path: root/fs/ntfs/attrib.c
2005-09-08NTFS: Fix handling of sparse attributes in ntfs_attr_make_non_resident().Anton Altaparmakov
Also, add BUG() checks to ntfs_attr_make_non_resident() and ntfs_attr_set() to ensure that these functions are never called for compressed or encrypted attributes. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-09-08NTFS: Fix several bugs in fs/ntfs/attrib.c.Anton Altaparmakov
- Fix a bug in ntfs_map_runlist_nolock() where we forgot to protect access to the allocated size in the ntfs inode with the size lock. - Fix ntfs_attr_vcn_to_lcn_nolock() and ntfs_attr_find_vcn_nolock() to return LCN_ENOENT when there is no runlist and the allocated size is zero. - Fix load_attribute_list() to handle the case of a NULL runlist. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-09-08NTFS: Add fs/ntfs/attrib.[hc]::ntfs_resident_attr_value_resize().Anton Altaparmakov
2005-06-25NTFS: Prepare for 2.1.23 release: Update documentation and bump version.Anton Altaparmakov
2005-06-25NTFS: Change ntfs_map_runlist_nolock() to only decompress the mapping pairsAnton Altaparmakov
if the requested vcn is inside it. Otherwise we get into problems when we try to map an out of bounds vcn because we then try to map the already mapped runlist fragment which causes ntfs_mapping_pairs_decompress() to fail and return error. Update ntfs_attr_find_vcn_nolock() accordingly. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-06-25NTFS: Add an extra parameter @last_vcn to ntfs_get_size_for_mapping_pairs()Anton Altaparmakov
and ntfs_mapping_pairs_build() to allow the runlist encoding to be partial which is desirable when filling holes in sparse attributes. Update all callers. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-06-25NTFS: Change the runlist terminator of the newly allocated cluster(s) toAnton Altaparmakov
LCN_ENOENT in ntfs_attr_make_non_resident(). Otherwise the runlist code gets confused. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-27NTFS: Use C99 style structure initialization after memory allocation whereAnton Altaparmakov
possible (fs/ntfs/{attrib.c,index.c,super.c}). Thanks to Al Viro and Pekka Enberg. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: Update attribute definition handling.Anton Altaparmakov
2005-05-05NTFS: Fix compilation when configured read-only.Anton Altaparmakov
- Add ifdef NTFS_RW around write specific code if fs/ntfs/runlist.[hc] and fs/ntfs/attrib.[hc]. - Minor bugfix to fs/ntfs/attrib.c::ntfs_attr_make_non_resident() where the runlist was not freed in all error cases. - Add fs/ntfs/runlist.[hc]::ntfs_rl_find_vcn_nolock(). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: Include linux/swap.h in fs/ntfs/attrib.c for mark_page_accessed().Anton Altaparmakov
2005-05-05NTFS: - Modify ->readpage and ->writepage (fs/ntfs/aops.c) so they detectAnton Altaparmakov
and handle the case where an attribute is converted from resident to non-resident by a concurrent file write. - Reorder some operations when converting an attribute from resident to non-resident (fs/ntfs/attrib.c) so it is safe wrt concurrent ->readpage and ->writepage. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: Add fs/ntfs/attrib.[hc]::ntfs_attr_make_non_resident().Anton Altaparmakov
2005-05-05NTFS: - Fix bug in fs/ntfs/attrib.c::ntfs_find_vcn_nolock() where afterAnton Altaparmakov
dropping the read lock and taking the write lock we were not checking whether someone else did not already do the work we wanted to do. - Rename ntfs_find_vcn_nolock() to ntfs_attr_find_vcn_nolock(). - Tidy up some comments in fs/ntfs/runlist.c. - Add LCN_ENOMEM and LCN_EIO definitions to fs/ntfs/runlist.h. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: Add fs/ntfs/attrib.[hc]::ntfs_attr_vcn_to_lcn_nolock() used by the newAnton Altaparmakov
write code. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: Add AT_EA in addition to AT_DATA to whitelist for being allowed to beAnton Altaparmakov
non-resident in fs/ntfs/attrib.c::ntfs_attr_can_be_non_resident(). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: - Split ntfs_map_runlist() into ntfs_map_runlist() and a non-lockingAnton Altaparmakov
helper ntfs_map_runlist_nolock() which is used by ntfs_map_runlist(). This allows us to map runlist fragments with the runlist lock already held without having to drop and reacquire it around the call. Adapt all callers. - Change ntfs_find_vcn() to ntfs_find_vcn_nolock() which takes a locked runlist. This allows us to find runlist elements with the runlist lock already held without having to drop and reacquire it around the call. Adapt all callers. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-04NTFS: Use i_size_read() in fs/ntfs/attrib.c::ntfs_attr_set().Anton Altaparmakov
