path: root/fs/nilfs2/page.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-14nilfs2: fix various typos in commentsRyusuke Konishi
This fixes various typos I found in comments of nilfs2. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-05-10nilfs2: ensure to clear dirty state when deleting metadata file blockRyusuke Konishi
This would fix the following failure during GC: nilfs_cpfile_delete_checkpoints: cannot delete block NILFS: GC failed during preparation: cannot delete checkpoints: err=-2 The problem was caused by a break in state consistency between page cache and btree; the above block was removed from the btree but the page buffering the block was remaining in the page cache in dirty state. This resolves the inconsistency by ensuring to clear dirty state of the page buffering the deleted block. Reported-by: David Arendt <admin@prnet.org> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-04-07nilfs2: replace BUG_ON and BUG calls triggerable from ioctlRyusuke Konishi
Pekka Enberg advised me: > It would be nice if BUG(), BUG_ON(), and panic() calls would be > converted to proper error handling using WARN_ON() calls. The BUG() > call in nilfs_cpfile_delete_checkpoints(), for example, looks to be > triggerable from user-space via the ioctl() system call. This will follow the comment and keep them to a minimum. Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07nilfs2: buffer and page operationsRyusuke Konishi
This adds common routines for buffer/page operations used in B-tree node caches, meta data files, or segment constructor (log writer). NILFS uses copy functions for buffers and pages due to the following reasons: 1) Relocation required for COW Since NILFS changes address of on-disk blocks, moving buffers in page cache is needed for the buffers which are not addressed by a file offset. If buffer size is smaller than page size, this involves partial copy of pages. 2) Freezing mmapped pages NILFS calculates checksums for each log to ensure its validity. If page data changes after the checksum calculation, this validity check will not work correctly. To avoid this failure for mmaped pages, NILFS freezes their data by copying. 3) Copy-on-write for DAT pages NILFS makes clones of DAT page caches in a copy-on-write manner during GC processes, and this ensures atomicity and consistency of the DAT in the transient state. In addition, NILFS uses two obsolete functions, nilfs_mark_buffer_dirty() and nilfs_clear_page_dirty() respectively. * nilfs_mark_buffer_dirty() was required to avoid NULL pointer dereference faults: Since the page cache of B-tree node pages or data page cache of pseudo inodes does not have a valid mapping->host, calling mark_buffer_dirty() for their buffers causes the fault; it calls __mark_inode_dirty(NULL) through __set_page_dirty(). * nilfs_clear_page_dirty() was needed in the two cases: 1) For B-tree node pages and data pages of the dat/gcdat, NILFS2 clears page dirty flags when it copies back pages from the cloned cache (gcdat->{i_mapping,i_btnode_cache}) to its original cache (dat->{i_mapping,i_btnode_cache}). 2) Some B-tree operations like insertion or deletion may dispose buffers in dirty state, and this needs to cancel the dirty state of their pages. clear_page_dirty_for_io() caused faults because it does not clear the dirty tag on the page cache. Signed-off-by: Seiji Kihara <kihara.seiji@lab.ntt.co.jp> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
