file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Patch removes trailing whitespaces.
Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com>
Signed-off-by: Joel Becker <joel.becker@oracle.com>
* remove asm/atomic.h inclusion from linux/utsname.h --
not needed after kref conversion
* remove linux/utsname.h inclusion from files which do not need it
NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however
due to some personality stuff it _is_ needed -- cowardly leave ELF-related
headers and files alone.
We BUG_ON() the same thing twice.
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.de>
Patch cleans printed errors in dlm_proxy_ast_handler(). The errors now includes
the node number that sent the (b)ast. Also it reduces the number of endian swaps
of the cookie.
Signed-off-by: Mark Fasheh <mfasheh@suse.com>
This patchset moves le*_add_cpu and be*_add_cpu functions from OCFS2 to core
header (1st), converts ext3 filesystem to this API (2nd) and replaces XFS
different named functions with new ones (3rd).
There are many places where these functions will be useful. Just look at:
grep -r 'cpu_to_[ble12346]*([ble12346]*_to_cpu.*[-+]' linux-src/ Patch for
ext3 is an example how conversions will probably look like.
This patch:
- move inline functions which add native byte order variable to
little/big endian variable to core header
* le16_add_cpu(__le16 *var, u16 val)
* le32_add_cpu(__le32 *var, u32 val)
* le64_add_cpu(__le64 *var, u64 val)
* be32_add_cpu(__be32 *var, u32 val)
- add for completeness:
* be16_add_cpu(__be16 *var, u16 val)
* be64_add_cpu(__be64 *var, u64 val)
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Acked-by: Mark Fasheh <mark.fasheh@oracle.com>
Cc: David Chinner <dgc@sgi.com>
Cc: Timothy Shimmin <tes@sgi.com>
Cc: <linux-ext4@vger.kernel.org>
Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
Currently o2net allows one handler function per message type. This
patch adds the ability to call another function to be called after
the handler has returned the message to the other node.
Handlers are now given the option of returning a context (in the form of a
void **) which will be passed back into the post message handler function.
Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
The dlm encodes the node number and a sequence number in the lock cookie.
It also stores the cookie in the lockres in the big endian format to avoid
swapping 8 bytes on each lock request. The bug here was that it was assuming
the cookie to be in the cpu format when decoding it for printing the error
message. This patch swaps the bytes before the print.
An AST can be delivered via the network after a lock has been removed, so no
need to print an error when we see that.
Don't wait until the AST will be fired to do the LVB copy into the lock
resource.
This patch converts the combination of list_del(A) and list_add(A, B) to
list_move(A, B) under fs/.
Cc: Ian Kent <raven@themaw.net>
Acked-by: Joel Becker <joel.becker@oracle.com>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Hans Reiser <reiserfs-dev@namesys.com>
Cc: Urban Widmark <urban@teststation.com>
Signed-off-by: Akinobu Mita <mita@miraclelinux.com>
A distributed lock manager built with the cluster file system use case
in mind. The OCFS2 dlm exposes a VMS style API, though things have
been simplified internally. The only lock levels implemented currently
are NLMODE, PRMODE and EXMODE.
