path: root/fs/nfs/write.c
2009-06-17nfs41 commit sequence setup done supportAndy Adamson
Separate commit calls from nfs41: sequence setup/done support Implement the commit rpc_call_prepare method for asynchronuos nfs rpcs, call nfs41_setup_sequence from respective rpc_call_validate_args methods. Call nfs4_sequence_done from respective rpc_call_done methods. Note that we need to pass a pointer to the nfs_server in calls data for passing on to nfs4_sequence_done. Signed-off-by: Andy Adamson<andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [pnfs: client data server write validate and release] Signed-off-by: Andy Adamson<andros@umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: Support sessions with O_DIRECT.] Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: separate free slot from sequence done] [nfs41: nfs4_sequence_free_slot use nfs_client for data server] Signed-off-by: Andy Adamson<andros@umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41 write sequence setup done supportAndy Adamson
Separate write calls from nfs41: sequence setup/done support Implement the write rpc_call_prepare method for asynchronuos nfs rpcs, call nfs41_setup_sequence from respective rpc_call_validate_args methods. Call nfs4_sequence_done from respective rpc_call_done methods. Note that we need to pass a pointer to the nfs_server in calls data for passing on to nfs4_sequence_done. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [pnfs: client data server write validate and release] Signed-off-by: Andy Adamson <andros@umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [move the nfs4_sequence_free_slot call in nfs_readpage_retry from] [nfs41: separate free slot from sequence done Signed-off-by: Andy Adamson <andros@umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: Support sessions with O_DIRECT.] Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: nfs4_sequence_free_slot use nfs_client for data server] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: set up seq_res.sr_slotidAndy Adamson
Initialize nfs4_sequence_res sr_slotid to NFS4_MAX_SLOT_TABLE. [was nfs41: sequence res use slotid] Signed-off-by: Andy Adamson <andros@netapp.com> [pulled definition of struct nfs4_sequence_res.sr_slotid to here] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-19NFS: Fix up a mismerged patchTrond Myklebust
Move the definition of nfs_need_commit() into the #ifdef CONFIG_NFS_V3 section as originally intended in the patch "NFS: cleanup - remove struct nfs_inode->ncommit" Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-11NFS: Throttle page dirtying while we're flushing to diskTrond Myklebust
The following patch is a combination of a patch by myself and Peter Staubach. Trond: If we allow other processes to dirty pages while a process is doing a consistency sync to disk, we can end up never making progress. Peter: Attached is a patch which addresses a continuing problem with the NFS client generating out of order WRITE requests. While this is compliant with all of the current protocol specifications, there are servers in the market which can not handle out of order WRITE requests very well. Also, this may lead to sub-optimal block allocations in the underlying file system on the server. This may cause the read throughputs to be reduced when reading the file from the server. Peter: There has been a lot of work recently done to address out of order issues on a systemic level. However, the NFS client is still susceptible to the problem. Out of order WRITE requests can occur when pdflush is in the middle of writing out pages while the process dirtying the pages calls generic_file_buffered_write which calls generic_perform_write which calls balance_dirty_pages_rate_limited which ends up calling writeback_inodes which ends up calling back into the NFS client to writes out dirty pages for the same file that pdflush happens to be working with. Signed-off-by: Peter Staubach <staubach@redhat.com> [modification by Trond to merge the two similar patches] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-11NFS: cleanup - remove struct nfs_inode->ncommitTrond Myklebust
2008-10-07NFS: Don't use range_cyclic for data integrity syncsTrond Myklebust
It is more efficient to write linearly starting from the beginning of the file. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-15NFS: Remove BKL requirement from attribute updatesTrond Myklebust
The main problem is dealing with inode->i_size: we need to set the inode->i_lock on all attribute updates, and so vmtruncate won't cut it. Make an NFS-private version of vmtruncate that has the necessary locking semantics. The result should be that the following inode attribute updates are protected by inode->i_lock nfsi->cache_validity nfsi->read_cache_jiffies nfsi->attrtimeo nfsi->attrtimeo_timestamp nfsi->change_attr nfsi->last_updated nfsi->cache_change_attribute nfsi->access_cache nfsi->access_cache_entry_lru nfsi->access_cache_inode_lru nfsi->acl_access nfsi->acl_default nfsi->nfs_page_tree nfsi->ncommit nfsi->npages nfsi->open_files nfsi->silly_list nfsi->acl nfsi->open_states inode->i_size inode->i_atime inode->i_mtime inode->i_ctime inode->i_nlink inode->i_uid inode->i_gid The following is protected by dir->i_mutex nfsi->cookieverf Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Allow redirtying of a completed unstable write.Trond Myklebust
Currently, if an unstable write completes, we cannot redirty the page in order to reflect a new change in the page data until after we've sent a COMMIT request. This patch allows a page rewrite to proceed without the unnecessary COMMIT step, putting it immediately back onto the dirty page list, undoing the VM unstable write accounting, and removing the NFS_PAGE_TAG_COMMIT tag from the NFS radix tree. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Clean up nfs_update_request()Trond Myklebust
Simplify the loop in nfs_update_request by moving into a separate function the code that attempts to update an existing cached NFS write. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Fix trace debugging nits in write.cChuck Lever
Clean up: fix a few dprintk messages that still need to show the RPC task ID correctly, and be sure we use the preferred %lld or %llu instead of %Ld or %Lu. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Revert commit 44dd151dTrond Myklebust
Revert commit 44dd151d "NFS: Don't mark a written page as uptodate until it is on disk". While it is true that the write may fail, that is always the case. There is no reason why we should treat data on pages that are not already marked as PG_uptodate as being special. The only thing we gain is a noticeable slowdown when re-reading these pages. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Optimise append writes with holesTrond Myklebust
If a file is being extended, and we're creating a hole, we might as well declare the entire page to be up to date. This patch significantly improves the write performance for sparse files in the case where lseek(SEEK_END) is used to append several non-contiguous writes at intervals of < PAGE_SIZE. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Fix a preemption count leak in nfs_update_requestTrond Myklebust
The commit 2785259631697ebb0749a3782cca206e2e542939 (nfs: use GFP_NOFS preloads for radix-tree insertion) appears to have introduced a bug: We only want to call radix_tree_preload() once after creating a request. Calling it every time we loop after we created the request, will cause preemption count leaks. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Nick Piggin <npiggin@suse.de>
2008-06-23NFS: nfs_updatepage(): don't mark page as dirty if an error occurredTrond Myklebust
2008-05-16nfs: fix race in nfs_dirty_requestFred Isaman
When called from nfs_flush_incompatible, the req is not locked, so req->wb_page might be set to NULL before it is used by PageWriteback. Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-04-19NFS: Ensure that rpc_run_task() errors are propagated back to the callerTrond Myklebust
2008-04-19NFS: Ensure that the write code cleans up properly when rpc_run_task() failsTrond Myklebust
2008-04-19NFS: Fix nfs_wb_page() to always exit with an error or a clean pageTrond Myklebust
It is possible for nfs_wb_page() to sometimes exit with 0 return value, yet the page is left in a dirty state. For instance in the case where the server rebooted, and the COMMIT request failed, then all the previously "clean" pages which were cached by the server, but were not guaranteed to have been writted out to disk, have to be redirtied and resent to the server. The fix is to have nfs_wb_page_priority() check that the page is clean before it exits... This fixes a condition that triggers the BUG_ON(PagePrivate(page)) in nfs_create_request() when we're in the nfs_readpage() path. Also eliminate a redundant BUG_ON(!PageLocked(page)) while we're at it. It turns out that clear_page_dirty_for_io() has the exact same test. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-19nfs: nfs_redirty_requestFred
Both flush functions have the same error handling routine. Pull it out as a function. Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-19Merge branch 'hotfixes' into develTrond Myklebust
2008-03-19nfs: don't ignore return value from nfs_pageio_add_requestFred Isaman
Ignoring the return value from nfs_pageio_add_request can cause deadlocks. In read path: call nfs_pageio_add_request from readpage_async_filler assume at this point that there are requests already in desc, that can't be merged with the current request. so nfs_pageio_doio is fired up to clear out desc. assume something goes wrong in setting up the io, so desc->pg_error is set. This causes nfs_pageio_add_request to return 0, *WITHOUT* adding the original request. BUT, since return code is ignored, readpage_async_filler assumes it has been added, and does nothing further, leaving page locked. do_generic_mapping_read will eventually call lock_page, resulting in deadlock In write path: page is marked dirty by generic_perform_write nfs_writepages is called call nfs_pageio_add_request from nfs_page_async_flush assume at this point that there are requests already in desc, that can't be merged with the current request. so nfs_pageio_doio is fired up to clear out desc. assume something goes wrong in setting up the io, so desc->pg_error is set. This causes nfs_page_async_flush to return 0, *WITHOUT* adding the original request, yet marking the request as locked (PG_BUSY) and in writeback, clearing dirty marks. The next time a write is done to the page, deadlock will result as nfs_write_end calls nfs_update_request Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-07NFS: Fix an f_mode/f_flags confusion in fs/nfs/write.cTrond Myklebust
O_SYNC is stored in filp->f_flags. Thanks to Al Viro for pointing out the bug. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-28Merge branch 'cleanups' into nextTrond Myklebust
2008-02-28SUNRPC: Remove now-redundant RCU-safe rpc_task free pathTrond Myklebust
Now that we've tightened up the locking rules for RPC queue wakeups, we can remove the RCU-safe kfree calls... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-25NFS: Ensure that the asynchronous RPC calls complete on nfsiod.Trond Myklebust
We want to ensure that rpc_call_ops that involve mntput() are run on nfsiod rather than on rpciod, so that they don't deadlock when the resulting umount calls rpc_shutdown_client(). Hence we specify that read, write and commit calls must complete on nfsiod. Ditto for NFSv4 open, lock, locku and close asynchronous calls. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-25NFS: Fix a deadlock with lazy umountTrond Myklebust
We can't allow rpc callback functions like task->tk_ops->rpc_call_prepare() and task->tk_ops->rpc_call_done() to call mntput() in any way, since that will cause a deadlock when the call to rpc_shutdown_client() attempts to wait on 'task' to complete. We can avoid the above deadlock by moving calls to mntput to task->tk_ops->rpc_release() callback, since at that time the task will be marked as completed, and so rpc_shutdown_client won't attempt to wait on it. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-25NFS: Fix an f_mode/f_flags confusion in fs/nfs/write.cTrond Myklebust
2008-02-13nfs: use GFP_NOFS preloads for radix-tree insertionNick Piggin
NFS should use GFP_NOFS mode radix tree preloads rather than GFP_ATOMIC allocations at radix-tree insertion-time. This is important to reduce the atomic memory requirement. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-07NFS: Fix a potential file corruption issue when writingTrond Myklebust
If the inode is flagged as having an invalid mapping, then we can't rely on the PageUptodate() flag. Ensure that we don't use the "anti-fragmentation" write optimisation in nfs_updatepage(), since that will cause NFS to write out areas of the page that are no longer guaranteed to be up to date. A potential corruption could occur in the following scenario: client 1 client 2 =============== =============== fd=open("f",O_CREAT|O_WRONLY,0644); write(fd,"fubar\n",6); // cache last page close(fd); fd=open("f",O_WRONLY|O_APPEND); write(fd,"foo\n",4); close(fd); fd=open("f",O_WRONLY|O_APPEND); write(fd,"bar\n",4); close(fd); ----- The bug may lead to the file "f" reading 'fubar\n\0\0\0\nbar\n' because client 2 does not update the cached page after re-opening the file for write. Instead it keeps it marked as PageUptodate() until someone calls invaldate_inode_pages2() (typically by calling read()). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-05Pagecache zeroing: zero_user_segment, zero_user_segments and zero_userChristoph Lameter
Simplify page cache zeroing of segments of pages through 3 functions zero_user_segments(page, start1, end1, start2, end2) Zeros two segments of the page. It takes the position where to start and end the zeroing which avoids length calculations and makes code clearer. zero_user_segment(page, start, end) Same for a single segment. zero_user(page, start, length) Length variant for the case where we know the length. We remove the zero_user_page macro. Issues: 1. Its a macro. Inline functions are preferable. 2. The KM_USER0 macro is only defined for HIGHMEM. Having to treat this special case everywhere makes the code needlessly complex. The parameter for zeroing is always KM_USER0 except in one single case that we open code. Avoiding KM_USER0 makes a lot of code not having to be dealing with the special casing for HIGHMEM anymore. Dealing with kmap is only necessary for HIGHMEM configurations. In those configurations we use KM_USER0 like we do for a series of other functions defined in highmem.h. Since KM_USER0 is depends on HIGHMEM the existing zero_user_page function could not be a macro. zero_user_* functions introduced here can be be inline because that constant is not used when these functions are called. Also extract the flushing of the caches to be outside of the kmap. [akpm@linux-foundation.org: fix nfs and ntfs build] [akpm@linux-foundation.org: fix ntfs build some more] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01Merge branch 'task_killable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'task_killable' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: (22 commits) Remove commented-out code copied from NFS NFS: Switch from intr mount option to TASK_KILLABLE Add wait_for_completion_killable Add wait_event_killable Add schedule_timeout_killable Use mutex_lock_killable in vfs_readdir Add mutex_lock_killable Use lock_page_killable Add lock_page_killable Add fatal_signal_pending Add TASK_WAKEKILL exit: Use task_is_* signal: Use task_is_* sched: Use task_contributes_to_load, TASK_ALL and TASK_NORMAL ptrace: Use task_is_* power: Use task_is_* wait: Use TASK_NORMAL proc/base.c: Use task_is_* proc/array.c: Use TASK_REPORT perfmon: Use task_is_* ... Fixed up conflicts in NFS/sunrpc manually..
2008-01-30NFS: Fix minor mixed sign comparison in NFS client's write logicChuck Lever
Clean up: PAGE_CACHE_SIZE is unsigned, and nfs_pageio_init() takes a size_t. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS/SUNRPC: Convert users of rpc_init_task+rpc_execute to rpc_run_task()Trond Myklebust
2008-01-30NFS: Clean up the (commit|read|write)_setup() callback routinesTrond Myklebust
Move the common code for setting up the nfs_write_data and nfs_read_data structures into fs/nfs/read.c, fs/nfs/write.c and fs/nfs/direct.c. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Clean up the initialisation of priority queue scheduling info.Trond Myklebust
We want the default scheduling priority (priority == 0) to remain RPC_PRIORITY_NORMAL. Also ensure that the priority wait queue scheduling is per process id instead of sometimes being per thread, and sometimes being per inode. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Cleanup of rpc_task initialisationTrond Myklebust
2008-01-30NFS: Clean up the write request locking.Trond Myklebust
Ensure that we set/clear NFS_PAGE_TAG_LOCKED when the nfs_page is hashed. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-12-06NFS: Switch from intr mount option to TASK_KILLABLEMatthew Wilcox
By using the TASK_KILLABLE infrastructure, we can get rid of the 'intr' mount option. We have to use _killable everywhere instead of _interruptible as we get rid of rpc_clnt_sigmask/sigunmask. Signed-off-by: Liam R. Howlett <howlett@gmail.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-11-26NFS: make nfs_wb_page_priority() staticAdrian Bunk
nfs_wb_page_priority() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-19NFS: Fix a writeback race...Trond Myklebust
This patch fixes a regression that was introduced by commit 44dd151d5c21234cc534c47d7382f5c28c3143cd We cannot zero the user page in nfs_mark_uptodate() any more, since a) We'd be modifying the page without holding the page lock b) We can race with other updates of the page, most notably because of the call to nfs_wb_page() in nfs_writepage_setup(). Instead, we do the zeroing in nfs_update_request() if we see that we're creating a request that might potentially be marked as up to date. Thanks to Olivier Paquet for reporting the bug and providing a test-case. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-17mm: count reclaimable pages per BDIPeter Zijlstra
Count per BDI reclaimable pages; nr_reclaimable = nr_dirty + nr_unstable. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17nfs: remove congestion_end()Peter Zijlstra
These patches aim to improve balance_dirty_pages() and directly address three issues: 1) inter device starvation 2) stacked device deadlocks 3) inter process starvation 1 and 2 are a direct result from removing the global dirty limit and using per device dirty limits. By giving each device its own dirty limit is will no longer starve another device, and the cyclic dependancy on the dirty limit is broken. In order to efficiently distribute the dirty limit across the independant devices a floating proportion is used, this will allocate a share of the total limit proportional to the device's recent activity. 3 is done by also scaling the dirty limit proportional to the current task's recent dirty rate. This patch: nfs: remove congestion_end(). It's redundant, clear_bdi_congested() already wakes the waiters. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-09NFS: Remove nfs_begin_data_update/nfs_end_data_updateTrond Myklebust
The lower level routines in fs/nfs/proc.c, fs/nfs/nfs3proc.c and fs/nfs/nfs4proc.c should already be dealing with the revalidation issues. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Replace file->private_data with calls to nfs_file_open_context()Trond Myklebust
2007-10-09NFS: Fall back to synchronous writes when a background write errors...Trond Myklebust
This helps prevent huge queues of background writes from building up whenever the server runs out of disk or quota space, or if someone changes the file access modes behind our backs. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Writeback optimisationTrond Myklebust
Schedule writes using WB_SYNC_NONE first, then come back for a second pass using WB_SYNC_ALL. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Clean up NFS writeback flush codeTrond Myklebust
The only user of nfs_sync_mapping_range() is nfs_getattr(), which uses it to flush out the entire inode without sending a commit. We therefore replace nfs_sync_mapping_range with a more appropriate helper. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Clean up nfs_writepages()Trond Myklebust
Just call write_cache_pages directly instead of hacking the writeback control structure in order to find out if we were called from writepages() or directly from the VM. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Clean up write code...Trond Myklebust
The addition of nfs_page_mkwrite means that We should no longer need to create requests inside nfs_writepage() Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
