path: root/fs/ntfs/inode.c
2006-03-23NTFS: Semaphore to mutex conversion.Ingo Molnar
The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2006-03-23NTFS: Add a missing call to flush_dcache_mft_record_page() inAnton Altaparmakov
fs/ntfs/inode.c::ntfs_write_inode(). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2006-03-23NTFS: Fix a bug in fs/ntfs/inode.c::ntfs_read_locked_index_inode() where weAnton Altaparmakov
forgot to update a temporary variable so loading index inodes which have an index allocation attribute failed. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2006-03-23NTFS: Add support for sparse files which have a compression unit of 0.Anton Altaparmakov
2006-02-24NTFS: - Cope with attribute list attribute having invalid flags.Anton Altaparmakov
Windows copes with this and even chkdsk does not detect or fix this so we have to cope with it, too. Thanks to Pawel Kot for reporting the problem. - Miscellaneous updates to layout.h. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2006-01-10[PATCH] replace inode_update_time with file_update_timeChristoph Hellwig
To allow various options to work per-mount instead of per-sb we need a struct vfsmount when updating ctime and mtime. This preparation patch replaces the inode_update_time routine with a file_update_atime routine so we can easily get at the vfsmount. (and the file makes more sense in this context anyway). Also get rid of the unused second argument - we always want to update the ctime when calling this routine. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-10-04NTFS: Enable ATTR_SIZE attribute changes in ntfs_setattr(). This completesAnton Altaparmakov
the initial implementation of file truncation. Now both open(2)ing a file with the O_TRUNC flag and the {,f}truncate(2) system calls will resize a file appropriately. The limitations are that only uncompressed and unencrypted files are supported. Also, there is only very limited support for highly fragmented files (the ones whose $DATA attribute is split into multiple attribute extents). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-10-04NTFS: Implement fs/ntfs/inode.[hc]::ntfs_truncate(). It only supportsAnton Altaparmakov
uncompressed and unencrypted files. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-09-19NTFS: Fix ntfs_{read,write}page() to cope with concurrent truncates better.Anton Altaparmakov
2005-09-08NTFS: Fixup handling of sparse, compressed, and encrypted attributes inAnton Altaparmakov
fs/ntfs/inode.c::ntfs_read_locked_{,attr_,index_}inode(). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-09-08NTFS: Truncate {a,c,m}time to the ntfs supported time granularity whenAnton Altaparmakov
updating the times in the inode in ntfs_setattr(). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-27NTFS: Remove spurious void pointer casts from fs/ntfs/.Pekka Enberg
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: Correct sparse file handling. The compressed values need to beAnton Altaparmakov
checked and set in the ntfs inode as done for compressed files and the compressed size needs to be used for vfs inode->i_blocks instead of the allocated size, again, as done for compressed files. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: Fix printk format warnings on ia64. (Randy Dunlap)Randy Dunlap
Signed-off-by: Randy Dunlap <rddunlap@osdl.org> Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: - Set the ntfs_inode->allocated_size to the real allocated size in theAnton Altaparmakov
mft record for resident attributes (fs/ntfs/inode.c). - Small readability cleanup to use "a" instead of "ctx->attr" everywhere (fs/ntfs/inode.c). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: - Add disable_sparse mount option together with a per volume sparseAnton Altaparmakov
enable bit which is set appropriately and a per inode sparse disable bit which is preset on some system file inodes as appropriate. - Enforce that sparse support is disabled on NTFS volumes pre 3.0. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: Use i_size_read() in fs/ntfs/inode.c once and then use the cached valueAnton Altaparmakov
afterwards when reading the size of the bitmap inode. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: - In fs/ntfs/compress.c, use i_size_read() at the start and then use theAnton Altaparmakov
cached value everywhere. Cache the initialized_size in the same way and protect the critical region where the two sizes are read using the new size_lock of the ntfs inode. - Add the new size_lock to the ntfs_inode structure (fs/ntfs/inode.h) and initialize it (fs/ntfs/inode.c). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
