path: root/fs/ocfs2/cluster/tcp.c
2008-02-26Update the i.MX31 Kernel to 2.6.232.6.23-mx31ads-2008022618072.6.23-mx31-200802261807Justin Waters
This is the result of a brute-force attempt to update the kernel to 2.6.23. Now that we have a git tree, our effort will be a little nicer in the future. Signed-off-by: Justin Waters <justin.waters@timesys.com>
2007-05-02ocfs2: fix sparse warnings in fs/ocfs2/clusterMark Fasheh
Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-03-14ocfs2: Proper cleanup in case of error in ocfs2_register_hb_callbacks()Joel Becker
If ocfs2_register_hb_callbacks() succeeds on its first callback but fails its second, it doesn't release the first on the way out. Fix that. While we're at it, o2hb_unregister_callback() never returns anything but 0, so let's make it void. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-02-07ocfs2: introduce sc->sc_send_lock to protect outbound outbound messagesZhen Wei
When there is a lot of multithreaded I/O usage, two threads can collide while sending out a message to the other nodes. This is due to the lack of locking between threads while sending out the messages. When a connected TCP send(), sendto(), or sendmsg() arrives in the Linux kernel, it eventually comes through tcp_sendmsg(). tcp_sendmsg() protects itself by acquiring a lock at invocation by calling lock_sock(). tcp_sendmsg() then loops over the buffers in the iovec, allocating associated sk_buff's and cache pages for use in the actual send. As it does so, it pushes the data out to tcp for actual transmission. However, if one of those allocation fails (because a large number of large sends is being processed, for example), it must wait for memory to become available. It does so by jumping to wait_for_sndbuf or wait_for_memory, both of which eventually cause a call to sk_stream_wait_memory(). sk_stream_wait_memory() contains a code path that calls sk_wait_event(). Finally, sk_wait_event() contains the call to release_sock(). The following patch adds a lock to the socket container in order to properly serialize outbound requests. From: Zhen Wei <zwei@novell.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-02-07ocfs2: Binds listener to the configured ip addressSunil Mushran
This patch binds the o2net listener to the configured ip address instead of INADDR_ANY for security. Fixes oss.oracle.com bugzilla#814. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-02-07ocfs2: Added post handler callable function in o2net message handlerKurt Hackel
Currently o2net allows one handler function per message type. This patch adds the ability to call another function to be called after the handler has returned the message to the other node. Handlers are now given the option of returning a context (in the form of a void **) which will be passed back into the post message handler function. Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com> Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-13[PATCH] Fix numerous kcalloc() calls, convert to kzalloc()Robert P. J. Day
All kcalloc() calls of the form "kcalloc(1,...)" are converted to the equivalent kzalloc() calls, and a few kcalloc() calls with the incorrect ordering of the first two arguments are fixed. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-11[patch 3/3] OCFS2 Configurable timeouts - Protocol changesAndrew Beekhof
Modify the OCFS2 handshake to ensure essential timeouts are configured identically on all nodes. Only allow changes when there are no connected peers Improves the logic in o2net_advance_rx() which broke now that sizeof(struct o2net_handshake) is greater than sizeof(struct o2net_msg) Included is the field for userspace-heartbeat timeout to avoid the need for further protocol changes. Uses a global spinlock to ensure the decisions to update configfs entries are made on the correct value. The region covered by the spinlock when incrementing the counter is much larger as this is the more critical case. Small cleanup contributed by Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Beekhof <abeekhof@suse.de> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-07[patch 2/3] OCFS2 Configurable timeoutsJeff Mahoney
Allow configuration of OCFS2 timeouts from userspace via configfs Signed-off-by: Andrew Beekhof <abeekhof@suse.de> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-06-29ocfs2: Cleanup message printsSunil Mushran
2006-06-27[PATCH] spin/rwlock init cleanupsIngo Molnar
locking init cleanups: - convert " = SPIN_LOCK_UNLOCKED" to spin_lock_init() or DEFINE_SPINLOCK() - convert rwlocks in a similar manner this patch was generated automatically. Motivation: - cleanliness - lockdep needs control of lock initialization, which the open-coded variants do not give - it's also useful for -rt and for lock debugging in general Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-01[PATCH] ocfs2: added source addr to bind() in o2net_start_connect()Sunil Mushran
to prevent confusion when a virtual ip is created on the same interface Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-02-03[PATCH] ocfs2: fix compile warningsMark Fasheh
Fix a couple of compile warnings found when compiling on a ppc64 build box. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-01-03[PATCH] OCFS2: The Second Oracle Cluster FilesystemZach Brown
Node messaging via tcp. Used by the dlm and the file system for point to point communication between nodes. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
