So osb->journal->j_trans_barrier should be got before page lock. But ocfs2_write_zero_page() and ocfs2_write_begin_inline() obey this locking order, and this will cause deadlock and hung the whole cluster. One deadlock catched is the following: PID: 13449 TASK: ffff8802e2f08180 CPU: 31 COMMAND: "oracle" #0 [ffff8802ee3f79b0] __schedule at ffffffff8150a524 #1 [ffff8802ee3f7a58] schedule at ffffffff8150acbf #2 [ffff8802ee3f7a68] rwsem_down_failed_common at ffffffff8150cb85 #3 [ffff8802ee3f7ad8] rwsem_down_read_failed at ffffffff8150cc55 #4 [ffff8802ee3f7ae8] call_rwsem_down_read_failed at ffffffff812617a4 #5 [ffff8802ee3f7b50] ocfs2_start_trans at ffffffffa0498919 [ocfs2] #6 [ffff8802ee3f7ba0] ocfs2_zero_start_ordered_transaction at ffffffffa048b2b8 [ocfs2] #7 [ffff8802ee3f7bf0] ocfs2_write_zero_page at ffffffffa048e9bd [ocfs2] #8 [ffff8802ee3f7c80] ocfs2_zero_extend_range at ffffffffa048ec83 [ocfs2] #9 [ffff8802ee3f7ce0] ocfs2_zero_extend at ffffffffa048edfd [ocfs2] #10 [ffff8802ee3f7d50] ocfs2_extend_file at ffffffffa049079e [ocfs2] #11 [ffff8802ee3f7da0] ocfs2_setattr at ffffffffa04910ed [ocfs2] #12 [ffff8802ee3f7e70] notify_change at ffffffff81187d29 #13 [ffff8802ee3f7ee0] do_truncate at ffffffff8116bbc1 #14 [ffff8802ee3f7f50] sys_ftruncate at ffffffff8116bcbd #15 [ffff8802ee3f7f80] system_call_fastpath at ffffffff81515142 RIP: 00007f8de750c6f7 RSP: 00007fffe786e478 RFLAGS: 00000206 RAX: 000000000000004d RBX: ffffffff81515142 RCX: 0000000000000000 RDX: 0000000000000200 RSI: 0000000000028400 RDI: 000000000000000d RBP: 00007fffe786e040 R8: 0000000000000000 R9: 000000000000000d R10: 0000000000000000 R11: 0000000000000206 R12: 000000000000000d R13: 00007fffe786e710 R14: 00007f8de70f8340 R15: 0000000000028400 ORIG_RAX: 000000000000004d CS: 0033 SS: 002b crash64> bt PID: 7610 TASK: ffff88100fd56140 CPU: 1 COMMAND: "ocfs2cmt" #0 [ffff88100f4d1c50] __schedule at ffffffff8150a524 #1 [ffff88100f4d1cf8] schedule at ffffffff8150acbf #2 [ffff88100f4d1d08] jbd2_log_wait_commit at ffffffffa01274fd [jbd2] #3 [ffff88100f4d1d98] jbd2_journal_flush at ffffffffa01280b4 [jbd2] #4 [ffff88100f4d1dd8] ocfs2_commit_cache at ffffffffa0499b14 [ocfs2] #5 [ffff88100f4d1e38] ocfs2_commit_thread at ffffffffa0499d38 [ocfs2] #6 [ffff88100f4d1ee8] kthread at ffffffff81090db6 #7 [ffff88100f4d1f48] kernel_thread_helper at ffffffff81516284 crash64> bt PID: 7609 TASK: ffff88100f2d4480 CPU: 0 COMMAND: "jbd2/dm-20-86" #0 [ffff88100def3920] __schedule at ffffffff8150a524 #1 [ffff88100def39c8] schedule at ffffffff8150acbf #2 [ffff88100def39d8] io_schedule at ffffffff8150ad6c #3 [ffff88100def39f8] sleep_on_page at ffffffff8111069e #4 [ffff88100def3a08] __wait_on_bit_lock at ffffffff8150b30a #5 [ffff88100def3a58] __lock_page at ffffffff81110687 #6 [ffff88100def3ab8] write_cache_pages at ffffffff8111b752 #7 [ffff88100def3be8] generic_writepages at ffffffff8111b901 #8 [ffff88100def3c48] journal_submit_data_buffers at ffffffffa0120f67 [jbd2] #9 [ffff88100def3cf8] jbd2_journal_commit_transaction at ffffffffa0121372[jbd2] #10 [ffff88100def3e68] kjournald2 at ffffffffa0127a86 [jbd2] #11 [ffff88100def3ee8] kthread at ffffffff81090db6 #12 [ffff88100def3f48] kernel_thread_helper at ffffffff81516284 Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Alex Chen <alex.chen@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-30ocfs2: Back out change to use OCFS2_MAXQUOTAS in ocfs2_setattr()Jan Kara
ocfs2_setattr() actually needs to really use MAXQUOTAS and not OCFS2_MAXQUOTAS since it will pass the array over to VFS. Currently this isn't a problem since MAXQUOTAS == OCFS2_MAXQUOTAS but it would be once we introduce project quotas. CC: Mark Fasheh <mfasheh@suse.com> CC: Joel Becker <jlbec@evilplan.org> CC: ocfs2-devel@oss.oracle.com Signed-off-by: Jan Kara <jack@suse.cz>
2014-09-17ocfs2: Don't use MAXQUOTAS valueJan Kara
MAXQUOTAS value defines maximum number of quota types VFS supports. This isn't necessarily the number of types ocfs2 supports and with addition of project quotas these two numbers stop matching. So make ocfs2 use its private definition. CC: Mark Fasheh <mfasheh@suse.com> CC: Joel Becker <jlbec@evilplan.org> CC: ocfs2-devel@oss.oracle.com Signed-off-by: Jan Kara <jack@suse.cz>
2014-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "This the bunch that sat in -next + lock_parent() fix. This is the minimal set; there's more pending stuff. In particular, I really hope to get acct.c fixes merged this cycle - we need that to deal sanely with delayed-mntput stuff. In the next pile, hopefully - that series is fairly short and localized (kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more iov_iter work. Most of prereqs for ->splice_write with sane locking order are there and Kent's dio rewrite would also fit nicely on top of this pile" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits) lock_parent: don't step on stale ->d_parent of all-but-freed one kill generic_file_splice_write() ceph: switch to iter_file_splice_write() shmem: switch to iter_file_splice_write() nfs: switch to iter_splice_write_file() fs/splice.c: remove unneeded exports ocfs2: switch to iter_file_splice_write() ->splice_write() via ->write_iter() bio_vec-backed iov_iter optimize copy_page_{to,from}_iter() bury generic_file_aio_{read,write} lustre: get rid of messing with iovecs ceph: switch to ->write_iter() ceph_sync_direct_write: stop poking into iov_iter guts ceph_sync_read: stop poking into iov_iter guts new helper: copy_page_from_iter() fuse: switch to ->write_iter() btrfs: switch to ->write_iter() ocfs2: switch to ->write_iter() xfs: switch to ->write_iter() ...
2014-06-12ocfs2: switch to iter_file_splice_write()Al Viro
2014-06-04fs/buffer.c: remove block_write_full_page_endio()Matthew Wilcox
The last in-tree caller of block_write_full_page_endio() was removed in January 2013. It's time to remove the EXPORT_SYMBOL, which leaves block_write_full_page() as the only caller of block_write_full_page_endio(), so inline block_write_full_page_endio() into block_write_full_page(). Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Dheeraj Reddy <dheeraj.reddy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-06ocfs2: switch to ->write_iter()Al Viro
2014-05-06ocfs2: switch to ->read_iter()Al Viro
tracepoints are evil, exhibit #6969... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06iov_iter_truncate()Al Viro
Now It Can Be Done(tm) - we don't need to do iov_shorten() in generic_file_direct_write() anymore, now that all ->direct_IO() instances are converted to proper iov_iter methods and honour iter->count and iter->iov_offset properly. Get rid of count/ocount arguments of generic_file_direct_write(), while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06start adding the tag to iov_iterAl Viro
For now, just use the same thing we pass to ->direct_IO() - it's all iovec-based at the moment. Pass it explicitly to iov_iter_init() and account for kvec vs. iovec in there, by the same kludge NFS ->direct_IO() uses. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06kill generic_segment_checks()Al Viro
all callers of ->aio_read() and ->aio_write() have iov/nr_segs already checked - generic_segment_checks() done after that is just an odd way to spell iov_length(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06generic_file_direct_write(): switch to iov_iterAl Viro
2014-04-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "The first vfs pile, with deep apologies for being very late in this window. Assorted cleanups and fixes, plus a large preparatory part of iov_iter work. There's a lot more of that, but it'll probably go into the next merge window - it *does* shape up nicely, removes a lot of boilerplate, gets rid of locking inconsistencie between aio_write and splice_write and I hope to get Kent's direct-io rewrite merged into the same queue, but some of the stuff after this point is having (mostly trivial) conflicts with the things already merged into mainline and with some I want more testing. This one passes LTP and xfstests without regressions, in addition to usual beating. BTW, readahead02 in ltp syscalls testsuite has started giving failures since "mm/readahead.c: fix readahead failure for memoryless NUMA nodes and limit readahead pages" - might be a false positive, might be a real regression..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) missing bits of "splice: fix racy pipe->buffers uses" cifs: fix the race in cifs_writev() ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure kill generic_file_buffered_write() ocfs2_file_aio_write(): switch to generic_perform_write() ceph_aio_write(): switch to generic_perform_write() xfs_file_buffered_aio_write(): switch to generic_perform_write() export generic_perform_write(), start getting rid of generic_file_buffer_write() generic_file_direct_write(): get rid of ppos argument btrfs_file_aio_write(): get rid of ppos kill the 5th argument of generic_file_buffered_write() kill the 4th argument of __generic_file_aio_write() lustre: don't open-code kernel_recvmsg() ocfs2: don't open-code kernel_recvmsg() drbd: don't open-code kernel_recvmsg() constify blk_rq_map_user_iov() and friends lustre: switch to kernel_sendmsg() ocfs2: don't open-code kernel_sendmsg() take iov_iter stuff to mm/iov_iter.c process_vm_access: tidy up a bit ...
2014-04-03ocfs2: call ocfs2_update_inode_fsync_trans when updating any inodeDarrick J. Wong
Ensure that ocfs2_update_inode_fsync_trans() is called any time we touch an inode in a given transaction. This is a follow-on to the previous patch to reduce lock contention and deadlocking during an fsync operation. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Cc: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Cc: Wengang <wen.gang.wang@oracle.com> Cc: Greg Marsden <greg.marsden@oracle.com> Cc: Srinivas Eeda <srinivas.eeda@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03ocfs2: llseek requires ocfs2 inode lock for the file in SEEK_ENDJensen
llseek requires ocfs2 inode lock for updating the file size in SEEK_END. because the file size maybe update on another node. This bug can be reproduce the following scenario: at first, we dd a test fileA, the file size is 10k. on NodeA: --------- 1) open the test fileA, lseek the end of file. and print the position. 2) close the test fileA on NodeB: 1) open the test fileA, append the 5k data to test FileA. 2) lseek the end of file. and print the position. 3) close file. At first we run the test program1 on NodeA , the result is 10k. And then run the test program2 on NodeB, the result is 15k. At last, we run the test program1 on NodeA again, the result is 10k. After applying this patch the three step result is 15k. test result: 1000000 times lseek call; index lseek with inode lock (unit:us) lseek without inode lock (unit:us) 1 1168162 555383 2 1168011 549504 3 1170538 549396 4 1170375 551685 5 1170444 556719 6 1174364 555307 7 1163294 551552 8 1170080 549350 9 1162464 553700 10 1165441 552594 avg 1168317 552519 avg with lock - avg without lock = 615798 (avg with lock - avg without lock)/1000000=0.615798 us Signed-off-by: Jensen <shencanquan@huawei.com> Cc: Jie Liu <jeff.liu@oracle.com> Acked-by: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Sunil Mushran <sunil.mushran@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03ocfs2: improve fsync efficiency and fix deadlock between aio_write and sync_fileDarrick J. Wong
Currently, ocfs2_sync_file grabs i_mutex and forces the current journal transaction to complete. This isn't terribly efficient, since sync_file really only needs to wait for the last transaction involving that inode to complete, and this doesn't require i_mutex. Therefore, implement the necessary bits to track the newest tid associated with an inode, and teach sync_file to wait for that instead of waiting for everything in the journal to commit. Furthermore, only issue the flush request to the drive if jbd2 hasn't already done so. This also eliminates the deadlock between ocfs2_file_aio_write() and ocfs2_sync_file(). aio_write takes i_mutex then calls ocfs2_aiodio_wait() to wait for unaligned dio writes to finish. However, if that dio completion involves calling fsync, then we can get into trouble when some ocfs2_sync_file tries to take i_mutex. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03ocfs2: change ip_unaligned_aio to of type mutex from atomit_tWengang Wang
There is a problem that waitqueue_active() may check stale data thus miss a wakeup of threads waiting on ip_unaligned_aio. The valid value of ip_unaligned_aio is only 0 and 1 so we can change it to be of type mutex thus the above prolem is avoid. Another benifit is that mutex which works as FIFO is fairer than wake_up_all(). Signed-off-by: Wengang Wang <wen.gang.wang@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-01ocfs2_file_aio_write(): switch to generic_perform_write()Al Viro
2014-04-01generic_file_direct_write(): get rid of ppos argumentAl Viro
always equal to &iocb->ki_pos. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01kill the 5th argument of generic_file_buffered_write()Al Viro
same story - it's &iocb->ki_pos in all cases Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-10ocfs2 syncs the wrong range...Al Viro
2014-02-10ocfs2: update inode size after zeroing the holeJunxiao Bi
fs-writeback will release the dirty pages without page lock whose offset are over inode size, the release happens at block_write_full_page_endio(). If not update, dirty pages in file holes may be released before flushed to the disk, then file holes will contain some non-zero data, this will cause sparse file md5sum error. To reproduce the bug, find a big sparse file with many holes, like vm image file, its actual size should be bigger than available mem size to make writeback work more frequently, tar it with -S option, then keep untar it and check its md5sum again and again until you get a wrong md5sum. Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Cc: Younger Liu <younger.liu@huawei.com> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-10ocfs2: fix issue that ocfs2_setattr() does not deal with new_i_size==i_sizeYounger Liu
The issue scenario is as following: - Create a small file and fallocate a large disk space for a file with FALLOC_FL_KEEP_SIZE option. - ftruncate the file back to the original size again. but the disk free space is not changed back. This is a real bug that be fixed in this patch. In order to solve the issue above, we modified ocfs2_setattr(), if attr->ia_size != i_size_read(inode), It calls ocfs2_truncate_file(), and truncate disk space to attr->ia_size. Signed-off-by: Younger Liu <younger.liu@huawei.com> Reviewed-by: Jie Liu <jeff.liu@oracle.com> Tested-by: Jie Liu <jeff.liu@oracle.com> Cc: Joel Becker <jlbec@evilplan.org> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Cc: Sunil Mushran <sunil.mushran@gmail.com> Reviewed-by: Jensen <shencanquan@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-10ocfs2: fix ocfs2_sync_file() if filesystem is readonlyYounger Liu
If filesystem is readonly, there is no need to flush drive's caches or force any uncommitted transactions. [akpm@linux-foundation.org: return -EROFS, not 0] Signed-off-by: Younger Liu <younger.liucn@gmail.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
