path: root/fs/ocfs2/alloc.c
2009-04-03ocfs2: Add a name indexed b-tree to directory inodesMark Fasheh
This patch makes use of Ocfs2's flexible btree code to add an additional tree to directory inodes. The new tree stores an array of small, fixed-length records in each leaf block. Each record stores a hash value, and pointer to a block in the traditional (unindexed) directory tree where a dirent with the given name hash resides. Lookup exclusively uses this tree to find dirents, thus providing us with constant time name lookups. Some of the hashing code was copied from ext3. Unfortunately, it has lots of unfixed checkpatch errors. I left that as-is so that tracking changes would be easier. Signed-off-by: Mark Fasheh <mfasheh@suse.com> Acked-by: Joel Becker <joel.becker@oracle.com>
2009-03-12ocfs2: Fix a bug found by sparse check.Tao Ma
We need to use le32_to_cpu to test rec->e_cpos in ocfs2_dinode_insert_check. Signed-off-by: Tao Ma <tao.ma@oracle.com> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-02-26ocfs2: Access and dirty the buffer_head in mark_written.Tao Ma
In __ocfs2_mark_extent_written, when we meet with the situation of c_split_covers_rec, the old solution just replace the extent record and forget to access and dirty the buffer_head. This will cause a problem when the unwritten extent is in an extent block. So access and dirty it. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-02-02ocfs2: add quota call to ocfs2_remove_btree_range()Mark Fasheh
We weren't reclaiming the clusters which get free'd from this function, so any user punching holes in a file would still have those bytes accounted against him/her. Add the call to vfs_dq_free_space_nodirty() to fix this. Interestingly enough, the journal credits calculation already took this into account. Signed-off-by: Mark Fasheh <mfasheh@suse.com> Acked-by: Jan Kara <jack@suse.cz>
2009-01-08remove lots of double-semicolonsFernando Carrijo
Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Theodore Ts'o <tytso@mit.edu> Acked-by: Mark Fasheh <mfasheh@suse.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: James Morris <jmorris@namei.org> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05ocfs2: Access the right buffer_head in ocfs2_merge_rec_left.Tao Ma
In commit "ocfs2: Use metadata-specific ocfs2_journal_access_*() functions", the wrong buffer_head is accessed. So change it to the right buffer_head. Signed-off-by: Tao Ma <tao.ma@oracle.com> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Create ocfs2_xattr_value_buf.Joel Becker
When an ocfs2 extended attribute is large enough to require its own allocation tree, we root it with an ocfs2_xattr_value_root. However, these roots can be a part of inodes, xattr blocks, or xattr buckets. Thus, they need a different journal access function for each container. We wrap the bh, its journal access function, and the value root (xv) in a structure called ocfs2_xattr_valu_buf. This is a package that can be passed around. In this first pass, we simply pass it to the extent tree code. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Use metadata-specific ocfs2_journal_access_*() functions.Joel Becker
The per-metadata-type ocfs2_journal_access_*() functions hook up jbd2 commit triggers and allow us to compute metadata ecc right before the buffers are written out. This commit provides ecc for inodes, extent blocks, group descriptors, and quota blocks. It is not safe to use extened attributes and metaecc at the same time yet. The ocfs2_extent_tree and ocfs2_path abstractions in alloc.c both hide the type of block at their root. Before, it didn't matter, but now the root block must use the appropriate ocfs2_journal_access_*() function. To keep this abstract, the structures now have a pointer to the matching journal_access function and a wrapper call to call it. A few places use naked ocfs2_write_block() calls instead of adding the blocks to the journal. We make sure to calculate their checksum and ecc before the write. Since we pass around the journal_access functions. Let's typedef them in ocfs2.h. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Wrap up the common use cases of ocfs2_new_path().Joel Becker
The majority of ocfs2_new_path() calls are: ocfs2_new_path(path_root_bh(otherpath), path_root_el(otherpath)); Let's call that ocfs2_new_path_from_path(). The rest do similar things from struct ocfs2_extent_tree. Let's call those ocfs2_new_path_from_et(). This will make the next change easier. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: block read meta ecc.Joel Becker
Add block check calls to the read_block validate functions. This is the almost all of the read-side checking of metaecc. xattr buckets are not checked yet. Writes are also unchecked, and so a read-write mount will quickly fail. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Add quota calls for allocation and freeing of inodes and spaceJan Kara
Add quota calls for allocation and freeing of inodes and space, also update estimates on number of needed credits for a transaction. Move out inode allocation from ocfs2_mknod_locked() because vfs_dq_init() must be called outside of a transaction. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Remove JBD compatibility layerMark Fasheh
JBD2 is fully backwards compatible with JBD and it's been tested enough with Ocfs2 that we can clean this code up now. Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Validate metadata only when it's read from disk.Joel Becker
Add an optional validation hook to ocfs2_read_blocks(). Now the validation function is only called when a block was actually read off of disk. It is not called when the buffer was in cache. We add a buffer state bit BH_NeedsValidate to flag these buffers. It must always be one higher than the last JBD2 buffer state bit. The dinode, dirblock, extent_block, and xattr_block validators are lifted to this scheme directly. The group_descriptor validator needs to be split into two pieces. The first part only needs the gd buffer and is passed to ocfs2_read_block(). The second part requires the dinode as well, and is called every time. It's only 3 compares, so it's tiny. This also allows us to clean up the non-fatal gd check used by resize.c. It now has no magic argument. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Wrap extent block reads in a dedicated function.Joel Becker
We weren't consistently checking extent blocks after we read them. Most places checked the signature, but none checked h_blkno or h_fs_signature. Create a toplevel ocfs2_read_extent_block() that does the read and the validation. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Morph the haphazard OCFS2_IS_VALID_DINODE() checks.Joel Becker
Random places in the code would check a dinode bh to see if it was valid. Not only did they do different levels of validation, they handled errors in different ways. The previous commit unified inode block reads, validating all block reads in the same place. Thus, these haphazard checks are no longer necessary. Rather than eliminate them, however, we change them to BUG_ON() checks. This ensures the assumptions remain true. All of the code paths to these checks have been audited to ensure they come from a validated inode read. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Wrap inode block reads in a dedicated function.Joel Becker
The ocfs2 code currently reads inodes off disk with a simple ocfs2_read_block() call. Each place that does this has a different set of sanity checks it performs. Some check only the signature. A couple validate the block number (the block read vs di->i_blkno). A couple others check for VALID_FL. Only one place validates i_fs_generation. A couple check nothing. Even when an error is found, they don't all do the same thing. We wrap inode reading into ocfs2_read_inode_block(). This will validate all the above fields, going readonly if they are invalid (they never should be). ocfs2_read_inode_block_full() is provided for the places that want to pass read_block flags. Every caller is passing a struct inode with a valid ip_blkno, so we don't need a separate blkno argument either. We will remove the validation checks from the rest of the code in a later commit, as they are no longer necessary. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: turn __ocfs2_remove_inode_range() into ocfs2_remove_btree_range()Mark Fasheh
This patch genericizes the high level handling of extent removal. ocfs2_remove_btree_range() is nearly identical to __ocfs2_remove_inode_range(), except that extent tree operations have been used where necessary. We update ocfs2_remove_inode_range() to use the generic helper. Now extent tree based structures have an easy way to truncate ranges. Signed-off-by: Mark Fasheh <mfasheh@suse.com> Acked-by: Joel Becker <joel.becker@oracle.com>
2009-01-05ocfs2: Add clusters free in dealloc_ctxt.Tao Ma
Now in ocfs2 xattr set, the whole process are divided into many small parts and they are wrapped into diffrent transactions and it make the set doesn't look like a real transaction. So we want to integrate it into a real one. In some cases we will allocate some clusters and free some in just one transaction. e.g, one xattr is larger than inline size, so it and its value root is stored within the inode while the value is outside in a cluster. Then we try to update it with a smaller value(larger than the size of root but smaller than inline size), we may need to free the outside cluster while allocate a new bucket(one cluster) since now the inode may be full. The old solution will lock the global_bitmap(if the local alloc failed in stress test) and then the truncate log. This will cause a ABBA lock with truncate log flush. This patch add the clusters free in dealloc_ctxt, so that we can record the free clusters during the transaction and then free it after we release the global_bitmap in xattr set. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-14ocfs2: Simplify ocfs2_read_block()Joel Becker
More than 30 callers of ocfs2_read_block() pass exactly OCFS2_BH_CACHED. Only six pass a different flag set. Rather than have every caller care, let's make ocfs2_read_block() take no flags and always do a cached read. The remaining six places can call ocfs2_read_blocks() directly. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-14ocfs2: Require an inode for ocfs2_read_block(s)().Joel Becker
Now that synchronous readers are using ocfs2_read_blocks_sync(), all callers of ocfs2_read_blocks() are passing an inode. Use it unconditionally. Since it's there, we don't need to pass the ocfs2_super either. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Don't check for NULL before brelse()Mark Fasheh
This is pointless as brelse() already does the check. Signed-off-by: Mark Fasheh
2008-10-13ocfs2: Switch over to JBD2.Joel Becker
ocfs2 wants JBD2 for many reasons, not the least of which is that JBD is limiting our maximum filesystem size. It's a pretty trivial change. Most functions are just renamed. The only functional change is moving to Jan's inode-based ordered data mode. It's better, too. Because JBD2 reads and writes JBD journals, this is compatible with any existing filesystem. It can even interact with JBD-based ocfs2 as long as the journal is formated for JBD. We provide a compatibility option so that paranoid people can still use JBD for the time being. This will go away shortly. [ Moved call of ocfs2_begin_ordered_truncate() from ocfs2_delete_inode() to ocfs2_truncate_for_delete(). --Mark ] Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Change ocfs2_get_*_extent_tree() to ocfs2_init_*_extent_tree()Joel Becker
The original get/put_extent_tree() functions held a reference on et_root_bh. However, every single caller already has a safe reference, making the get/put cycle irrelevant. We change ocfs2_get_*_extent_tree() to ocfs2_init_*_extent_tree(). It no longer gets a reference on et_root_bh. ocfs2_put_extent_tree() is removed. Callers now have a simpler init+use pattern. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Comment struct ocfs2_extent_tree_operations.Joel Becker
struct ocfs2_extent_tree_operations provides methods for the different on-disk btrees in ocfs2. Describing what those methods do is probably a good idea. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Make ocfs2_extent_tree the first-class representation of a tree.Joel Becker
We now have three different kinds of extent trees in ocfs2: inode data (dinode), extended attributes (xattr_tree), and extended attribute values (xattr_value). There is a nice abstraction for them, ocfs2_extent_tree, but it is hidden in alloc.c. All the calling functions have to pick amongst a varied API and pass in type bits and often extraneous pointers. A better way is to make ocfs2_extent_tree a first-class object. Everyone converts their object to an ocfs2_extent_tree() via the ocfs2_get_*_extent_tree() calls, then uses the ocfs2_extent_tree for all tree calls to alloc.c. This simplifies a lot of callers, making for readability. It also provides an easy way to add additional extent tree types, as they only need to be defined in alloc.c with a ocfs2_get_<new>_extent_tree() function. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Add an insertion check to ocfs2_extent_tree_operations.Joel Becker
A couple places check an extent_tree for a valid inode. We move that out to add an eo_insert_check() operation. It can be called from ocfs2_insert_extent() and elsewhere. We also have the wrapper calls ocfs2_et_insert_check() and ocfs2_et_sanity_check() ignore NULL ops. That way we don't have to provide useless operations for xattr types. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Create specific get_extent_tree functions.Joel Becker
A caller knows what kind of extent tree they have. There's no reason they have to call ocfs2_get_extent_tree() with a NULL when they could just as easily call a specific function to their type of extent tree. Introduce ocfs2_dinode_get_extent_tree(), ocfs2_xattr_tree_get_extent_tree(), and ocfs2_xattr_value_get_extent_tree(). They only take the necessary arguments, calling into the underlying __ocfs2_get_extent_tree() to do the real work. __ocfs2_get_extent_tree() is the old ocfs2_get_extent_tree(), but without needing any switch-by-type logic. ocfs2_get_extent_tree() is now a wrapper around the specific calls. It exists because a couple alloc.c functions can take et_type. This will go later. Another benefit is that ocfs2_xattr_value_get_extent_tree() can take a struct ocfs2_xattr_value_root* instead of void*. This gives us typechecking where we didn't have it before. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Determine an extent tree's max_leaf_clusters in an et_op.Joel Becker
Provide an optional extent_tree_operation to specify the max_leaf_clusters of an ocfs2_extent_tree. If not provided, the value is 0 (unlimited). Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Use struct ocfs2_extent_tree in ocfs2_num_free_extents().Joel Becker
ocfs2_num_free_extents() re-implements the logic of ocfs2_get_extent_tree(). Now that ocfs2_get_extent_tree() does not allocate, let's use it in ocfs2_num_free_extents() to simplify the code. The inode validation code in ocfs2_num_free_extents() is not needed. All callers are passing in pre-validated inodes. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Provide the get_root_el() method to ocfs2_extent_tree_operations.Joel Becker
The root_el of an ocfs2_extent_tree needs to be calculated from et->et_object. Make it an operation on et->et_ops. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Make 'private' into 'object' on ocfs2_extent_tree.Joel Becker
The 'private' pointer was a way to store off xattr values, which don't live at a set place in the bh. But the concept of "the object containing the extent tree" is much more generic. For an inode it's the struct ocfs2_dinode, for an xattr value its the value. Let's save off the 'object' at all times. If NULL is passed to ocfs2_get_extent_tree(), 'object' is set to bh->b_data; Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Make ocfs2_extent_tree get/put instead of alloc.Joel Becker
Rather than allocating a struct ocfs2_extent_tree, just put it on the stack. Fill it with ocfs2_get_extent_tree() and drop it with ocfs2_put_extent_tree(). Now the callers don't have to ENOMEM, yet still safely ref the root_bh. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Prefix the ocfs2_extent_tree structure.Joel Becker
The members of the ocfs2_extent_tree structure gain a prefix of 'et_'. All users are updated. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Prefix the extent tree operations structure.Joel Becker
The ocfs2_extent_tree_operations structure gains a field prefix on its members. The ->eo_sanity_check() operation gains a wrapper function for completeness. All of the extent tree operation wrappers gain a consistent name (ocfs2_et_*()). Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Optionally limit extent size in ocfs2_insert_extent()Tao Ma
In xattr bucket, we want to limit the maximum size of a btree leaf, otherwise we'll lose the benefits of hashing because we'll have to search large leaves. So add a new field in ocfs2_extent_tree which indicates the maximum leaf cluster size we want so that we can prevent ocfs2_insert_extent() from merging the leaf record even if it is contiguous with an adjacent record. Other btree types are not affected by this change. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Add xattr index tree operationsTao Ma
When necessary, an ocfs2_xattr_block will embed an ocfs2_extent_list to store large numbers of EAs. This patch adds a new type in ocfs2_extent_tree_type and adds the implementation so that we can re-use the b-tree code to handle the storage of many EAs. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: reserve inline space for extended attributeTiger Yang
Add the structures and helper functions we want for handling inline extended attributes. We also update the inline-data handlers so that they properly function in the event that we have both inline data and inline attributes sharing an inode block. Signed-off-by: Tiger Yang <tiger.yang@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Add extent tree operation for xattr value btreesTao Ma
Add some thin wrappers around ocfs2_insert_extent() for each of the 3 different btree types, ocfs2_inode_insert_extent(), ocfs2_xattr_value_insert_extent() and ocfs2_xattr_tree_insert_extent(). The last is for the xattr index btree, which will be used in a followup patch. All the old callers in file.c etc will call ocfs2_dinode_insert_extent(), while the other two handle the xattr issue. And the init of extent tree are handled by these functions. When storing xattr value which is too large, we will allocate some clusters for it and here ocfs2_extent_list and ocfs2_extent_rec will also be used. In order to re-use the b-tree operation code, a new parameter named "private" is added into ocfs2_extent_tree and it is used to indicate the root of ocfs2_exent_list. The reason is that we can't deduce the root from the buffer_head now. It may be in an inode, an ocfs2_xattr_block or even worse, in any place in an ocfs2_xattr_bucket. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Make high level btree extend code genericTao Ma
Factor out the non-inode specifics of ocfs2_do_extend_allocation() into a more generic function, ocfs2_do_cluster_allocation(). ocfs2_do_extend_allocation calls ocfs2_do_cluster_allocation() now, but the latter can be used for other btree types as well. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Abstract ocfs2_extent_tree in b-tree operations.Tao Ma
In the old extent tree operation, we take the hypothesis that we are using the ocfs2_extent_list in ocfs2_dinode as the tree root. As xattr will also use ocfs2_extent_list to store large value for a xattr entry, we refactor the tree operation so that xattr can use it directly. The refactoring includes 4 steps: 1. Abstract set/get of last_eb_blk and update_clusters since they may be stored in different location for dinode and xattr. 2. Add a new structure named ocfs2_extent_tree to indicate the extent tree the operation will work on. 3. Remove all the use of fe_bh and di, use root_bh and root_el in extent tree instead. So now all the fe_bh is replaced with et->root_bh, el with root_el accordingly. 4. Make ocfs2_lock_allocators generic. Now it is limited to be only used in file extend allocation. But the whole function is useful when we want to store large EAs. Note: This patch doesn't touch ocfs2_commit_truncate() since it is not used for anything other than truncate inode data btrees. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Use ocfs2_extent_list instead of ocfs2_dinode.Tao Ma
ocfs2_extend_meta_needed(), ocfs2_calc_extend_credits() and ocfs2_reserve_new_metadata() are all useful for extent tree operations. But they are all limited to an inode btree because they use a struct ocfs2_dinode parameter. Change their parameter to struct ocfs2_extent_list (the part of an ocfs2_dinode they actually use) so that the xattr btree code can use these functions. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Modify ocfs2_num_free_extents for future xattr usage.Tao Ma
ocfs2_num_free_extents() is used to find the number of free extent records in an inode btree. Hence, it takes an "ocfs2_dinode" parameter. We want to use this for extended attribute trees in the future, so genericize the interface the take a buffer head. A future patch will allow that buffer_head to contain any structure rooting an ocfs2 btree. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-03ocfs2: fiemap supportMark Fasheh
Plug ocfs2 into ->fiemap. Some portions of ocfs2_get_clusters() had to be refactored so that the extent cache can be skipped in favor of going directly to the on-disk records. This makes it easier for us to determine which extent is the last one in the btree. Also, I'm not sure we want to be caching fiemap lookups anyway as they're not directly related to data read/write. Signed-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: ocfs2-devel@oss.oracle.com Cc: linux-fsdevel@vger.kernel.org
2008-05-21ocfs2 endianness fixesAl Viro
2008-04-18ocfs2: Use BUG_ONJulia Lawall
if (...) BUG(); should be replaced with BUG_ON(...) when the test has no side-effects to allow a definition of BUG_ON that drops the code completely. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @ disable unlikely @ expression E,f; @@ ( if (<... f(...) ...>) { BUG(); } | - if (unlikely(E)) { BUG(); } + BUG_ON(E); ) @@ expression E,f; @@ ( if (<... f(...) ...>) { BUG(); } | - if (E) { BUG(); } + BUG_ON(E); ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-18ocfs2: Add inode stealing for ocfs2_reserve_new_inodeTao Ma
Inode allocation is modified to look in other nodes allocators during extreme out of space situations. We retry our own slot when space is freed back to the global bitmap, or whenever we've allocated more than 1024 inodes from another slot. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-18ocfs2: Enable cross extent block merge.Tao Ma
In ocfs2_figure_merge_contig_type, we judge whether there exists a cross extent block merge and enable it by setting CONTIG_LEFT and CONTIG_RIGHT accordingly. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-18ocfs2: Add support for cross extent blockTao Ma
In ocfs2_merge_rec_left, when we find the merge extent is "CONTIG_RIGHT" with the first extent record of the next extent block, we will merge it to the next extent block and change all the related extent blocks accordingly. In ocfs2_merge_rec_right, when we find the merge extent is "CONTIG_LEFT" with the last extent record of the previous extent block, we will merge it to the prevoius extent block and change all the related extent blocks accordingly. As for CONTIG_LEFTRIGHT, we will handle CONTIG_RIGHT first so that when the index is zero, the merge process will be more efficient and easier. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-02-05Pagecache zeroing: zero_user_segment, zero_user_segments and zero_userChristoph Lameter
Simplify page cache zeroing of segments of pages through 3 functions zero_user_segments(page, start1, end1, start2, end2) Zeros two segments of the page. It takes the position where to start and end the zeroing which avoids length calculations and makes code clearer. zero_user_segment(page, start, end) Same for a single segment. zero_user(page, start, length) Length variant for the case where we know the length. We remove the zero_user_page macro. Issues: 1. Its a macro. Inline functions are preferable. 2. The KM_USER0 macro is only defined for HIGHMEM. Having to treat this special case everywhere makes the code needlessly complex. The parameter for zeroing is always KM_USER0 except in one single case that we open code. Avoiding KM_USER0 makes a lot of code not having to be dealing with the special casing for HIGHMEM anymore. Dealing with kmap is only necessary for HIGHMEM configurations. In those configurations we use KM_USER0 like we do for a series of other functions defined in highmem.h. Since KM_USER0 is depends on HIGHMEM the existing zero_user_page function could not be a macro. zero_user_* functions introduced here can be be inline because that constant is not used when these functions are called. Also extract the flushing of the caches to be outside of the kmap. [akpm@linux-foundation.org: fix nfs and ntfs build] [akpm@linux-foundation.org: fix ntfs build some more] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03fs/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
