path: root/fs/ntfs/file.c
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-25ntfs: use add_to_page_cache_lru()Minchan Kim
Quote from Nick piggin's about btrfs patch - http://www.mail-archive.com/linux-btrfs@vger.kernel.org/msg04472.html. "add_to_page_cache_lru is exported, so it should be used. Benefits over using a private pagevec: neater code, 128 bytes fewer stack used, percpu lru ordering is preserved, and finally don't need to flush pagevec before returning so batching may be shared with other LRU insertions." Let's use it instead of private pagevec in ntfs, too. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Anton Altaparmakov <aia21@cantab.net> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25ntfs: clean up ntfs_attr_extend_initializedMinchan Kim
cached_page and lru_pvec have not been used. Let's remove the arguments. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-23ntfs: remove ntfs_file_writeChristoph Hellwig
do_sync_write() does the right thing for turning the aio_writev method into a normal non-vectored synchronous write, no need to duplicate it in ntfs. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-14ntfs: Use new syncing helpers and update commentsJan Kara
Use new syncing helpers in .write and .aio_write functions. Also remove superfluous syncing in ntfs_file_buffered_write() and update comments about generic_osync_inode(). CC: Anton Altaparmakov <aia21@cantab.net> CC: linux-ntfs-dev@lists.sourceforge.net Signed-off-by: Jan Kara <jack@suse.cz>
2008-10-20vmscan: split LRU lists into anon & file setsRik van Riel
Split the LRU lists in two, one set for pages that are backed by real file systems ("file") and one for pages that are backed by memory and swap ("anon"). The latter includes tmpfs. The advantage of doing this is that the VM will not have to scan over lots of anonymous pages (which we generally do not want to swap out), just to find the page cache pages that it should evict. This patch has the infrastructure and a basic policy to balance how much we scan the anon lists and how much we scan the file lists. The big policy changes are in separate patches. [lee.schermerhorn@hp.com: collect lru meminfo statistics from correct offset] [kosaki.motohiro@jp.fujitsu.com: prevent incorrect oom under split_lru] [kosaki.motohiro@jp.fujitsu.com: fix pagevec_move_tail() doesn't treat unevictable page] [hugh@veritas.com: memcg swapbacked pages active] [hugh@veritas.com: splitlru: BDI_CAP_SWAP_BACKED] [akpm@linux-foundation.org: fix /proc/vmstat units] [nishimura@mxp.nes.nec.co.jp: memcg: fix handling of shmem migration] [kosaki.motohiro@jp.fujitsu.com: adjust Quicklists field of /proc/meminfo] [kosaki.motohiro@jp.fujitsu.com: fix style issue of get_scan_ratio()] Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26[patch 3/5] vfs: change remove_suid() to file_remove_suid()Miklos Szeredi
All calls to remove_suid() are made with a file pointer, because (similarly to file_update_time) it is called when the file is written. Clean up callers by passing in a file instead of a dentry. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-02-05Pagecache zeroing: zero_user_segment, zero_user_segments and zero_userChristoph Lameter
Simplify page cache zeroing of segments of pages through 3 functions zero_user_segments(page, start1, end1, start2, end2) Zeros two segments of the page. It takes the position where to start and end the zeroing which avoids length calculations and makes code clearer. zero_user_segment(page, start, end) Same for a single segment. zero_user(page, start, length) Length variant for the case where we know the length. We remove the zero_user_page macro. Issues: 1. Its a macro. Inline functions are preferable. 2. The KM_USER0 macro is only defined for HIGHMEM. Having to treat this special case everywhere makes the code needlessly complex. The parameter for zeroing is always KM_USER0 except in one single case that we open code. Avoiding KM_USER0 makes a lot of code not having to be dealing with the special casing for HIGHMEM anymore. Dealing with kmap is only necessary for HIGHMEM configurations. In those configurations we use KM_USER0 like we do for a series of other functions defined in highmem.h. Since KM_USER0 is depends on HIGHMEM the existing zero_user_page function could not be a macro. zero_user_* functions introduced here can be be inline because that constant is not used when these functions are called. Also extract the flushing of the caches to be outside of the kmap. [akpm@linux-foundation.org: fix nfs and ntfs build] [akpm@linux-foundation.org: fix ntfs build some more] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17fs: correct SuS compliance for open of large file without optionsAlan Cox
The early LFS work that Linux uses favours EFBIG in various places. SuSv3 specifically uses EOVERFLOW for this as noted by Michael (Bug 7253) [EOVERFLOW] The named file is a regular file and the size of the file cannot be represented correctly in an object of type off_t. We should therefore transition to the proper error return code Signed-off-by: Alan Cox <alan@redhat.com> Cc: Theodore Tso <tytso@mit.edu> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12NTFS: Fix a mount time deadlock.Anton Altaparmakov
Big thanks go to Mathias Kolehmainen for reporting the bug, providing debug output and testing the patches I sent him to get it working. The fix was to stop calling ntfs_attr_set() at mount time as that causes balance_dirty_pages_ratelimited() to be called which on systems with little memory actually tries to go and balance the dirty pages which tries to take the s_umount semaphore but because we are still in fill_super() across which the VFS holds s_umount for writing this results in a deadlock. We now do the dirty work by hand by submitting individual buffers. This has the annoying "feature" that mounting can take a few seconds if the journal is large as we have clear it all. One day someone should improve on this by deferring the journal clearing to a helper kernel thread so it can be done in the background but I don't have time for this at the moment and the current solution works fine so I am leaving it like this for now. Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-12ntfs: use zero_user_pageNate Diller
Use zero_user_page() instead of open-coding it. [akpm@linux-foundation.org: kmap-type fixes] Signed-off-by: Nate Diller <nate.diller@gmail.com> Acked-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08mm: move common segment checks to separate helper functionDmitriy Monakhov
[akpm@linux-foundation.org: cleanup] Signed-off-by: Monakhov Dmitriy <dmonakhov@openvz.org> Cc: Christoph Hellwig <hch@lst.de> Acked-by: Anton Altaparmakov <aia21@cam.ac.uk> Acked-by: David Chinner <dgc@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: make read_cache_page synchronousNick Piggin
Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2006-12-08[PATCH] ntfs: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the ntfs filesystem code. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove readv/writev methods and use aio_read/aio_write insteadBadari Pulavarty
This patch removes readv() and writev() methods and replaces them with aio_read()/aio_write() methods. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Vectorize aio_read/aio_write fileop methodsBadari Pulavarty
This patch vectorizes aio_read() and aio_write() methods to prepare for collapsing all aio & vectored operations into one interface - which is aio_read()/aio_write(). Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Michael Holzheu <HOLZHEU@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] fs/ntfs: Conversion to generic booleanRichard Knutsson
Conversion of booleans to: generic-boolean.patch (2006-08-23) Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Prepare for __copy_from_user_inatomic to not zero missed bytesNeilBrown
The problem is that when we write to a file, the copy from userspace to pagecache is first done with preemption disabled, so if the source address is not immediately available the copy fails *and* *zeros* *the* *destination*. This is a problem because a concurrent read (which admittedly is an odd thing to do) might see zeros rather that was there before the write, or what was there after, or some mixture of the two (any of these being a reasonable thing to see). If the copy did fail, it will immediately be retried with preemption re-enabled so any transient problem with accessing the source won't cause an error. The first copying does not need to zero any uncopied bytes, and doing so causes the problem. It uses copy_from_user_atomic rather than copy_from_user so the simple expedient is to change copy_from_user_atomic to *not* zero out bytes on failure. The first of these two patches prepares for the change by fixing two places which assume copy_from_user_atomic does zero the tail. The two usages are very similar pieces of code which copy from a userspace iovec into one or more page-cache pages. These are changed to remove the assumption. The second patch changes __copy_from_user_inatomic* to not zero the tail. Once these are accepted, I will look at similar patches of other architectures where this is important (ppc, mips and sparc being the ones I can find). This patch: There is a problem with __copy_from_user_inatomic zeroing the tail of the buffer in the case of an error. As it is called in atomic context, the error may be transient, so it results in zeros being written where maybe they shouldn't be. In the usage in filemap, this opens a window for a well timed read to see data (zeros) which is not consistent with any ordering of reads and writes. Most cases where __copy_from_user_inatomic is called, a failure results in __copy_from_user being called immediately. As long as the latter zeros the tail, the former doesn't need to. However in *copy_from_user_iovec implementations (in both filemap and ntfs/file), it is assumed that copy_from_user_inatomic will zero the tail. This patch removes that assumption, so that after this patch it will be safe for copy_from_user_inatomic to not zero the tail. This patch also adds some commentary to filemap.h and asm-i386/uaccess.h. After this patch, all architectures that might disable preempt when kmap_atomic is called need to have their __copy_from_user_inatomic* "fixed". This includes - powerpc - i386 - mips - sparc Signed-off-by: Neil Brown <neilb@suse.de> Cc: David Howells <dhowells@redhat.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] read_mapping_page for address spacePekka Enberg
Add read_mapping_page() which is used for callers that pass mapping->a_ops->readpage as the filler for read_cache_page. This removes some duplication from filesystem code. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[PATCH] NTFS: Critical bug fix (affects MIPS and possibly others)Anton Altaparmakov
Many thanks to Pauline Ng for the detailed bug report and analysis! Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23NTFS: Remove all the make_bad_inode() calls. This should only be calledAnton Altaparmakov
from read inode and new inode code paths. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2006-03-07NTFS: Fix two compiler warnings on Alpha. Thanks to Andrew Morton forAnton Altaparmakov
reporting them. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2006-02-24NTFS: Implement support for sector sizes above 512 bytes (up to the maximumAnton Altaparmakov
supported by NTFS which is 4096 bytes).
2006-01-19Merge branch 'master' of /usr/src/ntfs-2.6/Anton Altaparmakov
2006-01-10[PATCH] replace inode_update_time with file_update_timeChristoph Hellwig
To allow various options to work per-mount instead of per-sb we need a struct vfsmount when updating ctime and mtime. This preparation patch replaces the inode_update_time routine with a file_update_atime routine so we can easily get at the vfsmount. (and the file makes more sense in this context anyway). Also get rid of the unused second argument - we always want to update the ctime when calling this routine. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-11-24NTFS: Fix a potential overflow by casting (index + 1) to s64 before doing aAnton Altaparmakov
left shift using PAGE_CACHE_SHIFT in fs/ntfs/file.c. Thanks to Andrew Morton pointing this out to. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-11-01NTFS: Fix a stupid bug causing writes to non-initialized pages to segfault.Anton Altaparmakov
2005-10-24NTFS: Fix compilation warnings with gcc-4.0.2 on SUSE 10.0.Anton Altaparmakov
2005-10-24NTFS: Use %z for size_t to fix compilation warnings. (Andrew Morton)Anton Altaparmakov
Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-10-19NTFS: Fix serious data corruption issue when writing.Anton Altaparmakov
Many thanks to Alberto Patino for testing and reporting the data corruption. And many apologies for corrupting his partition. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-10-19NTFS: $EA attributes can be both resident non-resident.Anton Altaparmakov
Minor tidying. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-10-11NTFS: The big ntfs write(2) rewrite has arrived. We now implement our ownAnton Altaparmakov
file operations ->write(), ->aio_write(), and ->writev() for regular files. This replaces the old use of generic_file_write(), et al and the address space operations ->prepare_write and ->commit_write. This means that both sparse and non-sparse (unencrypted and uncompressed) files can now be extended using the normal write(2) code path. There are two limitations at present and these are that we never create sparse files and that we only have limited support for highly fragmented files, i.e. ones whose data attribute is split across multiple extents. When such a case is encountered, EOPNOTSUPP is returned. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-09-08NTFS: Remove bogus setting of PageError in ntfs_read_compressed_block().Anton Altaparmakov
2005-05-04NTFS: Use i_size_read() in fs/ntfs/file.c::ntfs_file_open().Anton Altaparmakov
