path: root/fs/nilfs2/file.c
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-10-01const: constify remaining file_operationsAlexey Dobriyan
[akpm@linux-foundation.org: fix KVM] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: mark remaining inode_operations as constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07nilfs2: use unlocked_ioctlRyusuke Konishi
Pekka Enberg suggested converting ->ioctl operations to use ->unlocked_ioctl to avoid BKL. The conversion was verified to be safe, so I will take it on this occasion. Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07nilfs2: remove compat ioctl codeRyusuke Konishi
This removes compat code from the nilfs ioctls and applies the same function for both .ioctl and .compat_ioctl file operations. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07nilfs2: fix missed-sync issue for do_sync_mapping_range()Ryusuke Konishi
Chris Mason pointed out that there is a missed sync issue in nilfs_writepages(): On Wed, 17 Dec 2008 21:52:55 -0500, Chris Mason wrote: > It looks like nilfs_writepage ignores WB_SYNC_NONE, which is used by > do_sync_mapping_range(). where WB_SYNC_NONE in do_sync_mapping_range() was replaced with WB_SYNC_ALL by Nick's patch (commit: ee53a891f47444c53318b98dac947ede963db400). This fixes the problem by letting nilfs_writepages() write out the log of file data within the range if sync_mode is WB_SYNC_ALL. This involves removal of nilfs_file_aio_write() which was previously needed to ensure O_SYNC sync writes. Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07nilfs2: segment constructorRyusuke Konishi
This adds the segment constructor (also called log writer). The segment constructor collects dirty buffers for every dirty inode, makes summaries of the buffers, assigns disk block addresses to the buffers, and then submits BIOs for the buffers. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07nilfs2: file operationsRyusuke Konishi
This adds primitives for regular file handling. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
