path: root/fs/nfsd/nfsctl.c
2012-12-10nfsd: make NFSd service structure allocated per netStanislav Kinsbursky
This patch makes main step in NFSd containerisation. There could be different approaches to how to make NFSd able to handle incoming RPC request from different network namespaces. The two main options are: 1) Share NFSd kthreads betwween all network namespaces. 2) Create separated pool of threads for each namespace. While first approach looks more flexible, second one is simpler and non-racy. This patch implements the second option. To make it possible to allocate separate pools of threads, we have to make it possible to allocate separate NFSd service structures per net. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-12-10nfsd: pass net to __write_ports() and downStanislav Kinsbursky
Precursor patch. Hard-coded "init_net" will be replaced by proper one in future. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-12-10nfsd: pass net to nfsd_set_nrthreads()Stanislav Kinsbursky
2012-12-10nfsd: pass net to nfsd_svc()Stanislav Kinsbursky
2012-12-10nfsd: pass net to nfsd_create_serv()Stanislav Kinsbursky
2012-11-28NFSD: Fold fault_inject.h into state.hBryan Schumaker
There were only a small number of functions in this file and since they all affect stored state I think it makes sense to put them in state.h instead. I also dropped most static inline declarations since there are no callers when fault injection is not enabled. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-11-28nfsd: make NFSv4 grace time per netStanislav Kinsbursky
Grace time is a part of NFSv4 state engine, which is constructed per network namespace. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-11-28nfsd: make NFSv4 lease time per netStanislav Kinsbursky
Lease time is a part of NFSv4 state engine, which is constructed per network namespace. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-11-28nfsd: remove redundant declarationsStanislav Kinsbursky
This is a cleanup patch. Functions nfsd_pool_stats_open() and nfsd_pool_stats_release() are declared in fs/nfsd/nfsd.h. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-09-10nfsd: remove unused listener-removal interfacesJ. Bruce Fields
You can use nfsd/portlist to give nfsd additional sockets to listen on. In theory you can also remove listening sockets this way. But nobody's ever done that as far as I can tell. Also this was partially broken in 2.6.25, by a217813f9067b785241cb7f31956e51d2071703a "knfsd: Support adding transports by writing portlist file". (Note that we decide whether to take the "delfd" case by checking for a digit--but what's actually expected in that case is something made by svc_one_sock_name(), which won't begin with a digit.) So, let's just rip out this stuff. Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-08-21nfsd: allow configuring nfsd to listen on 5-digit portsJ. Bruce Fields
Note a 16-bit value can require up to 5 digits. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-08-21nfsd: remove redundant "port" argumentJ. Bruce Fields
"port" in all these functions is always NFS_PORT. nfsd can already be run on a nonstandard port using the "nfsd/portlist" interface. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-08-20nfsd4: declare nfs4_recoverydir properlyJ. Bruce Fields
2012-07-25NFSd: introduce nfsd_destroy() helperStanislav Kinsbursky
2012-05-31SUNRPC: move per-net operations from svc_destroy()Stanislav Kinsbursky
The idea is to separate service destruction and per-net operations, because these are two different things and the mix looks ugly. Notes: 1) For NFS server this patch looks ugly (sorry for that). But these place will be rewritten soon during NFSd containerization. 2) LockD per-net counter increase int lockd_up() was moved prior to make_socks() to make lockd_down_net() call safe in case of error. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-04-12nfsd: allocate id-to-name and name-to-id caches in per-net operations.Stanislav Kinsbursky
2012-04-12nfsd: pass network context to idmap init/exit functionsStanislav Kinsbursky
These functions will be called from per-net operations. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-04-12nfsd: allocate export and expkey caches in per-net operations.Stanislav Kinsbursky
2012-04-12nfsd: make expkey cache allocated per network namespace contextStanislav Kinsbursky
This patch also changes svcauth_unix_purge() function: added network namespace as a parameter and thus loop over all networks was replaced by only one call for ip map cache purge. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-04-12nfsd: make export cache allocated per network namespace contextStanislav Kinsbursky
This patch also changes prototypes of nfsd_export_flush() and exp_rootfh(): network namespace parameter added. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-04-11nfsd: pass network context to export caches init/shutdown routinesStanislav Kinsbursky
2012-04-11nfsd: pass svc_export_cache pointer as private data to "exports" seq file opsStanislav Kinsbursky
Global svc_export_cache cache is going to be replaced with per-net instance. So prepare the ground for it. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-03-29nfsd: only register cld pipe notifier when CONFIG_NFSD_V4 is enabledJeff Layton
Otherwise, we get a warning or error similar to this when building with CONFIG_NFSD_V4 disabled: ERROR: "nfsd4_cld_block" [fs/nfsd/nfsd.ko] undefined! Fix this by wrapping the calls to rpc_pipefs_notifier_register and ..._unregister in another function and providing no-op replacements when CONFIG_NFSD_V4 is disabled. Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-03-26nfsd: add notifier to handle mount/unmount of rpc_pipefs sbJeff Layton
In the event that rpc_pipefs isn't mounted when nfsd starts, we must register a notifier to handle creating the dentry once it is mounted, and to remove the dentry on unmount. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-03-26nfsd: add a per-net-namespace struct for nfsdJeff Layton
Eventually, we'll need this when nfsd gets containerized fully. For now, create a struct on a per-net-namespace basis that will just hold a pointer to the cld_net structure. That struct will hold all of the per-net data that we need for the cld tracker. Eventually we can add other pernet objects to struct nfsd_net. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-01-31SUNRPC: search for service transports in network namespace contextStanislav Kinsbursky
Service transports are parametrized by network namespace. And thus lookup of transport instance have to take network namespace into account. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: J. Bruce Fields <bfields@redhat.com>
2012-01-31SUNRPC: parametrize rpc_pton() by network contextStanislav Kinsbursky
Parametrize rpc_pton() by network context and thus force it's callers to pass in network context instead of using hard-coded "init_net". Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-01-14Merge branch 'for-3.3' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-3.3' of git://linux-nfs.org/~bfields/linux: (31 commits) nfsd4: nfsd4_create_clid_dir return value is unused NFSD: Change name of extended attribute containing junction svcrpc: don't revert to SVC_POOL_DEFAULT on nfsd shutdown svcrpc: fix double-free on shutdown of nfsd after changing pool mode nfsd4: be forgiving in the absence of the recovery directory nfsd4: fix spurious 4.1 post-reboot failures NFSD: forget_delegations should use list_for_each_entry_safe NFSD: Only reinitilize the recall_lru list under the recall lock nfsd4: initialize special stateid's at compile time NFSd: use network-namespace-aware cache registering routines SUNRPC: create svc_xprt in proper network namespace svcrpc: update outdated BKL comment nfsd41: allow non-reclaim open-by-fh's in 4.1 svcrpc: avoid memory-corruption on pool shutdown svcrpc: destroy server sockets all at once svcrpc: make svc_delete_xprt static nfsd: Fix oops when parsing a 0 length export nfsd4: Use kmemdup rather than duplicating its implementation nfsd4: add a separate (lockowner, inode) lookup nfsd4: fix CONFIG_NFSD_FAULT_INJECTION compile error ...
2012-01-06vfs: prefer ->dentry->d_sb to ->mnt->mnt_sbAl Viro
2011-11-07NFSD: Call nfsd4_init_slabs() from init_nfsd()Bryan Schumaker
init_nfsd() was calling free_slabs() during cleanup code, but the call to init_slabs() was hidden in nfsd4_state_init(). This could be confusing to people unfamiliar with the code. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-11-07NFSD: Added fault injectionBryan Schumaker
Fault injection on the NFS server makes it easier to test the client's state manager and recovery threads. Simulating errors on the server is easier than finding the right conditions that cause them naturally. This patch uses debugfs to add a simple framework for fault injection to the server. This framework is a config option, and can be enabled through CONFIG_NFSD_FAULT_INJECTION. Assuming you have debugfs mounted to /sys/debug, a set of files will be created in /sys/debug/nfsd/. Writing to any of these files will cause the corresponding action and write a log entry to dmesg. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-10-31fs: add module.h to files that were implicitly using itPaul Gortmaker
Some files were using the complete module.h infrastructure without actually including the header at all. Fix them up in advance so once the implicit presence is removed, we won't get failures like this: CC [M] fs/nfsd/nfssvc.o fs/nfsd/nfssvc.c: In function 'nfsd_create_serv': fs/nfsd/nfssvc.c:335: error: 'THIS_MODULE' undeclared (first use in this function) fs/nfsd/nfssvc.c:335: error: (Each undeclared identifier is reported only once fs/nfsd/nfssvc.c:335: error: for each function it appears in.) fs/nfsd/nfssvc.c: In function 'nfsd': fs/nfsd/nfssvc.c:555: error: implicit declaration of function 'module_put_and_exit' make[3]: *** [fs/nfsd/nfssvc.o] Error 1 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-31nfsd: remove include/linux/nfsd/syscall.hJ. Bruce Fields
We don't need this any more. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-15nfsd: Remove deprecated nfsctl system call and related code.NeilBrown
As promised in feature-removal-schedule.txt it is time to remove the nfsctl system call. Userspace has perferred to not use this call throughout 2.6 and it has been excluded in the default configuration since 2.6.36 (9 months ago). So this patch removes all the code that was being compiled out. There are still references to sys_nfsctl in various arch systemcall tables and related code. These should be cleaned out too, probably in the next merge window. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-06-06nfsd: fix dependency of nfsd on auth_rpcgssJ. Bruce Fields
Commit b0b0c0a26e84 "nfsd: add proc file listing kernel's gss_krb5 enctypes" added an nunnecessary dependency of nfsd on the auth_rpcgss module. It's a little ad hoc, but since the only piece of information nfsd needs from rpcsec_gss_krb5 is a single static string, one solution is just to share it with an include file. Cc: stable@kernel.org Reported-by: Michael Guntsche <mike@it-loops.com> Cc: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-03-14nfsd: fix compile errorJ. Bruce Fields
"fs/built-in.o: In function `supported_enctypes_show': nfsctl.c:(.text+0x7beb0): undefined reference to `gss_mech_get_by_name' nfsctl.c:(.text+0x7bebc): undefined reference to `gss_mech_put' " Reported-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-03-07nfsd: add proc file listing kernel's gss_krb5 enctypesKevin Coffman
Add a new proc file which lists the encryption types supported by the kernel's gss_krb5 code. Newer MIT Kerberos libraries support the assertion of acceptor subkeys. This enctype information allows user-land (svcgssd) to request that the Kerberos libraries limit the encryption types that it uses when generating the subkeys. Signed-off-by: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-04nfsd4: move idmap and acl header files into fs/nfsdJ. Bruce Fields
These are internal nfsd interfaces. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-12-17nfs: add missed CONFIG_NFSD_DEPRECATEDbookjovi@gmail.com
these pieces of code only make sense when CONFIG_NFSD_DEPRECATED enabled Signed-off-by: Jovi Zhang <bookjovi@gmail.com> fs/nfsd/nfsctl.c | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-) Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-10-29convert get_sb_single() usersAl Viro
2010-10-26Merge branch 'for-2.6.37' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.37' of git://linux-nfs.org/~bfields/linux: (99 commits) svcrpc: svc_tcp_sendto XPT_DEAD check is redundant svcrpc: no need for XPT_DEAD check in svc_xprt_enqueue svcrpc: assume svc_delete_xprt() called only once svcrpc: never clear XPT_BUSY on dead xprt nfsd4: fix connection allocation in sequence() nfsd4: only require krb5 principal for NFSv4.0 callbacks nfsd4: move minorversion to client nfsd4: delay session removal till free_client nfsd4: separate callback change and callback probe nfsd4: callback program number is per-session nfsd4: track backchannel connections nfsd4: confirm only on succesful create_session nfsd4: make backchannel sequence number per-session nfsd4: use client pointer to backchannel session nfsd4: move callback setup into session init code nfsd4: don't cache seq_misordered replies SUNRPC: Properly initialize sock_xprt.srcaddr in all cases SUNRPC: Use conventional switch statement when reclassifying sockets sunrpc/xprtrdma: clean up workqueue usage sunrpc: Turn list_for_each-s into the ..._entry-s ... Fix up trivial conflicts (two different deprecation notices added in separate branches) in Documentation/feature-removal-schedule.txt
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-01sunrpc: Add net argument to svc_create_xprtPavel Emelyanov
Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-27sunrpc: Add net to pure API callsPavel Emelyanov
There are two calls that operate on ip_map_cache and are directly called from the nfsd code. Other places will be handled in a different way. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-23nfsd: Export get_task_comm for nfsdPavel Emelyanov
The git://linux-nfs.org/~bfields/linux.git nfsd-next branch doesn't compile when nfsd is a module with the following error: ERROR: "get_task_comm" [fs/nfsd/nfsd.ko] undefined! Replace the get_task_comm call with direct comm access, which is safe for current. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-22nfsd: allow deprecated interface to be compiled out.NeilBrown
Add CONFIG_NFSD_DEPRECATED, default to y. Only include deprecated interface if this is defined. This allows distros to remove this interface before the official removal, and allows developers to test without it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-22nfsd: formally deprecate legacy nfsd syscall interfaceNeilBrown
The syscall interface is has been replaced by a more flexible interface since 2.6.0. It is time to work towards discarding the old interface. So add a entry in feature-removal-schedule.txt and print a warning when the interface is used. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-08-06nfsd: don't allow setting maxblksize after svc createdJ. Bruce Fields
It's harmless to set this after the server is created, but also ineffective, since the value is only used at the time of svc_create_pooled(). So fail the attempt, in keeping with the pattern set by write_versions, write_{lease,grace}time and write_recoverydir. (This could break userspace that tried to write to nfsd/max_block_size between setting up sockets and starting the server. However, such code wouldn't have worked anyway, and I don't know of any examples--rpc.nfsd in nfs-utils, probably the only user of the interface, doesn't do that.) Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-07-29gcc-4.6: nfsd: fix initialized but not read warningsAndi Kleen
Fixes at least one real minor bug: the nfs4 recovery dir sysctl would not return its status properly. Also I finished Al's 1e41568d7378d ("Take ima_path_check() in nfsd past dentry_open() in nfsd_open()") commit, it moved the IMA code, but left the old path initializer in there. The rest is just dead code removed I think, although I was not fully sure about the "is_borc" stuff. Some more review would be still good. Found by gcc 4.6's new warnings. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-07-23nfsd: just keep single lockd reference for nfsdJeff Layton
Right now, nfsd keeps a lockd reference for each socket that it has open. This is unnecessary and complicates the error handling on startup and shutdown. Change it to just do a lockd_up when starting the first nfsd thread just do a single lockd_down when taking down the last nfsd thread. Because of the strange way the sv_count is handled this requires an extra flag to tell whether the nfsd_serv holds a reference for lockd or not. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
