path: root/fs/nfsd/nfsctl.c
2011-10-31fs: add module.h to files that were implicitly using itPaul Gortmaker
Some files were using the complete module.h infrastructure without actually including the header at all. Fix them up in advance so once the implicit presence is removed, we won't get failures like this: CC [M] fs/nfsd/nfssvc.o fs/nfsd/nfssvc.c: In function 'nfsd_create_serv': fs/nfsd/nfssvc.c:335: error: 'THIS_MODULE' undeclared (first use in this function) fs/nfsd/nfssvc.c:335: error: (Each undeclared identifier is reported only once fs/nfsd/nfssvc.c:335: error: for each function it appears in.) fs/nfsd/nfssvc.c: In function 'nfsd': fs/nfsd/nfssvc.c:555: error: implicit declaration of function 'module_put_and_exit' make[3]: *** [fs/nfsd/nfssvc.o] Error 1 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-31nfsd: remove include/linux/nfsd/syscall.hJ. Bruce Fields
We don't need this any more. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-15nfsd: Remove deprecated nfsctl system call and related code.NeilBrown
As promised in feature-removal-schedule.txt it is time to remove the nfsctl system call. Userspace has perferred to not use this call throughout 2.6 and it has been excluded in the default configuration since 2.6.36 (9 months ago). So this patch removes all the code that was being compiled out. There are still references to sys_nfsctl in various arch systemcall tables and related code. These should be cleaned out too, probably in the next merge window. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-06-06nfsd: fix dependency of nfsd on auth_rpcgssJ. Bruce Fields
Commit b0b0c0a26e84 "nfsd: add proc file listing kernel's gss_krb5 enctypes" added an nunnecessary dependency of nfsd on the auth_rpcgss module. It's a little ad hoc, but since the only piece of information nfsd needs from rpcsec_gss_krb5 is a single static string, one solution is just to share it with an include file. Cc: stable@kernel.org Reported-by: Michael Guntsche <mike@it-loops.com> Cc: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-03-14nfsd: fix compile errorJ. Bruce Fields
"fs/built-in.o: In function `supported_enctypes_show': nfsctl.c:(.text+0x7beb0): undefined reference to `gss_mech_get_by_name' nfsctl.c:(.text+0x7bebc): undefined reference to `gss_mech_put' " Reported-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-03-07nfsd: add proc file listing kernel's gss_krb5 enctypesKevin Coffman
Add a new proc file which lists the encryption types supported by the kernel's gss_krb5 code. Newer MIT Kerberos libraries support the assertion of acceptor subkeys. This enctype information allows user-land (svcgssd) to request that the Kerberos libraries limit the encryption types that it uses when generating the subkeys. Signed-off-by: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-04nfsd4: move idmap and acl header files into fs/nfsdJ. Bruce Fields
These are internal nfsd interfaces. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-12-17nfs: add missed CONFIG_NFSD_DEPRECATEDbookjovi@gmail.com
these pieces of code only make sense when CONFIG_NFSD_DEPRECATED enabled Signed-off-by: Jovi Zhang <bookjovi@gmail.com> fs/nfsd/nfsctl.c | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-) Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-10-29convert get_sb_single() usersAl Viro
2010-10-26Merge branch 'for-2.6.37' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.37' of git://linux-nfs.org/~bfields/linux: (99 commits) svcrpc: svc_tcp_sendto XPT_DEAD check is redundant svcrpc: no need for XPT_DEAD check in svc_xprt_enqueue svcrpc: assume svc_delete_xprt() called only once svcrpc: never clear XPT_BUSY on dead xprt nfsd4: fix connection allocation in sequence() nfsd4: only require krb5 principal for NFSv4.0 callbacks nfsd4: move minorversion to client nfsd4: delay session removal till free_client nfsd4: separate callback change and callback probe nfsd4: callback program number is per-session nfsd4: track backchannel connections nfsd4: confirm only on succesful create_session nfsd4: make backchannel sequence number per-session nfsd4: use client pointer to backchannel session nfsd4: move callback setup into session init code nfsd4: don't cache seq_misordered replies SUNRPC: Properly initialize sock_xprt.srcaddr in all cases SUNRPC: Use conventional switch statement when reclassifying sockets sunrpc/xprtrdma: clean up workqueue usage sunrpc: Turn list_for_each-s into the ..._entry-s ... Fix up trivial conflicts (two different deprecation notices added in separate branches) in Documentation/feature-removal-schedule.txt
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-01sunrpc: Add net argument to svc_create_xprtPavel Emelyanov
Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-27sunrpc: Add net to pure API callsPavel Emelyanov
There are two calls that operate on ip_map_cache and are directly called from the nfsd code. Other places will be handled in a different way. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-23nfsd: Export get_task_comm for nfsdPavel Emelyanov
The git://linux-nfs.org/~bfields/linux.git nfsd-next branch doesn't compile when nfsd is a module with the following error: ERROR: "get_task_comm" [fs/nfsd/nfsd.ko] undefined! Replace the get_task_comm call with direct comm access, which is safe for current. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-22nfsd: allow deprecated interface to be compiled out.NeilBrown
Add CONFIG_NFSD_DEPRECATED, default to y. Only include deprecated interface if this is defined. This allows distros to remove this interface before the official removal, and allows developers to test without it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-22nfsd: formally deprecate legacy nfsd syscall interfaceNeilBrown
The syscall interface is has been replaced by a more flexible interface since 2.6.0. It is time to work towards discarding the old interface. So add a entry in feature-removal-schedule.txt and print a warning when the interface is used. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-08-06nfsd: don't allow setting maxblksize after svc createdJ. Bruce Fields
It's harmless to set this after the server is created, but also ineffective, since the value is only used at the time of svc_create_pooled(). So fail the attempt, in keeping with the pattern set by write_versions, write_{lease,grace}time and write_recoverydir. (This could break userspace that tried to write to nfsd/max_block_size between setting up sockets and starting the server. However, such code wouldn't have worked anyway, and I don't know of any examples--rpc.nfsd in nfs-utils, probably the only user of the interface, doesn't do that.) Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-07-29gcc-4.6: nfsd: fix initialized but not read warningsAndi Kleen
Fixes at least one real minor bug: the nfs4 recovery dir sysctl would not return its status properly. Also I finished Al's 1e41568d7378d ("Take ima_path_check() in nfsd past dentry_open() in nfsd_open()") commit, it moved the IMA code, but left the old path initializer in there. The rest is just dead code removed I think, although I was not fully sure about the "is_borc" stuff. Some more review would be still good. Found by gcc 4.6's new warnings. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-07-23nfsd: just keep single lockd reference for nfsdJeff Layton
Right now, nfsd keeps a lockd reference for each socket that it has open. This is unnecessary and complicates the error handling on startup and shutdown. Change it to just do a lockd_up when starting the first nfsd thread just do a single lockd_down when taking down the last nfsd thread. Because of the strange way the sv_count is handled this requires an extra flag to tell whether the nfsd_serv holds a reference for lockd or not. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-07-23nfsd: fix error handling in __write_ports_addxprtJeff Layton
__write_ports_addxprt calls nfsd_create_serv. That increases the refcount of nfsd_serv (which is tracked in sv_nrthreads). The service only decrements the thread count on error, not on success like __write_ports_addfd does, so using this interface leaves the nfsd thread count high. Fix this by having this function call svc_destroy() on error to release the reference (and possibly to tear down the service) and simply decrement the refcount without tearing down the service on success. This makes the sv_threads handling work basically the same in both __write_ports_addxprt and __write_ports_addfd. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-07-23nfsd: fix error handling when starting nfsd with rpcbind downJeff Layton
The refcounting for nfsd is a little goofy. What happens is that we create the nfsd RPC service, attach sockets to it but don't actually start the threads until someone writes to the "threads" procfile. To do this, __write_ports_addfd will create the nfsd service and then will decrement the refcount when exiting but won't actually destroy the service. This is fine when there aren't errors, but when there are this can cause later attempts to start nfsd to fail. nfsd_serv will be set, and that causes __write_versions to return EBUSY. Fix this by calling svc_destroy on nfsd_serv when this function is going to return error. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-05-25kernel-wide: replace USHORT_MAX, SHORT_MAX and SHORT_MIN with USHRT_MAX, ↵Alexey Dobriyan
SHRT_MAX and SHRT_MIN - C99 knows about USHRT_MAX/SHRT_MAX/SHRT_MIN, not USHORT_MAX/SHORT_MAX/SHORT_MIN. - Make SHRT_MIN of type s16, not int, for consistency. [akpm@linux-foundation.org: fix drivers/dma/timb_dma.c] [akpm@linux-foundation.org: fix security/keys/keyring.c] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-04Merge commit 'v2.6.34-rc6'J. Bruce Fields
Conflicts: fs/nfsd/nfs4callback.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-06nfsd4: document lease/grace-period limitsJ. Bruce Fields
The current documentation here is out of date, and not quite right. (Future work: some user documentation would be useful.) Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-03-06nfsd4: allow setting grace period timeJ. Bruce Fields
Allow explicit configuration of the grace period time as well as the lease period time. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-03-06nfsd4: reshuffle lease-setting code to allow reuseJ. Bruce Fields
We'll soon allow setting the grace period, so we'll want to share this code. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-03-06nfsd4: remove unnecessary lease-setting functionJ. Bruce Fields
This is another layer of indirection that doesn't really buy us anything. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-03-06nfsd4: simplify references to nfsd4 lease timeJ. Bruce Fields
Instead of accessing the lease time directly, some users call nfs4_lease_time(), and some a macro, NFSD_LEASE_TIME, defined as nfs4_lease_time(). Neither layer of indirection serves any purpose. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-01-27NFSD: Create PF_INET6 listener in write_portsChuck Lever
Try to create a PF_INET6 listener for NFSD, if IPv6 is enabled in the kernel. Make sure nfsd_serv's reference count is decreased if __write_ports_addxprt() failed to create a listener. See __write_ports_addfd(). Our current plan is to rely on rpc.nfsd to create appropriate IPv6 listeners when server-side NFS/IPv6 support is desired. Legacy behavior, via the write_threads or write_svc kernel APIs, will remain the same -- only IPv4 listeners are created. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> [bfields@citi.umich.edu: Move error-handling code to end] Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-01-26SUNRPC: NFS kernel APIs shouldn't return ENOENT for "transport not found"Chuck Lever
write_ports() converts svc_create_xprt()'s ENOENT error return to EPROTONOSUPPORT so that rpc.nfsd (in user space) can report an error message that makes sense. It turns out that several of the other kernel APIs rpc.nfsd use can also return ENOENT from svc_create_xprt(), by way of lockd_up(). On the client side, an NFSv2 or NFSv3 mount request can also return the result of lockd_up(). This error may also be returned during an NFSv4 mount request, since the NFSv4 callback service uses svc_create_xprt() to create the callback listener. An ENOENT error return results in a confusing error message from the mount command. Let's have svc_create_xprt() return EPROTONOSUPPORT instead of ENOENT. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-15nfsd: remove pointless paths in file headersJ. Bruce Fields
The new .h files have paths at the top that are now out of date. While we're here, just remove all of those from fs/nfsd; they never served any purpose. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-14nfsd: new interface to advertise export featuresJ. Bruce Fields
Soon we will add the new V4ROOT flag, and allow the INSECURE flag to vary by pseudoflavor. It would be useful for nfs-utils (for example, for improved exportfs error reporting) to be able to know when this happens. Use this new interface for that purpose. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-14nfsd: Move private headers to source directoryBoaz Harrosh
Lots of include/linux/nfsd/* headers are only used by nfsd module. Move them to the source directory Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-14nfsd: Source files #include cleanupsBoaz Harrosh
Now that the headers are fixed and carry their own wait, all fs/nfsd/ source files can include a minimal set of headers. and still compile just fine. This patch should improve the compilation speed of the nfsd module. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-10-01const: constify remaining file_operationsAlexey Dobriyan
[akpm@linux-foundation.org: fix KVM] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-25knfsd: Replace lock_kernel with a mutex in nfsd pool stats.Ryusei Yamaguchi
lock_kernel() in knfsd was replaced with a mutex. The later commit 03cf6c9f49a8fea953d38648d016e3f46e814991 ("knfsd: add file to export stats about nfsd pools") did not follow that change. This patch fixes the issue. Also move the get and put of nfsd_serv to the open and close methods (instead of start and stop methods) to allow atomic check and increment of reference count in the open method (where we can still return an error). Signed-off-by: Ryusei Yamaguchi <mandel59@gmail.com> Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Cc: Greg Banks <gnb@fmeh.org> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-08-21Merge branch 'nfs-for-2.6.32' of ↵J. Bruce Fields
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 into for-2.6.32-incoming Conflicts: net/sunrpc/cache.c
2009-08-09NFSD: Support IPv6 addresses in write_failover_ip()Chuck Lever
In write_failover_ip(), replace the sscanf() with a call to the common sunrpc.ko presentation address parser. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-07-28nfsd: minor write_pool_threads exit cleanupJ. Bruce Fields
2009-07-28Fix memory leak in write_pool_threadsEric Sesterhenn
kmemleak produces the following warning unreferenced object 0xc9ec02a0 (size 8): comm "cat", pid 19048, jiffies 730243 backtrace: [<c01bf970>] create_object+0x100/0x240 [<c01bfadb>] kmemleak_alloc+0x2b/0x60 [<c01bcd4b>] __kmalloc+0x14b/0x270 [<c02fd027>] write_pool_threads+0x87/0x1d0 [<c02fcc08>] nfsctl_transaction_write+0x58/0x70 [<c02fcc6f>] nfsctl_transaction_read+0x4f/0x60 [<c01c2574>] vfs_read+0x94/0x150 [<c01c297d>] sys_read+0x3d/0x70 [<c0102d6b>] sysenter_do_call+0x12/0x32 [<ffffffff>] 0xffffffff write_pool_threads() only frees nthreads on error paths, in the success case we leak it. Signed-off-by: Eric Sesterhenn <eric.sesterhenn@lsexperts.de> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18nfsd: don't take nfsd_mutex twice when setting number of threads.NeilBrown
Currently when we write a number to 'threads' in nfsdfs, we take the nfsd_mutex, update the number of threads, then take the mutex again to read the number of threads. Mostly this isn't a big deal. However if we are write '0', and portmap happens to be dead, then we can get unpredictable behaviour. If the nfsd threads all got killed quickly and the last thread is waiting for portmap to respond, then the second time we take the mutex we will block waiting for the last thread. However if the nfsd threads didn't die quite that fast, then there will be no contention when we try to take the mutex again. Unpredictability isn't fun, and waiting for the last thread to exit is pointless, so avoid taking the lock twice. To achieve this, get nfsd_svc return a non-negative number of active threads when not returning a negative error. Signed-off-by: NeilBrown <neilb@suse.de>
2009-04-28NFSD: Stricter buffer size checking in fs/nfsd/nfsctl.cChuck Lever
Clean up: For consistency, handle output buffer size checking in a other nfsctl functions the same way it's done for write_versions(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28NFSD: Stricter buffer size checking in write_versions()Chuck Lever
While it's not likely today that there are enough NFS versions to overflow the output buffer in write_versions(), we should be more careful about detecting the end of the buffer. The number of NFS versions will only increase as NFSv4 minor versions are added. Note that this API doesn't behave the same as portlist. Here we attempt to display as many versions as will fit in the buffer, and do not provide any indication that an overflow would have occurred. I don't have any good rationale for that. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28NFSD: Stricter buffer size checking in write_recoverydir()Chuck Lever
While it's not likely a pathname will be longer than SIMPLE_TRANSACTION_SIZE, we should be more careful about just plopping it into the output buffer without bounds checking. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28SUNRPC: pass buffer size to svc_sock_names()Chuck Lever
Adjust the synopsis of svc_sock_names() to pass in the size of the output buffer. Add a documenting comment. This is a cosmetic change for now. A subsequent patch will make sure the buffer length is passed to one_sock_name(), where the length will actually be useful. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28SUNRPC: pass buffer size to svc_addsock()Chuck Lever
Adjust the synopsis of svc_addsock() to pass in the size of the output buffer. Add a documenting comment. This is a cosmetic change for now. A subsequent patch will make sure the buffer length is passed to one_sock_name(), where the length will actually be useful. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28NFSD: Prevent a buffer overflow in svc_xprt_names()Chuck Lever
The svc_xprt_names() function can overflow its buffer if it's so near the end of the passed in buffer that the "name too long" string still doesn't fit. Of course, it could never tell if it was near the end of the passed in buffer, since its only caller passes in zero as the buffer length. Let's make this API a little safer. Change svc_xprt_names() so it *always* checks for a buffer overflow, and change its only caller to pass in the correct buffer length. If svc_xprt_names() does overflow its buffer, it now fails with an ENAMETOOLONG errno, instead of trying to write a message at the end of the buffer. I don't like this much, but I can't figure out a clean way that's always safe to return some of the names, *and* an indication that the buffer was not long enough. The displayed error when doing a 'cat /proc/fs/nfsd/portlist' is "File name too long". Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28NFSD: move lockd_up() before svc_addsock()Chuck Lever
Clean up. A couple of years ago, a series of commits, finishing with commit 5680c446, swapped the order of the lockd_up() and svc_addsock() calls in __write_ports(). At that time lockd_up() needed to know the transport protocol of the passed-in socket to start a listener on the same transport protocol. These days, lockd_up() doesn't take a protocol argument; it always starts both a UDP and TCP listener. It's now more straightforward to try the lockd_up() first, then do a lockd_down() if the svc_addsock() fails. Careful review of this code shows that the svc_sock_names() call is used only to close the just-opened socket in case lockd_up() fails. So it is no longer needed if lockd_up() is done first. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
