[ Upstream commit 99bbf6ecc694dfe0b026e15359c5aa2a60b97a93 ]
consider the sequence of commands:
mkdir -p /import/nfs /import/bind /import/etc
mount --bind / /import/bind
mount --make-private /import/bind
mount --bind /import/etc /import/bind/etc
exportfs -o rw,no_root_squash,crossmnt,async,no_subtree_check localhost:/
mount -o vers=4 localhost:/ /import/nfs
ls -l /import/nfs/etc
You would not expect this to report a stale file handle.
Yet it does.
The manipulations under /import/bind cause the dentry for
/etc to get the DCACHE_MOUNTED flag set, even though nothing
is mounted on /etc. This causes nfsd to call
nfsd_cross_mnt() even though there is no mountpoint. So an
upcall to mountd for "/etc" is performed.
The 'crossmnt' flag on the export of / causes mountd to
report that /etc is exported as it is a descendant of /. It
assumes the kernel wouldn't ask about something that wasn't
a mountpoint. The filehandle returned identifies the
filesystem and the inode number of /etc.
When this filehandle is presented to rpc.mountd, via
"nfsd.fh", the inode cannot be found associated with any
name in /etc/exports, or with any mountpoint listed by
getmntent(). So rpc.mountd says the filehandle doesn't
exist. Hence ESTALE.
This is fixed by teaching nfsd not to trust DCACHE_MOUNTED
too much. It is just a hint, not a guarantee.
Change nfsd_mountpoint() to return '1' for a certain mountpoint,
'2' for a possible mountpoint, and 0 otherwise.
Then change nfsd_crossmnt() to check if follow_down()
actually found a mountpount and, if not, to avoid performing
a lookup if the location is not known to certainly require
an export-point.
Signed-off-by: NeilBrown <neilb@suse.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 783112f7401ff449d979530209b3f6c2594fdb4e upstream.
Both the NFS protocols and the Linux VFS use a setattr operation with a
bitmap of attributes to set to set various file attributes including the
file size and the uid/gid.
The Linux syscalls never mix size updates with unrelated updates like
the uid/gid, and some file systems like XFS and GFS2 rely on the fact
that truncates don't update random other attributes, and many other file
systems handle the case but do not update the other attributes in the
same transaction. NFSD on the other hand passes the attributes it gets
on the wire more or less directly through to the VFS, leading to updates
the file systems don't expect. XFS at least has an assert on the
allowed attributes, which caught an unusual NFS client setting the size
and group at the same time.
To handle this issue properly this splits the notify_change call in
nfsd_setattr into two separate ones.
Tested-by: Chuck Lever <chuck.lever@oracle.com>
commit 758e99fefe1d9230111296956335cd35995c0eaf upstream.
Simplify exit paths, size_change use.
I only implemented the sync version of this call, since it's the
easiest. I can simply call vfs_copy_range() and have the vfs do the
right thing for the filesystem being exported.
Signed-off-by: Anna Schumaker <bjschuma@netapp.com>
b44061d0b9 introduced a dentry ref counting bug. Previously we were
grabbing one ref to dchild in nfsd_create(), but with the creation of
nfsd_create_locked() we have a ref for dchild from the lookup in
nfsd_create(), and then another ref in nfsd_create_locked(). The ref
from the lookup in nfsd_create() is never dropped and results in
dentries still in use at unmount.
Signed-off-by: Josef Bacik <jbacik@fb.com>
Fixes: b44061d0b9 "nfsd: reorganize nfsd_create"
Reported-by: kernel test robot <xiaolong.ye@intel.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
We changed this around in f135af1041f ('nfsd: reorganize nfsd_create')
so "dchild" can't be an error pointer any more. Also, dchild can't be
NULL here (and dput would already handle this even if it was).
We need an fh_verify to make sure we at least have a dentry, but actual
permission checks happen later.
Minor cleanup, no change in behavior.
vfs_{create,mkdir,mknod} each begin with a call to may_create(), which
returns EEXIST if the object already exists.
This check is therefore unnecessary.
(In the NFSv2 case, nfsd_proc_create also has such a check. Contrary to
RFC 1094, our code seems to believe that a CREATE of an existing file
should succeed. I'm leaving that behavior alone.)
There's some odd logic in nfsd_create() that allows it to be called with
the parent directory either locked or unlocked. The only already-locked
caller is NFSv2's nfsd_proc_create(). It's less confusing to split out
the unlocked case into a separate function which the NFSv2 code can call
directly.
Also fix some comments while we're here.
Create and other nfsd ops generally assume we can call lookup_one_len on
inodes with S_IFDIR set. Al says that this assumption isn't true in
general, though it should be for the filesystem objects nfsd sees.
Add a check just to make sure our assumption isn't violated.
Remove a couple checks for i_op->lookup in create code.
lookup_one_len already has this check.
The only effect of this patch is to return access instead of perm in the
0-length-filename case. I actually prefer nfserr_perm (or _inval?), but
I doubt anyone cares.
The isdotent check seems redundant too, but I worry that some client
might actually care about that strange nfserr_exist error.
When doing a create (mkdir/mknod) on a name, it's worth
checking the name exists first before returning EACCES in case
the directory is not writeable by the user.
This makes return values on the client more consistent
regardless of whenever the entry there is cached in the local
cache or not.
Another positive side effect is certain programs only expect
EEXIST in that case even despite POSIX allowing any valid
error to be returned.
Signed-off-by: Oleg Drokin <green@linuxhacker.ru>
This way we can set kiocb flags also from the sync read/write path for
the read_iter/write_iter operations. For now there is no way to pass
flags to plain read/write operations as there is no real need for that,
and all flags passed are explicitly rejected for these files.
Signed-off-by: Milosz Tanski <milosz@adfin.com>
[hch: rebased on top of my kiocb changes]
Reviewed-by: Stephen Bates <stephen.bates@pmcs.com>
Tested-by: Stephen Bates <stephen.bates@pmcs.com>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
Pull nfsd updates from Bruce Fields:
"Smaller bugfixes and cleanup, including a fix for a failures of
kerberized NFSv4.1 mounts, and Scott Mayhew's work addressing ACK
storms that can affect some high-availability NFS setups"
* tag 'nfsd-4.5' of git://linux-nfs.org/~bfields/linux:
nfsd: add new io class tracepoint
nfsd: give up on CB_LAYOUTRECALLs after two lease periods
nfsd: Fix nfsd leaks sunrpc module references
lockd: constify nlmsvc_binding structure
lockd: use to_delayed_work
nfsd: use to_delayed_work
Revert "svcrdma: Do not send XDR roundup bytes for a write chunk"
lockd: Register callbacks on the inetaddr_chain and inet6addr_chain
nfsd: Register callbacks on the inetaddr_chain and inet6addr_chain
sunrpc: Add a function to close temporary transports immediately
nfsd: don't base cl_cb_status on stale information
nfsd4: fix gss-proxy 4.1 mounts for some AD principals
nfsd: fix unlikely NULL deref in mach_creds_match
nfsd: minor consolidation of mach_cred handling code
nfsd: helper for dup of possibly NULL string
svcrpc: move some initialization to common code
nfsd: fix a warning message
nfsd: constify nfsd4_callback_ops structure
nfsd: recover: constify nfsd4_client_tracking_ops structures
Add some new tracepoints in the nfsd read/write codepaths. The idea
is that this will give us the ability to measure how long each phase of
a read or write operation takes.
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
Pull misc vfs updates from Al Viro:
"All kinds of stuff. That probably should've been 5 or 6 separate
branches, but by the time I'd realized how large and mixed that bag
had become it had been too close to -final to play with rebasing.
Some fs/namei.c cleanups there, memdup_user_nul() introduction and
switching open-coded instances, burying long-dead code, whack-a-mole
of various kinds, several new helpers for ->llseek(), assorted
cleanups and fixes from various people, etc.
One piece probably deserves special mention - Neil's
lookup_one_len_unlocked(). Similar to lookup_one_len(), but gets
called without ->i_mutex and tries to avoid ever taking it. That, of
course, means that it's not useful for any directory modifications,
but things like getting inode attributes in nfds readdirplus are fine
with that. I really should've asked for moratorium on lookup-related
changes this cycle, but since I hadn't done that early enough... I
*am* asking for that for the coming cycle, though - I'm going to try
and get conversion of i_mutex to rwsem with ->lookup() done under lock
taken shared.
There will be a patch closer to the end of the window, along the lines
of the one Linus had posted last May - mechanical conversion of
->i_mutex accesses to inode_lock()/inode_unlock()/inode_trylock()/
inode_is_locked()/inode_lock_nested(). To quote Linus back then:
| This is an automated patch using
| sed 's/mutex_lock(&\(.*\)->i_mutex)/inode_lock(\1)/'
| sed 's/mutex_unlock(&\(.*\)->i_mutex)/inode_unlock(\1)/'
| sed 's/mutex_lock_nested(&\(.*\)->i_mutex,[ ]*I_MUTEX_\([A-Z0-9_]*\))/inode_lock_nested(\1, I_MUTEX_\2)/'
| sed 's/mutex_is_locked(&\(.*\)->i_mutex)/inode_is_locked(\1)/'
| sed 's/mutex_trylock(&\(.*\)->i_mutex)/inode_trylock(\1)/'
| with a very few manual fixups
I'm going to send that once the ->i_mutex-affecting stuff in -next
gets mostly merged (or when Linus says he's about to stop taking
merges)"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
nfsd: don't hold i_mutex over userspace upcalls
fs:affs:Replace time_t with time64_t
fs/9p: use fscache mutex rather than spinlock
proc: add a reschedule point in proc_readfd_common()
logfs: constify logfs_block_ops structures
fcntl: allow to set O_DIRECT flag on pipe
fs: __generic_file_splice_read retry lookup on AOP_TRUNCATED_PAGE
fs: xattr: Use kvfree()
[s390] page_to_phys() always returns a multiple of PAGE_SIZE
nbd: use ->compat_ioctl()
fs: use block_device name vsprintf helper
lib/vsprintf: add %*pg format specifier
fs: use gendisk->disk_name where possible
poll: plug an unused argument to do_poll
amdkfd: don't open-code memdup_user()
cdrom: don't open-code memdup_user()
rsxx: don't open-code memdup_user()
mtip32xx: don't open-code memdup_user()
[um] mconsole: don't open-code memdup_user_nul()
[um] hostaudio: don't open-code memdup_user()
We need information about exports when crossing mountpoints during
lookup or NFSv4 readdir. If we don't already have that information
cached, we may have to ask (and wait for) rpc.mountd.
In both cases we currently hold the i_mutex on the parent of the
directory we're asking rpc.mountd about. We've seen situations where
rpc.mountd performs some operation on that directory that tries to take
the i_mutex again, resulting in deadlock.
With some care, we may be able to avoid that in rpc.mountd. But it
seems better just to avoid holding a mutex while waiting on userspace.
It appears that lookup_one_len is pretty much the only operation that
needs the i_mutex. So we could just drop the i_mutex elsewhere and do
something like
mutex_lock()
lookup_one_len()
mutex_unlock()
In many cases though the lookup would have been cached and not required
the i_mutex, so it's more efficient to create a lookup_one_len() variant
that only takes the i_mutex when necessary.
Signed-off-by: NeilBrown <neilb@suse.de>
This is basically a remote version of the btrfs CLONE operation,
so the implementation is fairly trivial. Made even more trivial
by stealing the XDR code and general framework Anna Schumaker's
COPY prototype.
Acked-by: J. Bruce Fields <bfields@fieldses.org>
...just for clarity.
According to rfc5661 18.16.4,
"If EXCLUSIVE4_1 was used, the client determines the attributes
used for the verifier by comparing attrset with cva_attrs.attrmask;"
So, EXCLUSIVE4_1 also needs those bitmask used to store the verifier.
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
This patch changes nfs4_preprocess_stateid_op so it always returns
a valid struct file if it has been asked for that. For that we
now allocate a temporary struct file for special stateids, and check
permissions if we got the file structure from the stateid. This
ensures that all callers will get their handling of special stateids
right, and avoids code duplication.
There is a little wart in here because the read code needs to know
if we allocated a file structure so that it can copy around the
read-ahead parameters. In the long run we should probably aim to
cache full file structures used with special stateids instead.
Refactor the raparam hash helpers to just deal with the raparms,
and keep opening/closing files separate from that.
NFSv2 can set the atime and/or mtime of a file to specific timestamps but not
to the server's current time. To implement the equivalent of utimes("file",
NULL), it uses a heuristic.
NFSv3 and later do support setting the atime and/or mtime to the server's
current time directly. The NFSv2 heuristic is still enabled, and causes
timestamps to be set wrong sometimes.
Fix this by moving the heuristic into the NFSv2 specific code. We can leave it
out of the create code path: the owner can always set timestamps arbitrarily,
and the workaround would never trigger.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
that's the bulk of filesystem drivers dealing with inodes of their own
Convert the following where appropriate:
(1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry).
(2) S_ISREG(dentry->d_inode) to d_is_reg(dentry).
(3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more
complicated than it appears as some calls should be converted to
d_can_lookup() instead. The difference is whether the directory in
question is a real dir with a ->lookup op or whether it's a fake dir with
a ->d_automount op.
In some circumstances, we can subsume checks for dentry->d_inode not being
NULL into this, provided we the code isn't in a filesystem that expects
d_inode to be NULL if the dirent really *is* negative (ie. if we're going to
use d_inode() rather than d_backing_inode() to get the inode pointer).
Note that the dentry type field may be set to something other than
DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS
manages the fall-through from a negative dentry to a lower layer. In such a
case, the dentry type of the negative union dentry is set to the same as the
type of the lower dentry.
However, if you know d_inode is not NULL at the call site, then you can use
the d_is_xxx() functions even in a filesystem.
There is one further complication: a 0,0 chardev dentry may be labelled
DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was
intended for special directory entry types that don't have attached inodes.
The following perl+coccinelle script was used:
use strict;
my @callers;
open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') ||
die "Can't grep for S_ISDIR and co. callers";
@callers = <$fd>;
close($fd);
unless (@callers) {
print "No matches\n";
exit(0);
my @cocci = (
'expression E;',
'- S_ISLNK(E->d_inode->i_mode)',
'+ d_is_symlink(E)',
'expression E;',
'- S_ISDIR(E->d_inode->i_mode)',
'+ d_is_dir(E)',
'expression E;',
'- S_ISREG(E->d_inode->i_mode)',
'+ d_is_reg(E)' );
my $coccifile = "tmp.sp.cocci";
open($fd, ">$coccifile") || die $coccifile;
print($fd "$_\n") || die $coccifile foreach (@cocci);
close($fd);
foreach my $file (@callers) {
chomp $file;
print "Processing ", $file, "\n";
system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 ||
die "spatch failed";
[AV: overlayfs parts skipped]
"A comparatively quieter cycle for nfsd this time, but still with two
larger changes:
- RPC server scalability improvements from Jeff Layton (using RCU
instead of a spinlock to find idle threads).
- server-side NFSv4.2 ALLOCATE/DEALLOCATE support from Anna
Schumaker, enabling fallocate on new clients"
* 'for-3.19' of git://linux-nfs.org/~bfields/linux: (32 commits)
nfsd4: fix xdr4 count of server in fs_location4
nfsd4: fix xdr4 inclusion of escaped char
sunrpc/cache: convert to use string_escape_str()
sunrpc: only call test_bit once in svc_xprt_received
fs: nfsd: Fix signedness bug in compare_blob
sunrpc: add some tracepoints around enqueue and dequeue of svc_xprt
sunrpc: convert to lockless lookup of queued server threads
sunrpc: fix potential races in pool_stats collection
sunrpc: add a rcu_head to svc_rqst and use kfree_rcu to free it
sunrpc: require svc_create callers to pass in meaningful shutdown routine
sunrpc: have svc_wake_up only deal with pool 0
sunrpc: convert sp_task_pending flag to use atomic bitops
sunrpc: move rq_cachetype field to better optimize space
sunrpc: move rq_splice_ok flag into rq_flags
sunrpc: move rq_dropme flag into rq_flags
sunrpc: move rq_usedeferral flag to rq_flags
sunrpc: move rq_local field to rq_flags
sunrpc: add a generic rq_flags field to svc_rqst and move rq_secure to it
nfsd: minor off by one checks in __write_versions()
sunrpc: release svc_pool_map reference when serv allocation fails
Signed-off-by: Jeff Layton <jlayton@primarydata.com>
The ALLOCATE operation is used to preallocate space in a file. I can do
this by using vfs_fallocate() to do the actual preallocation.
ALLOCATE only returns a status indicator, so we don't need to write a
special encode() function.
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
The vfs_fsync_range() call during write processing got the end of the
range off by one. The range is inclusive, not exclusive. The error has
nfsd sync more data than requested -- it's correct but unnecessary
overhead.
The call during commit processing is correct so I copied that pattern in
write processing. Maybe a helper would be nice but I kept it trivial.
This is untested. I found it while reviewing code for something else
entirely.
Signed-off-by: Zach Brown <zab@zabbo.net>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris.
Mostly ima, selinux, smack and key handling updates.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (65 commits)
integrity: do zero padding of the key id
KEYS: output last portion of fingerprint in /proc/keys
KEYS: strip 'id:' from ca_keyid
KEYS: use swapped SKID for performing partial matching
KEYS: Restore partial ID matching functionality for asymmetric keys
X.509: If available, use the raw subjKeyId to form the key description
KEYS: handle error code encoded in pointer
selinux: normalize audit log formatting
selinux: cleanup error reporting in selinux_nlmsg_perm()
KEYS: Check hex2bin()'s return when generating an asymmetric key ID
ima: detect violations for mmaped files
ima: fix race condition on ima_rdwr_violation_check and process_measurement
ima: added ima_policy_flag variable
ima: return an error code from ima_add_boot_aggregate()
ima: provide 'ima_appraise=log' kernel option
ima: move keyring initialization to ima_init()
PKCS#7: Handle PKCS#7 messages that contain no X.509 certs
PKCS#7: Better handling of unsupported crypto
KEYS: Overhaul key identification when searching for asymmetric keys
KEYS: Implement binary asymmetric key ID handling
This fixes a failure in xfstests generic/313 because nfs doesn't update
mtime on a truncate. The protocol requires this to be done implicity
for a size changing setattr.
Empty files and missing xattrs do not guarantee that a file was
just created. This patch passes FILE_CREATED flag to IMA to
reliably identify new files.
Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Cc: <stable@vger.kernel.org> 3.14+
Commit 2a7420c03e504 (nfsd: Ensure that nfsd_create_setattr commits
files to stable storage), added a couple of calls to commit_metadata,
but doesn't convert their return codes to __be32 in the appropriate
places.
Cc: Trond Myklebust <trond.myklebust@primarydata.com>
Since nfsd_create_setattr strips the mode from the struct iattr, it
is quite possible that it will optimise away the call to nfsd_setattr
altogether.
If this is the case, then we never call commit_metadata() on the
newly created file.
Also ensure that both nfsd_setattr() and nfsd_create_setattr() fail
when the call to commit_metadata fails.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Commit db2e747b1499 (vfs: remove mode parameter from vfs_symlink())
have remove mode parameter from vfs_symlink.
So that, iattr isn't needed by nfsd_symlink now, just remove it.
Currently nfsd_symlink has a weird hack to serve callers who don't
null-terminate symlink data: it looks ahead at the next byte to see if
it's zero, and copies it to a new buffer to null-terminate if not.
That means callers don't have to null-terminate, but they *do* have to
ensure that the byte following the end of the data is theirs to read.
That's a bit subtle, and the NFSv4 code actually got this wrong.
So let's just throw out that code and let callers pass null-terminated
strings; we've already fixed them to do that.
The callers expect a __be32 return and the functions they call return
__be32, so having these return int is just wrong. Also, nfsd_finish_read
can be made static.
Don't using cache_get besides export.h, using exp_get for export.
The splice and readv cases are actually quite different--for example the
former case ignores the array of vectors we build up for the latter.
It is probably clearer to separate the two cases entirely.
There's some code duplication between the split out encoders, but this
is only temporary and will be fixed by a later patch.
