path: root/fs/nilfs2
2009-08-31nilfs2: fix preempt count underflow in nilfs_btnode_prepare_change_keyRyusuke Konishi
This will fix the following preempt count underflow reported from users with the title "[NILFS users] segctord problem" (Message-ID: <949415.6494.qm@web58808.mail.re1.yahoo.com> and Message-ID: <debc30fc0908270825v747c1734xa59126623cfd5b05@mail.gmail.com>): WARNING: at kernel/sched.c:4890 sub_preempt_count+0x95/0xa0() Hardware name: HP Compaq 6530b (KR980UT#ABC) Modules linked in: bridge stp llc bnep rfcomm l2cap xfs exportfs nilfs2 cowloop loop vboxnetadp vboxnetflt vboxdrv btusb bluetooth uvcvideo videodev v4l1_compat v4l2_compat_ioctl32 arc4 snd_hda_codec_analog ecb iwlagn iwlcore rfkill lib80211 mac80211 snd_hda_intel snd_hda_codec ehci_hcd uhci_hcd usbcore snd_hwdep snd_pcm tg3 cfg80211 psmouse snd_timer joydev libphy ohci1394 snd_page_alloc hp_accel lis3lv02d ieee1394 led_class i915 drm i2c_algo_bit video backlight output i2c_core dm_crypt dm_mod Pid: 4197, comm: segctord Not tainted 2.6.30-gentoo-r4-64 #7 Call Trace: [<ffffffff8023fa05>] ? sub_preempt_count+0x95/0xa0 [<ffffffff802470f8>] warn_slowpath_common+0x78/0xd0 [<ffffffff8024715f>] warn_slowpath_null+0xf/0x20 [<ffffffff8023fa05>] sub_preempt_count+0x95/0xa0 [<ffffffffa04ce4db>] nilfs_btnode_prepare_change_key+0x11b/0x190 [nilfs2] [<ffffffffa04d01ad>] nilfs_btree_assign_p+0x19d/0x1e0 [nilfs2] [<ffffffffa04d10ad>] nilfs_btree_assign+0xbd/0x130 [nilfs2] [<ffffffffa04cead7>] nilfs_bmap_assign+0x47/0x70 [nilfs2] [<ffffffffa04d9bc6>] nilfs_segctor_do_construct+0x956/0x20f0 [nilfs2] [<ffffffff805ac8e2>] ? _spin_unlock_irqrestore+0x12/0x40 [<ffffffff803c06e0>] ? __up_write+0xe0/0x150 [<ffffffff80262959>] ? up_write+0x9/0x10 [<ffffffffa04ce9f3>] ? nilfs_bmap_test_and_clear_dirty+0x43/0x60 [nilfs2] [<ffffffffa04cd627>] ? nilfs_mdt_fetch_dirty+0x27/0x60 [nilfs2] [<ffffffffa04db5fc>] nilfs_segctor_construct+0x8c/0xd0 [nilfs2] [<ffffffffa04dc3dc>] nilfs_segctor_thread+0x15c/0x3a0 [nilfs2] [<ffffffffa04dbe20>] ? nilfs_construction_timeout+0x0/0x10 [nilfs2] [<ffffffff80252633>] ? add_timer+0x13/0x20 [<ffffffff802370da>] ? __wake_up_common+0x5a/0x90 [<ffffffff8025e960>] ? autoremove_wake_function+0x0/0x40 [<ffffffffa04dc280>] ? nilfs_segctor_thread+0x0/0x3a0 [nilfs2] [<ffffffffa04dc280>] ? nilfs_segctor_thread+0x0/0x3a0 [nilfs2] [<ffffffff8025e556>] kthread+0x56/0x90 [<ffffffff8020cdea>] child_rip+0xa/0x20 [<ffffffff8025e500>] ? kthread+0x0/0x90 [<ffffffff8020cde0>] ? child_rip+0x0/0x20 This problem was caused due to a missing radix_tree_preload() call in the retry path of nilfs_btnode_prepare_change_key() function. Reported-by: Eric A <eric225125@yahoo.com> Reported-by: Jerome Poulin <jeromepoulin@gmail.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Jerome Poulin <jeromepoulin@gmail.com> Cc: stable@kernel.org
2009-08-19nilfs2: fix oopses with doubly mounted snapshotsRyusuke Konishi
will fix kernel oopses like the following: # mount -t nilfs2 -r -o cp=20 /dev/sdb1 /test1 # mount -t nilfs2 -r -o cp=20 /dev/sdb1 /test2 # umount /test1 # umount /test2 BUG: sleeping function called from invalid context at arch/x86/mm/fault.c:1069 in_atomic(): 0, irqs_disabled(): 1, pid: 3886, name: umount.nilfs2 1 lock held by umount.nilfs2/3886: #0: (&type->s_umount_key#31){+.+...}, at: [<c10b398a>] deactivate_super+0x52/0x6c irq event stamp: 1219 hardirqs last enabled at (1219): [<c135c774>] __mutex_unlock_slowpath+0xf8/0x119 hardirqs last disabled at (1218): [<c135c6d5>] __mutex_unlock_slowpath+0x59/0x119 softirqs last enabled at (1214): [<c1033316>] __do_softirq+0x1a5/0x1ad softirqs last disabled at (1205): [<c1033354>] do_softirq+0x36/0x5a Pid: 3886, comm: umount.nilfs2 Not tainted 2.6.31-rc6 #55 Call Trace: [<c1023549>] __might_sleep+0x107/0x10e [<c13603c0>] do_page_fault+0x246/0x397 [<c136017a>] ? do_page_fault+0x0/0x397 [<c135e753>] error_code+0x6b/0x70 [<c136017a>] ? do_page_fault+0x0/0x397 [<c104f805>] ? __lock_acquire+0x91/0x12fd [<c1050a62>] ? __lock_acquire+0x12ee/0x12fd [<c1050a62>] ? __lock_acquire+0x12ee/0x12fd [<c1050b2b>] lock_acquire+0xba/0xdd [<d0d17d3f>] ? nilfs_detach_segment_constructor+0x2f/0x2fa [nilfs2] [<c135d4fe>] down_write+0x2a/0x46 [<d0d17d3f>] ? nilfs_detach_segment_constructor+0x2f/0x2fa [nilfs2] [<d0d17d3f>] nilfs_detach_segment_constructor+0x2f/0x2fa [nilfs2] [<c104ea2c>] ? mark_held_locks+0x43/0x5b [<c104ecb1>] ? trace_hardirqs_on_caller+0x10b/0x133 [<c104ece4>] ? trace_hardirqs_on+0xb/0xd [<d0d09ac1>] nilfs_put_super+0x2f/0xca [nilfs2] [<c10b3352>] generic_shutdown_super+0x49/0xb8 [<c10b33de>] kill_block_super+0x1d/0x31 [<c10e6599>] ? vfs_quota_off+0x0/0x12 [<c10b398f>] deactivate_super+0x57/0x6c [<c10c4bc3>] mntput_no_expire+0x8c/0xb4 [<c10c5094>] sys_umount+0x27f/0x2a4 [<c10c50c6>] sys_oldumount+0xd/0xf [<c10031a4>] sysenter_do_call+0x12/0x38 ... This turns out to be a bug brought by an -rc1 patch ("nilfs2: simplify remaining sget() use"). In the patch, a new "put resource" function, nilfs_put_sbinfo() was introduced to delay freeing nilfs_sb_info struct. But the nilfs_put_sbinfo() mistakenly used atomic_dec_and_test() function to check the reference count, and it caused the nilfs_sb_info was freed when user mounted a snapshot twice. This bug also suggests there was unseen memory leak in usual mount /umount operations for nilfs. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-08-18nilfs2: missing a read lock for segment writer in nilfs_attach_checkpoint()Zhang Qiang
'ns_cno' of structure 'the_nilfs' must be protected from segment writer, in other words, the caller of nilfs_get_checkpoint should hold read lock for nilfs->ns_segctor_sem. This patch adds the lock/unlock operations in nilfs_attach_checkpoint() when calling nilfs_cpfile_get_checkpoint(). Signed-off-by: Zhang Qiang <zhangqiang.buaa@gmail.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-08-02nilfs2: fix missing unlock in error path of nilfs_mdt_write_pageRyusuke Konishi
This adds a missing unlock of nilfs->ns_writer_mutex in nilfs_mdt_write_page() function. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-08-01nilfs2: fix oops due to inconsistent state in page with discrete b-tree nodesRyusuke Konishi
Andrea Gelmini gave me a report that a kernel oops hit on a nilfs filesystem with a 1KB block size when doing rsync. This turned out to be caused by an inconsistency of dirty state between a page and its buffers storing b-tree node blocks. If the page had multiple buffers split over multiple logs, and if the logs were written at a time, a dirty flag remained in the page even every dirty flag in the buffers was cleared. This will fix the failure by dropping the dirty flag properly for pages with the discrete multiple b-tree nodes. Reported-by: Andrea Gelmini <andrea.gelmini@gmail.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Andrea Gelmini <andrea.gelmini@gmail.com> Cc: stable@kernel.org
2009-07-14fs/Kconfig: move nilfs2 outRyusuke Konishi
fs/Kconfig file was split into individual fs/*/Kconfig files before nilfs was merged. I've found the current config entry of nilfs is tainting the work. Sorry, I didn't notice. This fixes the violation. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Alexey Dobriyan <adobriyan@gmail.com>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-05nilfs2: fix disorder in cp count on error during deleting checkpointsJiro SEKIBA
This fixes a bug that checkpoint count gets wrong on errors when deleting a series of checkpoints. The count error is persistent since the checkpoint count is stored on disk. Some userland programs refer to the count via ioctl, and this bugfix is needed to prevent malfunction of such programs. Signed-off-by: Jiro SEKIBA <jir@unicus.jp> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: stable@kernel.org
2009-07-05nilfs2: fix lockdep warning between regular file and inode fileRyusuke Konishi
This will fix the following false positive of recursive locking which lockdep has detected: ============================================= [ INFO: possible recursive locking detected ] 2.6.30-nilfs #42 --------------------------------------------- nilfs_cleanerd/10607 is trying to acquire lock: (&bmap->b_sem){++++-.}, at: [<e0d025b7>] nilfs_bmap_lookup_at_level+0x1a/0x74 [nilfs2] but task is already holding lock: (&bmap->b_sem){++++-.}, at: [<e0d024e0>] nilfs_bmap_truncate+0x19/0x6a [nilfs2] other info that might help us debug this: 2 locks held by nilfs_cleanerd/10607: #0: (&nilfs->ns_segctor_sem){++++.+}, at: [<e0d0d75a>] nilfs_transaction_begin+0xb6/0x10c [nilfs2] #1: (&bmap->b_sem){++++-.}, at: [<e0d024e0>] nilfs_bmap_truncate+0x19/0x6a [nilfs2] Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-07-05nilfs2: fix incorrect KERN_CRIT messages in case of write failuresRyusuke Konishi
In case of write-failure retries, the following KERN_CRIT level messages are mistakenly output by nilfs_dat_commit_start() function: nilfs_dat_commit_start: vbn = 408463, start = 12506, end = 18446744073709551615, pbn = 530210 nilfs_dat_commit_start: vbn = 408515, start = 12506, end = 18446744073709551615, pbn = 530211 nilfs_dat_commit_start: vbn = 408464, start = 12506, end = 18446744073709551615, pbn = 530212 ... This suppresses these messages. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: stable@kernel.org
2009-07-05nilfs2: fix hang problem of log writer which occurs after write failuresRyusuke Konishi
Leandro Lucarella gave me a report that nilfs gets stuck after its write function fails. The problem turned out to be caused by bugs which leave writeback flag on pages. This fixes the problem by ensuring to clear the writeback flag in error path. Reported-by: Leandro Lucarella <llucax@gmail.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: stable@kernel.org
2009-07-05nilfs2: remove unlikely directive causing mis-conversion of error codeRyusuke Konishi
The following error code handling in nilfs_segctor_write() function wrongly converted negative error codes to a truth value (i.e. 1): err = unlikely(err) ? : res; which originaly meant to be err = err ? : res; This mis-conversion caused that write or sync functions receive the unexpected error code. This fixes the bug by removing the unlikely directive. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: stable@kernel.org
2009-06-24switch nilfs2 to inode->i_aclAl Viro
Actually, get rid of private analog, since nothing in there is using ACLs at all so far. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: (22 commits) nilfs2: support contiguous lookup of blocks nilfs2: add sync_page method to page caches of meta data nilfs2: use device's backing_dev_info for btree node caches nilfs2: return EBUSY against delete request on snapshot nilfs2: modify list of unsupported features in caveats nilfs2: enable sync_page method nilfs2: set bio unplug flag for the last bio in segment nilfs2: allow future expansion of metadata read out via get info ioctl NILFS2: Pagecache usage optimization on NILFS2 nilfs2: remove nilfs_btree_operations from btree mapping nilfs2: remove nilfs_direct_operations from direct mapping nilfs2: remove bmap pointer operations nilfs2: remove useless b_low and b_high fields from nilfs_bmap struct nilfs2: remove pointless NULL check of bpop_commit_alloc_ptr function nilfs2: move get block functions in bmap.c into btree codes nilfs2: remove nilfs_bmap_delete_block nilfs2: remove nilfs_bmap_put_block nilfs2: remove header file for segment list operations nilfs2: eliminate removal list of segments nilfs2: add sufile function that can modify multiple segment usages ...
2009-06-11nilfs2: get rid of bd_mount_sem use from nilfsRyusuke Konishi
This will remove every bd_mount_sem use in nilfs. The intended exclusion control was replaced by the previous patch ("nilfs2: correct exclusion control in nilfs_remount function") for nilfs_remount(), and this patch will replace remains with a new mutex that this inserts in nilfs object. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11nilfs2: correct exclusion control in nilfs_remount functionRyusuke Konishi
nilfs_remount() changes mount state of a superblock instance. Even though nilfs accesses other superblock instances during mount or remount, the mount state was not properly protected in nilfs_remount(). Moreover, nilfs_remount() has a lock order reversal problem; nilfs_get_sb() holds: 1. bdev->bd_mount_sem 2. sb->s_umount (sget acquires) and nilfs_remount() holds: 1. sb->s_umount (locked by the caller in vfs) 2. bdev->bd_mount_sem To avoid these problems, this patch divides a semaphore protecting super block instances from nilfs->ns_sem, and applies it to the mount state protection in nilfs_remount(). With this change, bd_mount_sem use is removed from nilfs_remount() and the lock order reversal will be resolved. And the new rw-semaphore, nilfs->ns_super_sem will properly protect the mount state except the modification from nilfs_error function. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11nilfs2: simplify remaining sget() useRyusuke Konishi
This simplifies the test function passed on the remaining sget() callsite in nilfs. Instead of checking mount type (i.e. ro-mount/rw-mount/snapshot mount) in the test function passed to sget(), this patch first looks up the nilfs_sb_info struct which the given mount type matches, and then acquires the super block instance holding the nilfs_sb_info. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11nilfs2: get rid of sget use for checking if current mount is presentRyusuke Konishi
This stops using sget() for checking if an r/w-mount or an r/o-mount exists on the device. This elimination uses a back pointer to the current mount added to nilfs object. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11nilfs2: get rid of sget use for acquiring nilfs objectRyusuke Konishi
This will change the way to obtain nilfs object in nilfs_get_sb() function. Previously, a preliminary sget() call was performed, and the nilfs object was acquired from a super block instance found by the sget() call. This patch, instead, instroduces a new dedicated function find_or_create_nilfs(); as the name implies, the function finds an existent nilfs object from a global list or creates a new one if no object is found on the device. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11nilfs2: remove meaningless EBUSY case from nilfs_get_sb functionRyusuke Konishi
The following EBUSY case in nilfs_get_sb() is meaningless. Indeed, this error code is never returned to the caller. if (!s->s_root) { ... } else if (!(s->s_flags & MS_RDONLY)) { err = -EBUSY; } This simply removes the else case. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11nilfs2: call nilfs2_write_super from nilfs2_sync_fsChristoph Hellwig
The call to ->write_super from __sync_filesystem will go away, so make sure nilfs2 performs the same actions from inside ->sync_fs. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11Push BKL down into ->remount_fs()Alessio Igor Bogani
[xfs, btrfs, capifs, shmem don't need BKL, exempt] Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11remove ->write_super call in generic_shutdown_superChristoph Hellwig
We just did a full fs writeout using sync_filesystem before, and if that's not enough for the filesystem it can perform it's own writeout in ->put_super, which many filesystems already do. Move a call to foofs_write_super into every foofs_put_super for now to guarantee identical behaviour until it's cleaned up by the individual filesystem maintainers. Exceptions: - affs already has identical copy & pasted code at the beginning of affs_put_super so no need to do it twice. - xfs does the right thing without it and I have changes pending for the xfs tree touching this are so I don't really need conflicts here.. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11Merge branch 'for-2.6.31' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.31' of git://git.kernel.dk/linux-2.6-block: (153 commits) block: add request clone interface (v2) floppy: fix hibernation ramdisk: remove long-deprecated "ramdisk=" boot-time parameter fs/bio.c: add missing __user annotation block: prevent possible io_context->refcount overflow Add serial number support for virtio_blk, V4a block: Add missing bounce_pfn stacking and fix comments Revert "block: Fix bounce limit setting in DM" cciss: decode unit attention in SCSI error handling code cciss: Remove no longer needed sendcmd reject processing code cciss: change SCSI error handling routines to work with interrupts enabled. cciss: separate error processing and command retrying code in sendcmd_withirq_core() cciss: factor out fix target status processing code from sendcmd functions cciss: simplify interface of sendcmd() and sendcmd_withirq() cciss: factor out core of sendcmd_withirq() for use by SCSI error handling code cciss: Use schedule_timeout_uninterruptible in SCSI error handling code block: needs to set the residual length of a bidi request Revert "block: implement blkdev_readpages" block: Fix bounce limit setting in DM Removed reference to non-existing file Documentation/PCI/PCI-DMA-mapping.txt ... Manually fix conflicts with tracing updates in: block/blk-sysfs.c drivers/ide/ide-atapi.c drivers/ide/ide-cd.c drivers/ide/ide-floppy.c drivers/ide/ide-tape.c include/trace/events/block.h kernel/trace/blktrace.c
2009-06-10nilfs2: support contiguous lookup of blocksRyusuke Konishi
Although get_block() callback function can return extent of contiguous blocks with bh->b_size, nilfs_get_block() function did not support this feature. This adds contiguous lookup feature to the block mapping codes of nilfs, and allows the nilfs_get_blocks() function to return the extent information by applying the feature. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: add sync_page method to page caches of meta dataRyusuke Konishi
This applies block_sync_page() function to the sync_page method of page caches for meta data files, gc page caches, and btree node buffers. This is a companion patch of ("nilfs2: enable sync_page mothod") which applied the function for data pages. This allows lock_page() for those meta data to unplug pending bio requests. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: use device's backing_dev_info for btree node cachesRyusuke Konishi
Previously, default_backing_dev_info was used for the mapping of btree node caches. This uses device dependent backing_dev_info to allow detailed control of the device for the btree node pages. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: return EBUSY against delete request on snapshotRyusuke Konishi
This helps userland programs like the rmcp command to distinguish error codes returned against a checkpoint removal request. Previously -EPERM was returned, and not discriminable from real permission errors. This also allows removal of the latest checkpoint because the deletion leads to create a new checkpoint, and thus it's harmless for the filesystem. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: enable sync_page methodRyusuke Konishi
This adds a missing sync_page method which unplugs bio requests when waiting for page locks. This will improve read performance of nilfs. Here is a measurement result using dd command. Without this patch: # mount -t nilfs2 /dev/sde1 /test # dd if=/test/aaa of=/dev/null bs=512k 1024+0 records in 1024+0 records out 536870912 bytes (537 MB) copied, 6.00688 seconds, 89.4 MB/s With this patch: # mount -t nilfs2 /dev/sde1 /test # dd if=/test/aaa of=/dev/null bs=512k 1024+0 records in 1024+0 records out 536870912 bytes (537 MB) copied, 3.54998 seconds, 151 MB/s Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: set bio unplug flag for the last bio in segmentRyusuke Konishi
This sets BIO_RW_UNPLUG flag on the last bio of each segment during write. The last bio should be unplugged immediately because the caller waits for the completion after the submission. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: allow future expansion of metadata read out via get info ioctlRyusuke Konishi
Nilfs has some ioctl commands to read out metadata from meta data files: - NILFS_IOCTL_GET_CPINFO for checkpoint file, - NILFS_IOCTL_GET_SUINFO for segment usage file, and - NILFS_IOCTL_GET_VINFO for Disk Address Transalation (DAT) file, respectively. Every routine on these metadata files is implemented so that it allows future expansion of on-disk format. But, the above ioctl commands do not support expansion even though nilfs_argv structure can handle arbitrary size for data exchanged via ioctl. This allows future expansion of the following structures which give basic format of the "get information" ioctls: - struct nilfs_cpinfo - struct nilfs_suinfo - struct nilfs_vinfo So, this introduces forward compatility of such ioctl commands. In this patch, a sanity check in nilfs_ioctl_get_info() function is changed to accept larger data structure [1], and metadata read routines are rewritten so that they become compatible for larger structures; the routines will just ignore the remaining fields which the current version of nilfs doesn't know. [1] The ioctl function already has another upper limit (PAGE_SIZE against a structure, which appears in nilfs_ioctl_wrap_copy function), and this will not cause security problem. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10NILFS2: Pagecache usage optimization on NILFS2Hisashi Hifumi
Hi, I introduced "is_partially_uptodate" aops for NILFS2. A page can have multiple buffers and even if a page is not uptodate, some buffers can be uptodate on pagesize != blocksize environment. This aops checks that all buffers which correspond to a part of a file that we want to read are uptodate. If so, we do not have to issue actual read IO to HDD even if a page is not uptodate because the portion we want to read are uptodate. "block_is_partially_uptodate" function is already used by ext2/3/4. With the following patch random read/write mixed workloads or random read after random write workloads can be optimized and we can get performance improvement. I did a performance test using the sysbench. 1 --file-block-size=8K --file-total-size=2G --file-test-mode=rndrw --file-fsync-freq=0 --fil e-rw-ratio=1 run -2.6.30-rc5 Test execution summary: total time: 151.2907s total number of events: 200000 total time taken by event execution: 2409.8387 per-request statistics: min: 0.0000s avg: 0.0120s max: 0.9306s approx. 95 percentile: 0.0439s Threads fairness: events (avg/stddev): 12500.0000/238.52 execution time (avg/stddev): 150.6149/0.01 -2.6.30-rc5-patched Test execution summary: total time: 140.8828s total number of events: 200000 total time taken by event execution: 2240.8577 per-request statistics: min: 0.0000s avg: 0.0112s max: 0.8750s approx. 95 percentile: 0.0418s Threads fairness: events (avg/stddev): 12500.0000/218.43 execution time (avg/stddev): 140.0536/0.01 arch: ia64 pagesize: 16k Thanks. Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: remove nilfs_btree_operations from btree mappingRyusuke Konishi
will remove indirect function calls using nilfs_btree_operations table. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: remove nilfs_direct_operations from direct mappingRyusuke Konishi
will remove indirect function calls using nilfs_direct_operations table. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: remove bmap pointer operationsRyusuke Konishi
Previously, the bmap codes of nilfs used three types of function tables. The abuse of indirect function calls decreased source readability and suffered many indirect jumps which would confuse branch prediction of processors. This eliminates one type of the function tables, nilfs_bmap_ptr_operations, which was used to dispatch low level pointer operations of the nilfs bmap. This adds a new integer variable "b_ptr_type" to nilfs_bmap struct, and uses the value to select the pointer operations. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: remove useless b_low and b_high fields from nilfs_bmap structRyusuke Konishi
This will cut off 16 bytes from the nilfs_bmap struct which is embedded in the on-memory inode of nilfs. The b_high field was never used, and the b_low field stores a constant value which can be determined by whether the inode uses btree for block mapping or not. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: remove pointless NULL check of bpop_commit_alloc_ptr functionRyusuke Konishi
This indirect function is set to NULL only for gc cache inodes, but the gc cache inodes never call this function. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: move get block functions in bmap.c into btree codesRyusuke Konishi
Two get block function for btree nodes, nilfs_bmap_get_block() and nilfs_bmap_get_new_block(), are called only from the btree codes. This relocation will increase opportunities of compiler optimization. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: remove nilfs_bmap_delete_blockRyusuke Konishi
nilfs_bmap_delete_block() is a wrapper function calling nilfs_btnode_delete(). This removes it for simplicity. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: remove nilfs_bmap_put_blockRyusuke Konishi
nilfs_bmap_put_block() is a wrapper function calling brelse(). This eliminates the wrapper for simplicity. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: remove header file for segment list operationsRyusuke Konishi
This will eliminate obsolete list operations of nilfs_segment_entry structure which has been used to handle mutiple segment numbers. The patch ("nilfs2: remove list of freeing segments") removed use of the structure from the segment constructor code, and this patch simplifies the remaining code by integrating it into recovery.c. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: eliminate removal list of segmentsRyusuke Konishi
This will clean up the removal list of segments and the related functions from segment.c and ioctl.c, which have hurt code readability. This elimination is applied by using nilfs_sufile_updatev() previously introduced in the patch ("nilfs2: add sufile function that can modify multiple segment usages"). Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: add sufile function that can modify multiple segment usagesRyusuke Konishi
This is a preparation for the later cleanup patch ("nilfs2: remove list of freeing segments"). This adds nilfs_sufile_updatev() to sufile, which can modify multiple segment usages at a time. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: unify bmap operations starting use of indirect block addressRyusuke Konishi
This simplifies some low level functions of bmap. Three bmap pointer operations, nilfs_bmap_start_v(), nilfs_bmap_commit_v(), and nilfs_bmap_abort_v(), are unified into one nilfs_bmap_start_v() function. And the related indirect function calls are replaced with it. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: remove nilfs_dat_prepare_free functionRyusuke Konishi
This function is unused. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-05-30nilfs2: fix bh leak in nilfs_cpfile_delete_checkpoints functionRyusuke Konishi
The nilfs_cpfile_delete_checkpoints() wrongly skips brelse() for the header block of checkpoint file in case of errors. This fixes the leak bug. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22nilfs2: fix memory leak in nilfs_ioctl_clean_segmentsRyusuke Konishi
This fixes a new memory leak problem in garbage collection. The problem was brought by the bugfix patch ("nilfs2: fix lock order reversal in nilfs_clean_segments ioctl"). Thanks to Kentaro Suzuki for finding this problem. Reported-by: Kentaro Suzuki <k_suzuki@ms.sylc.co.jp> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-05-12nilfs2: check size of array structured data exchanged via ioctlsRyusuke Konishi
Although some ioctls of nilfs2 exchange data in the form of indirectly referenced array, some of them lack size check on the array elements. This inserts the missing checks and rejects requests if data of ioctl does not have a valid format. We usually don't have to check size of structures that we associated with ioctl commands because the size is tested implicitly for identifying ioctl command; the checks this patch adds are for the cases where the implicit check is not applied. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
