path: root/fs/nfs
2007-07-10sendfile: convert nfs to using splice_read()Jens Axboe
Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-30NFS: Fix a refcount leakage in O_DIRECTTrond Myklebust
The current code is leaking a reference to dreq->kref when the calls to nfs_direct_read_schedule() and nfs_direct_write_schedule() return an error. This patch moves the call to kref_put() from nfs_direct_wait() back into nfs_direct_read() and nfs_direct_write() (which are the functions that actually took the reference in the first place) fixing the leak. Thanks to Denis V. Lunev for spotting the bug and proposing the original fix. Acked-by: Denis V. Lunev <dlunev@gmail.com> Acked-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-24NFS: Fix nfs_direct_dirty_pages()Trond Myklebust
We only need to dirty the pages that were actually read in. Also convert nfs_direct_dirty_pages() to call set_page_dirty() instead of set_page_dirty_lock(). A call to lock_page() is unacceptable in an rpciod callback function. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-24NFS: Fix handful of compiler warnings in direct.cChuck Lever
This patch fixes a couple of signage issues that were causing an Oops when running the LTP diotest4 test. get_user_pages() returns a signed error, hence we need to be careful when comparing with the unsigned number of pages from data->npages. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-24NFS: Avoid a deadlock situation on writeTrond Myklebust
When processes are allowed to attempt to lock a non-contiguous range of nfs write requests, it is possible for generic_writepages to 'wrap round' the address space, and call writepage() on a request that is already locked by the same process. We avoid the deadlock by checking if the page index is contiguous with the list of nfs write requests that is already held in our nfs_pageio_descriptor prior to attempting to lock a new request. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-17Merge branch 'master' of /home/trondmy/repositories/git/linux-2.6/Trond Myklebust
2007-05-14NFS: Fix more sparse warningsTrond Myklebust
- fs/nfs/nfs4xdr.c:2499:42: warning: incorrect type in argument 2 (different signedness) - fs/nfs/nfs4xdr.c:2658:49: warning: incorrect type in argument 4 (different explicit signedness) - fs/nfs/nfs4xdr.c:2683:50: warning: incorrect type in argument 4 (different explicit signedness) - fs/nfs/nfs4xdr.c:3063:68: warning: incorrect type in argument 4 (different explicit signedness) - fs/nfs/nfs4xdr.c:3065:68: warning: incorrect type in argument 4 (different explicit signedness) - fs/nfs/callback_xdr.c:138:31: warning: incorrect type in argument 2 (different signedness) Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-14NFS: Fix some 'sparse' warnings...Trond Myklebust
- fs/nfs/dir.c:610:8: warning: symbol 'nfs_llseek_dir' was not declared. Should it be static? - fs/nfs/dir.c:636:5: warning: symbol 'nfs_fsync_dir' was not declared. Should it be static? - fs/nfs/write.c:925:19: warning: symbol 'req' shadows an earlier one - fs/nfs/write.c:61:6: warning: symbol 'nfs_commit_rcu_free' was not declared. Should it be static? - fs/nfs/nfs4proc.c:793:5: warning: symbol 'nfs4_recover_expired_lease' was not declared. Should it be static? Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-14NFS4: Fix incorrect use of sizeof() in fs/nfs/nfs4xdr.cTrond Myklebust
The XDR code should not depend on the physical allocation size of structures like nfs4_stateid and nfs4_verifier since those may have to change at some future date. We therefore replace all uses of sizeof() with constants like NFS4_VERIFIER_SIZE and NFS4_STATEID_SIZE. This also has the side-effect of fixing some warnings of the type format ‘%u’ expects type ‘unsigned int’, but argument X has type ‘long unsigned int’ on 64-bit systems Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-14NFS: use zero_user_pageNate Diller
Use zero_user_page() instead of the newly deprecated memclear_highpage_flush(). Signed-off-by: Nate Diller <nate.diller@gmail.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-09NFS: Kill the obsolete NFS_PARANOIAJesper Juhl
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-09NFS: use __set_current_state()Milind Arun Choudhary
use __set_current_state(TASK_*) instead of current->state = TASK_*, in fs/nfs Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-09NFS: Clean up NFSv4 XDR error messageChuck Lever
Make it more useful for debugging purposes. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-09NFS: NFS client underestimates how large an NFSv4 SETATTR reply can beChuck Lever
The maximum size of an NFSv4 SETATTR compound reply should include the GETATTR operation that we send. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-09NFS: Remove redundant check in nfs_check_verifier()Trond Myklebust
The check for nfs_attribute_timeout(dir) in nfs_check_verifier is redundant: nfs_lookup_revalidate() will already call nfs_revalidate_inode() on the parent dir when necessary. The only case where this is not done is the case of a negative dentry. Fix this case by moving up the revalidation code. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-09NFS: Fix a jiffie wraparound issueTrond Myklebust
dentry verifiers are always set to the parent directory's cache_change_attribute. There is no reason to be testing for anything other than equality when we're trying to find out if the dentry has been checked since the last time the directory was modified. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-08nfs: fix congestion control: use atomic_longsPeter Zijlstra
Change the atomic_t in struct nfs_server to atomic_long_t in anticipation of machines that can handle 8+TB of (4K) pages under writeback. However I suspect other things in NFS will start going *bang* by then. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Merge branch 'server-cluster-locking-api' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'server-cluster-locking-api' of git://linux-nfs.org/~bfields/linux: gfs2: nfs lock support for gfs2 lockd: add code to handle deferred lock requests lockd: always preallocate block in nlmsvc_lock() lockd: handle test_lock deferrals lockd: pass cookie in nlmsvc_testlock lockd: handle fl_grant callbacks lockd: save lock state on deferral locks: add fl_grant callback for asynchronous lock return nfsd4: Convert NFSv4 to new lock interface locks: add lock cancel command locks: allow {vfs,posix}_lock_file to return conflicting lock locks: factor out generic/filesystem switch from setlock code locks: factor out generic/filesystem switch from test_lock locks: give posix_test_lock same interface as ->lock locks: make ->lock release private data before returning in GETLK case locks: create posix-to-flock helper functions locks: trivial removal of unnecessary parentheses
2007-05-07mm: make read_cache_page synchronousNick Piggin
Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-06locks: give posix_test_lock same interface as ->lockMarc Eshel
posix_test_lock() and ->lock() do the same job but have gratuitously different interfaces. Modify posix_test_lock() so the two agree, simplifying some code in the process. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu>
2007-05-06locks: make ->lock release private data before returning in GETLK caseJ. Bruce Fields
The file_lock argument to ->lock is used to return the conflicting lock when found. There's no reason for the filesystem to return any private information with this conflicting lock, but nfsv4 is. Fix nfsv4 client, and modify locks.c to stop calling fl_release_private for it in this case. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Cc: "Trond Myklebust" <Trond.Myklebust@netapp.com>"
2007-05-04NFS: Fix a compile glitch on 64-bit systemsTrond Myklebust
fs/nfs/pagelist.c:226: error: conflicting types for 'nfs_pageio_init' include/linux/nfs_page.h:80: error: previous declaration of 'nfs_pageio_init' was here Thanks to Andrew for spotting this... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-02NFS: Clean up nfs_create_request commentsJason Uhlenkott
Remove some stale comments about hard limits which went away in 2.5. Signed-off-by: Jason Uhlenkott <juhlenko@akamai.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-02NFS4: invalidate cached acl on setaclJ. Bruce Fields
The ACL that the server sets may not be exactly the one we set--for example, it may silently turn off bits that it does not support. So we should remove any cached ACL so that any subsequent request for the ACL will go to the server. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30NFS: Fix directory caching problem - with test case and patch.Neil Brown
Try running this script in an NFS mounted directory (Client relatively recent - 2.6.18 has the problem as does 2.6.20). ------------------------------------------------------ #!/bin/bash # # This script will produce the following errormessage from tar: # # tar: newdir/innerdir/innerfile: file changed as we read it # create dirs rm -rf nfstest mkdir -p nfstest/dir/innerdir # create files (should not be empty) echo "Hello World!" >nfstest/dir/file echo "Hello World!" >nfstest/dir/innerdir/innerfile # problem only happens if we sleep before chmod sleep 1 # change file modes chmod -R a+r nfstest # rename dir mv nfstest/dir nfstest/newdir # tar it tar -cf nfstest/nfstest.tar -C nfstest newdir # restore old dir name mv nfstest/newdir nfstest/dir -------------------------------------------------------- What happens: The 'chmod -R' does a readdir_plus in each directory and the results get cached in the page cache. It then updates the ctime on each file by one second. When this happens, the post-op attributes are used to update the ctime stored on the client to match the value in the kernel. The 'mv' calls shrink_dcache_parent on the directory tree which flushes all the dentries (so a new lookup will be required) but doesn't flush the inodes or pagecache. The 'tar' does a readdir on each directory, but (in the case of 'innerdir' at least) satisfies it from the pagecache and uses the READDIRPLUS data to update all the inodes. In the case of 'innerdir/innerfile', the ctime is out of date. 'tar' then calls 'lstat' on innerdir/innerfile getting an old ctime. It then opens the file (triggering a GETATTR), reads the content, and then calls fstat to see if anything has changed. It finds that ctime has changed and so complains. The problem seems to be that the cache readdirplus info is kept around for too long. My patch below discards pagecache data for directories when dentry_iput is called on them. This effectively removes the symptom which convinces me that I correctly understand the problem. However I'm not convinced that is a proper solution, as there could easily be other races that trigger the same problem without being affected by this 'fix'. One possibility would be to require that readdirplus pagecache data be only used *once* to instantiate an inode. Somehow it should then be invalidated so that if the dentry subsequently disappears, it will cause a new request to the server to fill in the stat data. Another possibility is to compare the cache_change_attribute on the inode with something similar for the readdirplus info and reject the info from readdirplus if it is too old. I haven't tried to implement these and would value other opinions before I do. Thanks, NeilBrown Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30NFS: Set meaningful value for fattr->time_start in readdirplus results.Neil Brown
Don't use uninitialsed value for fattr->time_start in readdirplus results. The 'fattr' structure filled in by nfs3_decode_direct does not get a value for ->time_start set. Thus if an entry is for an inode that we already have in cache, when nfs_readdir_lookup calls nfs_fhget, it will call nfs_refresh_inode and may update the inode with out-of-date information. Directories are read a page at a time, so each page could have a different timestamp that "should" be used to set the time_start for the fattr for info in that page. However storing the timestamp per page is awkward. (We could stick in the first 4 bytes and only read 4092 bytes, but that is a bigger code change than I am interested it). This patch ignores the readdir_plus attributes if a readdir finds the information already in cache, and otherwise sets ->time_start to the time the readdir request was sent to the server. It might be nice to store - in the directory inode - the time stamp for the earliest readdir request that is still in the page cache, so that we don't ignore attribute data that we don't have to. This patch doesn't do that. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30NFS: Added support to turn off the NFSv3 READDIRPLUS RPC.Steve Dickson
READDIRPLUS can be a performance hindrance when the client is working with large directories. In addition, some servers still have bugs in their implementations (e.g. Tru64 returns wrong values for the fsid). Add a mount flag to enable users to turn it off at mount time following the implementation in Apple's NFS client. Signed-off-by: Steve Dickson <steved@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30NFS: switch NFSROOT to use new rpcbind clientChuck Lever
It is arguable whether NFSROOT will support IPv6, and thus whether rpcb_getport_external needs to support rpcbind versions greater than 2. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30SUNRPC: RPC buffer size estimates are too largeChuck Lever
The RPC buffer size estimation logic in net/sunrpc/clnt.c always significantly overestimates the requirements for the buffer size. A little instrumentation demonstrated that in fact rpc_malloc was never allocating the buffer from the mempool, but almost always called kmalloc. To compute the size of the RPC buffer more precisely, split p_bufsiz into two fields; one for the argument size, and one for the result size. Then, compute the sum of the exact call and reply header sizes, and split the RPC buffer precisely between the two. That should keep almost all RPC buffers within the 2KiB buffer mempool limit. And, we can finally be rid of RPC_SLACK_SPACE! Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30NFS: Use pgoff_t in structures and functions that pass page cache offsetsTrond Myklebust
2007-04-30NFS: Clean up nfs_sync_mapping_wait()Trond Myklebust
It has no business touching wbc->pages_skipped. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30NFS: Fix a buffer overflow in the allocation of struct nfs_read/writedataTrond Myklebust
2007-04-30NFS: Fix a race when doing NFS write coalescingTrond Myklebust
Currently we do write coalescing in a very inefficient manner: one pass in generic_writepages() in order to lock the pages for writing, then one pass in nfs_flush_mapping() and/or nfs_sync_mapping_wait() in order to gather the locked pages for coalescing into RPC requests of size "wsize". In fact, it turns out there is actually a deadlock possible here since we only start I/O on the second pass. If the user signals the process while we're in nfs_sync_mapping_wait(), for instance, then we may exit before starting I/O on all the requests that have been queued up. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30NFS: Cleanup for nfs_readpages()Trond Myklebust
Do the coalescing of read requests into block sized requests at start of I/O as we scan through the pages instead of going through a second pass. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30NFS: Another cleanup of the read/write request coalescing codeTrond Myklebust
2007-04-30NFS: Cleanup the coalescing codeTrond Myklebust
2007-04-30NFS: Don't wait for congestion in nfs_update_request()Trond Myklebust
It is redundant, and will interfere with the call to balance_dirty_pages_ratelimited_nr in generic_file_write(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30NFS: statfs error-handling fixAmnon Aaronsohn
The nfs statfs function returns a success code on error, and fills the output buffer with invalid values. The attached patch makes it return a correct error code instead. Signed-off-by: Amnon Aaronsohn <amnonaar@gmail.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> (Modified patch to reinstate the dprintk())
2007-04-30NFS: Fix nfs_set_page_dirty()Trond Myklebust
Be more careful about testing page->mapping. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-20NFS: Fix race in nfs_set_page_dirtyTrond Myklebust
Protect nfs_set_page_dirty() against races with nfs_inode_add_request. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-20NFS: Fix the 'desynchronized value of nfs_i.ncommit' errorTrond Myklebust
Redirtying a request that is already marked for commit will screw up the accounting for NR_UNSTABLE_NFS as well as nfs_i.ncommit. Ensure that all requests on the commit queue are labelled with the PG_NEED_COMMIT flag, and avoid moving them onto the dirty list inside nfs_page_mark_flush(). Also inline nfs_mark_request_dirty() into nfs_page_mark_flush() for atomicity reasons. Avoid dropping the spinlock until we're done marking the request in the radix tree and have added it to the ->dirty list. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-20NFS: Don't clear PG_writeback until after we've processed unstable writesTrond Myklebust
Ensure that we don't release the PG_writeback lock until after the page has either been redirtied, or queued on the nfs_inode 'commit' list. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-20NFS: clean up the unstable write codeTrond Myklebust
Get rid of the inlined #ifdefs. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-15NFS: Fix a list corruption problemTrond Myklebust
We must remove the request from whatever list it is currently on before we can add it to the dirty list. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-14NFS: Ensure PG_writeback is cleared when writeback failsTrond Myklebust
If the writebacks are cancelled via nfs_cancel_dirty_list, or due to the memory allocation failing in nfs_flush_one/nfs_flush_multi, then we must ensure that the PG_writeback flag is cleared. Also ensure that we actually own the PG_writeback flag whenever we schedule a new writeback by making nfs_set_page_writeback() return the value of test_set_page_writeback(). The PG_writeback page flag ends up replacing the functionality of the PG_FLUSHING nfs_page flag, so we rip that out too. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-14NFS: Fix two bugs in the O_DIRECT write codeTrond Myklebust
Do not flag an error if the COMMIT call fails and we decide to resend the writes. Let the resend flag the error if it fails. If a write has failed, then nfs_direct_write_result should not attempt to send a commit. It should just exit asap and return the error to the user. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
