path: root/fs/nfsd/nfsctl.c
2009-12-15nfsd: remove pointless paths in file headersJ. Bruce Fields
The new .h files have paths at the top that are now out of date. While we're here, just remove all of those from fs/nfsd; they never served any purpose. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-14nfsd: new interface to advertise export featuresJ. Bruce Fields
Soon we will add the new V4ROOT flag, and allow the INSECURE flag to vary by pseudoflavor. It would be useful for nfs-utils (for example, for improved exportfs error reporting) to be able to know when this happens. Use this new interface for that purpose. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-14nfsd: Move private headers to source directoryBoaz Harrosh
Lots of include/linux/nfsd/* headers are only used by nfsd module. Move them to the source directory Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-14nfsd: Source files #include cleanupsBoaz Harrosh
Now that the headers are fixed and carry their own wait, all fs/nfsd/ source files can include a minimal set of headers. and still compile just fine. This patch should improve the compilation speed of the nfsd module. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-10-01const: constify remaining file_operationsAlexey Dobriyan
[akpm@linux-foundation.org: fix KVM] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-25knfsd: Replace lock_kernel with a mutex in nfsd pool stats.Ryusei Yamaguchi
lock_kernel() in knfsd was replaced with a mutex. The later commit 03cf6c9f49a8fea953d38648d016e3f46e814991 ("knfsd: add file to export stats about nfsd pools") did not follow that change. This patch fixes the issue. Also move the get and put of nfsd_serv to the open and close methods (instead of start and stop methods) to allow atomic check and increment of reference count in the open method (where we can still return an error). Signed-off-by: Ryusei Yamaguchi <mandel59@gmail.com> Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Cc: Greg Banks <gnb@fmeh.org> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-08-21Merge branch 'nfs-for-2.6.32' of ↵J. Bruce Fields
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 into for-2.6.32-incoming Conflicts: net/sunrpc/cache.c
2009-08-09NFSD: Support IPv6 addresses in write_failover_ip()Chuck Lever
In write_failover_ip(), replace the sscanf() with a call to the common sunrpc.ko presentation address parser. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-07-28nfsd: minor write_pool_threads exit cleanupJ. Bruce Fields
2009-07-28Fix memory leak in write_pool_threadsEric Sesterhenn
kmemleak produces the following warning unreferenced object 0xc9ec02a0 (size 8): comm "cat", pid 19048, jiffies 730243 backtrace: [<c01bf970>] create_object+0x100/0x240 [<c01bfadb>] kmemleak_alloc+0x2b/0x60 [<c01bcd4b>] __kmalloc+0x14b/0x270 [<c02fd027>] write_pool_threads+0x87/0x1d0 [<c02fcc08>] nfsctl_transaction_write+0x58/0x70 [<c02fcc6f>] nfsctl_transaction_read+0x4f/0x60 [<c01c2574>] vfs_read+0x94/0x150 [<c01c297d>] sys_read+0x3d/0x70 [<c0102d6b>] sysenter_do_call+0x12/0x32 [<ffffffff>] 0xffffffff write_pool_threads() only frees nthreads on error paths, in the success case we leak it. Signed-off-by: Eric Sesterhenn <eric.sesterhenn@lsexperts.de> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18nfsd: don't take nfsd_mutex twice when setting number of threads.NeilBrown
Currently when we write a number to 'threads' in nfsdfs, we take the nfsd_mutex, update the number of threads, then take the mutex again to read the number of threads. Mostly this isn't a big deal. However if we are write '0', and portmap happens to be dead, then we can get unpredictable behaviour. If the nfsd threads all got killed quickly and the last thread is waiting for portmap to respond, then the second time we take the mutex we will block waiting for the last thread. However if the nfsd threads didn't die quite that fast, then there will be no contention when we try to take the mutex again. Unpredictability isn't fun, and waiting for the last thread to exit is pointless, so avoid taking the lock twice. To achieve this, get nfsd_svc return a non-negative number of active threads when not returning a negative error. Signed-off-by: NeilBrown <neilb@suse.de>
2009-04-28NFSD: Stricter buffer size checking in fs/nfsd/nfsctl.cChuck Lever
Clean up: For consistency, handle output buffer size checking in a other nfsctl functions the same way it's done for write_versions(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28NFSD: Stricter buffer size checking in write_versions()Chuck Lever
While it's not likely today that there are enough NFS versions to overflow the output buffer in write_versions(), we should be more careful about detecting the end of the buffer. The number of NFS versions will only increase as NFSv4 minor versions are added. Note that this API doesn't behave the same as portlist. Here we attempt to display as many versions as will fit in the buffer, and do not provide any indication that an overflow would have occurred. I don't have any good rationale for that. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28NFSD: Stricter buffer size checking in write_recoverydir()Chuck Lever
While it's not likely a pathname will be longer than SIMPLE_TRANSACTION_SIZE, we should be more careful about just plopping it into the output buffer without bounds checking. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28SUNRPC: pass buffer size to svc_sock_names()Chuck Lever
Adjust the synopsis of svc_sock_names() to pass in the size of the output buffer. Add a documenting comment. This is a cosmetic change for now. A subsequent patch will make sure the buffer length is passed to one_sock_name(), where the length will actually be useful. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28SUNRPC: pass buffer size to svc_addsock()Chuck Lever
Adjust the synopsis of svc_addsock() to pass in the size of the output buffer. Add a documenting comment. This is a cosmetic change for now. A subsequent patch will make sure the buffer length is passed to one_sock_name(), where the length will actually be useful. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28NFSD: Prevent a buffer overflow in svc_xprt_names()Chuck Lever
The svc_xprt_names() function can overflow its buffer if it's so near the end of the passed in buffer that the "name too long" string still doesn't fit. Of course, it could never tell if it was near the end of the passed in buffer, since its only caller passes in zero as the buffer length. Let's make this API a little safer. Change svc_xprt_names() so it *always* checks for a buffer overflow, and change its only caller to pass in the correct buffer length. If svc_xprt_names() does overflow its buffer, it now fails with an ENAMETOOLONG errno, instead of trying to write a message at the end of the buffer. I don't like this much, but I can't figure out a clean way that's always safe to return some of the names, *and* an indication that the buffer was not long enough. The displayed error when doing a 'cat /proc/fs/nfsd/portlist' is "File name too long". Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28NFSD: move lockd_up() before svc_addsock()Chuck Lever
Clean up. A couple of years ago, a series of commits, finishing with commit 5680c446, swapped the order of the lockd_up() and svc_addsock() calls in __write_ports(). At that time lockd_up() needed to know the transport protocol of the passed-in socket to start a listener on the same transport protocol. These days, lockd_up() doesn't take a protocol argument; it always starts both a UDP and TCP listener. It's now more straightforward to try the lockd_up() first, then do a lockd_down() if the svc_addsock() fails. Careful review of this code shows that the svc_sock_names() call is used only to close the just-opened socket in case lockd_up() fails. So it is no longer needed if lockd_up() is done first. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28NFSD: Finish refactoring __write_ports()Chuck Lever
Clean up: Refactor transport name listing out of __write_ports() to make it easier to understand and maintain. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28NFSD: Note an additional requirement when passing TCP sockets to portlistChuck Lever
User space must call listen(3) on SOCK_STREAM sockets passed into /proc/fs/nfsd/portlist, otherwise that listener is ignored. Document this. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28NFSD: Refactor socket creation out of __write_ports()Chuck Lever
Clean up: Refactor the socket creation logic out of __write_ports() to make it easier to understand and maintain. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28NFSD: Refactor portlist socket closing into a helperChuck Lever
Clean up: Refactor the socket closing logic out of __write_ports() to make it easier to understand and maintain. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28NFSD: Refactor transport addition out of __write_ports()Chuck Lever
Clean up: Refactor transport addition out of __write_ports() to make it easier to understand and maintain. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-28NFSD: Refactor transport removal out of __write_ports()Chuck Lever
Clean up: Refactor transport removal out of __write_ports() to make it easier to understand and maintain. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-06Merge branch 'for-2.6.30' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.30' of git://linux-nfs.org/~bfields/linux: (81 commits) nfsd41: define nfsd4_set_statp as noop for !CONFIG_NFSD_V4 nfsd41: define NFSD_DRC_SIZE_SHIFT in set_max_drc nfsd41: Documentation/filesystems/nfs41-server.txt nfsd41: CREATE_EXCLUSIVE4_1 nfsd41: SUPPATTR_EXCLCREAT attribute nfsd41: support for 3-word long attribute bitmask nfsd: dynamically skip encoded fattr bitmap in _nfsd4_verify nfsd41: pass writable attrs mask to nfsd4_decode_fattr nfsd41: provide support for minor version 1 at rpc level nfsd41: control nfsv4.1 svc via /proc/fs/nfsd/versions nfsd41: add OPEN4_SHARE_ACCESS_WANT nfs4_stateid bmap nfsd41: access_valid nfsd41: clientid handling nfsd41: check encode size for sessions maxresponse cached nfsd41: stateid handling nfsd: pass nfsd4_compound_state* to nfs4_preprocess_{state,seq}id_op nfsd41: destroy_session operation nfsd41: non-page DRC for solo sequence responses nfsd41: Add a create session replay cache nfsd41: create_session operation ...
2009-04-03nfsd41: control nfsv4.1 svc via /proc/fs/nfsd/versionsBenny Halevy
Support enabling and disabling nfsv4.1 via /proc/fs/nfsd/versions by writing the strings "+4.1" or "-4.1" correspondingly. Use user mode nfs-utils (rpc.nfsd option) to enable. This will allow us to get rid of CONFIG_NFSD_V4_1 [nfsd41: disable support for minorversion by default] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-03-28SUNRPC: Change svc_create_xprt() to take a @family argumentChuck Lever
The sv_family field is going away. Pass a protocol family argument to svc_create_xprt() instead of extracting the family from the passed-in svc_serv struct. Again, as this is a listener socket and not an address, we make this new argument an "int" protocol family, instead of an "sa_family_t." Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28NFSD: If port value written to /proc/fs/nfsd/portlist is invalid, return EINVALChuck Lever
Make sure port value read from user space by write_ports is valid before passing it to svc_find_xprt(). If it wasn't, the writer would get ENOENT instead of EINVAL. Noticed-by: J. Bruce Fields <bfields@fieldses.org> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-18knfsd: add file to export stats about nfsd poolsGreg Banks
Add /proc/fs/nfsd/pool_stats to export to userspace various statistics about the operation of rpc server thread pools. This patch is based on a forward-ported version of knfsd-add-pool-thread-stats which has been shipping in the SGI "Enhanced NFS" product since 2006 and which was previously posted: http://article.gmane.org/gmane.linux.nfs/10375 It has also been updated thus: * moved EXPORT_SYMBOL() to near the function it exports * made the new struct struct seq_operations const * used SEQ_START_TOKEN instead of ((void *)1) * merged fix from SGI PV 990526 "sunrpc: use dprintk instead of printk in svc_pool_stats_*()" by Harshula Jayasuriya. * merged fix from SGI PV 964001 "Crash reading pool_stats before nfsds are started". Signed-off-by: Greg Banks <gnb@sgi.com> Signed-off-by: Harshula Jayasuriya <harshula@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NFSD: Add documenting comments for nfsctl interfaceChuck Lever
Document the NFSD sysctl interface laid out in fs/nfsd/nfsctl.c. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NFSD: Replace open-coded integer with macroChuck Lever
Clean up: Instead of open-coding 2049, use the NFS_PORT macro. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NFSD: Fix a handful of coding style issues in write_filehandle()Chuck Lever
Clean up: follow kernel coding style. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NFSD: clean up failover sysctl function namingChuck Lever
Clean up: Rename recently-added failover functions to match the naming convention in fs/nfsd/nfsctl.c. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-10-31fs: replace NIPQUAD()Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-23[PATCH] switch nfsd to kern_path()Al Viro
2008-10-04NLM: Remove unused argument from svc_addsock() functionChuck Lever
Clean up: The svc_addsock() function no longer uses its "proto" argument, so remove it. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-10-04NLM: Remove "proto" argument from lockd_up()Chuck Lever
Clean up: Now that lockd_up() starts listeners for both transports, the "proto" argument is no longer needed. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-07-26[PATCH] get rid of indirect users of namei.hAl Viro
fs.h needs path.h, not namei.h; nfs_fs.h doesn't need it at all. Several places in the tree needed direct include. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-15lockd: Pass "struct sockaddr *" to new failover-by-IP functionChuck Lever
Pass a more generic socket address type to nlmsvc_unlock_all_by_ip() to allow for future support of IPv6. Also provide additional sanity checking in failover_unlock_ip() when constructing the server's IP address. As an added bonus, provide clean kerneldoc comments on related NLM interfaces which were recently added. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-06-23knfsd: clean up nfsd filesystem interfacesJeff Layton
Several of the nfsd filesystem interfaces allow changes to parameters that don't have any effect on a running nfsd service. They are only ever checked when nfsd is started. This patch fixes it so that changes to those procfiles return -EBUSY if nfsd is already running to make it clear that changes on the fly don't work. The patch should also close some relatively harmless races between changing the info in those interfaces and starting nfsd, since these variables are being moved under the protection of the nfsd_mutex. Finally, the nfsv4recoverydir file always returns -EINVAL if read. This patch fixes it to return the recoverydir path as expected. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-06-23knfsd: Replace lock_kernel with a mutex for nfsd thread startup/shutdown ↵Neil Brown
locking. This removes the BKL from the RPC service creation codepath. The BKL really isn't adequate for this job since some of this info needs protection across sleeps. Also, add some comments to try and clarify how the locking should work and to make it clear that the BKL isn't necessary as long as there is adequate locking between tasks when touching the svc_serv fields. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-29nfsd: use proc_create to setup de->proc_fopsDenis V. Lunev
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-25lockd: unlock lockd locks held for a certain filesystemWendy Cheng
Add /proc/fs/nfsd/unlock_filesystem, which allows e.g.: shell> echo /mnt/sfs1 > /proc/fs/nfsd/unlock_filesystem so that a filesystem can be unmounted before allowing a peer nfsd to take over nfs service for the filesystem. Signed-off-by: S. Wendy Cheng <wcheng@redhat.com> Cc: Lon Hohberger <lhh@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> fs/lockd/svcsubs.c | 66 +++++++++++++++++++++++++++++++++++++++----- fs/nfsd/nfsctl.c | 65 +++++++++++++++++++++++++++++++++++++++++++ include/linux/lockd/lockd.h | 7 ++++ 3 files changed, 131 insertions(+), 7 deletions(-)
2008-04-25lockd: unlock lockd locks associated with a given server ipWendy Cheng
For high-availability NFS service, we generally need to be able to drop file locks held on the exported filesystem before moving clients to a new server. Currently the only way to do that is by shutting down lockd entirely, which is often undesireable (for example, if you want to continue exporting other filesystems). This patch allows the administrator to release all locks held by clients accessing the client through a given server ip address, by echoing that address to a new file, /proc/fs/nfsd/unlock_ip, as in: shell> echo 10.1.1.2 > /proc/fs/nfsd/unlock_ip The expected sequence of events can be: 1. Tear down the IP address 2. Unexport the path 3. Write IP to /proc/fs/nfsd/unlock_ip to unlock files 4. Signal peer to begin take-over. For now we only support IPv4 addresses and NFSv2/v3 (NFSv4 locks are not affected). Also, if unmounting the filesystem is required, we assume at step 3 that clients using the given server ip are the only clients holding locks on the given filesystem; otherwise, an additional patch is required to allow revoking all locks held by lockd on a given filesystem. Signed-off-by: S. Wendy Cheng <wcheng@redhat.com> Cc: Lon Hohberger <lhh@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> fs/lockd/svcsubs.c | 66 +++++++++++++++++++++++++++++++++++++++----- fs/nfsd/nfsctl.c | 65 +++++++++++++++++++++++++++++++++++++++++++ include/linux/lockd/lockd.h | 7 ++++ 3 files changed, 131 insertions(+), 7 deletions(-)
2008-04-23nfsd: fix sparse warningsHarvey Harrison
Add extern to nfsd/nfsd.h fs/nfsd/nfssvc.c:146:5: warning: symbol 'nfsd_nrthreads' was not declared. Should it be static? fs/nfsd/nfssvc.c:261:5: warning: symbol 'nfsd_nrpools' was not declared. Should it be static? fs/nfsd/nfssvc.c:269:5: warning: symbol 'nfsd_get_nrthreads' was not declared. Should it be static? fs/nfsd/nfssvc.c:281:5: warning: symbol 'nfsd_set_nrthreads' was not declared. Should it be static? fs/nfsd/export.c:1534:23: warning: symbol 'nfs_exports_op' was not declared. Should it be static? Add include of auth.h fs/nfsd/auth.c:27:5: warning: symbol 'nfsd_setuser' was not declared. Should it be static? Make static, move forward declaration closer to where it's needed. fs/nfsd/nfs4state.c:1877:1: warning: symbol 'laundromat_main' was not declared. Should it be static? Make static, forward declaration was already marked static. fs/nfsd/nfs4idmap.c:206:1: warning: symbol 'idtoname_parse' was not declared. Should it be static? fs/nfsd/vfs.c:1156:1: warning: symbol 'nfsd_create_setattr' was not declared. Should it be static? Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-23IPv6 support for NFS server export cachesAurélien Charbon
This adds IPv6 support to the interfaces that are used to express nfsd exports. All addressed are stored internally as IPv6; backwards compatibility is maintained using mapped addresses. Thanks to Bruce Fields, Brian Haley, Neil Brown and Hideaki Joshifuji for comments Signed-off-by: Aurelien Charbon <aurelien.charbon@bull.net> Cc: Neil Brown <neilb@suse.de> Cc: Brian Haley <brian.haley@hp.com> Cc: YOSHIFUJI Hideaki / 吉藤英明 <yoshfuji@linux-ipv6.org> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01nfsd: more careful input validation in nfsctl write methodsJ. Bruce Fields
Neil Brown points out that we're checking buf[size-1] in a couple places without first checking whether size is zero. Actually, given the implementation of simple_transaction_get(), buf[-1] is zero, so in both of these cases the subsequent check of the value of buf[size-1] will catch this case. But it seems fragile to depend on that, so add explicit checks for this case. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: NeilBrown <neilb@suse.de>
2008-02-01svc: Add svc_xprt_names service to replace svc_sock_namesTom Tucker
Create a transport independent version of the svc_sock_names function. The toclose capability of the svc_sock_names service can be implemented using the svc_xprt_find and svc_xprt_close services. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01knfsd: Support adding transports by writing portlist fileTom Tucker
Update the write handler for the portlist file to allow creating new listening endpoints on a transport. The general form of the string is: <transport_name><space><port number> For example: echo "tcp 2049" > /proc/fs/nfsd/portlist This is intended to support the creation of a listening endpoint for RDMA transports without adding #ifdef code to the nfssvc.c file. Transports can also be removed as follows: '-'<transport_name><space><port number> For example: echo "-tcp 2049" > /proc/fs/nfsd/portlist Attempting to add a listener with an invalid transport string results in EPROTONOSUPPORT and a perror string of "Protocol not supported". Attempting to remove an non-existent listener (.e.g. bad proto or port) results in ENOTCONN and a perror string of "Transport endpoint is not connected" Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
